gambler172
4,025 -
Posts posted by gambler172
Hi Chris
checked the new version....works very well....great
work.
Hi Rev
checked the actual version.....works very well.
No bugs or glitches....Highscore saving works fine
with Atarvox or Savekey 😁
Hope this information helps.
Hi Bob
just played Pac XM on my CONCERTO...works very well.Now i am waiting for my XM.....Hope it will arrive sooon
7 minutes ago, Jaden (JRH) said:Okay seriously, what is your problem?
Oh...did i tell a Name???
Bob is our greatest coder and in the past........some guys always criticized his work,without doing it better or without coding a 7800 game.....I can tell a lot,but then i should be able to do it better.You should know,that the 7800 System is limited in its abilities....and Bob does always
the best...if it is possible.It is the same,like Bentley Bear.
Oh...i am still waiting for your Pacland file ,or is your Project dead?
Hi Bob
will check this soon......great work.What i do not like,is that some guys always criticize....oh...i want
better colours..oh i want this.....
I cannot hear this anymore.You did a really great
job and must see such stupid comments.
I wish this guys would do something for the 7800...
1 hour ago, aaron1677 said:Hey Gambler,
Yep, I feel the same as TIX - you're welcome to use the background houses I created. I'm also working on something else, but am on here often and wish you good luck with the project! 👍
Hi Aaron
well...i think about Jaden...he talked to be the One
who continues????
But until now......only one stupid comment.....
I do not need to continue this,if he does.....
So let us wait,what he says.....
Anybody get Space Lords to run on altirra?
No comments by Jaden???
Hoped to see a new version???
No comments by Tix
and aaron?
too bad....
Maybe Giles could try to contact them?
Hi Vinnie
welcome back 😁
Well..i have such a thing....it works really well.
Maybe i would trade it against interesting 7800 stuff😁
Hi Guys
if anybody....maybe Jason continues working on this.
Some things should be cleared....is it ok for Giles,
Tix and Aaron,that there sprites and tiles can be used in a Pacland...or Pacworld game....a game designer should have clearance about this.
21 hours ago, Giles N said:It could become a completely independent game - using Pac-inspired elements; PAC WORLD...
(4 Worlds with 8 stages)...
So let us see,what Jason has in mind 😉
i am waiting for an update.
Come on Jason....show,what you can
On 1/24/2020 at 9:22 PM, Mitch said:Thanks for checking. There was not a cover on the Eprom so I guess it may have started to erase.
Mitch
is there a 3600 Asteroids somewhere available?
7 hours ago, Giles N said:Your advice taken!!
Just a lot to (re-)learn...
Kevin said the same,what i always said.And yes,Bentley is a great game....much better than
Pacland.A Jumpnrun with Pacland graphics is still
possible.However it will take a lot of work.
Well,i wanna see,what Jaden has to show....😉
Seems he is really good...
so i watch the whole thing from the background.
Hi Smitty
any news???
39 minutes ago, aaron1677 said:Side by side comparisons attached.
TIX/Jaden sprites on left, Gambler version on right.
I feel like we should be using TIX sprites for everything. Especially if down the line we are able to add more frames of animation. @gambler172, I totally understand where you're coming from as far as the "many hours of work" it would take to build a great "Jump&Run" game, but I feel like that's the point. I'd rather invest the time to build backgrounds for more of an actual "port" version of PacLand, because if it's designed and built to the 7800's FULL capabilities, PacLand could potentially be one of the very best platformers on the system. It could be a real showcase of the ProSystem's power, both artistically and gameplay wise. PacLand is almost the perfect title to build a great version within the abilities of the 7800.
Could we do a "passable" game using the existing parameters? Yes. But I'd rather invest time and energy into pushing the system and doing the very best game possible! Right now, it's playing as an almost identical version of Bentley, with swapped out sprites.
Down the line, it may be possible to get the editor tweaked to fit PacLand, to make it a more unique experience, apart from Bentley. Reverse scrolling, added frames of animation, increased sprite width, and more changes are all possible....which would make testing the current version of the game a bit irrelevant bc everything would shift with these sorts of changes.
Just my two cents.
One last time....Bob did not create the editor...the editor cannot be changed....either Jaden uses it or not....You can play with SCROLLING...ok......but why do you guys want original Pacland....this could be done,from the scratch...without emulator....and for sure NOT by me.
Changing colours of the enemies is possible.....i am
tired of telling the whole thing again and again.....
and cause Giles started the topic....i want to have
some of his enemies in the game too.But i give up
and let Jaden do,what he wants.....
On 4/17/2020 at 2:15 AM, MrBeefy said:Ha! Is the 7800 going to be home to every Pac-Man game?
Probably not worth much but I like the recent sprite too.
Just for info.....This is NOT the original Pacland.
It is a Pacland fangame in style of Bentley.....NOTHING more....play it...like it....or not.I just played the original Pacland and i think,it
is a bad game....too heavy...no fun at all.
So again......here is NO original Pacland 😬
6 hours ago, Giles N said:@Jaden (JRH) and @gambler172: perhaps the two of you could cooperate and «compare notes»
as to how the Bentley-Engine is best worked to get best graphical output/graphical settings!
Lets co-operate!
I have another idea...let Jaden show,what he can.....
he may use my actual version and can do what he
wants.......he is soo good,he does not need me.
For sure,he can do a complete new area from the scratch.
11 minutes ago, aaron1677 said:Yes. Aside from Level 2-1, which levels are "ready" to be tested?
only Level 1 with its 8 stages....in stage 8 there is the mini boss at the end and Level 2 stage 1....i put
Big Boss at the end.....normally,he will not appear
soo early.
But till now,i got only one silly comment and the
small number of downloads,shows that there is no
interest in such a project 😢
And it would be a damn heavy work,to build a reasonable JumpnRun....with dozens hours of work.
6 minutes ago, Giles N said:I flickered a lot on one the PAL emulators.
Which emulator do you use?
i use Prosystem 😁
works ver y well
8 minutes ago, Giles N said:I am in Europe.
Do I run the file on any 7800 emulator or NTSC specific emulator.
(sorry for being so, well, unpro)
works on both....Pal or Ntsc
Hi Guys
here my latest file....If you take the "W" at the beginning....you will be warped to Level2 stage 1
otherwise just Play Level 1 through 8 stages.....Before i continue working on this.....i Need some testplayers.Level1 is full playable....also Level2 stage 1.I Need to know....is the game too easy or too heavy...or is the difficulty OK???
Please do not come up with suggestions....i only want,that someone is playing the game.
It makes no sense to spend lots of time with a game,Nobody wants......
Graphic corrections,like colours,dark outline,BOSS changes..............can be done,when the game engine is ok.
And when everything is done......we can get Music.
8 hours ago, aaron1677 said:Yes I can definitely do this. I think the houses need to be much bigger for sure. But Gambler is saying it's not possible? There must be a way...
In a later Level,i can use big houses...but then i can
use only one or two.......
8 hours ago, aaron1677 said:@gambler172 @Giles N This is Jaden's interpretation of TIX's sprite of PacMan. IMO, this one looks much better (with the dark outline) and hat. I know you are making the hat a powerup, but maybe he can just "glow/blink" when he has the invincibility and have that hat on all the time, which i think looks much better. Can we get our hero looking like this?
We can discuss this,when gameplay is finished...
also i can change BIG BOSS anytime.
13 minutes ago, Giles N said:This is 8 pixels wide; give feedback what can be improved...
this will fit
Pete Rose Baseball for 7800 to buy? Can't find anywhere!
in Atari 7800
No wonder...it is rare....and if you look for the Pal version...it isvdamn rare....and if you want the Pal version in the plastic box....
