toddtmw
+AtariAge Subscriber
    1,138
Posts posted by toddtmw
  1. 2 minutes ago, santosp said:
    It is my own failure to mention it, and not a design defect of wt808.  In this last "mini" version,  the holes have moved so they come in  straight line with cartridge connector.
    It's weird, because the cartridge port insert that I printed from @foft's design, those holes line up well and I could plug a cart in. (I am able to attach the screws to the cart port with the adapter or to the four corners, but not both. When I had it connected to the cart port, inserting a cart appeared to work, although I did not power it when it was attached that way...)
  2. I received my Eclaire XL this weekend. It really is an amazing device. It is a nice cross between an emulator and real hardware. I can use it instead of my real hardware giving it a break. It is smaller than my real hardware too. Plus, I can plug real devices into it. I can print to my printer and read from real floppies. That really is the biggest gap on the emulation front. As awesome as Altirra is (and it IS awesome!!!) I cannot print from it, nor can I use it to access real floppies.
    This device really is the best of all worlds.
    @wt808, I printed your XL case. My printer is 145x145x140(ish). By standing each half up on its long end and rotating the z axis 45 degrees it just BARELY fit. (it was 142 mm high, but my printer handled that okay.) I had to use a crap-ton of supports, but they came away nicely.
    The only issue I had (and I'm sure this is more to do with the way I printed it) is that the cartridge port standoffs were about half a hole off toward the PBI port. I just pulled it into Tinkercad and did some frankensteining and am now printing the bottom case. If it works out, I will either send you my stl, post it as a remix, or let you do a better job with the original models than I did with the hack job. (Really depends on if others experienced the same issue or not.)
    For this run, I moved the standoff's pretty much exacly 1 mm away from the PBI.
    Here are some pictures. (I put some M3 bolts through the corner holes and put hex nuts on them to hold them in place without the top half of the case on.)
    IMG_9344.HEICIMG_7646.HEIC
    Thanks, everyone!
    PS Is there any reason the joystick ports are arranged opposite of the original Atari 800? It threw me for a loop for a bit until I read the markings on the board...
  3. 25 minutes ago, fujidude said:
    How well does Altiirra run then under Windows 10 running on a raspberry Pi?
    This is a non-answer, but I tried to build a PI to try it. First, I tried the new pi 4, but the software has not been set up to work on that yet.
    So, then I built it on a Pi3 and during setup of the OS, it throws an error and I cannot get that far. Based on how slow the setup screens are, if Altirra runs at all on that hardware, it will be painfully slow.
  4. Hi. Now that I have my SDM working, and I am using it...
    Is there something I can do to get it to display the contents of the directories alphabetically? I mean, they have this great feature to jump to a letter, (shift+<letter>) but if it is not alphabetical, that isn't as useful.
    Also, it would be great if it could filter out the stupid files that macs put on windows disks... (I'm installing a mac utility to address it, but it would be nice if the Atari menu program could do it.)
    Thanks.
