Posts
1,133 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by Bmack36
No official price yet. Trying to keep it a little under $200 for the system.
Whats this about this colectorvision HD. I hear it plays Colecovision, MSX, Sega Master System cartridges. I encourage more FGPA if it's done right. Im not a museum to have these ageing about to fail or rot consoles in my home.
I watched Madlittlepixel youtube channel about this coming out and having a kickstarter.
Here is a link to the Collectorvision Game System thread if you are interested:
http://atariage.com/forums/topic/265958-collectorvision-game-system/
EASTER UPDATE:
We are currently working on the case design and have a preliminary design in mind (very early in the process):
We have changed the feature list a little:
For now we are only doing HDMI video output (directly from the system). This is to reduce costs to those who don't need analog video
SGM support
Added SNES controller port. This will allow the use of the super famicom ntt data controller as well as allow those without a cv controller to play the system with a standard snes controller. (Player 1 only)
Expansion port (not compatible with original expansion modules) that will allow future addons
Power and reset buttons modeled after the joystick of docked controllers see picture above
We are still working to see which cores will be available at launch.
- 10
I am hoping to have an update here soon with more information about the system
- 1
Are you releasing this as an open source project, or is the firmware closed source?
Children of the Night is an amazing RPG. very Zelda like and definately a must get.
- 1
I just ordered more boards yesterday because the first run I did are almost gone.
Have you found that you needed the pots, or did the colors look fine with just the jumpers.
I just finished it. It was really good. There are some tough challenges in the game.
I had heard about the ZX-UNO but not the other two.
I hope I am not stepping on some toes but I would like to give them some protips on the Collectorvision board.
It should have ESD protection on the two controller ports, keyboard port, and RGB/audio outputs. The original Coleco had a big problem with the controller ports failing due to ESD. Also, the audio looks like it is just some RC filtered PWM from the FPGA. A real audio DAC isn't very expensive and would sound a whole lot better. Ditto for the video DAC. I see what looks like 3 bits of weighted resistors but not a DAC. I don't see any pullup resistors on the inputs either, unless they (and possible ESD protection) is on the bottom. Also, DDR/SDRAM would be a lot cheaper and 32 times bigger (i.e. 16mbyte vs. 512K) for the RAM.
Thanks Kevtris.
I always welcome others opinions especially when they are as knowledgeable as you.
The image from the linked post is actually a little out of date.
The controllers, keyboard, and a few other ports that have been added are running through a gtl2000dgg,118 level converter which is rated for ESD suppression and "hot insertion". So I think it should be fine on ESD protection,
The VGA port was modeled after the F18a's video output, but I have actually decided to remove the analog video and audio and just do HDMI only to keep costs down.
I had gone back and forth about SRAM vs SDRAM or doing both, but decided to go with the SRAM since it was already implemented and working.
check the atarimax settings to make sure you don't have autoskip bios setting. The error you are getting is saying the SGM can't detect the 8k of ram that replaces the bios area. This can happen when you enable the bios skip option on the atarimax cart.
It might be a little bit of "not invented here" talking, but I generally don't see the set of peripherals or design that I like in the existing FPGA videogame boards that exist. I know of about 5 or 6 of them at this point. Usually the peripheral set is lacking in some way. And since I like hardware there is something to designing my own that is very satisfying. The "Standard platform" that satisfies one set of devs might not satisfy others. All of the FPGA videogame boards up until the mister add-on has been composite, s-video, or RGB. The amount of RAM has been lacking, too. I know of the following projects. have I missed any?
* MCC-216
* FPGA Arcade "Replay" board.
* MIST
* Papilio FPGA board (not really marketed as an FPGA videogame board)
* A2601 (seems to be a one off project)
* MiSTER (dev board + add-ons)
There is also:
ZX-UNO zxuno.speccy.org
ZX-Spectrum Next https://www.specnext.com/
Collectorvision game system is also in development http://atariage.com/forums/topic/265958-collectorvision-game-system/page-4?do=findComment&comment=3922459
- 2
That auction was listed as local pickup only until after it ended. I know I would have bid if shipping had been an option.
- 2
Colecovision HSC Season 11 - Round 7 - James Bond 007
in ColecoVision High Score Club
The 007 rating on expert is attainable (i did it using savestates so this score is not part of the contest). I just wanted to verify the 007 score was attainable.
This score does not count toward the contest. This was a run without losing a life.
