potatohead
    4,794
    16
Posts posted by potatohead
  1. Just caught what Batari was saying about releasing on tape for Supercharger.
    Will on tape capabilities be an option for Glenn Saunders Super-Supercharger? And is that the Chimera?
    If so, that's huge, IMHO. Shipping games on CD for use with that thing would really open up some doors, IMHO.
    Just rambling, anyone have any new info to share?
  2. Hey all!
    Ooze is stalled because:
    Personal issues. (move from hell soaked every dime I had --still catching up and working lots of OT to do it)
    That's the biggie.
    Coupla smaller issues are:
    New Bb environment will allow for most of the feature ideas tossed out to be completed. That means there is a game there, I just need to get into a space to complete it.
    For some features, I'll need some hardware to actually test on.
    Long story short, keep it on the list, there is time yet this year to get what I want to get done!
    BTW: This community rocks. The moment I get some free cash (and actually get it in my hand instead of thinking I'll get it), I'll be buying some carts! Amazing work on these.
  3. I want to use the paddle input to detect when a switch is closed to ground. I've used up all the port and trig inpus already - so I can't do it that way. The way I have the circuit set up is one end of a 4k resistor to +5v and the other to paddle1 input, then 1 end of switch to ground and other to paddle1 input. Then I do a LDX $271 - CPX #228 - BEQ routine. This work most times but sometimes gets stuck <> 228. Is there a more reliable way to do this - fast pot dump, or checking a register before I read it.
    As an alternative to the range, simply compare one way or another, keeping the dividing value close enough to the open state to allow for as much variation as possible, without getting unwanted closed conditions.
  4. I'm working on a new one now. Would it be easier to program a Breakthru (where the ball keeps going after it hits a block) or Breakout (where the ball comes down after it hits a block)? Also, how do you get bBASIC to know when a block gets hit and to remove it from the playfield?
    Use the collision registers. The 2600 will tell you, by setting a bit in one of them, when your ball object hits your brick object.
    If {register from the list I linked above} = some value, then gosub get_rid_of_block.
    Once you have detected the collision, then you need to compare the position of the ball to where the blocks are and erase one.
    This is going to take some math, typically dividing the ball position by something to get the x block number for the pfpixel command.
    bB has collision commands, take a look at them.
    Do something goofy, like change the color of the ball first, to let you know you have successfully detected the collision state, then work on getting rid of the blocks.
  5. As for the ball movement, if you factor out english (paddle velocity), then you can divide the paddle into zones.
    Change the ball angle depending on the zone. You do this by comparing the paddle x coordinate and the ball x coordinate at the moment they collide.
  6. I've read that before, it's just one of the registers that isn't used outright in bB so I didn't recognize it. Thanks for clearing that up.
    I'm a bit old school in that regard. If there is a register, I prefer to just use it as I would any other variable.
  7. 93 if CXP1FB < 64 then 154
    I didn't see any DIM statements, what in the world is CXP1FB?
    That's a collision register. All of the key memory addresses has a label like this. Sometimes, it's easier to just use the label than anything else.
    Here is one list of them, I know there are others:
    http://alienbill.com/2600/101/docs/stella.html
    There are things that happen in the 2600, such as a bit getting set when the playfield and a player overlap. Those bits exist at the memory addresses defined by the label.
    The statement in the sample game checks to see if a player (the ball shape) touches the playfield. If it does, then the brick closest to the ball (based on it's xy coordinates) is removed.
  8. Here is that old version. Took a while to track down the post.
    http://www.atariage.com/forums/index.php?s...72428&st=50
    1 rem smartbranching on
    5 AUDC0 = 12 : AUDF0 = 3
    10 x = 50 : y = 90 : w = rand : v = 60
    11 d = 1 : e = 255 : f = 0 : g = 0 : h = 1 : i = 0 : j = 0 : k = 0 : l = 0
    12 if w > 100 then w = 100
    14 if w < 40 then w = 40
    20 COLUPF = 54 : COLUBK = 17
    22 pfhline 0 2 31 on
    23 pfhline 0 3 31 on
    30 COLUP0 = 120 : player0x = x : player0y = y : l = l - 1
    40 scorecolor = 10
    45 player0:
    %01000010
    %11111111
    %11111111
    %00000000
    end
    46 player1:
    %00011000
    %00111100
    %01111110
    %00111100
    %00011000
    end
    47 a = a + 1 : if a < 3 then 90
    49 a = 0 : i = INPT4
    51 w = w + d : v = v + e
    52 if l = 0 then l = 4 : w = w - d
    64 player1x = w : player1y = v
    65 pfvline 0 0 11 on
    66 pfhline 0 0 31 on
    67 pfvline 31 0 11 on
    68 pfhline 0 11 31 on
    69 AUDV0 = 0
    90 drawscreen
    92 f = x + 250 : g = x + 5
    94 if l = 1 then 154
    110 j = w - 28 : j = j / 2 : j = j / 2
    112 pfpixel j 3 off : l = 1
    118 AUDF0 = 58 : h = 1
    130 if e = 1 then e = 255
    134 if e = 255 then e = 1
    154 if v > 88 then 159
    157 goto 173
    159 e = 255 : h = 1 : l = 0
    160 if w < f then e = 1 : h = 0 : AUDF0 = 50
    162 if w > g then e = 1 : h = 0 : AUDF0 = 50
    173 if v < 15 then e = 1 : h = 1 : AUDF0 = 40 : l = 0
    175 if w > 148 then d = 255 : h = 1 : AUDF0 = 70 : l = 0
    177 if w < 35 then d = 1 : h = 1 : AUDF0 = 70 : l = 0
    179 if h = 1 then h = 0 : AUDV0 = 15
    180 if joy0left then x = x - 1
    190 if joy0right then x = x + 1
    195 if i < 15 then 5
    200 goto 30
    This was waay back in bB history. Line numbers required, only simple expressions allowed, etc.... Maybe I'll do this again with the latest version.
  9. I wrote that. It was the first build of bB that Batari released. I'm not sure the code would run, unchanged in more recent versions of bB.
    The machine I wrote it on is not up at the moment. I've got to power it up anyway for some unrelated things, I'll go digging to see what I find.
  10. Nah, he deserves more punishment for throwing all that gaudy glitter onto the screen when you're playing Tempest 2000. Hey, knock it off with the ticker tape parade! I'm trying to play a video game here!
    Seriously though, I can't blame Jeff for making derivitives of popular games like Centipede and Tempest, especially when some of those games are officially licensed. Besides, what is Centipede but a faster-paced, entomology-themed Space Invaders?
    JR
    Ahh but he did his job well. That frustration you feel when the pixellation is at it's peak, is a cultivated thing. Without it, Tempest 2000 would be a great game, but would not so easily invoke that trance state all shooter, twitch gamers go for. Pixellation at it's finest! That kind of thing is rare these days.
  11. It's also on the 5200. NM, it looks like even the 400 has more RAM than the 7800.
    The 400 and 5200 have 16K of RAM. The 7800 has 4K. Those two machines also include a 160x100 graphics mode which uses 4K of RAM for a full-screen bitmap; the 7800 has no such mode and would thus likely require 8K of RAM for a 160x200 full-screen 4-color bitmap.
    I keep hearing about these limitations on the 7800... sounds to me like the old 2600 is actually more flexible --or nobody has really put the screws to the 7800 just yet.
    Couldn't sprites be dynamically aligned where they need to be to draw the lines? No worse than the 2600 way of doing things is it?
  12. Yeah, people still say stuff like "hey did you get that new Bruce Springsteen album yet?" even though everything is on CD now.
    Isn't the word Album still appropriate as in a collection of individual recordings? Asking if one has gotten the LP or the Record is old news, but an album is still an album, regardless of the media carrying it. (Tape, CD, Vinyl, 8 Track, Zip file, mp3, etc...)
    Think of it like Photo Album, which is a collection of individual photos.
  13. 1982 my uncle got a 400. I got a 600xl in 1984. Those were the best summers of my life.
    No kidding. Back then it was possible to completely understand a computer. Well, a lot more completely than is generally possible today. Of all the Atari machines, I like the 400 for it's sleek lines and the 2600 because the original said Video Computer System on it. There was an air of professionalism and innovation to that name that really stuck in my mind.
    Fast forward to today... I've still got the 400, looking to get a 2600 that says VCS on it and a 7800 + supercharger. For me the real interest was the technology vision --lots of interesting ways of doing things on the Atari --some of which are still relevant today. I guess that's not totally honest. I also loved --and still do love the hardware. Jay Miner had a special touch when it came to these things. The Atari video sub-systems (one could argue the 2600 is a video sub-system that just happens to play games!) are a wonderful melding of software and hardware. This has turned out to be distinctive as new display techniques have been innovated to this day. The smarter you are, the more the machine will do. Not many other systems are like that.
    Those two attributes remain a core influence on how I view computing today. Having multiple platforms, each with strengths and weaknesses, serve to highlight the difference between what is computing and the actual computing platform used to compute! That may sound Zen, but it's as important of a realization as the difference between software and data, for example.
    I'm glad I got to learn computing when I did. It's a wonderful time when one could go to the grocery store and purchase magazines filled with code, news, games and HACKING! Not only was hacking accepted, but encouraged! Getting more out of your hardware and making it do what you want were the issues of the day. Somehow in this bland, largely win32 and Mac world, we have lost some of that. (Well, unless you embrace the beast that is Linux!)
    My old 400 and 7800 are connected to an SGI indy. I use the video in to display their displays in a little window, not unlike the one you get when you run an emulator. Puts things in perspective some times.
    Somebody needs to make a $50 computer that connects to a TV that makes use of the amazing portable media we have today. Make it open, simple with a good CPU that is easily programmed in assembler. Mix in a Jay style video system with just enough limits to make creating displays and games the artform it is on the Atari machines.
    (And it is art too. Look at the excellent homebrews seen here these days. Done for the fun of it, they all would be worth millions back in the day. We won't see the same for modern day machines because the simple joy of computing and the art of realizing immersion within sharp limits is not there on modern hardware.)
  14. Found a minor bug:
    If you pick up the final letter of EXTRA (haven't tested with SPECIAL yet) and that finishes the current part, the game will skip the next part.
    Good catch!
    New build:
    - fixed a bug that would cause a level to skip if the last letter in EXTRA or SPECIAL was collected to finish the current level
    Thanks!
    PS: New high score:
    Part 23: 435,220 :)
    Just tried playing this one. Great job BTW!
    It's stuck on the first screen. All dots gone, but no advancement to the next level.
    Playing on the latest Stella release.
  15. Since I only had 2 official bBasic entries, I decided to cancel the contest altogether. It's no offense to those who did work towards the contest, but I think there had to be more competition for it to be a valid contest.
    I started a couple Supercharger games, but found it hard to get excited about coding for a platform that requires exotic hardware but can't use it to anything near its capabilities. Something like 4A50 seems much more interesting, though I'm wondering whether I should have included "magic writes". They're rather nice, but they mean that 4A50 games won't be supportable on the Krokodile Cart.
    The magic writes are not the only reason why 4A50 can't be supported. The chip is full and I simply can't support anything new with the current design. So it would make very little sense to modify your design. If I had space, the next thing I would add is F0, E0, AR or FE (because I think the original bs modes have highest priority). And If I should ever make a modification to the Krokodiles design, then I can support 4A50 no matter how it would finally look like.
    I want the 4a50 to become a reality. The magic writes are gonna open some doors that will make very good use of the hardware. In the end, they will be worth it, IMHO.
  16. (big ass quote removed)
    Yeah, got rid of my CoCo 3, but kept the Atari too. Still miss that damn 6809 though. I've always thought at 6809 computer with atari style hardware would be damn cool. Wonder if that's possible in the older A8's where the CPU is on a card?
    "Jay Miner got it" --yes he did. Software controlled video hardware forces a style of programming that is keyed to the video output. It also allows for innovation to occur that can extend the life of the system far beyond it's years. For me, watching that happen and tinkering once in a while, is what makes the Atari machines stand out. Machines with Jay's touch are really Atari machines. (Which is exactly why I never owned an ST.)
    Jay went on to create many specialized display systems for medical imaging and other highly sensitive visual applications. Too bad his vision never moved forward past the Amiga in the home computer scene. Wonder how he would have done 3D?
    There is a strong case for saying most of the 8bitters participated in the revolution in some way too. All of them brought something interesting to the table and got a lot of us computing. One nice thing about that time was the differences. If a person had exposure to different machines, then that thing we call computing became seperated from the hardware in a healthy way. I run Linux, IRIX and win32 today for that very reason. Having different platforms around feels like home in a way that's hard to explain? Anyone here feel the same?
    Another thread idea maybe: What machines today are the most Atari like? I nominate the SGI O2 as one. Cool custom hardware, Unified Memory Archeture (however you spell it), interesting GUI, video in, out, etc... Kind of closed such that it takes some hacking to really make the chips go, etc...
  17. I think it's OS was revolutionary. Device independant I/O, in 8K of assembly was no small feat. The while interrupt driven display system was revolutionary too, display lists in particular being a distinctive feature at the time.
    Open? Nope. Ataris were closed as hell. I had a whole lot of fun on My Atari --still do. But it was the totally open Apple ][ that showed me the ropes. I had to spend money to do cool things on the Atari in assembler. The apple came ready to program on all levels out of the box. Big difference.
    Expandability was a big minus with the Atari, on the other hand, having 4 bi-directional latched I/O ports was a big plus.
    Most powerful? Apple ][, because of it's ability to scale.
    I'm gonna set all of this aside though and point to the CoCo 2 & 3 as the most powerful 8Bitters around. Too bad we didn't see the 6809 in more 8 bit machines. Pure assembly nirvana.
  18. Good work so far.
    Where the author has posted their source code, you should include it as well. Having just the binaries kind of limits the overall utility of an archive, IMHO.
    Also, in the Homebrew Discussion forum, Ooze is at version 0.9x. Probably should get that one and source from my blog (if you are gonna do sources.)
    Another source of games is the computer science students projects. Might be a good idea to contact the instructor to see if those games can be archived as well. That thread is in the Basic Programming forum.
    I would link, but am short on time. Sorry...
  19. Ditto Batari's lifesaver... lots 'o fun and fairly easy to grok out of the gate.
    I'm wondering if 8bit assembly newbies would not be better off doing some simple things with the Atari 8bitters in emulation. That's how I started on assembly language and I remember much of it to this day.
    It's much easier to do little things in assembly, within an established framework, than it is to just haul off and do the whole works in assembly from the get go.
    Of course, that's what Batari Basic is all about too... just rambling this afternoon I guess.
