keebz
    116
Posts posted by keebz
  1. What if you have to hit 88pmh before the car travels too far to the right.
    I've been thinking about this. Since the data is there and the space is bumped up, I kinda wonder if maybe we don't do a title screen and instead show both the time and speed and it becomes the fastest to 88MPH, Using the extra space to create a GFX for a time travel effect?
  2. Dropping a title screen in should be straight forward. If you want you can just provide a separate asm file for that and I'll stitch them together. What if you have to hit 88pmh before the car travels too far to the right. MPH looks good, but you didn't attach the source file too.
    Again forgive me for I know not what I do lol.
    I tried to save the assembly file in stella using savedis in the debugger but I only get an asm file for the current state of the game. I then tried to use distella in the command prompt but it didn't output what I think you are looking for. The format seemed really wrong.
    Google as I may, and reading the Stella docs... I can't find any explanation as to how I would export the entire assembly file... Still looking
    update: I have attached what distella is outputting but it isn't right. I think it isn't showing the GFX because I didn't use it properly. Stella's "savedis" exports correctly but only exports the current frame, not the whole game.
    Is there any documentation on how to do this?
    Update2: I didn't know you had to play the game a bit for it to decode all the GFX and data in order to get the assembly file to correctly save. I don't know if there is a better way to do this, if so I'd appreciate any guidance. But needless to say the new asm file does look a lot better.
    OUTATIME (by Keebz) - Dragster hackMPH.asm
  3. MPH Graphics... Here you go!
    Also, I saw you bumped it up to 4K!
    If you could help me understand how to point that to a title screen at launch I'd could make a awesome title screen.
    There a lot I think could be done with this. The game play needs some tweaking because hitting 88mph basically just means "go into 4th gear and wait"
    But its really a great wip!
    Hopefully I can work on it some this weekend as well.
    OUTATIME (by Keebz) - Dragster hackMPH.bin
  4. Graphic pointers are derived from ram_b3 and ram_b5. Values outside the range 00-99 produce other parts of the display such as blown and early. Fortunately there was enough room for two more tiles in that ROM page. So I was able to hardcode b5 to $fe and put some place holder graphic data there for you to turn into MPH. (Search the ASM file for MPH to find the spot to edit)
    It still needs some tweaking to fix the speed. Right now the speed variable counts in binary but displays in BCD, so it jumps all over the place. The speed climbs too fast too, causing you to hit 88MPH way too soon.
    attachicon.gifOUTATIME (by Keebz) - Dragster hack.bin
    attachicon.gifOUTATIME (by Keebz) - Dragster hack.asm
    I have to much to learn... this is amazing. I spent all day just figuring out how to get the counter to not turn over.
    Edit: I can't thank you enough for this. Its really helpful to have something to compare.
  5. I've spent a huge chunk of my day trying to understand this and research and googling... Gotta admit it's way over my head. What I have found, I know that it is on Ram_B5,B6 and located at F354.
    What I don't know... How to increase from 2k to 4 k
    Take that space and make the bites available as MPH
    and point F354 to it and just turn off the decimals.
    Sorry, if this is too newb for everyone. I'd love to make this project work but I'm just not tracking with these tutorials.
    Edit: I was able to get the miliseconds to read 00 by setting Ram_b5 to $ea $ea
    Now it just shows .00 with no change at the moment.
  6. 6502 assembly isn't as bad as it first looks. Give this a read and it should be enough to get you started. http://www.atariage.com/2600/programming/2600_101/03first.html
    When you get stuck just post the asm file and explain what you're trying to do, what you've done, and what you can't get to work.
    Btw, a lot of the variables are outlined here but you have to add $80 to them to get the actual address because he's listed them as offsets from $0080.
    Don't forget you can change RAM values directly in stella. So an easy way to verify a variable is to change it's value and see if it effects the game as expected. Just don't forget that the game may overwrite your changed value.
    Using stella I can see that B5 and B6 are what is writing the milliseconds to player 1 and player 2. This reads as Ram_b5/b6 but I can't find that for the life of me. Not that it isn't there, I just don't know what to do next with this information.
    I'm reading the stella debugger manual now, not getting very far. But ill keep going
  7.
    First I used ~ to open the stella debugger at different times during play. Watching the RAM values change as I did allowed me to spot $b3 as the variable for 1st player time in seconds and $c0 as the speed of the 1st player. Then I used "trapread $b3" to find the places where the time in seconds is read from. The assumption here is that the code which displays the time must first read its value from RAM. Sure enough it breaks around $f357. Looking at the disassembly in the debugger it's easy to spot the $b3 used to indicate where it's reading from. Then it's just a matter of changing that to the speed variable instead.
    I think the next step would be to find the code that loads the subsecond portion of the timer and then hardcode it to point to graphics data for "mph". To make things easier, you probably would want to disassemble the rom to an asm file so you can make changes in assembly instead of patching bytes in the bin file. I'd also bump it up to a 4k game so you don't have to worry about squeezing in new graphic data. There are several tools you can use to generate the asm file. Just search for 6502 disassembler and find one you like. Then you'll need dasm to assemble it back into a bin. Make sure you have disassemble and reassemble working before you make any changes.
    I have so much to learn. I only understood about 1/5 of this but I'll keep digging. Maybe I can start by finding the decimal times and whatever sets the rate of speed. Hopefully without getting into assembly... I looked at the asm with distella and it's not even greek... it's wingdings to me.
  8. Patch $f357 to be $c0 instead of $b3 to make the timer display the speed in place of seconds
    Can you help me understand this better. My assembly knowledge is non-existent.
    UPDATE:
    Never mind I figured out what you said. It's way to early without coffee for me.
    I'd love to get to a place where it vanished in a flash at 88mph but I have no idea how to alter game play like that. For instance, how did you know that f357 did that when changed to b3?
    Ideally, I'd like to slow the car down and make it hard to get to 88mph without blowing. Take out the decimal read out. And make the vehicle flash out if hit 88mph. But I have no idea even where to start.
    I'd be happy to just get the car to slow the car down and make it hard to get to 88mph without blowing. Take out the decimal read out.
  9. Thomas achieved a 32.05 at some point using his Barnstorming hack described in the old forum thread.
    http://atariage.com/forums/topic/10989-barnstorming-game-1-3204-what-the/page-9?hl=%2Bbarnstorming+%2Bno+%2Bwindmills&do=findComment&comment=110625
    I'm really interested in understanding how he achieved it. Flying straight doesn't seem to get a .05 it always yields a .07 BUT I can consistently get a .05 flying off the ground. It's just really weird.
  10. Hi there,
    I can definitely say this is not a theory. Barnstorming and Grand Prix are very similar. Your speed is reduced by ~6% for moving vertically which is similar to Grand Prix.
    Not sure how the time would be different for you. I didn't see the speed being reduced for flying on the ground.
    Well sure, that's kind of what I meant. Moving vertically should reduce your speed and thus your time. Call it moving vertically or moving pixels... I think we mean the same thing.
    However, if you watch the attached video, you'll see how high off the ground I was towards the end. I was taking video at different movement positions to see how it changed the speed/time when this happened. That's how I ended up with the video at all. By everything I can tell, I should not have been able to get that far off the ground and still get a 32.07 let alone a 3.05.
    To clarify, I have NEVER gotten anything but a 3.07 on a hardware play by staying on the ground. BUT also, if you stay on the ground and hold down (causing no vertical movement) your speed still drops significantly. So actual movement isn't the only factor as well.
    Still experimenting.
  11. If there is such thing a hack world record... I JUST SET IT!
    In 2002 someone removed all the windmills to see what the best possible time would be if you just flew straight. It was confirmed that it was 32.07 "absolutely impossible to beat"
    I have been testing this because I really like the game and something has always been off about how no one really knows what works against your time.
    So I was experimenting with the no windmills hack and different locations. Thinking, if the "pixel movement works against you" theory was correct, then flying straight couldn't be beaten... turns out that is completely wrong!
    Indeed, if you just punch the gas and fly straight you will get 32.07 every time BUT I just beat it.
    I flew close to the roof with consistent power and just broke the previously held fastest possible time with 32.05!
    I don't know what this means for the game theory, but it confirms the clocks are not consistent OR pixel movement don't always work against you.
    I can't find anywhere a time lower than 32.07... can someone help me confirm this?
    BarnStorming32_05_Sm.mp4
  12. Stranger Things - "Barb's Revenge" - By Lee Keebz Kebler
    Everyone else forgot about Barb and now it's time for revenge!
    Help Barb as she claws her way out of the Upside Down!
    Fight Darts, DemoDogs and Demogorgons with a trusty flashy light and your wits.
    ________
    Waffles, big glasses, bikes and other power ups are found along the way.
    And be on the look out for Eleven!
    (a Dig Dug Hack)
    -Keebz
    Stranger Things - Barbs Revenge (by Keebz).bin
    • Like 6
