emmanuelf
New Members
    89
Posts posted by emmanuelf
  1. Going to user programmable (which is great) complicate things fast.
    Going from initial ATF150X, you need to add a sram and a microcontroller.
    You could perhaps collapse the microcontroller and the CPLD with a microchip or atmel µC with sufficient CLC cells.
    Or try to go single chip with a PSoC 5200.
    Next is the FPGA way ...
  2. Hello,
    Interesting.
    I had exactly the same idea. As ramdacs are all obsolete and as I don't want to base a design on "new old stock" or refurbished ebay/aliexpress parts, my plan was to use a small CPLD or FPGA and a still active video dac like ADV7125/3.
    As I want the design to be fully open even at the toolchain, I go for FPGA, a Lattice iCE40 (LP8K) and protyping with a TinyFPGA BX. A MachXO with 5v tolerant pin and integrated Flash is more appropriate but is a no go for me.
    It seems a little overkill as a first though, as it complicate things (level adaptation etc ...) but could be a generic base for many converters. The stocks of music ramdac used in Tim 2600 RGB board will not be avaible eternally.
    I had targeted the Intellivision first, but I will use the extras in the FPGA for my "universal 2600" project which will drive programmable clock, button rewiring etc... with a soft core or with the help of a little µC.
    For the intv, the pll could help to regenerate and tune a clean hsync from scratch.
    But as I am very slow at completing my projects, you definitively will have something working before me 😊
  3. XRGB 8 pin mini-din is the de-facto standard for RGB modded retro hardware.
    Starting to put more video standards on it is I think a bad idea. There is already well established standards for that with on the shelf cables : RCA and 4pin mini din.
    The only exception I would made it to put mono audio signal on the 8 pin mini din as the scart has audio input too on the same cable.
  4. There is the soon to be retired, but widely available BH7236AF from Rohm. Less than 6$ by one from trusted sources like Mouser, 60 cents from Aliexpress.
    It is used in the RGB board for the 2600 from Tim Worthington.
    Higher pin count but near zero external component need (and no external clock). Correction, it need the color subcarrier too.
    Add: It could serve as a proper 75ohm driver for all the outputs including RGB and CSYNC and clamp RGB out on sync. But does not have the LPF of the THS7374.
    Could be tried in another revision to cut down the cost and adding composite and s-video.
  5. You should be able to put the divider before the aop without disturbing mux transitions if you choose a high to ground value.
    For the rest, ok I understand your use-case.
    On my side I'm only interested in pure standard connection. These sega cables are pure hack I don't like, proper driver/buffering is the base. These special purpose driver are immune to short circuit, to esd, specialy designed to drive 75ohm imputs etc...
    All other things could/are working, but are not as clean/robust and able to face all the diversity of real conditions.
    But this is a personal point of view that I understand some will disagree with, especially from a DIY/Hobby/Hacking perspective.
  6. Quote
    I didn't need one of the THS7374 channels, so I swapped it for a '7314.
    Not good. You need the same buffering for CSYNC as for R/G/B. THS7374 give you a complete coherent interfacing with the display device RGB/Scart interface. CSYNC is subject to the same double 75ohm impedance matching (150ohm) see p26 of THS7374 data-sheet. Without, in real condition you will go into trouble with CSYNC at one time or another.
    Otherwise, good job!
    PS: why using followers and dividers instead of proper gain on each channel ? Ac coupling and "high"/not low impedance output on the coupling is not ideal.
  7. 4 hours ago, Falonn said:
    At first it had seemed to amplify the noise from my failing console and give the worst picture I'd seen yet.  Then I decided to try enabling the low-pass-filter built into the THS7374.  As a rule I try to avoid that sort of post-processing, but in this case... magic.
    Don't forget that you are dealing with signals considered very very high speed for protoboards.
    On a properly routed PCB, you will get even better results with or without the (to be enabled anyway in this use case) LPF.
  8. Yes, but proper routing and mechanical design is an art too, it is a valuable part of the final result. As this is a pure disinterested unfinished work giveaway, I assume that the original attribution and credit is a simple unintentional  omission.
    For the missing capacitor and labeling value error, the design was clearly marked as "Untested, use at own risk".
    To be complete and for the record, don't miss the R25 BoM value error: R25 must be 680R and not 680K.
    With a little bit of shifting/rerouting to add a THS7374 at the output, and some values tuning, this is the best price/quality compromise.
    LMH1251 is very costly, a pain to integrate with most pin unused and really overkill for the limited colorspace of the TMS.
  9. You forgot the citrus3000psi ColecoRGB PAL
    And for XR8052, you have plenty of possible replacements : From AD you have AD8052, AD8042, ADA4891-2, AD8062
    I don't see why is is "passable".
    All these suffer proper video output buffering. But you discovered these recently with the magic of THS7374 and his integrated LPF ;-)
  10. Better use the PAL version to completely remove the color burst.
    I bet that your are seeing is the result of the different summing of R-Y/B-Y/Y color burst. Only the Y signal color burst must be keep to not be affected by summing and be subtracted via Vref.
    The original TI circuit is only valid for 100% compliant TV witch should refer to the back-porch level ant not to the minus of colorburst/back-porch but if the discrimination of the distorted colorburst fail, back-porch level referencing may fail depending of the implementation.
  11. J3-7 is 0v referenced, J3-6 is -5v referenced.
    The later could be omitted and considered as a test point.
    The -5v referencing is need because of the ac coupling at the input needed for the -5v/12v used for the AOP and the command of the 4066.
  12. Quote
    Yeah, the main reason for the 1881 is to reduce component count.  It may also do a better job than the discrete circuit, but keeping the size of the board down has a higher priority.
    For a refreshed circuit, don't forget about the hugely improved LMH1981, more pins but worth it in all other aspects.
  13. Quote
    @ChildOfCv RGB signal blanking is not overkill in a pure RGB input ? Ok it work on an analogue TV, but could perhaps disturb the analogue front end of the OSSC (which is not a TV front end).
    Forget what I said. During blanking, RGB signal should be very low, normally at black level but near 0v with some equipments to get them working.
    All of these will for me to put mine under the scope ;-)
    Need a little bit of motivation and some time and space. Will try to arrange that.
  14. 1 hour ago, ChildOfCv said:
    Well, one thing I know is that R167 is 82 ohms, not 68 :P
    I checked Mister Fab's trace work and don't see any such connection.  Q22 is the Y preamp, just like Q25 and Q20 are the R-Y and B-Y preamps, and it follows the pattern of the other two, so that's probably correct.  The sync detector samples pin 4 instead of the Y output because as soon as sync is signaled, the component outputs are shorted together and forced to a bias voltage by the network of U29C, U30A, and U30B.  At least that's my theory.
    Ok, I miss  the ac coupling via C147.
    Yes that is my understanding too.
  15. Yes, LM1881 based sync separator/stripper.
    But it was a false track.
    Did you not miss a junction between the base of Q22 and the output of U29B ?
