Thomas Jentzsch
    27,895
Posts posted by Thomas Jentzsch
  1. I know the labels "amateur" and "pro" are from the programmer's guide, but the A/B difficulty was frequently also labelled as Expert/Novice (e.g. on my Vader console) and Advanced/Beginner too. IMO the latter is easier to remember.
    BTW: Why did you draw and list the bits in reverse order?
  2. The problem are not the people who have great ideas. The problem are the people who think they have great ideas.
    There were just too many posts where the latter were presenting their ideas in a way, that developers should be grateful if they are allowed to implement them. Usually without even a basic understanding of the system limitations, no thought out concepts, no details, nothing. Some of these people even didn't even want to get into detail, because they were afraid someone might steal their idea.
    Yes, there were exceptions (e.g. Salstadt and a few others), but the majority was like the people I described above. That's why this thread was created, so that we could forward them here. Without having to explain them over and over again why developers are not waiting in line to implement their "great" ideas.
  3. 14 minutes ago, ZeroPage Homebrew said:
    Such is the struggle playing games meant for CRTs that have a TON more tolerance than digital equipment.
    Yes, and for a developer this allows some fine tuning. E.g. display more scanlines or slightly change the game speed when not using fractional math.
    The problem is that modern equipment isn't tolerant anymore. Not vice versa. :)
  4. 4 hours ago, Omegamatrix said:
    The latest the write can be done though is ending on cycle 19 as A, X, and Y are in use.
    Ending at cycle 21 by my math. Which should be OK because of the 5 cycles earlier HMOVE. It looks OK on my PAL console.
    BTW: I changed COL_TEXT for PAL into $28 (COL_28 is $38 for PAL). $38 has a slight tint to red.
  5. 18 minutes ago, johnnywc said:
    I gave it a test.  Through the front pot, it does seem better in that it does detect the 1st joystick properly now, but unfortunately it doesn't seem to be able to read any joysticks plugged into the additional port (port 3 or port 4). 😕   It performed the same through the USB connector in my tests also; it could just read inputs from the first joystick.
    However, it may just be because I have no way of mapping those ports because they aren't recognized as inputs with Stella.  Meaning, when I try to map inputs to joysticks P2 and P3, I can't map to the additional joysticks because Stella would need to set DUMPPORTS high to enable the physical joystick connected to port 3 of the QuadTari.  I'm confused actually; I'm not sure how it would work in software, but somehow you would need to map using the 2nd physical joystick connected to QuadTari port 3 to Stella joystick port P2.  (and the same for QT port 4/Stella joystick input configuration for P3).  :ponder:
    Hm, I get your problem. I suppose I need a QuadTari first to sort out the problems.
    Anyway, thanks for testing.
  6. Another idea how to save cycles: Use M0 and M1 alternatively! That way you have to update the stack pointer (LDX #ENAM1, TXS instead of PLA) only every 4 lines. I think that should work, no?
    So that would save 4 cycles every 4 lines. Together with one wasted cycle we would have another 5 cycles free every 4 lines.
    This would allow e.g. updating the background in 3 out of 4 lines. Or we could move "lda #RIGHT_8, sta HMP1" to the beginning of KERNEL_2 (before lda #{9}, not 100% sure about the timing). Then there would be 5 free cycles at the end of KERNEL_2 and 5 free cycles at the beginning of every 2nd KERNEL_1. That would allow e.g. changing the foreground colors.
  7. 3 hours ago, Random Terrain said:
    Like I posted above, why didn't the person who originally put the incorrect information on the page have to jump through 500 flaming hoops to prove it? If they did, the page wouldn't have to be corrected now.
    The wrong info was added July 14th, 2018 with a link to AtariMania. There Super Breakout is listed as "Year 1978".
    Looks like AtariMania is generally accepted as a reliable source of information. But obviously it is wrong (probably because the label says (C)1978, any idea why?) and the error replicated to Wikipedia too. I suggest to contact AtariMania first and make them correct their error. That should avoid discussion with the people at Wikipedia.
  8.
    4 minutes ago, JetSetIlly said:
    I was confused by the Stella UI. I thought selecting Developer Settings in the TIA Tab would turn on developer settings only for the TIA but it turns them on everywhere.
    I agree, the UI is not optimal there. But the Debugger tab has no separate player/developer settings, so I had to repeat the radio buttons on each of the other tabs.
