421 -
Posts posted by Mot
Can't find:
2600 laserease
and
2600 Reflex if it is Video Reflex then the entry is:
Video Reflex [tab] FootCraz [tab] VIDRFLX [tab] 4K [tab] 78BIOS
Hi,
I was trying to make the very best MenuGenerator with the very best rom data base.
It is probably out-of-date but you all can look at this
Also I made a MenuGenerator in Java and it is here:
Anyone is welcome to take this stuff and change it and claim credit for it.
I can try to add these to my DB. In my CC2ROMDB I put in the controller and the company for each rom, but my CC2ROMDB.txt will still work with the exe on Cuttle Cart 2 Site.
So, I broke under pressure and carefully lifted up the top of the shrinkwrap after cutting it open so I can open up my sealed, boxed copy of Ballblazer for the Atari 7800, and I noticed the front label is silver while the top/end label is red. Was this a mis-print, or does anyone else here have a cartridge like this?Did you see:Ballblazer Color label - Red end label?
Are the '84 editions better made than the '87 ones? Also, I understand the expansion ports aren't connected on the board, but were there any plans for utilizing it? The same "add a disk drive/keyboard and turn your ProSystem into a home computer" ideas or something game related (i.e. external POKEY support or added RAM)?The 84 w/expansion port has been said to be more compatable then the 87 ones.
The exapansion port was mostly for a LaserDisc thing see: Atari History Museum's Atari 7800 Pro System page.
And if you have about an hour, listen to Steve Golson of GCC (the co that made the 7800) tell how the 7800 happened.
I loved it. Thanks Curt!
They do talk about the keyboard. The first proto was to hook to the cart slot (I think).
The final proto hooks up to joystick port #2.
Anyway read that page and it will answer all these questions.
Does anyone know if this works for Frogger with sound?
7800: Frogger 10/07/05 (WIP)(uses Pokey) FROGR78 78HSCPOK HSCPOKQU
I think we need a FAQ for the CC2
How do d/l a newly created game and put it on my CC2 and play it?
Most people take their MENU.TXT file and add the new game entry to it and then they use the CC2MenuConverter program to take the MENU.TXT file and make a MENU.CC2 file.
If someone in the thread posts the CC2 settings ( the bankswitching and the startup) you should use them. Otherwise you will need to ask or try to figure them out on your own.
First, get the size of the rom file.
ect......
So let’s say you want to play the new Q*Bert, you would take your current MENU.txt file and add the new entry at the bottom (maybe) like this:
7800: Q*Bert WIP QBERT78 HSC_32K HSC
7800: Q*Bert WIP<tab>QBERT78<tab>HSC_32K<tab>HSC<tab>
run the CC2MenuConverter program on the MENU.txt file and then take the BIN file (and NOT THE a78 FILE) and rename it QBERT78.bin (to match the name in the entry above) and put it in the GAMES directory on your MMC card. Also put the new MENU.CC2 in the root of the MMC and you are ready to play.
okay for those exact english people, I ran out of space for a queston mark, for the person who doesnt get it I rewrote it, for those who think im a noob thats truenow then JUST AWNSER THE QUESTON, nothing funny ok?
for those who dont know what im trying to do, im planning to mod my atari fb2 so it can play atari games. Our friend ben (the guy with the cool portable website) used a 51/4 floppy drive for his portable, rather than looking for one or ordering one from best electronics, I know that fry's electronics probably has a 51/4 somwhere so, I wanted to go the faster route rather than waste a perfectly good atari 2600. Will it work?
OK I think I got it! Here is what he is asking:
I have (or I can get) an old 5 ¼ inch floppy disk drive connecter with the ribbon cable. Can I use this connector instead of ordering a new 2600 cart connector + new ribbon cable, or cannibalizing an old 2600 just for the connector, to hack in a 2600 cartridge connector into my Flashback 2?
In other words, will an old 5 ¼ inch floppy disk drive connecter be used to put 2600 cartridges into?
It seems that Ben used one for one of his projects, see the picture above.
I was noticing that one of our newer members has an image from the 1982 Atari game catalogs as his avatar, and at that size, the image looks almost like a stylized picture of a "wizard" with outstretched arms -- in particular, the wizard from the Brain Games artwork.Anybody else with me on this?
At first glance, I thought it was a samurai out-fit.
(the avatar picture is a bit smaller, so it makes the chance of seeing things greater.)
No Benjamin J. Heckendorn has never used a 5 and 1/4 Floppy diskette to create a Porable Atari 2600.
But I think the main question is will Ben make a Portable 2600 out of the Flashback 2
because this would be a lot smaller
and a lot less power consuming product.
you forgot something there Mot, I said FLOPPY DRIVE NOT FLOPPY DISK.
I liked the way that you added alll that information but you were talking about a diskette NOT A DRIVE.
Well first off, I don’t think anyone truly knows what you are asking.
But if you have a FLOPPY DRIVE, you MUST use a FLOPPY DISK in the drive otherwise it will be good for nothing. Unless you are trying to say something to the effect: "Can parts from a 5 1/4 floppy disk drive be used for an Atari 2600 cartridge?”
And maybe you are thinking (like Retro Archaeologist had thought you where asking)
Can you use a 5 1/4 floppy disk drive type ribbon cable to add a Cartridge Port to your Flashback 2?
And if this is your question look at Hacking the Atari Flashback and particularly Page 3 for your answer.
And if you are still asking something else; please reword your question and we will be glad to answer it.
Perceived scarcity also plays an amazing role in determining prices. Someone else joked that as soon as Chad sells out, the things will sell for $300 on ebay. I don't know if that's quite true, but I would expect that there are a number of users who, if told that they had to spend $200 today or never ever be able to get a CC2 would do so; many of these users, however, see no particular rush and so they're perfectly happy to survive without a CC2 until tomorrow, and the day after, etc.
After the first batch was gone and Chad said no more, one went on e-bay for $400.
I got most of them to work except "Q*Bert"
I changed to:
7800: Q*Bert WIP QBERT78 HSC_32K HSC 6a4865d8 WIP -
So here is the new DB with these def's added:
I love the trakball version of Centipede.
Are these correct?
Boggle (Prototype) BOGGLE 2K 78BIOS 666b38f0 7800: Q*Bert WIP CENTTB78 HSC_16K HSC 6a4865d8 Ixion (Prototype) IXION F8 78BIOS 6c791880 7800: Centipede (Trackball hack) TB CENTTB78 HSC_16K HSC 0e416a41 7800: Trackball test program TB TESTTB78 HSC_16K HSC 0f07c50e 7800: Frogger (WIP)(uses Pokey) BD78POK 78HSCPOK HSCPOKQU 59f19b41
The 2600 cartridge connector and (Optional) cartridge guide can be obtained from:B&C Atari Sales & Service - www.myatari.com
Best Electronics - Atari Parts & Sales - www.best-electronics-ca.com
OK, I put in sub-menu into that program of mine:It does put in a sub menu for each company and each controller, so this will go 3 levels deep and make a lot of files to put on your MMC card.
This still is/maybe buggy, so be warned. I can try to fix everything. (maybe I should start a new thread for bugs and enhancements.)
Here is what it looks like now:
Have fun
Now it will sub menu at different levels. So if a company has more then 20 items:
it will put in a entry like this in the COMPANY.CC2:
----20th Century Fox (Menu 22 itms)-----
and will create a sub-menu like this:
Alien Alligator People (Proto) Bank Heist Beany Bopper Crash Dive Crypts of Chaos Deadly Duck Earth Dies Screaming Entity (Proto) Fantastic Voyage Fast Eddie Flash Gordon M*A*S*H Mega Force Pick Up (Proto) Planet of the Apes (Proto) Porky's Revenge of the BS Tomatoes Save The Whales Spacemaster X-7 Turmoil Worm War I Return to COMPANY <<<<<<<<<<<<<<<<<<<<<<
Here is my controller menu:
----------2-Btn (Menu 29 itms)---------- ---------------BoostrGrp---------------- Omega Race BoostrGrp ---------------CosmicCmd---------------- Survival Run CosmicCmd -----------------Drive------------------ Indy 500 Drive Stell-a-Sketch Drive ----------------FootCraz---------------- Video Jogger FootCraz Video Reflex FootCraz ----------------Joy+TPad---------------- Star Raiders Joy+TPad --------Joystick (Menu 641 itms)-------- -----------------Keypad----------------- BASIC Programming Keypad Brain Games Keypad Code Breaker Keypad Concentration Keypad MagiCard Keypad SynthCart (Paul Slocum) Keypad ----------------KidCtrl----------------- Alpha-Beam with Ernie KidCtrl Big Bird's Egg Catch KidCtrl Cookie Monster Munch KidCtrl Grover's Music Maker (Proto) KidCtrl Holy Moley (Proto) KidCtrl Monstercise (Proto) KidCtrl Oscar's Trash Race KidCtrl Peek-A-Boo (Proto) KidCtrl -----------------KidVid----------------- Berenstein Bears Smurfs Save the Day ------------------LGun------------------ 7800: Barnyard Blaster LGun 7800: Meltdown LGun Sentinel LGun Shooting Arcade (Proto) LGun ---------Paddles (Menu 45 itms)--------- Return to ROOT MENU <<<<<<<<<<<<<<<<<<<<
In here there are sub-menu's for:
2-Btn, Joystick, and Paddles
If you can think of a better way to put these sub-menus items in please let me know.
Happy CC2-ing.
In the current discription of Barnstorming:
The game is notable as being the first Activision game with a sunset in the horizonYou could add a link to the Venetian Blinds Demo
because of
The sunset was later used in the background of Barnstorming.Just my 2 cents.
Sorry, didn't see that option. This must have changed while up-grading?
Have fun
Chad,
One minor thing: When you come back to the menu after powering off and back on, it is no longer in the menu but at the top menu, with –select- highlighted.
Did you want that to happen, because with the old menus, it didn’t do that?
OK there is something wrong with the new CCROMDB.TXT and this program when it comes to company order.
The program will gen with controller order and/or game name order.
The program is getting an error in the Company order part and will not go on to the controller order section after this error. I will need to fix and replace the program, maybe this weekend.
Soory
It didn't have it...I copied and pasted to word the menu file txt generated and there is only entries for names.
no companies no controllers.
just renamed my other cc2 file and games GAESold and Menu.old and put the new generated file in but it only had the names,
when I ran it without names checked I got nothing but the GAMES folder, nothing in the txt file... (nothing in the cc2 file either!)
OK, I'll look into it and get back to you.
@mot: That would be awesome!BTW I just ran the java applet just like I would the menu generator, with a copy of all of my roms in a folder with the cc2romdb that you provided. I selected all three methods of ordering the roms... ran the program and got the memu.txt, menu.cc2 and GAMES folder as expected nice little progress list, but no format change when running in the cc2...the alternate controler games were still all mixed in there was no grouping by company or anything, did I do something wrong?
If you selected all three check boxes, then you will have to go past all the usual entries sorted by game name to the part that has them sorted by company name then then to the part where it is sorted by controller type.
or
go backwards to see the controller type section.
I guess a script to add the stuff you want could be done using the CC2ROMDB.TXT that I wrote.
The hard part of what you want is sorting the game name while ignoring the prefix.
I think only a few people seem to want to sort their CC2 menu in different ways other than just game name around here. ?
One thing I would like to have a 2 level menu on the cc2 so the top level would be:
GAME NAME
COMPANY NAME
CONTROLLER TYPE
Once you select one of these choices, the sub menu would appear with a list of the games in that order.
That would be realy spiffy dude!
The CC2ROMDB is there a way to safely edit that so that "(PAL)" at the end = "P: " at the begining so that all the PAL games are in a group, likewise the non protos, (proto) = "Proto: " , Hack/Home = "Hk: " or "Hb: " and the alternate required controlers "C:(ctrl type) "((conversly all the NTSC games could have an "N:" instead, depending on region))
In the DB that I created I have company as one of the attributes this takes care of "Hacks" as this is listed as Hacks as the company.
I was thinking of putting a check box in my Java Menu gen program, to filter by removing all (PAL) roms but you can always just take out the PAL (or NTSC) from the input directory.
(ctrl type)2B -two button
BG -booster grip
KC -kids controller
KB -key board
PK -pokey
AV -Atarivox
FC -footcraz
TP -touchpad
Pl -paddel
DC -driving controler
ML- mindlink
TF- Track and Feild controller
with the hierarchy being Proto/pal/7800/H/controler not normal (name of game)
= "Proto: P: 78: (Hk:or Hb:) C(xy): " or a total of 20 being the longest possible string if we leave in spaces... if its a proto pal 7800 hack/homebrew that uses alternate controlers... (not likely to be a released hack/homebrew that is also a proto)
of coruse you could have it omit spaces that would save room also.
...just cuz I'm lazy and run the menu generator frequently.
In the CC2ROMDB.TXT that I created I put in this as one of the attributes and here are all of them:
private static final String[][] CONTROLLS = { {"2", "2-Btn"}, {"K", "Keypad"}, {"P", "Paddles"}, {"D", "Drive"}, {"C", "CosmicCmd"}, {"B", "BoostrGrp"}, {"F", "FootCraz"}, {"I", "KidCtrl"}, {"V", "Joy+TPad"}, {"L", "LGun"}, {"JL", "Joy/LGun"}, {"J2L", "2BJoy/LGun"}, {"KV", "KidVid"}, {"TB", "Trackball"} };and I wrote the Java menu gen to go with this data so it will sort the games in controler order. So I can plug my paddles in and go to the paddle part of the menu and play these at one time.
Sample output menu is:
----------------Joystick---------------- 7800: Asteroids 7800: Ballblazer 7800: Centipede : ----------------Paddles----------------- Astroblast Paddles Bachelorette Party Paddles Backgammon Paddles
CUTTLE CARD Technical infos of bin files
in Atari 7800
Here are my results from looking at each of these games.
2600 Aztec Challenge. I found A-VCS-tec Challenge and the rom there looks (to me) that it is a PAL Demo.
AVCStec Challenge pal demo (WIP) AVCSTEC F8 78BIOS d5db7577 Hack 0 -
2600 Bounce
Bounce (WIP) BOUNCE 4K 78BIOS 348750fe Hack 0 -
2600 Crazy Balloon
Crazy Balloon (WIP) CRAZYBL 4K 78BIOS 1c5abf0a Hack - -
Crazy Balloon PAL (WIP) CRAZYBLP 4K 78BIOS 1749ecc4 Hack - -
2600 Incoming
This seems to have no sound to me, so:
Incoming (no sound) INCOMING 4K 78BIOS ffd43cd3 Hack - -
2600 Ladybug
No sound and enemies don't move.
Ladybug no sound demo (WIP) LADYBUG F8 78BIOS e22fe26e Hack - -
2600 Laserease
Can't find.
2600 Reflex
Can't find but if it is Video Reflex then the entry is:
2600 Robot City
No sound and I can't kill the enemies.
Robot City (WIP) ROBOTCTY 4K 78BIOS 03335d0d Hack - -
7800 Frogger
7800: Frogger 12/18/05 (WIP)(uses Pokey) FROGR78 78HSCPOK HSCPOKQU 43b33c6e WIP - -
7800 Q*Bert
7800 Senso
Still working on it.
7800 Tubes
No sound for me (is this pokey?) but here is the entry.
7800: Tubes 8/9/05 (WIP) TUBES78 7800_16K 78BIOS 3029e893 Hack - -
