toddtmw
+AtariAge Subscriber
    1,138
Posts posted by toddtmw
  1. Greetings all.
    I have been trying to get printing working for weeks now. Mostly, I want to use Print Shop.
    Anyway, I bought an 850 interface and I bought a Panasonic KX-P1091. Then, I loaded the print shop disk into the APE software and tried to do printer setup. The results were really bad. Sometimes, I would get a little bit of output, sometimes I would get garbage, sometimes it would just form feed paper.
    So, I figured the 850 was bad and bought an Ape Face printer adapater. It only has one SIO port, so I could not use my SIO2PC. So, I wrote the print shop images to disk and used real disks with the APE Face and everything worked. So, I took apart the 850 and reseated all of the chips and hooked it up and it worked with real disks. But, when I attach the SIO2PC, it does not work.
    I know the SIO2PC has printer capabilities. I have the setting turned off, but it appears it is still interfering. Has anyone else experienced this issue?
    Any advice on getting this to work?
    Thank you.
    -Todd
  2. I have an APE face and an APE SIO2PC.
    Each one has only one SIO port.
    Can I create a cable where I take three SIO ends and wire all three of each wire together to plug them both in? Or does there have to be some "hardware" to handle that?
    Thanks.
    -Todd
  3. It does beep if I do not have any drives connected. In that configuration, if I type LPRINT "HELLO" I get an error 138 even though gah printer is on. I'll assume my jury-rigged cord is to blame. The documentation on what goes where is difficult because it's not always clear whether I am looking at a diagram of the cord or the port. Plus I'm translating from 15-pin to 25-pin to centronics so there are three chances to get it wrong.
  4. So, I got an Atari 850 Interface off of eBay. It lights up, but I've never used one before.
    I'm trying to print to a Panasonic KX-P1091 that powers up and prints the test lines of text when you turn it on with the button pressed.
    Then, I bought a DB15 extension cable and a DB25 to Parallel cable and then used breadboard jumpers with the male pins bent at the tip so they get friction inside the female side of the DB15 cable and forced the female sides down over the pins on the male side of the DB25 end of the printer cable.
    I used this pinout for the female cable (My logic is that this should be exactly like the female port on the 850 interface):
    850 Printer Port (15-pin female connector):
                         1. ~Data Strobe
                         2. Data bit 0
                         3. Data bit 1
    8               1   4. Data bit 2
      o o o o o o o o    5. Data bit 3
       o o o o o o o     6. Data bit 4
    15             9    7. Data bit 5
                         8. Data bit 6
                         9. Data pins pull-up (+5v)
                         11. Signal ground
                         12. ~Fault (Must be +5 for printer port to operate)
                         13. Busy
                         15. Data bit 7
    And ran them to the equivalent (I think) correct pin on the DB25 that corresponds to this:
    36-pin Centronics (male)  |     DB15P (850 Interface)
                    1                         1 - Data Strobe
                    2                         2 - D0
                    3                         3 - D1
                    4                         4 - D2
                    5                         5 - D3
                    6                         6 - D4
                    7                         7 - D5
                    8                         8 - D6
                   16                        11 - Gnd
                   32                        12 - Fault
                   11                        13 - Busy
                    9                        15 - D7
    Using the translation on this web page:
    https://www.lammertbies.nl/comm/cable/parallel.html
    (Using the parallel printer cable table in the second section.)
    Of course, when I hook it all up, it doesn't print. (I'm using Print Shop test page telling it I have Panasonic to test).
    So, do I need to do something special to get the 850 interface to work with Atari? Or does it just work when you plug it in?
    I mean, basically, I don't know if the 850 is bad, the printer is bad or the cable is bad. (I suspect it is the cable given the way I jury-rigged it together...)
    Any thoughts or pointers would be greatly appreciated.
    Thanks!
  5. I just recieved an 800xl off eBay. The dos disk it came with loaded a ram disk, which I thought was odd. I opened it up and found this memory upgrade inside. It's pretty clear this is some kind of 256k upgrade for the 800xl. (Akthought the Google doesn't seem to find much about it... Anyone have any information in this one?) Is there software out there that can tell what kind of memory mod a computer has without opening it?
    Is there software to test these larger memory mods to make sure they still work?
    Thanks.
    Pictures:
  6. Honestly, there are some people on this board I would like to ignore. There are so many helpful people, but there are a very few who just really don't offer value.
    I'm sure there are people that would want to ignore me too....
  7. I never had an 850 interface back in the day. I had one of those SIO devices with a little box that ended in a centronics port for my printer and I bought the Atari modem that did native SIO ports.
    My question:
    Why did the 850 have FOUR serial ports? What else besides a modem could you plug into them? And could you actually use more than one at a time? (If you had more than one phone line, could you hook up multiple modems and run a BBS that could handle more than one simultaneous session?
    Thanks!
  8. There is an empty field my my house. The sign that said that a new retail building was coming in 2001 deteriorated and fell down in 2004. The one that replaced it that said 2010 is barely legible.
    How many times will this copyright date change (or maybe it will just get outdated) before they stop renewing the domain and it all just quietly goes away?
    Todd
