doubledown
    2,761
Posts posted by doubledown
  1. I'd have to take one apart to show you. I don't have internal pics of any of the work I've done. The easiest way to do it is this. If you have a SEGA A/V cable plug it into the port. Flip over the board and with a multimeter check for continunaty against each RCA Plug's tip to each of the 9 solder pads. So for example hook one lead to the center tip of the video wire (yellow) and touch the other lead to each of the 9 solder joints untill you find which one it matches. Do the same for the audio. Then surrounding those 9 solder points there should be 4 larger solder points. Those are the solder points for the Mini-Din connector itself and they are also all grounds. Grab your ground from there. If I'm not mistaken there are some versions of the Sega Model II that doesn't have stereo sound so you would grab the audio (mono) positive wire to the center of the panel mount RCA jack and the ground to the ground ring and then just piggy back those signals over to the other audio jack. Not true stereo, but at least it will give you sound out of both speakers.
  2. It's real easy. Composite audio/video is already wired to the din connector on the back. The original cord comes out of the console into an external RF modulator and then into your TV. Here is a pinout of the A/V output port:
    http://www.gamesx.com/avpinouts/genesisav.htm
    When you're done it should look somthing like this:
    http://img102.exs.cx/img102/4291/19_1.jpg
    And while you're at it you might as well de-solder the original red LED and install a "Sonic Blue" one, like this:
    http://img49.exs.cx/img49/828/GenesisIILED.jpg
  3. Viking Video Games and Opcode Games are proud to announce the third round of the VVG/OCG-RPS Tournament of Champions.
    Included in this announcement is the complete list of matches and instructions about how to submit your set of throws.
    Here is the complete list of matches for the third round:
    Ted Chung x Ben Langbert
    Chris Nobert x Greg Griffin
    Michael Markowski x Chris Wingate
    Brad Jewell x Rossignol Numa
    Steve Wicoff x Chris Perjak
    Scott Einsig x William Pilgrim
    All contestants are now required to send email to [email protected], including the following information:
    Full name.
    Password.
    Ordered set of 5 throws.
    Entries will be accepted untill 11:59 EST Saturday 12/08/04. The complete list of results will be published here on Sunday 12/09/04.
    Thanks for participating and good luck!
    The Viking Video Games and Opcode Games management.
  4. VVG and OG are proud to announce the partial results for the second round of RPS Tournament of Champions.
    Patrick Bulch (PRSRP) x Ted Chung (RPPRS) = 2-2 (tie)
    Joe Kollar (PSRPS) x Chris Nobert (PRPSS) = 0-3 (Chriswon)
    Kyle Koehsmtedt (N/S) x Michael Markowski (PRRSP)= 0-5 (Michael won)
    Jason Mazure (SRRPR) x Brad Jewell (RRSRP) = 2-2 (tie)
    Steve Wicoff (SRRSP) x Toby Wickwire (PSSRR) = 4-1 (Steve won)
    Scott Einsig (SPPRS) x Joe Lambert (PSRRS) = 2-1 (Scott won)
    Oliver Pyper (PSSRR) x Ben Langbert (PRPRP)= 1-2 (Ben won)
    Greg Griffin (SRRPS) x Chris Keilback (N/S) = 5-0 (Greg won)
    Chris Wingate (SPRPR) x Tanya Craver (SRRPS) = 2-0 (Chris won)
    Rossignol Numa (PPPPP) x Brett Gladson (RSRPR) = 3-1 (Rossignol won)
    Bradley Karston (N/S) x Chris Perjak (SPRPS) = 0-5 (Chris won)
    William Pilgrim("bye" round)
    Contestants who have tied must now submit a new set of 5 throws. Entries will be accepted until 11:59 PM EST Monday 12/06/2004. In the event of a new tie, the first contest to win a "game" will be declared the winner for that match. For example, player1 (SRRPS) x player2 (PPRPS) = 1-1, but since player1 won the first game (scissor x paper), he/she will be declared the winner for that match.
    The new matches for the 3rd round will be revealed on Tuesday, once all tie-breakers are resolved.
    Congratulations all winners!
    The VVG and OG management
  5. Most inportantly the INTV II has unplugable joysticks. Allowing you to use the Wico Command Control or the Amiga Power-Stick joysticks made for the Intellivision.
    As far as the Coleco-published games compatability there is an easy mod to remedy that problem. A couple of wires and a switch allows it to boot-up around the lock-out.
  6. The description is O.K. Although putting a space between Coleco and Vision will draw less traffic.
    The starting bid is a little bit high.
    I would like to see more pictures, and a little better quality for that kind of starting bid.
    I would prefer a slightly higher feedback rating for the seller.
    I usually like to see the seller have been an Ebay member just a little longer.
    I sometimes like to know an estimated shipping cost.
    The "Sellers Payment Instructions" are very clear and concise.
    Luckily he takes PayPal with all credit card forms of payment.
    Take a look, and please don't outbid me.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...8151580716&rd=1
  7. Nice job, thats really cool... 8)
    Btw, whats the difference between "Hyper Blue" and "Sonic Blue" ??  ;)
    No difference. The LED is technically called Hyper Blue due to it's water-clear lens and its output frequency. I call it "Sonic Blue" to give it more symbolism for the SEGA console.
    At times there are a lot of guys who will pay big bucks for Intellivision items. You might want to try to do some of your mods on some original Intellivision systems. My guess is that you might make more than your Colecovision mods.
    I briefly tried the A/V mod for the INTV II, but couldn't get it to work. When I get some extra time I'll get back to it.
  8. I'm at it again. More modded video game consoles just in time for Christmas. This one is my pride and joy so far I think. Cramming all those components and wiring inside that tiny case was definately a challenge. Please let me know what you think.
    MODDED SEGA GENESIS MODEL 3 - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...item=8151002800
    Also I have a refurbished and Modded Magnavox Odyssey 2 up for auction right now with composite A/V outputs.
    MODDED ODYSSEY 2 - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...me=STRK:MESE:IT
  9. I know we all know that people who don't know shit about video games, but love garage sales and love Ebay over use the hell out of the word "RARE." I just happen to be going through the Ebay - Video Game - listings with a search for "ColecoVision" and was absolutely dumbfounded by the number of auctions with the word "RARE" in the title. So in further research I found these results:
    Auctions in the Ebay category - "Video Games" - 228766
    of those 228766, those with the following phrase in the title:
    "Rare" - 8692
    of those 8692, those with the following phrase in the title:
    "Very Rare" - 897
    "Super Rare" - 976
    "Ultra Rare" - 893
    "Extremely Rare" - 36
    "Extreme Rare" - 20
    Now while some items actually are reasonably rare, most of them are something along the lines of an Atari Vader with 3 copies of Combat, or an original NES with the hard to find Super Mario Bros. It's starting to get real damn annoying. Now I don't sell a helluva lot of rare stuff, I like to hoard it for myself, but when I do sell something of a rarity I sure as hell don't spam the hell out of the title and description with what has become my most hated word - "RARE". The only people that the word Rare is going to mean anything to are the real collectors and hobbyists and they already know what is rare.
    This has been an editorial by DoubleDown.
    Please rant along with me.
  10. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...item=8150335982
    Magnavox ODYSSEY II
    Up for auction is a completely refurbished and modified Magnavox ODYSSEY II computer game console. Included in the auction are the ODYSSEY II console, 2 standard controllers, 11 game cartridges, a power supply, and a 6 ft. gold-plated, color-coded A/V cable. Everything is 100% guaranteed working, including console, controllers, games, and modifications.
    The games that are included in the auction are as follows:
    (1) Alpine Skiing! – Complete with box and manual
    (1) Baseball! – Complete with box and manual
    (1) Bowling! / Basketball! – Complete with box and manual
    (1) Casino Slot Machine! – Complete with box and manual
    (1) Computer Golf! – With box, no manual
    (1) K.C. Munchkin! – Complete with box and manual
    (1) Las Vegas Blackjack! – With box, no manual
    (1) Speedway! / Spin-Out! / Crypto-Logic! – Complete with box and manual
    (1) Thunderball! – Complete with box and manual
    (1) UFO! – Complete with box and manual
    (1) Volleyball! – Complete with box and manual
    Also included is a 26 page game catalog.
    Modifications:
    1: Gold-Plated, Color-Coded, RCA Audio/Video Output Jacks
    This modification allows you to directly connect the game system to modern televisions or home theater systems. No longer are you required to use a TV/game switch, or forced to deal with blinking white sprites or audio “humming” while playing the game. This allows for the clearest picture and sounds ever available with an ODYSSEY II.
    2: LED Power Indicator Light
    This hyper blue LED has been installed on the face of the console above the power switch to indicate that the game console is turned on.
    All of the modifications and refurbishing work was professionally done and installed by me. I also cleaned the entire console and controller casings, as well as burnished, de-oxidized, and conditioned the cartridge slot contacts.
  11. Viking Video Games and Opcode Games are proud to announce the second round of the VVG/OCG-RPS Tournament of Champions.
    Here is the complete list of matches for the second round:
    Patrick Bulch x Ted Chung
    Joe Kollar x Chris Nobert
    Kyle Koehsmtedt x Michael Markowski
    Jason Mazure x Brad Jewell
    Steve Wicoff x Toby Wickwire
    Scott Einsig x Joe Lambert
    Oliver Pyper x Ben Langbert
    Greg Griffin x Chris Keilback
    Chris Wingate x Tanya Craver
    Rossignol Numa x Brett Gladson
    Bradley Karston x Chris Perjak
    And the luck guy to be awarded a "bye" round is William Pilgrim. So Bill, you are the first contestant to get to the 3rd round. Congratulations!
    All contestants (except William Pilgrim) are now required to send email to [email protected], including the following information:
    Full name.
    Password.
    Entries will be accepted untill 11:59 EST Tuesday 11/30/04. The complete list of results will be published here on Wednesday 12/01/04.
