LASooner
    443
Posts posted by LASooner
  1. It's probably a case of me not doing the CWRITE command. I'll keep stabbing at it until I get it right because I want my next game, whatever it may be, to be able to take advantage of this soundlist feature in XB256. I've done it once before on a little game but it was nothing flashy, years back.
    Edit:
    Yes if you look at LaSooner's reply to me, his line 2810 and line 2820 I think I might have missed them out, thinking they were not needed. Obviously, they are.
    Yeah, that's the line that loads the data into the VDP.
  2. If you're running from XB you need that line, otherwise you don't need it.
    Are your sounds not working in just the compiled program or in XB as well.
    The steps I use to successfully get it working are
    use SLCONVERT to create the list
    Assemble to generate the OBJ
    use COMPRESS to create the VDP data to read in, set whether it's in low or high memory, it will generate the addresses for each sound.
    Merge the data with your XB file
    Read the compressed data into the VDP before playing the sounds
    2810 READ A$::IF A$="" THEN 2820::CALL LINK("CWRITE",A$)::GOTO 2810
    2820 RETURN
    Use CALL LINK("PLAY",[address#]) to play each sound in your game
    When you compile it should work just fine.
    Remember any CALL SOUND statements in your program will override anything playing on player 1
    Where is it not working for you? Are you getting errors when you assemble the soundlist?
  3. FIX: I had a dyslexic number.
    Having a problem with my Sound List. It works fine from the command line. Playing the music works and playing sound effects over it works fine too...
    But, when I'm in my game, music works fine, but once the sound effect is played, the music stops and it plays just annoying tone indefinitely.
    If I just take the merge file and only the merge file and do:
    10 CALL LINK("PLAY",MUSIC)
    20 CALL LINK("PLAY",SOUND)
    it does the same thing (annoying indefinite)
    Without revealing anything, here are the sound effect portions of my file:
    2000 !SOUND
    2010 !PLAYER2
    2020 CALL SOUND(10, -5, 1)
    2030 CALL SOUND(10, -5, 1)
    2040 CALL SOUND(10, -5, 1)
    2050 CALL SOUND(10, -5, 1)
    2060 CALL SOUND(10, -5, 1)
    2600 STOP
    3000 !NOISE
    3010 !PLAYER2
    3020 CALL SOUND(33,110,0,-7,0)
    3030 STOP
    Any clues?
    Your music is not using player 2 correct?
    Because if it is that's what causing it. If it's not any standard CALL SOUND statement will also interrupt it
  4. Convert9918 will convert bitmap images...
    If youre just wanting to make up a game board for a game in GMODE1, youll be limited to 32X24 screen locations.
    :D
    Correction 32x24 color locations, 256x192 pixels :waving:
  5. Here's my updated code
    TID Bit:
    //								NIGHT STALKER TI 99/4a
    //			By John McGinley (AtariAge:LASOONER)
    //					3/14/2018
    //		VARIABLE LIST
    //			SCR		=	Score
    //			SCOR$	= 	Score Print String
    //			P		=	Players left
    //			B		=	Bullets left
    //			DS		=	Player Death state (0-Alive, 1-Dead, 2-Stunned, 3-Game Over)
    //			FRM		=	Animation Frame Number
    //			M		=	Enemy Array Value
    //			A		= 	Variable for FOR/NEXT loop
    //			BA(1)	=	Active Bullet State Player
    //			BA(2)	=	Active Bullet State Main Robot
    //			BA(3)	=	Active Bullet State Second Robot
    //			BA(4)	=	Active Bullet State Third Robot
    //			S 		=	Fire Button State
    //			RBT		=	Robot Character Value
    //			BAT1A	=	Bat1/2nd Robot Character Value
    //			BAT2A	=	Bat2/3rd Robot Character Value
    //			GP		=	Gun Position Spawn Location Value
    //			GPX		=	Gun Position Spawn X
    //			GPY		=	Gun Position Spawn Y
    //			PKX		=	Player Sprite Coincidence Value X
    //			PKY		=	Player Sprite Coincidence Value Y
    //			MX		=	Player Sprite Position X
    //			MY		=	Player Sprite Position Y
    //			PX		=	Joystick Value Left/Right
    //			PY		=	Joystick Value Up/Down
    //			AN		=	Animation Character offset
    //			GA(1)	=	Player GCHAR Y Offset 1
    //			GA(2)	=	Player GCHAR X Offset 1
    //			GA(3)	=	Player GCHAR Y Offset 2
    //			GA(4)	=	Player GCHAR X Offset 2
    //			MZ1		=	Maze Character Check 1
    //			MZ2		=	Maze Character Check 2
    //			DD		=	Player Death Animation Frame
    //			DW		= 	Player After Death Respawn delay
    //			ST		=	Player Stunner Animation Frame
    //			SW		=	Player After Stun Recovery delay
    //			BD(1)	=	Bullet Direction Player
    //			BD(2)	=	Bullet Direction Main Robot
    //			BD(3)	=	Bullet Direction 2nd Robot
    //			BD(4)	=	Bullet Direction 3rd Robot
    //			BYO(1)	=	Bullet Origin Y Player
    //			BXO(1)	=	Bullet Origin X Player
    //			BYO(2)	=	Bullet Origin Y Main Robot
    //			BXO(2)	=	Bullet Origin X Main Robot
    //			BYO(3)	=	Bullet Origin Y 2nd Robot
    //			BXO(3)	=	Bullet Origin X 2nd Robot
    //			BYO(4)	=	Bullet Origin Y 3rd Robot
    //			BXO(5)	=	Bullet Origin X 3rd Robot
    //			BLY(1)	=	Bullet Position Y Player
    //			BLX(1)	=	Bullet Position X Player
    //			BLY(2)	=	Bullet Position Y Main Robot
    //			BLX(2)	=	Bullet Position X Main Robot
    //			BLY(3)	=	Bullet Position Y 2nd Robot
    //			BLX(3)	=	Bullet Position X 2nd Robot
    //			BLY(4)	=	Bullet Position Y 3rd Robot
    //			BLX(5)	=	Bullet Position X 3rd Robot
    //			DR(1)	=	Main Robot Death State (0-Alive, 1-Dead)
    //			DR(2)	=	Bat1/2nd Robot Death State (0-Alive, 1-Dead)
    //			DR(3)	=	Bat2/3rd Robot Death State (0-Alive, 1-Dead)
    //			DR(4)	=	Spider Death State (0-Alive, 1-Dead)
    //			BC		=	Bullet Collision GCHAR check upper/left
    //			BC1		=	Bullet Collision GCHAR check upper/right
    //			BC2		=	Bullet Collision GCHAR check lower/left
    //			BC3		=	Bullet Collision GCHAR check lower/right
    //			GC		= 	Gun Pick Up Coincidence Value
    //			PV(1)		=	Robot Point Value
    //			PV(2)		=	Bat1/Robot 2 Point Value
    //			PV(3)		=	Bat2/Robot 3 Point Value
    //			PV(4)		=	Spider Point Value
    //			RY(1)	=	Main Robot Y Position
    //			RX(1)	=	Main Robot X Position
    //			RP(1)	=	Main Robot Direction
    //			RS(1)	=	Main Robot Speed
    //			RY(2)	=	Bat1/2nd Robot Y Position
    //			RX(2)	=	Bat1/2nd Robot X Position
    //			RP(2)	=	Bat1/2nd Robot Direction
    //			RS(2)	=	Bat1/2nd Robot Speed
    //			RY(3)	=	Bat2/3rd Robot Y Position
    //			RX(3)	=	Bat2/3rd X Position
    //			RP(3)	=	Bat2/3rd Direction
    //			RS(3)	=	Bat2/3rd Speed
    //			RY(4)	=	Spider Y Position
    //			RX(4)	=	Spider X Position
    //			RP(4)	=	Spider Direction
    //			RS(4)	=	Spider Speed
    //			RBC		=	Main Robot Color
    //			RD(1)	=	Main Robot Direction Multiplier
    //			RD(2)	=	Bat1/2nd Direction Multiplier
    //			RD(3)	=	Bat2/3rd Direction Multiplier
    //			RD(4)	=	Spider Direction Multiplier
    //			RC		=	Intersection Direction Value
    //			DRW		=	Main Robot Respawn Delay
    //			Audio VDP Addresses
    //			Shooting=2832
    //			Pick Up Item=2760
    //			Player Spawn=2649
    //			Bat Explosion=2585
    //			Robot Explosion=2513
    //			Heartbeat=2432
    //			Theme Music=2930
    //									TITLE SCREEN			 								/
    						DIM BA(5),GA(4),BD(4),BXO(4),BYO(4),BLY(4),BLX(4),DR(4),PV(4),RY(4),RX(4),RS(4),RP(4),RD(4),DRW(4)
    						DIM YA(7),YB(7),YC(7),XA(11),XB(11),XC(11),I1A(6),I2A(4),I3A(5),I4A(7),I5A(3),I6A(5),I7A(3),I8A(3)
    						DIM I1B(6), I2B(4),I3B(5),I4B(7),I5B(3),I6B(5),I7B(3),I8B(3)
    						CALL LINK("SCRN2") :: CALL SCREEN(2) :: CALL MAGNIFY (3) ::CALL CLEAR :: GOSUB _SETMAZEDATALIMITS :: RANDOMIZE :: GOSUB _SOUNDS
    						//:: CALL LINK("PLAY",2930) :: GOSUB _TITLE
    		//_TITLEPAUSE:
    						//CALL LINK("DELAY",6000)
    		_GAMESTART:
    						CALL SCREEN(2):: CALL CLEAR :: SCR=0 :: P=5 :: B=0 :: DS=0 :: FRM=0 :: CDT=0 :: BNK=1 :: GOSUB _SPRITES
    //									SET UP SPRITES AND MAZE 								/
    		_CREATESPRITES:
    						CALL LINK("PLAY",0) :: GOSUB _MAZE :: CALL LINK("PLAY",2432) :: GOSUB _SHOWBUNKERSPRITES :: GOSUB _SPAWNPLAYER :: GOSUB _SPAWNSPIDER :: GOSUB _SPAWNROBOT :: GOSUB _SPAWNBAT1 :: GOSUB _SPAWNBAT2
    						CALL LINK("DISPLY",1,31,CHR$(48+B)) :: CALL LINK("DISPLY",1,14,CHR$(,1,6)	:: FOR A=1 TO 4 :: BA(A)=0 :: NEXT A :: GOSUB _GUNPOS2 :: CALL LOAD(-1,5)
    //									GAME LOOP												/
    		_LOOP:
    						M=M+1 :: IF M=5 THEN M=1
    						ON M GOSUB _FRAME1,_FRAME2,_FRAME1,_FRAME2  :: GOSUB _MOVECHARACTER :: GOSUB _MOVEROBOT :: GOSUB _HITDETECTION :: GOSUB _CHARACTERCOLLISION
    						IF BA(M)=1 THEN GOSUB _SHOOTMOVE
    						IF BNK=1 AND BDW=1 THEN GOSUB _SHOWBUNKERSPRITES
    						IF BNK=0 AND BDW=0 THEN GOSUB _HIDEBUNKERSPRITES
    						IF (S>0)*(BA(1)=0) THEN GOSUB _SHOOT
    							IF BA(M+1)=0 THEN GOSUB _ROBOTSHOOT
    						CALL LINK("SYNC") :: GOTO _LOOP
    //									ANIMATION FRAMES										/
    		_FRAME1:
    					CALL PATTERN(#4,RBT,#5,BAT1A,#6,BAT2A,#7,SPIDA) ::
    					IF B>0 THEN RETURN
    					CALL LINK("COLOR2",-1,12,5) :: RETURN //Gun Flash 1
    		_FRAME2:
    					CALL PATTERN(#4,RBT+4,#5,BAT1B,#6,BAT2B,#7,SPIDB)
    					IF B>0 THEN RETURN
    					CALL LINK("COLOR2",-1,5,5) :: RETURN //Gun Flash 2
    //									GUN SPAWNING											/
    		_SPAWNGUN:
    					CALL LINK("IRND",9,GP) :: IF GP>4 THEN GP=GP/2
    					ON GP+1 GOTO _GUNPOS1,_GUNPOS2,_GUNPOS3,_GUNPOS4,_GUNPOS5
    		_GUNPOS1:
    					GPX=15 :: GPY=13 :: PKX=113  :: PKY=97  ::  GOTO _DISPLAYGUN
    		_GUNPOS2:
    					GPX=15 :: GPY=7  :: PKX=113  :: PKY=49  ::  GOTO _DISPLAYGUN
    		_GUNPOS3:
    					GPX=29 :: GPY=21 :: PKX=225  :: PKY=161 ::  GOTO _DISPLAYGUN
    		_GUNPOS4:
    					GPX=28 :: GPY=7  :: PKX=217  :: PKY=49  ::  GOTO _DISPLAYGUN
    		_GUNPOS5:
    					GPX=5  :: GPY=21 :: PKX=33   :: PKY=161 ::  GOTO _DISPLAYGUN
    		_DISPLAYGUN:
    					CALL LINK("DISPLY",GPY,GPX,CHR$(16)) :: CALL LINK("DISPLY",GPY,GPX+1,CHR$(18)) :: CALL LINK("DISPLY",GPY+1,GPX,CHR$(17)) :: CALL LINK("DISPLY",GPY+1,GPX+1,CHR$(19)) :: RETURN
    		_CLEARGUN:
    					CALL LINK("PLAY",2760) :: CALL LINK("DISPLY",GPY,GPX,CHR$(32),1,2) :: CALL LINK("DISPLY",GPY+1,GPX,CHR$(32),1,2) :: RETURN
    //									PLAYER MOVEMENT											/
    		_DEADSTATE:
    					ON DS GOSUB _DEAD,_STUNNED,_GAMEOVER :: RETURN
    		_MOVECHARACTER:
    					CALL POSITION(#3,MY,MX)
    						IF DS>0 THEN GOTO  _DEADSTATE
    		_KEEPMOVING:
    						IF B=0 THEN GOSUB _CHECKGUN
    					CALL KEY(1,K,S) :: CALL JOYST(1,PX,PY) :: AN=AN+4 :: IF (PX=0)*(PY=0) THEN _STAND
    						IF PX<0 THEN _RUNLEFT
    						IF PX>0 THEN _RUNRIGHT
    						IF PY<0 THEN _RUNDN
    						IF PY>0 THEN _RUNUP
    		_RUNLEFT:
    						IF AN>12 THEN AN=0
    					CALL PATTERN(#3,32+AN) :: PY=0 :: GOSUB _MAZEHORZ
    		_COLMAP:
    					GA(1)=1 :: GA(2)=1 :: GA(3)=2 :: GA(4)=1 :: GOSUB _GRAPHICCHK
    						IF (MZ1=32)*(MZ2=32) THEN GOSUB _LEFT
    						IF (MZ1>15)*(MZ1<20)*(MZ2>15)*(MZ2<20) THEN GOSUB _LEFT
    						IF (MX>33)*(MY>33) THEN _LEFTEND
    						IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB _WEBLEFT
    		_LEFTEND:
    					GOTO _MOVERETURN
    		_RUNRIGHT:
    						IF AN>12 THEN AN=0
    					CALL PATTERN(#3,48+AN) :: PY=0 :: GOSUB _MAZEHORZ
    			_COLMAP2:
    					GA(1)=1 :: GA(2)=3 :: GA(3)=2 :: GA(4)=3 :: GOSUB _GRAPHICCHK
    						IF (MZ1=32)*(MZ2=32) THEN GOSUB _RIGHT
    						IF (MZ1>15)*(MZ1<20)*(MZ2>15)*(MZ2<20) THEN GOSUB _RIGHT
    						IF (MX>33)*(MY>33) THEN _RIGHTEND
    						IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB _WEBRIGHT
    			_RIGHTEND:
    					GOTO _MOVERETURN
    		_RUNUP:
    						IF AN>4 THEN AN=0
    					CALL PATTERN(#3,68+AN) :: PX=0 :: GOSUB _MAZEVERT
    			_COLMAP4:
    					GA(1)=1 :: GA(2)=1 :: GA(3)=1 :: GA(4)=2 :: GOSUB _GRAPHICCHK
    						IF (MZ1=32)*(MZ2=32) THEN GOSUB _UP
    						IF (MZ1>15)*(MZ1<20)*(MZ2>15)*(MZ2<20) THEN GOSUB _UP
    						IF (MX>33)*(MY>33) THEN _UPEND
    						IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB _WEBUP
    			_UPEND:
    					GOTO _MOVERETURN
    		_RUNDN:
    						IF AN>4 THEN AN=0
    			_COLMAP6:
    					GA(1)=3 :: GA(2)=1 :: GA(3)=3 :: GA(4)=2 :: GOSUB _GRAPHICCHK
    						IF (MZ1=32)*(MZ2=32) THEN GOSUB _DOWN
    						IF (MZ1>15)*(MZ1<20) THEN GOSUB _DOWN
    						IF (MX>33)*(MY>33) THEN _DNEND
    						IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB _WEBDOWN
    			_DNEND:
    					GOTO _MOVERETURN
    		_GRAPHICCHK:
    					CALL GCHAR(INT(MY/8)+GA(1),INT(MX/8)+GA(2),MZ1) :: CALL GCHAR(INT(MY/8)+GA(3),INT(MX/8)+GA(4),MZ2) :: RETURN
    		_MAZEHORZ:
    					FOR A=1 TO 7 :: IF MY>YA(A) AND MY<YB(A) THEN MY=YC(A)
    					NEXT A :: IF (MX>97)*(MX<137)*(MY>41)*(MY<89) THEN _DRAWBUNKERTOKEN
    					IF (MX<97)+(MX>137) THEN _HIDEBUNKERTOKEN ELSE RETURN
    				_DRAWBUNKERTOKEN:
    					BNK=1 :: BDW=1 :: RETURN
    				_HIDEBUNKERTOKEN:
    					BNK=0 :: BDW=0 :: RETURN
    		_MAZEVERT:
    					FOR A=1 TO 11 :: IF MX>XA(A) AND MX<XB(A) THEN MX=XC(A)
    					NEXT A :: 	RETURN
    //					  PLAYER ANIMATIONS                     //
    		_STAND:
    					CALL PATTERN(#3,64) :: AN=-4 :: GOTO _MOVERETURN
    		//Set Dead anim frames and Wait before respawn
    		_DEAD:
    					DS=1 :: DD=DD+1 :: DW=DW+1 :: IF DW=15 THEN _RESETPLAYER
    						IF DD>2 THEN DD=1
    					ON DD GOSUB _DEADFRAME1,_DEADFRAME2 :: CALL LINK("PLAY",2649) :: RETURN
    		//Set Stunned anim frames and Wait before respawn
    		_STUNNED:
    					DS=2 :: ST=ST+1 :: SW=SW+1 :: IF SW=60 THEN DS=0 :: ST=0 :: SW=0 :: RETURN
    						IF ST=4 THEN ST=3
    					ON ST GOSUB _STUNFRAME1,_STUNFRAME2,_STUNFRAME3 :: RETURN
    		_DEADFRAME1:
    					DF1=48 :: DF2=12 :: GOTO _DEADSTATEDRAW
    		_DEADFRAME2:
    					DF1=48 :: DF2=9 :: GOTO _DEADSTATEDRAW
    		_STUNFRAME1:
    					DF1=76 :: DF2=12 :: GOTO _DEADSTATEDRAW
    		_STUNFRAME2:
    					DF1=80 :: DF2=12 :: GOTO _DEADSTATEDRAW
    		_STUNFRAME3:
    					DF1=84 :: DF2=12 :: GOTO _DEADSTATEDRAW
    		_DEADSTATEDRAW:
    					CALL SPRITE(#3,DF1,DF2,MY,MX) :: RETURN
    		_RESETPLAYER:
    					DW=0 :=P-1 :: B=0	:: DD=0	:: BNK=1 :: BDW=1
    						IF P<0 THEN DS=3 :: CALL LINK("DISPLY",1,28,CHR$(48)) :: RETURN
    					CALL LINK("DISPLY",1,28,CHR$(48+P)) :: GOSUB _CLEARGUN :: CALL LINK("DISPLY",1,31,CHR$(48+B)) :: GOSUB _SPAWNGUN :: GOSUB _SPAWNPLAYER ::  RETURN
    		_MOVERETURN:
    						IF PX=0 AND PY=0 THEN RETURN
    		_LIMITS:
    						IF MY<17 THEN MY=17
    						IF MY>161 THEN MY=161
    						IF MX<9 THEN MX=9
    						IF MX>233 THEN MX=233
    		_POSITION:
    					CALL LOCATE(#3,MY,MX) :: RETURN
    		_GAMEOVER:
    					CALL LINK("PLAY",0) :: CALL DELSPRITE (#3) :: CALL LINK("DISPLY",14,12,"GAME OVER") :: CALL KEY(1,K,S) :: IF S=0 THEN _GAMEOVER
    					CALL DELSPRITE (ALL) :: GOTO _GAMESTART
    		_DOWN:
    					BD(1)=3 ::  MY=MY+2 :: RETURN
    		_UP:
    					BD(1)=1 ::  MY=MY-2 :: RETURN
    		_LEFT:
    					BD(1)=4 ::  MX=MX-2 :: RETURN
    		_RIGHT:
    					BD(1)=2 ::  MX=MX+2 :: RETURN
    		_WEBDOWN:
    					MY=MY+1 :: RETURN
    		_WEBUP:
    					MY=MY-1 :: RETURN
    		_WEBLEFT:
    					MX=MX-1 :: RETURN
    		_WEBRIGHT:
    					MX=MX+1 :: RETURN
    //									PLAYER SHOOTING											/
    		_SHOOT:
    						IF B=0 THEN RETURN
    					BYO(1)=0 :: BXO(1)=0 :: ON BD(1) GOTO _BULLETUP,_BULLETRT,_BULLETDN,_BULLETLT
    			_BULLETUP:
    					BYO(1)=-1 :: GOSUB _BULLETDIRECTION :: RETURN
    			_BULLETRT:
    					BXO(1)=1 :: GOSUB _BULLETDIRECTION :: RETURN
    			_BULLETDN:
    					BYO(1)=1 :: GOSUB _BULLETDIRECTION :: RETURN
    			_BULLETLT:
    					BXO(1)=-1 :: GOSUB _BULLETDIRECTION :: RETURN
    		_BULLETDIRECTION:
    					BA(1)=1 :: BLY(1)=MY+BYO(1) :: BLX(1)=MX+BXO(1) :: B=B-1 :: IF B=0 THEN GOSUB _SPAWNGUN
    					CALL LINK("DISPLY",1,31,CHR$(48+B)) :: CALL LINK("PLAY",2832) :: CALL SPRITE (#8,96,10,BLY(1),BLX(1)) :: RETURN
    //									ROBOT SHOOTING											/
    		_ROBOTSHOOT:
    						IF M=4 THEN RETURN
    						IF DR(M)=1 THEN RETURN
    					GOTO _NOBATS
    		_ROBOTSHOOTRTN:
    						IF M+1=5 THEN RETURN
    						IF BA(M+1)=1 THEN RETURN
    					BYO(M+1)=0 :: BXO(M+1)=0 :: IF (RX(M)>MX-16)*(RX(M)<MX+16) THEN _ROBOTSHOTUPDN
    						IF (RY(M)>MY-16)*(RY(M)<MY+16) THEN _ROBOTSHOTLEFTRIGHT
    					RETURN
    		_ROBOTSHOTDRAW:
    					BA(M+1)=1 :: BLY(M+1)=RY(M)+BYO(M+1) :: BLX(M+1)=RX(M)+BXO(M+1) :: CALL LINK("PLAY",2832) :: CALL SPRITE (#8+M,96,10,BLY(M+1),BLX(M+1)) :: RETURN
    //		ROBOT BULLET Direction		//
    			//Robot Shoots UP if player is UP, Robot Shoots DOWN if player is DOWN
    		_ROBOTSHOTUPDN:
    						IF RY(M)>MY THEN BYO(M+1)=-1 ELSE BYO(M+1)=1
    					GOTO _ROBOTSHOTDRAW
    			//Robot Shoots Left if player is left, Robot Shoots Right if player is right
    		_ROBOTSHOTLEFTRIGHT:
    						IF RX(M)>MX THEN BXO(M+1)=-1 ELSE BXO(M+1)=1
    					GOTO _ROBOTSHOTDRAW
    		_NOBATS:
    						IF (M=2)*(BAT1A=140) THEN RETURN
    						IF (M=3)*(BAT2A=116) THEN RETURN ELSE _ROBOTSHOOTRTN
    //									MOVE BULLET												/
    		_SHOOTMOVE:
    						IF (BA(M)=0)+(M=5) THEN RETURN
    						IF (M=3)*(BAT1A=140) THEN RETURN
    						IF (M=4)*(BAT2A=116) THEN RETURN
    						IF BYO(M)=-1 THEN BLD(M)=-1 :: GOTO _BULUPDN
    						IF BXO(M)=1 THEN BLD(M)=1 :: GOTO _BULLEFTRIGHT
    						IF BYO(M)=1 THEN BLD(M)=1 :: GOTO _BULUPDN
    						IF BXO(M)=-1 THEN BLD(M)=-1 :: GOTO _BULLEFTRIGHT
    		_BULUPDN:
    					BLY(M)=BLY(M)+8*BLD(M) :: GOTO _BULPOSITION
    		_BULLEFTRIGHT:
    					BLX(M)=BLX(M)+8*BLD(M)
    		_BULPOSITION:
    					FOR A=1 TO 4 :: IF BA(A)=1 THEN CALL LOCATE(#7+A,BLY(A),BLX(A))
    					NEXT A
    						IF (BLY(M)<17)+(BLY(M)>161)+(BLX(M)<9)+(BLX(M)>233) THEN GOSUB _BULKILL
    						IF (BLY(M)<65)*(BLY(M)>55)*(BLX(M)>88)*(BLX(M)<138) THEN GOSUB _BULKILL
    					CALL GCHAR(INT(BLY(M)/8)+1,INT(BLX(M)/8)+1,BC) :: CALL GCHAR(INT(BLY(M)/8)+2,INT(BLX(M)/8)+1,BC1)
    					CALL GCHAR(INT(BLY(M)/8)+1,INT(BLX(M)/8)+2,BC2) :: CALL GCHAR(INT(BLY(M)/8)+2,INT(BLX(M)/8)+2,BC3)
    						IF (BC<>32)+(BC1<>32)+(BC2<>32)+(BC3<>32) THEN _BULPENITRATION
    					RETURN
    		_BULKILL:
    					CALL DELSPRITE (#7+M) :: BA(M)=0 :: BLY(M)=0 :: BLX(M)=0 :: RETURN
    		_BULPENITRATION:
    						IF (BC>15)*(BC<20) THEN RETURN ELSE _BP1
    				_BP1:	IF (BC1>15)*(BC1<20) THEN RETURN ELSE _BP2
    				_BP2:	IF (BC2>15)*(BC2<20) THEN RETURN ELSE _BP3
    				_BP3:	IF (BC3>15)*(BC3<20) THEN RETURN ELSE _BULKILL
    		_CHECKGUN:
    					CALL COINC(#3,PKY,PKX,4,GC) :: IF GC=0 THEN RETURN
    					CALL LINK("PLAY",2760) :: GOSUB _CLEARGUN :: B=6 :: CALL LINK("DISPLY",1,31,CHR$(48+B)) :: RETURN
    //									HIT DETECTION											/
    		_HITDETECTION:
    						IF DS=1 THEN _BADGUYS
    						FOR A=2 TO 4
    						IF (BLY(A)>MY-*(BLY(A)<MY+*(BLX(A)>MX-*(BLX(A)<MX+ THEN DS=1 :: IF M>2 THEN _ROBOTHIT
    						NEXT A
    		_BADGUYS:	ON M GOTO _ROBOTHIT,_BAT1HIT,_BAT2HIT,_SPIDERHIT
    		_ROBOTHIT:
    					IF DR(1)=1 THEN RETURN
    					IF (BLY(1)>RY(1)-*(BLY(1)<RY(1)+*(BLX(1)>RX(1)-*(BLX(1)<RX(1)+ THEN _ROBOTSHOT ELSE RETURN
    		_BAT1HIT:	IF DR(2)=1 THEN RETURN
    					IF (BLY(1)>RY(2)-*(BLY(1)<RY(2)+*(BLX(1)>RX(2)-*(BLX(1)<RX(2)+ THEN _BATSHOT1 ELSE RETURN
    		_BAT2HIT:	IF DR(3)=1 THEN RETURN
    					IF (BLY(1)>RY(3)-*(BLY(1)<RY(3)+*(BLX(1)>RX(3)-*(BLX(1)<RX(3)+ THEN _BATSHOT2 ELSE RETURN
    		_SPIDERHIT:	IF DR(4)=1 THEN RETURN
    					IF (BLY(1)>RY(4)-*(BLY(1)<RY(4)+*(BLX(1)>RX(4)-*(BLX(1)<RX(4)+ THEN _SPIDERSHOT ELSE RETURN
    					RETURN
    		_ROBOTSHOT:
    					HP=HP-1 :: IF HP<0 THEN _SHIELDSDOWN
    					CALL SPRITE(#16,92,12,RY(1),RX(1)) :: CALL LINK("PLAY",2760) :: CALL DELSPRITE (#8,#16) :: BA(1)=0 :: BLY(1)=0 :: BLX(1)=0 :: RBC=16 :: RETURN
    		_SHIELDSDOWN:
    					 N=1 :: DR(1)=1 :: RBT=120 ::CALL SPRITE(#12,128,RBC,RY(1),RX(1),-3,3) ::CALL MOTION(#4,-3,-3) :: GOTO _UPDATESCORE
    		_BATSHOT1:
    					N=2 :: DR(2)=1 :: BAT1A=120 :: BAT1B=124 :: GOTO _DRAWDEADBAT
    		_BATSHOT2:
    					N=3 :: DR(3)=1 :: BAT2A=120 :: BAT2B=124 :: GOTO _DRAWDEADBAT
    		_SPIDERSHOT:
    					N=4 :: DR(4)=1 :: SPIDA=120 :: SPIDB=124 :: GOTO _DRAWDEADBAT
    		_DRAWDEADBAT:
    					CALL SPRITE(#3+N,120,10,RY(N),RX(N)) :: GOTO _UPDATESCORE
    		_UPDATESCORE:
    					RX(N)=6 :: RY(N)=6 :: CALL LINK("PLAY",2513) :: SCR=SCR+PV(N) :: SCOR$=STR$(SCR)&"00" :: CALL LINK("DISPLY",1,14,SCOR$):: RETURN
    		_CHARACTERCOLLISION:
    						IF (DS=1)+(DS=2) THEN RETURN
    						IF (RY(M)>MY-12)*(RY(M)<MY+12)*(RX(M)>MX-12)*(RX(M)<MX+12) THEN _STUNCHK ELSE RETURN
    		_STUNCHK:
    						IF M=1 THEN DS=1
    						IF SCR<50 THEN _BATSTUN
    						IF (BS1=2)*(M=2) THEN DS=1
    						IF (BS2=2)*(M=3) THEN DS=1
    					DS=2 :: RETURN
    		_BATSTUN:
    						IF M>1 THEN DS=2
    					RETURN
    //									SPAWNS													/
    		_SPAWNPLAYER:
    					CALL SPRITE(#3,64,12,73,113) :: CALL LINK("PLAY",2649) :: DS=0 :: RETURN
    		_SPAWNROBOT:
    					//Robot
    					RY(1)=161 :: RX(1)=17 :: RP(1)=2
    						IF SCR>=800 THEN _SPAWNINVS
    						IF SCR>=300 THEN _SPAWNBLACK
    						IF SCR>=150 THEN _SPAWNWHITE
    						IF SCR>=50 THEN _SPAWNBLUE
    					RBT=100 :: RBC=15 :: PV(1)=3 :: RS(1)=2 :: HP=0
    		_DRAWROBOT:
    					CALL SPRITE(#4,RBT,RBC,RY(1),RX(1)) :: RETURN
    		_SPAWNBLUE:
    					GOSUB _ADVROBOT :: RBC=6 :: PV(1)=5 :: HP=0 :: GOTO _DRAWROBOT
    		_SPAWNWHITE:
    					GOSUB _WHITEROBOTSPRITE :: GOSUB _ADVROBOT :: RBC=16 :: PV(1)=10 :: HP=2 ::  GOTO _DRAWROBOT
    		_SPAWNBLACK:
    					GOSUB _BLACKROBOTSPRITE :: GOSUB _ADVROBOT :: RBC=2 :: PV(1)=20 ::  HP=2 ::  GOTO _DRAWROBOT
    		_SPAWNINVS:
    					GOSUB _ADVROBOT :: RBC=1 :: PV(1)=40 :: HP=2 ::  GOTO _DRAWROBOT
    		_ADVROBOT: 	RBT=108 :: RS(1)=4	:: RETURN
    		_SPAWNBAT1:
    					//Bat 1/ Robot 2
    						IF SCR<50 THEN _BAT1 ELSE _RB2
    			_BAT1:
    					BAT1A=140 :: BAT1B=116 :: RY(2)=49  :: RX(2)=217 :: RP(2)=4 :: RS(2)=2 :: PV(2)=2 :: BS1=1 :: CALL SPRITE(#5,BAT1A,2,RY(2),RX(2)) :: RETURN
    			_RB2:
    					BAT1A=100 :: BAT1B=104 :: RY(2)=161 :: RX(2)=17 :: RP(2)=2 :: RS(2)=2 :: PV(2)=3 :: BS1=2 :: CALL SPRITE(#5,BAT1A,15,RY(2),RX(2)) :: RETURN
    		_SPAWNBAT2:
    					//Bat 2/ Robot 3
    						IF SCR<50 THEN _BAT2 ELSE _RB3
    			_BAT2:
    					BAT2A=116 :: BAT2B=140 :: RY(3)=113 :: RX(3)=209 :: RP(3)=2 :: RS(3)=2 :: PV(3)=2 :: BS2=1 ::  CALL SPRITE(#6,BAT2A,2,RY(3),RX(3)) :: RETURN
    			_RB3:
    					BAT2A=104 :: BAT2B=100 :: RY(3)=161 :: RX(3)=17	 :: RP(3)=2 :: RS(3)=2 :: PV(3)=3 :: BS2=2 ::  CALL SPRITE(#6,BAT2A,15,RY(3),RX(3)) :: RETURN
    		_SPAWNSPIDER:
    					//Spider
    					SPIDA=132 :: SPIDB=136 :: RY(4)=49 :: RX(4)=9 :: RP(4)=3 :: RS(4)=2 :: PV(4)=2 :: CALL SPRITE(#7,SPIDA,4,RY(4),RX(4)) :: RETURN
    //									MOVE ROBOT SUBROUTINE									/
    		_MOVEROBOT:
    					IF (M=1)*(DR(1)=1) THEN _ROBOTDEATH
    					IF (M=2)*(DR(2)=1) THEN _BAT1DEATH
    					IF (M=3)*(DR(3)=1) THEN _BAT2DEATH
    					IF (M=4)*(DR(4)=1) THEN _SPIDDEATH
    			_MVBACK:	GOSUB _MAZECHECK :: ON RP(M) GOTO _MOVROBOTUP,_MOVROBOTRT,_MOVROBOTDN,_MOVROBOTLT
    			_MOVROBOTUP:
    					RD(M)=-1 	:: GOTO _ROBOTUPDN
    			_MOVROBOTRT:
    					RD(M)=1 	:: GOTO _ROBOTLEFTRIGHT
    			_MOVROBOTDN:
    					RD(M)=1 	:: GOTO _ROBOTUPDN
    			_MOVROBOTLT:
    					RD(M)=-1 	:: GOTO _ROBOTLEFTRIGHT
    				_ROBOTUPDN:
    					RY(M)=RY(M)+RS(M)*RD(M) :: GOTO _ROBOTPOSITION
    				_ROBOTLEFTRIGHT:
    					RX(M)=RX(M)+RS(M)*RD(M)
    			_ROBOTPOSITION:
    					CALL LOCATE(#M+3,RY(M),RX(M)) :: RETURN
    //									ROBOT DECISION TREES									/
    		_MAZECHECK:
    					IF (RX(M)=9)*(RY(M)=161) THEN RP(M)=2 :: RETURN
    					FOR A=1 TO 6 :: IF RX(M)=I1A(A) AND RY(M)=I1B(A) THEN _INTERSECTION1
    					NEXT A
    					FOR A=1 TO 4 :: IF RX(M)=I2A(A) AND RY(M)=I2B(A) THEN _INTERSECTION2
    					NEXT A
    					FOR A=1 TO 5 :: IF RX(M)=I3A(A) AND RY(M)=I3B(A) THEN _INTERSECTION3
    					NEXT A
    					FOR A=1 TO 7 :: IF RX(M)=I4A(A) AND RY(M)=I4B(A) THEN _INTERSECTION4
    					NEXT A
    					FOR A=1 TO 3 :: IF RX(M)=I5A(A) AND RY(M)=I5B(A) THEN _INTERSECTION5
    					NEXT A
    					FOR A=1 TO 5 :: IF RX(M)=I6A(A) AND RY(M)=I6B(A) THEN _INTERSECTION6
    					NEXT A
    					FOR A=1 TO 3 :: IF RX(M)=I7A(A) AND RY(M)=I7B(A) THEN _INTERSECTION7
    					NEXT A
    					FOR A=1 TO 3 :: IF RX(M)=I8A(A) AND RY(M)=I8B(A) THEN _INTERSECTION8
    					NEXT A
    						RETURN
    			_RND3:
    					CALL LINK("IRND",4,RC) :: RC=RC+1:: RETURN
    			_INTERSECTION1:
    					GOSUB _LEVELCHK :: ON RC GOTO _INUP,_INRT,_INDN,_INRT
    			_INTERSECTION2:
    					GOSUB _LEVELCHK :: ON RC GOTO _INUP,_INLT,_INDN,_INLT
    			_INTERSECTION3:
    					GOSUB _LEVELCHK :: ON RC GOTO _INDN,_INRT,_INDN,_INLT
    			_INTERSECTION4:
    					GOSUB _LEVELCHK :: ON RC GOTO _INUP,_INRT,_INUP,_INLT
    			_INTERSECTION5:
    					GOSUB _LEVELCHK :: ON RC GOTO _INDN,_INRT,_INDN,_INRT
    			_INTERSECTION6:
    					GOSUB _LEVELCHK :: ON RC GOTO _INDN,_INLT,_INDN,_INLT
    			_INTERSECTION7:
    					GOSUB _LEVELCHK :: ON RC GOTO _INUP,_INRT,_INUP,_INRT
    			_INTERSECTION8:
    					GOSUB _LEVELCHK :: ON RC GOTO _INUP,_INLT,_INUP,_INLT
    			_LEVELCHK:
    						IF  (M=1)*(RS(1)=4)  THEN GOSUB _CHASE ELSE GOSUB _RND3
    					RETURN
    			_INTERSECTIONDIRECTIONS:
    				_INUP:
    					RP(M)=1 :: RETURN
    				_INRT:
    					RP(M)=2 :: RETURN
    				_INDN:
    					RP(M)=3 :: RETURN
    				_INLT:
    					RP(M)=4 :: RETURN
    			_CHASE:
    						IF (RY(1)>MY-32)*(RY(1)<MY+32)*(RX(1)<MX) THEN RC=2 :: RETURN
    						IF (RY(1)>MY-32)*(RY(1)<MY+32)*(RX(1)>MX) THEN RC=4 :: RETURN
    						IF (RX(1)>MX-32)*(RX(1)<MX+32)*(RY(1)>MY) THEN RC=1 :: RETURN
    						IF (RX(1)>MX-32)*(RX(1)<MX+32)*(RY(1)<MY) THEN RC=3 :: RETURN
    						GOSUB _RND3 :: RETURN
    //									ROBOT DEATH												/
    			_ROBOTDEATH:
    					DR(1)=1 :: DRW(1)=DRW(1)+1 :: IF DRW(1)<10 THEN RETURN
    					DR(1)=0 :: DRW(1)=0 :: CALL DELSPRITE(#4,#12) :: GOTO _SPAWNROBOT
    			_BAT1DEATH:
    					DR(2)=1 :: DRW(2)=DRW(2)+1 :: IF DRW(2)<10 THEN RETURN
    					DR(2)=0 :: DRW(2)=0 :: CALL DELSPRITE(#5) :: GOTO _SPAWNBAT1
    			_BAT2DEATH:
    					DR(3)=1 :: DRW(3)=DRW(3)+1 :: IF DRW(3)<10 THEN RETURN
    					DR(3)=0 :: DRW(3)=0 :: CALL DELSPRITE(#6) :: GOTO _SPAWNBAT2
    			_SPIDDEATH:
    					DR(4)=1 :: DRW(4)=DRW(4)+1 :: IF DRW(4)<10 THEN RETURN
    					DR(4)=0 :: DRW(4)=0 :: CALL DELSPRITE(#5) :: GOTO _SPAWNSPIDER
    //									READ DATA SUBROUTINES									/
    			_MAZE:
    					RESTORE 30001 :: GOTO _READDATA
    			//_TITLE:
    					//RESTORE 10001 :: GOTO _READDATA
    			_SPRITES:
    					RESTORE 20001 :: GOTO _READDATA
    			_WHITEROBOTSPRITE:
    					RESTORE 30501 :: GOTO _READDATA
    			_BLACKROBOTSPRITE:
    					RESTORE 30531 :: GOTO _READDATA
    			_SOUNDS:
    					RESTORE 30602 :: GOTO _READDATA
    			_READDATA:
    					READ A$ :: IF A$="" THEN _READDATADONE :: CALL LINK("CWRITE",A$) :: GOTO _READDATA
    			_READDATADONE:
    					RETURN
    //									MAZE DATA												/
    		_SETMAZEDATALIMITS:
    			RESTORE _PLAYERMAZELIMITS
    			FOR MD=1 TO 7 :: READ MDA,MDB,MDC :: YA(MD)=MDA :: YB(MD)=MDB :: YC(MD)=MDC :: NEXT MD
    			FOR MD=1 TO 11 :: READ MDA,MDB,MDC :: XA(MD)=MDA :: XB(MD)=MDB :: XC(MD)=MDC :: NEXT MD
    			FOR MD=1 TO 6 :: READ MDA,MDB :: I1A(MD)=MDA :: I1B(MD)=MDB :: NEXT MD
    			FOR MD=1 TO 4 :: READ MDA,MDB :: I2A(MD)=MDA :: I2B(MD)=MDB :: NEXT MD
    			FOR MD=1 TO 5 :: READ MDA,MDB :: I3A(MD)=MDA :: I3B(MD)=MDB :: NEXT MD
    			FOR MD=1 TO 7 :: READ MDA,MDB :: I4A(MD)=MDA :: I4B(MD)=MDB :: NEXT MD
    			FOR MD=1 TO 3 :: READ MDA,MDB :: I5A(MD)=MDA :: I5B(MD)=MDB :: NEXT MD
    			FOR MD=1 TO 5 :: READ MDA,MDB :: I6A(MD)=MDA :: I6B(MD)=MDB :: NEXT MD
    			FOR MD=1 TO 3 :: READ MDA,MDB :: I7A(MD)=MDA :: I7B(MD)=MDB :: NEXT MD
    			FOR MD=1 TO 3 :: READ MDA,MDB :: I8A(MD)=MDA :: I8B(MD)=MDB :: NEXT MD
    			RETURN
    		_PLAYERMAZELIMITS:
    			DATA 14,26,17,43,57,49,73,87,81,91,109,97,107,114,113,123,148,129,153,180,161
    			DATA 8,14,9,28,40,33,50,64,57,75,89,81,103,121,113,123,136,129,138,152,148
    			DATA 161,177,169,186,199,193,210,224,217,225,233,233
    		_ROBOTMAZELIMITS:
    			DATA 33,81,57,49,57,129,81,97,169,129,169,81,33,129,57,81,169,97,233,113
    			DATA 81,49,129,17,169,17,193,17,217,49,57,161,81,129,129,49,145,97,145,161,169,161,217,81
    			DATA 9,17,57,17,193,113,33,17,145,49,145,129,233,17,233,81,9,129,33,161,193,49
    			DATA 193,129,233,49,233,161
    //									BUNKER SPRITES											/
    		_SHOWBUNKERSPRITES:
    				CALL SPRITE(#1,88,6,65,113,#2,92,6,81,113)
    				CALL LINK("DISPLY",9,15,CHR$(32),1,2) :: CALL LINK("DISPLY",10,15,CHR$(32),1,2) :: CALL LINK("DISPLY",11,15,CHR$(32),1,2) :: BDW=0 :: RETURN
    		_HIDEBUNKERSPRITES:
    				CALL LINK("DISPLY",9,15,CHR$(5),1,2) :: CALL LINK("DISPLY",10,15,CHR$(6),1,2) :: CALL LINK("DISPLY",11,15,CHR$(0),1,2) :: CALL DELSPRITE (#1,#2)
    				BDW=1 :: RETURN
    Here's the translated Basic Code
    100 DIM BA(5),GA(4),BD(4),BXO(4),BYO(4),BLY(4),BLX(4),DR(4),PV(4),RY(4),RX(4),RS(4),RP(4),RD(4),DRW(4)
    110 DIM YA(7),YB(7),YC(7),XA(11),XB(11),XC(11),I1A(6),I2A(4),I3A(5),I4A(7),I5A(3),I6A(5),I7A(3),I8A(3)
    120 DIM I1B(6),I2B(4),I3B(5),I4B(7),I5B(3),I6B(5),I7B(3),I8B(3)
    130 CALL LINK("SCRN2")::CALL SCREEN(2)::CALL MAGNIFY (3)::CALL CLEAR::GOSUB 2830::RANDOMIZE::GOSUB 2800
    140 CALL SCREEN(2)::CALL CLEAR::SCR=0:=5::B=0::DS=0::FRM=0::CDT=0::BNK=1::GOSUB 2770
    150 CALL LINK("PLAY",0)::GOSUB 2760::CALL LINK("PLAY",2432)::GOSUB 3020::GOSUB 1980::GOSUB 2170::GOSUB 1990::GOSUB 2110::GOSUB 2140
    160 CALL LINK("DISPLY",1,31,CHR$(48+B))::CALL LINK("DISPLY",1,14,CHR$(,1,6)::FOR A=1 TO 4::BA(A)=0::NEXT A::GOSUB 330::CALL LOAD(-1,5)
    170 M=M+1::IF M=5 THEN M=1
    180 ON M GOSUB 250,270,250,270::GOSUB 400::GOSUB 2180::GOSUB 1670::GOSUB 1890
    190 IF BA(M)=1 THEN GOSUB 1430
    200 IF BNK=1 AND BDW=1 THEN GOSUB 3020
    210 IF BNK=0 AND BDW=0 THEN GOSUB 3040
    220 IF (S>0)*(BA(1)=0) THEN GOSUB 1200
    230 IF BA(M+1)=0 THEN GOSUB 1280
    240 CALL LINK("SYNC")::GOTO 170
    250 CALL PATTERN(#4,RBT,#5,BAT1A,#6,BAT2A,#7,SPIDA)::IF B>0 THEN RETURN
    260 CALL LINK("COLOR2",-1,12,5)::RETURN
    270 CALL PATTERN(#4,RBT+4,#5,BAT1B,#6,BAT2B,#7,SPIDB)
    280 IF B>0 THEN RETURN
    290 CALL LINK("COLOR2",-1,5,5)::RETURN
    300 CALL LINK("IRND",9,GP)::IF GP>4 THEN GP=GP/2
    310 ON GP+1 GOTO 320,330,340,350,360
    320 GPX=15::GPY=13::PKX=113::PKY=97::GOTO 370
    330 GPX=15::GPY=7::PKX=113::PKY=49::GOTO 370
    340 GPX=29::GPY=21::PKX=225::PKY=161::GOTO 370
    350 GPX=28::GPY=7::PKX=217::PKY=49::GOTO 370
    360 GPX=5::GPY=21::PKX=33::PKY=161::GOTO 370
    370 CALL LINK("DISPLY",GPY,GPX,CHR$(16))::CALL LINK("DISPLY",GPY,GPX+1,CHR$(18))::CALL LINK("DISPLY",GPY+1,GPX,CHR$(17))::CALL LINK("DISPLY",GPY+1,GPX+1,CHR$(19))::RETURN
    380 CALL LINK("PLAY",2760)::CALL LINK("DISPLY",GPY,GPX,CHR$(32),1,2)::CALL LINK("DISPLY",GPY+1,GPX,CHR$(32),1,2)::RETURN
    390 ON DS GOSUB 890,920,1100::RETURN
    400 CALL POSITION(#3,MY,MX)
    410 IF DS>0 THEN GOTO 390
    420 IF B=0 THEN GOSUB 1650
    430 CALL KEY(1,K,S)::CALL JOYST(1,PX,PY)::AN=AN+4::IF (PX=0)*(PY=0) THEN 880
    440 IF PX<0 THEN 480
    450 IF PX>0 THEN 560
    460 IF PY<0 THEN 720
    470 IF PY>0 THEN 640
    480 IF AN>12 THEN AN=0
    490 CALL PATTERN(#3,32+AN)::PY=0::GOSUB 810
    500 GA(1)=1::GA(2)=1::GA(3)=2::GA(4)=1::GOSUB 800
    510 IF (MZ1=32)*(MZ2=32) THEN GOSUB 1140
    520 IF (MZ1>15)*(MZ1<20)*(MZ2>15)*(MZ2<20) THEN GOSUB 1140
    530 IF (MX>33)*(MY>33) THEN 550
    540 IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB 1180
    550 GOTO 1040
    560 IF AN>12 THEN AN=0
    570 CALL PATTERN(#3,48+AN)::PY=0::GOSUB 810
    580 GA(1)=1::GA(2)=3::GA(3)=2::GA(4)=3::GOSUB 800
    590 IF (MZ1=32)*(MZ2=32) THEN GOSUB 1150
    600 IF (MZ1>15)*(MZ1<20)*(MZ2>15)*(MZ2<20) THEN GOSUB 1150
    610 IF (MX>33)*(MY>33) THEN 630
    620 IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB 1190
    630 GOTO 1040
    640 IF AN>4 THEN AN=0
    650 CALL PATTERN(#3,68+AN)::PX=0::GOSUB 860
    660 GA(1)=1::GA(2)=1::GA(3)=1::GA(4)=2::GOSUB 800
    670 IF (MZ1=32)*(MZ2=32) THEN GOSUB 1130
    680 IF (MZ1>15)*(MZ1<20)*(MZ2>15)*(MZ2<20) THEN GOSUB 1130
    690 IF (MX>33)*(MY>33) THEN 710
    700 IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB 1170
    710 GOTO 1040
    720 IF AN>4 THEN AN=0
    730 CALL PATTERN(#3,68+AN)::PX=0::GOSUB 860
    740 GA(1)=3::GA(2)=1::GA(3)=3::GA(4)=2::GOSUB 800
    750 IF (MZ1=32)*(MZ2=32) THEN GOSUB 1120
    760 IF (MZ1>15)*(MZ1<20) THEN GOSUB 1120
    770 IF (MX>33)*(MY>33) THEN 790
    780 IF (MZ1>31)*(MZ1<47)*(MZ2>31)*(MZ2<47) THEN GOSUB 1160
    790 GOTO 1040
    800 CALL GCHAR(INT(MY/8)+GA(1),INT(MX/8)+GA(2),MZ1)::CALL GCHAR(INT(MY/8)+GA(3),INT(MX/8)+GA(4),MZ2)::RETURN
    810 FOR A=1 TO 7::IF MY>YA(A) AND MY<YB(A) THEN MY=YC(A)
    820 NEXT A::IF (MX>97)*(MX<137)*(MY>41)*(MY<89) THEN 840
    830 IF (MX<97)+(MX>137) THEN 850 ELSE RETURN
    840 BNK=1::BDW=1::RETURN
    850 BNK=0::BDW=0::RETURN
    860 FOR A=1 TO 11::IF MX>XA(A) AND MX<XB(A) THEN MX=XC(A)
    870 NEXT A::RETURN
    880 CALL PATTERN(#3,64)::AN=-4::GOTO 1040
    890 DS=1::DD=DD+1::DW=DW+1::IF DW=15 THEN 1010
    900 IF DD>2 THEN DD=1
    910 ON DD GOSUB 950,960::CALL LINK("PLAY",2649)::RETURN
    920 DS=2::ST=ST+1::SW=SW+1::IF SW=60 THEN DS=0::ST=0::SW=0::RETURN
    930 IF ST=4 THEN ST=3
    940 ON ST GOSUB 970,980,990::RETURN
    950 DF1=48::DF2=12::GOTO 1000
    960 DF1=48::DF2=9::GOTO 1000
    970 DF1=76::DF2=12::GOTO 1000
    980 DF1=80::DF2=12::GOTO 1000
    990 DF1=84::DF2=12::GOTO 1000
    1000 CALL SPRITE(#3,DF1,DF2,MY,MX)::RETURN
    1010 DW=0:=P-1::B=0::DD=0::BNK=1::BDW=1
    1020 IF P<0 THEN DS=3::CALL LINK("DISPLY",1,28,CHR$(48))::RETURN
    1030 CALL LINK("DISPLY",1,28,CHR$(48+P))::GOSUB 380::CALL LINK("DISPLY",1,31,CHR$(48+B))::GOSUB 300::GOSUB 1980::RETURN
    1040 IF PX=0 AND PY=0 THEN RETURN
    1050 IF MY<17 THEN MY=17
    1060 IF MY>161 THEN MY=161
    1070 IF MX<9 THEN MX=9
    1080 IF MX>233 THEN MX=233
    1090 CALL LOCATE(#3,MY,MX)::RETURN
    1100 CALL LINK("PLAY",0)::CALL DELSPRITE (#3)::CALL LINK("DISPLY",14,12,"GAME OVER")::CALL KEY(1,K,S)::IF S=0 THEN 1100
    1110 CALL DELSPRITE (ALL)::GOTO 140
    1120 BD(1)=3::MY=MY+2::RETURN
    1130 BD(1)=1::MY=MY-2::RETURN
    1140 BD(1)=4::MX=MX-2::RETURN
    1150 BD(1)=2::MX=MX+2::RETURN
    1160 MY=MY+1::RETURN
    1170 MY=MY-1::RETURN
    1180 MX=MX-1::RETURN
    1190 MX=MX+1::RETURN
    1200 IF B=0 THEN RETURN
    1210 BYO(1)=0::BXO(1)=0::ON BD(1) GOTO 1220,1230,1240,1250
    1220 BYO(1)=-1::GOSUB 1260::RETURN
    1230 BXO(1)=1::GOSUB 1260::RETURN
    1240 BYO(1)=1::GOSUB 1260::RETURN
    1250 BXO(1)=-1::GOSUB 1260::RETURN
    1260 BA(1)=1::BLY(1)=MY+BYO(1)::BLX(1)=MX+BXO(1)::B=B-1::IF B=0 THEN GOSUB 300
    1270 CALL LINK("DISPLY",1,31,CHR$(48+B))::CALL LINK("PLAY",2832)::CALL SPRITE (#8,96,10,BLY(1),BLX(1))::RETURN
    1280 IF M=4 THEN RETURN
    1290 IF DR(M)=1 THEN RETURN
    1300 GOTO 1410
    1310 IF M+1=5 THEN RETURN
    1320 IF BA(M+1)=1 THEN RETURN
    1330 BYO(M+1)=0::BXO(M+1)=0::IF (RX(M)>MX-16)*(RX(M)<MX+16) THEN 1370
    1340 IF (RY(M)>MY-16)*(RY(M)<MY+16) THEN 1390
    1350 RETURN
    1360 BA(M+1)=1::BLY(M+1)=RY(M)+BYO(M+1)::BLX(M+1)=RX(M)+BXO(M+1)::CALL LINK("PLAY",2832)::CALL SPRITE (#8+M,96,10,BLY(M+1),BLX(M+1))::RETURN
    1370 IF RY(M)>MY THEN BYO(M+1)=-1 ELSE BYO(M+1)=1
    1380 GOTO 1360
    1390 IF RX(M)>MX THEN BXO(M+1)=-1 ELSE BXO(M+1)=1
    1400 GOTO 1360
    1410 IF (M=2)*(BAT1A=140) THEN RETURN
    1420 IF (M=3)*(BAT2A=116) THEN RETURN ELSE 1310
    1430 IF (BA(M)=0)+(M=5) THEN RETURN
    1440 IF (M=3)*(BAT1A=140) THEN RETURN
    1450 IF (M=4)*(BAT2A=116) THEN RETURN
    1460 IF BYO(M)=-1 THEN BLD(M)=-1::GOTO 1500
    1470 IF BXO(M)=1 THEN BLD(M)=1::GOTO 1510
    1480 IF BYO(M)=1 THEN BLD(M)=1::GOTO 1500
    1490 IF BXO(M)=-1 THEN BLD(M)=-1::GOTO 1510
    1500 BLY(M)=BLY(M)+8*BLD(M)::GOTO 1520
    1510 BLX(M)=BLX(M)+8*BLD(M)
    1520 FOR A=1 TO 4::IF BA(A)=1 THEN CALL LOCATE(#7+A,BLY(A),BLX(A))
    1530 NEXT A
    1540 IF (BLY(M)<17)+(BLY(M)>161)+(BLX(M)<9)+(BLX(M)>233) THEN GOSUB 1600
    1550 IF (BLY(M)<65)*(BLY(M)>55)*(BLX(M)>88)*(BLX(M)<138) THEN GOSUB 1600
    1560 CALL GCHAR(INT(BLY(M)/8)+1,INT(BLX(M)/8)+1,BC)::CALL GCHAR(INT(BLY(M)/8)+2,INT(BLX(M)/8)+1,BC1)
    1570 CALL GCHAR(INT(BLY(M)/8)+1,INT(BLX(M)/8)+2,BC2)::CALL GCHAR(INT(BLY(M)/8)+2,INT(BLX(M)/8)+2,BC3)
    1580 IF (BC<>32)+(BC1<>32)+(BC2<>32)+(BC3<>32) THEN 1610
    1590 RETURN
    1600 CALL DELSPRITE (#7+M)::BA(M)=0::BLY(M)=0::BLX(M)=0::RETURN
    1610 IF (BC>15)*(BC<20) THEN RETURN ELSE 1620
    1620 IF (BC1>15)*(BC1<20) THEN RETURN ELSE 1630
    1630 IF (BC2>15)*(BC2<20) THEN RETURN ELSE 1640
    1640 IF (BC3>15)*(BC3<20) THEN RETURN ELSE 1600
    1650 CALL COINC(#3,PKY,PKX,4,GC)::IF GC=0 THEN RETURN
    1660 CALL LINK("PLAY",2760)::GOSUB 380::B=6::CALL LINK("DISPLY",1,31,CHR$(48+B))::RETURN
    1670 IF DS=1 THEN 1710
    1680 FOR A=2 TO 4
    1690 IF (BLY(A)>MY-*(BLY(A)<MY+*(BLX(A)>MX-*(BLX(A)<MX+ THEN DS=1::IF M>2 THEN 1720
    1700 NEXT A
    1710 ON M GOTO 1720,1740,1760,1780
    1720 IF DR(1)=1 THEN RETURN
    1730 IF (BLY(1)>RY(1)-*(BLY(1)<RY(1)+*(BLX(1)>RX(1)-*(BLX(1)<RX(1)+ THEN 1810 ELSE RETURN
    1740 IF DR(2)=1 THEN RETURN
    1750 IF (BLY(1)>RY(2)-*(BLY(1)<RY(2)+*(BLX(1)>RX(2)-*(BLX(1)<RX(2)+ THEN 1840 ELSE RETURN
    1760 IF DR(3)=1 THEN RETURN
    1770 IF (BLY(1)>RY(3)-*(BLY(1)<RY(3)+*(BLX(1)>RX(3)-*(BLX(1)<RX(3)+ THEN 1850 ELSE RETURN
    1780 IF DR(4)=1 THEN RETURN
    1790 IF (BLY(1)>RY(4)-*(BLY(1)<RY(4)+*(BLX(1)>RX(4)-*(BLX(1)<RX(4)+ THEN 1860 ELSE RETURN
    1800 RETURN
    1810 HP=HP-1::IF HP<0 THEN 1830
    1820 CALL SPRITE(#16,92,12,RY(1),RX(1))::CALL LINK("PLAY",2760)::CALL DELSPRITE (#8,#16)::BA(1)=0::BLY(1)=0::BLX(1)=0::RBC=16::RETURN
    1830 N=1::DR(1)=1::RBT=120::CALL SPRITE(#12,128,RBC,RY(1),RX(1),-3,3)::CALL MOTION(#4,-3,-3)::GOTO 1880
    1840 N=2::DR(2)=1::BAT1A=120::BAT1B=124::GOTO 1870
    1850 N=3::DR(3)=1::BAT2A=120::BAT2B=124::GOTO 1870
    1860 N=4::DR(4)=1::SPIDA=120::SPIDB=124::GOTO 1870
    1870 CALL SPRITE(#3+N,120,10,RY(N),RX(N))::GOTO 1880
    1880 RX(N)=6::RY(N)=6::CALL LINK("PLAY",2513)::SCR=SCR+PV(N)::SCOR$=STR$(SCR)&"00"::CALL LINK("DISPLY",1,14,SCOR$)::RETURN
    1890 IF (DS=1)+(DS=2) THEN RETURN
    1900 IF (RY(M)>MY-12)*(RY(M)<MY+12)*(RX(M)>MX-12)*(RX(M)<MX+12) THEN 1910 ELSE RETURN
    1910 IF M=1 THEN DS=1
    1920 IF SCR<50 THEN 1960
    1930 IF (BS1=2)*(M=2) THEN DS=1
    1940 IF (BS2=2)*(M=3) THEN DS=1
    1950 DS=2::RETURN
    1960 IF M>1 THEN DS=2
    1970 RETURN
    1980 CALL SPRITE(#3,64,12,73,113)::CALL LINK("PLAY",2649)::DS=0::RETURN
    1990 RY(1)=161::RX(1)=17::RP(1)=2
    2000 IF SCR>=800 THEN 2090
    2010 IF SCR>=300 THEN 2080
    2020 IF SCR>=150 THEN 2070
    2030 IF SCR>=50 THEN 2060
    2040 RBT=100::RBC=15::PV(1)=3::RS(1)=2::HP=0
    2050 CALL SPRITE(#4,RBT,RBC,RY(1),RX(1))::RETURN
    2060 GOSUB 2100::RBC=6::PV(1)=5::HP=0::GOTO 2050
    2070 GOSUB 2780::GOSUB 2100::RBC=16::PV(1)=10::HP=2::GOTO 2050
    2080 GOSUB 2790::GOSUB 2100::RBC=2::PV(1)=20::HP=2::GOTO 2050
    2090 GOSUB 2100::RBC=1::PV(1)=40::HP=2::GOTO 2050
    2100 RBT=108::RS(1)=4::RETURN
    2110 IF SCR<50 THEN 2120 ELSE 2130
    2120 BAT1A=140::BAT1B=116::RY(2)=49::RX(2)=217::RP(2)=4::RS(2)=2::PV(2)=2::BS1=1::CALL SPRITE(#5,BAT1A,2,RY(2),RX(2))::RETURN
    2130 BAT1A=100::BAT1B=104::RY(2)=161::RX(2)=17::RP(2)=2::RS(2)=2::PV(2)=3::BS1=2::CALL SPRITE(#5,BAT1A,15,RY(2),RX(2))::RETURN
    2140 IF SCR<50 THEN 2150 ELSE 2160
    2150 BAT2A=116::BAT2B=140::RY(3)=113::RX(3)=209::RP(3)=2::RS(3)=2::PV(3)=2::BS2=1::CALL SPRITE(#6,BAT2A,2,RY(3),RX(3))::RETURN
    2160 BAT2A=104::BAT2B=100::RY(3)=161::RX(3)=17::RP(3)=2::RS(3)=2::PV(3)=3::BS2=2::CALL SPRITE(#6,BAT2A,15,RY(3),RX(3))::RETURN
    2170 SPIDA=132::SPIDB=136::RY(4)=49::RX(4)=9::RP(4)=3::RS(4)=2::PV(4)=2::CALL SPRITE(#7,SPIDA,4,RY(4),RX(4))::RETURN
    2180 IF (M=1)*(DR(1)=1) THEN 2680
    2190 IF (M=2)*(DR(2)=1) THEN 2700
    2200 IF (M=3)*(DR(3)=1) THEN 2720
    2210 IF (M=4)*(DR(4)=1) THEN 2740
    2220 GOSUB 2300::ON RP(M) GOTO 2230,2240,2250,2260
    2230 RD(M)=-1::GOTO 2270
    2240 RD(M)=1::GOTO 2280
    2250 RD(M)=1::GOTO 2270
    2260 RD(M)=-1::GOTO 2280
    2270 RY(M)=RY(M)+RS(M)*RD(M)::GOTO 2290
    2280 RX(M)=RX(M)+RS(M)*RD(M)
    2290 CALL LOCATE(#M+3,RY(M),RX(M))::RETURN
    2300 IF (RX(M)=9)*(RY(M)=161) THEN RP(M)=2::RETURN
    2310 FOR A=1 TO 6::IF RX(M)=I1A(A) AND RY(M)=I1B(A) THEN 2490
    2320 NEXT A
    2330 FOR A=1 TO 4::IF RX(M)=I2A(A) AND RY(M)=I2B(A) THEN 2500
    2340 NEXT A
    2350 FOR A=1 TO 5::IF RX(M)=I3A(A) AND RY(M)=I3B(A) THEN 2510
    2360 NEXT A
    2370 FOR A=1 TO 7::IF RX(M)=I4A(A) AND RY(M)=I4B(A) THEN 2520
    2380 NEXT A
    2390 FOR A=1 TO 3::IF RX(M)=I5A(A) AND RY(M)=I5B(A) THEN 2530
    2400 NEXT A
    2410 FOR A=1 TO 5::IF RX(M)=I6A(A) AND RY(M)=I6B(A) THEN 2540
    2420 NEXT A
    2430 FOR A=1 TO 3::IF RX(M)=I7A(A) AND RY(M)=I7B(A) THEN 2550
    2440 NEXT A
    2450 FOR A=1 TO 3::IF RX(M)=I8A(A) AND RY(M)=I8B(A) THEN 2560
    2460 NEXT A
    2470 RETURN
    2480 CALL LINK("IRND",4,RC)::RC=RC+1::RETURN
    2490 GOSUB 2570::ON RC GOTO 2590,2600,2610,2600
    2500 GOSUB 2570::ON RC GOTO 2590,2620,2610,2620
    2510 GOSUB 2570::ON RC GOTO 2610,2600,2610,2620
    2520 GOSUB 2570::ON RC GOTO 2590,2600,2590,2620
    2530 GOSUB 2570::ON RC GOTO 2610,2600,2610,2600
    2540 GOSUB 2570::ON RC GOTO 2610,2620,2610,2620
    2550 GOSUB 2570::ON RC GOTO 2590,2600,2590,2600
    2560 GOSUB 2570::ON RC GOTO 2590,2620,2590,2620
    2570 IF (M=1)*(RS(1)=4) THEN GOSUB 2630 ELSE GOSUB 2480
    2580 RETURN
    2590 RP(M)=1::RETURN
    2600 RP(M)=2::RETURN
    2610 RP(M)=3::RETURN
    2620 RP(M)=4::RETURN
    2630 IF (RY(1)>MY-32)*(RY(1)<MY+32)*(RX(1)<MX) THEN RC=2::RETURN
    2640 IF (RY(1)>MY-32)*(RY(1)<MY+32)*(RX(1)>MX) THEN RC=4::RETURN
    2650 IF (RX(1)>MX-32)*(RX(1)<MX+32)*(RY(1)>MY) THEN RC=1::RETURN
    2660 IF (RX(1)>MX-32)*(RX(1)<MX+32)*(RY(1)<MY) THEN RC=3::RETURN
    2670 GOSUB 2480::RETURN
    2680 DR(1)=1::DRW(1)=DRW(1)+1::IF DRW(1)<10 THEN RETURN
    2690 DR(1)=0::DRW(1)=0::CALL DELSPRITE(#4,#12)::GOTO 1990
    2700 DR(2)=1::DRW(2)=DRW(2)+1::IF DRW(2)<10 THEN RETURN
    2710 DR(2)=0::DRW(2)=0::CALL DELSPRITE(#5)::GOTO 2110
    2720 DR(3)=1::DRW(3)=DRW(3)+1::IF DRW(3)<10 THEN RETURN
    2730 DR(3)=0::DRW(3)=0::CALL DELSPRITE(#6)::GOTO 2140
    2740 DR(4)=1::DRW(4)=DRW(4)+1::IF DRW(4)<10 THEN RETURN
    2750 DR(4)=0::DRW(4)=0::CALL DELSPRITE(#5)::GOTO 2170
    2760 RESTORE 30001::GOTO 2810
    2770 RESTORE 20001::GOTO 2810
    2780 RESTORE 30501::GOTO 2810
    2790 RESTORE 30531::GOTO 2810
    2800 RESTORE 30602::GOTO 2810
    2820 RETURN
    2830 RESTORE 2950
    2840 FOR MD=1 TO 7::READ MDA,MDB,MDC::YA(MD)=MDA::YB(MD)=MDB::YC(MD)=MDC::NEXT MD
    2850 FOR MD=1 TO 11::READ MDA,MDB,MDC::XA(MD)=MDA::XB(MD)=MDB::XC(MD)=MDC::NEXT MD
    2860 FOR MD=1 TO 6::READ MDA,MDB::I1A(MD)=MDA::I1B(MD)=MDB::NEXT MD
    2870 FOR MD=1 TO 4::READ MDA,MDB::I2A(MD)=MDA::I2B(MD)=MDB::NEXT MD
    2880 FOR MD=1 TO 5::READ MDA,MDB::I3A(MD)=MDA::I3B(MD)=MDB::NEXT MD
    2890 FOR MD=1 TO 7::READ MDA,MDB::I4A(MD)=MDA::I4B(MD)=MDB::NEXT MD
    2900 FOR MD=1 TO 3::READ MDA,MDB::I5A(MD)=MDA::I5B(MD)=MDB::NEXT MD
    2910 FOR MD=1 TO 5::READ MDA,MDB::I6A(MD)=MDA::I6B(MD)=MDB::NEXT MD
    2920 FOR MD=1 TO 3::READ MDA,MDB::I7A(MD)=MDA::I7B(MD)=MDB::NEXT MD
    2930 FOR MD=1 TO 3::READ MDA,MDB::I8A(MD)=MDA::I8B(MD)=MDB::NEXT MD
    2940 RETURN
    2950 DATA 14,26,17,43,57,49,73,87,81,91,109,97,107,114,113,123,148,129,153,180,161
    2960 DATA 8,14,9,28,40,33,50,64,57,75,89,81,103,121,113,123,136,129,138,152,148
    2970 DATA 161,177,169,186,199,193,210,224,217,225,233,233
    2980 DATA 33,81,57,49,57,129,81,97,169,129,169,81,33,129,57,81,169,97,233,113
    2990 DATA 81,49,129,17,169,17,193,17,217,49,57,161,81,129,129,49,145,97,145,161,169,161,217,81
    3000 DATA 9,17,57,17,193,113,33,17,145,49,145,129,233,17,233,81,9,129,33,161,193,49
    3010 DATA 193,129,233,49,233,161
    3020 CALL SPRITE(#1,88,6,65,113,#2,92,6,81,113)
    3030 CALL LINK("DISPLY",9,15,CHR$(32),1,2)::CALL LINK("DISPLY",10,15,CHR$(32),1,2)::CALL LINK("DISPLY",11,15,CHR$(32),1,2)::BDW=0::RETURN
    3040 CALL LINK("DISPLY",9,15,CHR$(5),1,2)::CALL LINK("DISPLY",10,15,CHR$(6),1,2)::CALL LINK("DISPLY",11,15,CHR$(0),1,2)::CALL DELSPRITE (#1,#2)
    3050 BDW=1::RETURN
    If you want to run the game in XB (which is awful), merge the attached compressed data statements file
    data.zip
  6. Updated Rom Image
    Find space or make new title screen
    Title screen is back I took the suggestion to use variable arrays for the maze constraints and intersections, and got a lot of memory back, the speed is about the same though.
    When converting my game from BASIC to XB I changed all of the mathematical logic statements in my IF-THENs to actual logic operators OR and AND. It will save a few bytes here and there, make it easier to read, and may even help execution speed (like that will matter when compiled, right?)
    So the code:
    890 IF (MX>8 )*(MX<14) THEN MX=9
    900 IF (MX>28)*(MX<40) THEN MX=33
    910 IF (MX>50)*(MX<64) THEN MX=57
    920 IF (MX>75)*(MX<89) THEN MX=81
    930 IF (MX>103)*(MX<121) THEN MX=113
    940 IF (MX>123)*(MX<136) THEN MX=129
    950 IF (MX>138)*(MX<152) THEN MX=148
    960 IF (MX>161)*(MX<177) THEN MX=169
    970 IF (MX>186)*(MX<199) THEN MX=193
    980 IF (MX>210)*(MX<224) THEN MX=217
    990 IF (MX>225)*(MX<233) THEN MX=233
    Could all be re-worked as
    890 IF MX>8 AND MX<14 THEN MX=9
    900 IF MX>28 AND MX<40 THEN MX=33
    910 IF MX>50 AND MX<64 THEN MX=57
    etc...
    Also, I spend a lot of time finding relationships and patterns, and sometimes reworking things to produce them, so I can use long mathematical formulas to produce desired results. Though I really recommend against that as it does tend to drive me bonkers and I get overly obsessed with it.
    So like here, spacing for your target values is 24 apart (9, 33, 57, 81, 133, ..., 217, 233) Find a way to quantify your testing ranges and you can give each range a value to multiply by 24 and add 9 ( MX=r*24+9, r=[0..10] ) Or, like I said, spare your sanity.
    Senior Falcon had posted the opposite of this in some other message thread. That is why I went with using * for AND and + for OR because he said it saved a little bit of memory. Is that not right?
    Here's the link:
    http://atariage.com/forums/topic/273371-4k-shortnsweet-game-contest/page-8?do=findComment&comment=3974965
  7. Wow LASooner!
    This is really already a fairly magnificent achievement. Your rendition of the game is simply beautiful!
    Here's a video for any of you out there whom haven't seen the original (1982) Night Stalker game on Intellivision:
    Being a long-time fan of the system, I absolutely love playing Night Stalker. Definitely one of the best games on the Intellivision.
    LASooner has nailed the look-sound-feel of the original game. BRAVO Sir!
    Especially notable: Love the Intellivision running man character and the spot-on: Maze, Gun, Spiders (better actually) and Robots... to include Spot-On Robot explosions. Sweet!
    Pulsing beat in the background? It's here too!
    The original game felt sluggish on Intellivision so I really don't feel like you're too far off on the pacing. Especially since yours is written in a variant of XB.
    Sure, it's compiled..but hey. I encourage you to continue to refine this game and show-off what can be done with Senior Falcon's XB256+Compiler tools.
    Very cool of you to post the code which will not only allow others to help optimize your code but will also allow noobs to learn from your experience! Again, BRAVO!
    WE NEED MORE BASIC PROGRAMMERS TRYING OUT THE AMAZING TOOLS SENIOR FALCON HAS PROVIDED.
    You even incorporated box art into the intro screen?! You ROCK!
    Learn more...wiki: https://en.wikipedia.org/wiki/Night_Stalker_(video_game)
    That game play looks sped up, am I crazy? Or maybe it's because I've been playing my dogsh*t slow version so much lately. :-)
    Thanks for the kind words shack, you've been a lot of help with the XB256 stuff
  8. Video should be working now YouTube marked it private for some reason
    So put the sprite positions for the robots and bats in a 2 dimensional array and check against that? Is that what you guys are saying?
    Something like XX(ROW,COL), Storing all the the intersection locations in that to check against. Do I have that right?
    And would that improve speed as well?
  9.
    Updated the Rom image in 1st post.
    Had to remove my title screen to make room, just so the game can run compiled. Will look into trying to free up memory, or just make a simple title.
    Bats and Spiders die from bullet hits from player
    Level 2+ Robots pursue player through maze
    Add delay before player and robot respawn
    Game is more or less feature complete, lots of debugging and performance issues to sort out. Level 4 robot features aren't critical as I don't think many will get there yet.
    Has anyone played it?
  10. I now have level 2 or higher robots chasing the player, it's working pretty well.
    However, I'm running out of memory after the game is compiled, I don't know why, but I'll have to look into optimizing it. In extended basic, the memory left is roughly 4.6k remaining before I run it, and roughly 3.6k remaining after running it, so I'm not sure what's happening after compiling that's causing me to lose that 3.6k, but that doesn't seem right.
    because of this I have not uploaded a new rom image since it doesn't run.
  11. Updated Rom image in Post 1:
    This is the last major hurdle, but in getting this working the delay for the robot respawn seems to have broken
    Game is playable but too slow, I need to optimize some more, also running up against memory limits, lots of if/then statements that I'll need to see if I can do it better, Notepad ++ reports 178 IF/THEN Statements
    If anyone wants to take a crack at improving speed and memory, I've included the code. I program in TIdBit so the comments are in that format.
    Be nice, Code is not my strong suit.
    EDIT:
    Updated in a later message, just didn't want people trying to fix problems I fixed
    http://atariage.com/forums/topic/276268-night-stalker-in-progress-xb256-compiled/?p=3985398
