gambler172
4,025 -
Posts posted by gambler172
16 minutes ago, Giles N said:too early....music,when everything is done.
I need the skull smaller....8x16. or 8x32
On 4/10/2020 at 1:55 PM, PacManPlus said:It would be cool to put that in place of the 'kill screen'
Hi Bob
hope evetything id ok?
HiGuys
anybody knows the SKULL,which appears in the Arcade game???
I could need a graphic......
In the meantime,i added a CLUB at the BIG BODS
added green mountains.....made some small changes..... added new clouds a new bin will follow sooon 😁
12 hours ago, Giles N said:tomorrow,i try to add a CLUB at this guy 😁
54 minutes ago, Giles N said:Are you able to do some tough stuff on our hero: Pac Man?
if i only could get a CLUB for your BIG BOSS????
But i use the one..i have
6 minutes ago, aaron1677 said:yep...this house i need....in the same size...like the
other houses,you made...
Starting in Level 2 might be possible somehow.....
for this...i will ask a friend....
6 minutes ago, Giles N said:In the Arcade, there’s only one ‘parallax’ of buildings, and then there are 2 parallaxes of hills in the horizon.
In my opinion we should go for that, if we are able to do it.
I added some Animation to your BIG BOSS...a Little bit.....
for sure...i can fill LEVEL2 stage 1 with more houses......hope to get another one from Aaron
.Scrolling is something...i Play around,when the most ART and GAMEPLAY is done,cause this is not soo easy......
Till now,we have a FOREST world and the beginning of LEVEL2.....in stage 2...i will add
SEA Landscape.....so i can change between the stages.One time a City with houes,then SEA Landscape.I also could draw the mountains in green colour...if this is better.A graphic for a cloud MUST have 8x16.
Hi Guys
added a mini Boss.....placed in Level1 stage 8
added the BIG BOSS in Level2 stage 1 .......just for testing......the stage is a little
bit too easy.....In the 1st stage touch the green "W" ans you will be brought to Level 2......stage 1.....To Play Level1...just jump over the green "W"...do not touch it.
I would like to know,if the game is too easy....so please check till Level 2 stage 1.
PS...i usedGiles BIG BOSS...cause the Big Boss MUST fly and unfortunately...
small Boss cannot be animated.
1 hour ago, Giles N said:this is not possible...would need more tiles and colours,which i do not have
24 minutes ago, Giles N said:What if one makes tiles in the color of the doors or the walls which has shade on them?
Can the blue be filled with tiles of brown or grey?
This would change the other objects in the zone....
like i said...i can play around with this,when main
work is done
1 minute ago, Giles N said:Try @TIX version; its more consistent in cumulative style and has 2 animation-frames...
The fatty one looks great,maybe he can get him smaller....The other one,i will use for sure...
2 minutes ago, Giles N said:this is not possible,because each zone has its main colour....maybe at a later point
4 hours ago, Giles N said:I don’t think Witch Mathilda from Bentley Bear has any animation.
Just an attack-pattern.
you are right,but i used your bosd and could do
some animation.....a little bit 😁
1 hour ago, Giles N said:I have some problems with my PC.
Could you post some screenshots of what the game looks like so far?
Hi Giles
i have no good cam......maybe someone else could do.Most of the changes are in Level 2 in the 1st stage.
Nice....plays very well.....could you also post an
atr File?
Hi Guys
time for an update...added a new enemy....made some small changes.....added the houses in Level 2..stage 1......added some clouds in Level 2 stage one and some other small changes.....Level 1 is playable and Level 2 stage 1 also....got no Feedback...if it is too easy or too heavy to Play.....
What i Need now is a small Boss enemy and a big size Boss enemy......This can be the same enemy or 2 different ones.....
I could also Need a 2nd ROCK.....
Hi Guys
new Version....changed ENDING of a stage...some other small changes.....Let me know about the difficulty ofthe stage 1-8....is it ok?? too easy???
Idea for homebrew title that 7800-homebrew dev. may consider to produce: Pac Land 1984
in Atari 7800
you need not draw jumpable platforms....i could use
touchable tiles.....but if you jump on the houses....the size does not fit......and if i make bigger houses,i run out of tiles.....maybe i can do
something in a later level....with less houses,but not
in level 2
When level 2....stage 1 is done.....we will see,what i have left and what i need.
