rj1307
    325
Posts posted by rj1307
  1. I will try to explain it, but my English is poor and I use the translator;)
    Regardless of whether the cartridge works in mode 1 or 2, the number of the selected game is stored in the eeprom memory cell. The number of this cell can be selected in the "quick start" mode, in the range 1-9. Writing to this cell occurs when you select the game and the display goes off.
    In the cartridges that I send to you, all 9 memory cells have the number 1 game written, i.e. APB, and memory number 1 is selected.
    For example, I often play three games: Rigar, Xenophobe, Shanghai and I like to watch the BadApple demo. So I write it in this way, regardless of the work mode (1 or 2): press the right button, wait until the "ants" pass and the number of the currently selected memory cell will be shown. I switch it to the right number number 2 and press the left button. The game is loaded and memorized in this memory cell. As it is read, I change the game to number 52 (Rygar) and wait for the console to turn off. From now on, game number 52 is stored in cell 2.
    I repeat this operation for the rest of the selected games and demos, i.e. in cell 3 I am writing game number 69 (Xenophobe), under cell 4 I am writing game number 56 (Shanghai) and in cell 4 I will remember demo number 131 (BadApple).
    Now, when I want to play Xenophobe, I turn on the console with the right button pressed, select memory number 3 and press the left button. The game will be loaded.
    Explanations require operation in mode 2, when the cartridge should wait for the game to be selected and then load it. Well, the entry to "quick start" causes one-off switching from mode 2 to 1, after turning off the console will return to mode 2.
  2. - ^ Cro§Bow ^ -, your initial problem was probably due to a bad contact in the cartridge's seat. AgaCart is 0.1mm thicker than the original cartridge, and the contacts are arranged at a slightly different angle. Repeatedly inserting and removing the cartridge cleaned the contacts. :)
    You write about resetting Lynx, do you know how to do it without turning off the console? I can send you the AgaCart schema for analysis. :)
    I think that you are unnecessarily worried about the damage of the console, in 2 months I pulled out and put the cartridge over 500 times and nothing bad happens. :)
  3. Is there anything I can modify on the AGA cart and/or Lynx mod that will allow me to use it? Regardless, the AGA cart is awesome!
    You can do the following for the test as follows:
    In the working console, change the software in AgaCart, for this purpose on an empty SD card, burn the agacart.bin file, put it in the console and turn on the power. The letter "P" will flash for a moment and go out, the software has been updated. From now AgaCart will not work with an unmodified console!
    Now in the console with voltage mod you need to short-circuit contacts 31 and 33 in the cartridge socket. In the picture I showed which they are.
    Change the SD card to the one with games, put it on the console and write if it works.
    agacart.bin
  4. At 100% McWill LCD is not the cause.
    Unfortunately, I do not know how the voltage mod is made, but I have some suspicion. In the original cartridge, contacts 33 (VCC) and 31 (PWR_ON) are shorted, while in AgaCart, contact 31 is controlled from Atmega64. If the voltage mod uses this signal, there may be problems, its maximum current is 20mA.
  5. Got mine. SUPER AWESOME. Definitely worth the $$. My only issue is I can't get it to work with any of my customized, McWill LCD Lynx. It looks like in your video you are using a modified Lynx... So I must just be doing something wrong.
    Can you describe what the problem is? Or take a photo of what it looks like?
    Yes, I am using a modified Lynx II and I have no problems.
    I've been fixing Lynx I so far and he did not want to work with AgaCart, the SD card error was showing up. The cause was a broken zener diode, on the electronics supply it was 7.8V!
  6. The design looks so nice that I would like to get one as well.
    Karri, should I add you to the list?
    Rafat, would you be willing to tell us the brand of 3D printer and filament you use for this? The quality is great.
    I have a Prusa i3 MK2.5S + MMU2 color module. Filament PLA Fiberlogy. This is how my set looks:
    • Like 4
  7. Hi, I wanted to present to you my version of the Lynx cartridge. The name and graphics on the sticker refer to my daughter Agata.
    5cc3588000ca7145m.jpg 364f154f6ed32495m.jpg d39b691075bb14afm.jpg a9765c31fcbb9070m.jpg ad2b161d19dd82cdm.jpg 5dbb8071c082325fm.jpg d8ac21acbbc1af1bm.jpg 168286389d1e89f3m.jpg d07f9977ebd2b170m.jpg
    Technical details
    - support for SD and SDHC cards to 32GB in the micro standard,
    - FAT16 and FAT32 files system support,
    - software upgrade from the SD card level (bootloader),
    - the ability to enable/disable verification of writing to the SRAM memory,
    - operation using two buttons,
    - support for up to 199 files (software restriction),
    - game numbers, error codes and other information displayed on the display at the back of the cartridge,
    - automatic memorising of the last used file number,
    - 9 memory cells to memorising the most used or favorite games, the so-called speed dial,
    - two modes of operation possible:
    1. after starting the console, the last used game file is automatically read from the SD card and saved in SRAM,
    2. after starting the console, cartridge waits for you to dial the number of the game and then it’s read from the SD card and saved in SRAM,
    - .LYX file support in size 256kB and 512kB (128kB after convertion to 256kB),
    - after loading the game the SD card is disconnected, to save energy,
    - every time you start the console cartridge counts the number of files in the root directory of the SD card and it does not allow you to choose the bigger number than the actual number of files,
    - the cartridge cover is a three-colored print from the 3D printer
    I have more information in the instructions.
    Manual_en.pdf
    Link to the online LYX converter: https://atarigamer.com/lynx/lnx2lyx
    Cart cost: 220PLN/ 52EUR/ 45GBP/ 57USD,  shipping 25PLN/ 5EUR/ 5GBP/ 6USD
    Pre-order list:
    1. im_reg - sent
    2. akira666 - sent
    3. gambler172 - sent
    4. -^Cro§Bow^- - sent
    5. Fadest - sent
    6. bdoi - sent
    7. bobandted - sent
    8. Knud - sent
    9. blainelocklair - sent
    10. Machine
    11. TrekMD - sent
    12. ilmapo81 - sent
    13. Jazzoff2000 - sent
    14. Tidus79001 - sent
    15. GadgetUK
    16. slx - sent
    17. ndary (2pcs) - sent
    18. hb1981 - sent
    19. SkydivinGirl - sent
    20. haightc - sent
    21. WildHairZero - sent
    22. bhall408 - sent
    23. famicomic - sent
    24. duqtito81 - sent
    25. modca - sent
    26. gamecomposer - sent
    27. fwfriend
    28. ataristi - sent
    29. Barral - sent
    30. cowdog360 - sent
    31. takaaki (2pcs) - sent
    32. KevinMos3 - sent
    33. fandenivoldsk - sent
    34. frap - sent
    35. arrowhead
    36. Iwantgames:) - sent
    37. swlovinist - sent
    38. nyandeyanen - sent
    39. Tab - sent
    40. sdrake - sent
    41. compil3r
    42. johncena1973 - sent
    43. Dreamersoy - sent
    44. astorri
    45. Zitruskeks - sent
    46. terminator.as - sent
    47. spidey_05 - sent
    48. corgi1 - sent
    49. Vyper68
    50. mcclure911
    51. Guitari
    52. CrashEd
    53. auricom - sent
    54. Tindron - sent
    55. power - sent
    56. mxnschx - sent
    57. AtariLogo87 - sent
    58. Alonsan
    59. Prometius
    60. gambler172 - sent
    61. drchizo - sent
    62. jaildesigner - sent
    63. djrodderz - sent
    64. rocco - sent
    65. saffron1
    66. karri - sent
    67. AKG - sent
    68. 8bitman - sent
    69. davidcalgary29 - sent
    70. Slumpwuffle - sent
    71. Ataridoremi4 (2pcs)- sent
    72. make_stair - sent
    73. piedude67 - sent
    74. addoni67 - sent
    75. Snakebond - sent
    76. Eric M - sent
    77. Hokis808 - sent
    78. FRK - sent
    79. puppetmark - sent
    80. AtomicFlounder - sent
    81. davepyne - sent
    82. Philsan - sent
    83. atarimonster
    84. jimmy - sent
    85. Freakrk00kman - sent
    86. Jawapower - sent
    87. pixelperfect - sent
    88. Splain - sent
    89. rondede - sent
    90. Bochum_Boy - sent
    91. bigoreilles
    92. FrankT - sent
    93. zeddex - sent
    94. RickR - sent
    95. Giant Bazooka (2pcs)
    96. Spintatotale - sent
    97. TXG/MNX
    98. Widdershins - sent
    99. jonwarby - sent
    100. mario64 - sent
    101. Retromills - sent
    102. deepfb - sent
    103. Retrogamer1983 - sent
    104. Gandor
    105. drchizo - sent
    106. peke - sent
    107. dmils - sent
    108. Alecolor - sent
    109. Mi1ez - sent
    110. RayXambeR - sent
    111. RockyRaccoon - sent
    112. arcanehacker - sent
    113. Felyx - sent
    114. nemaon - sent
    115. GenesisGuy66 - sent
    116. Terop - sent
    117. UHATEIT - sent
    118. johncena1973 - sent
    119. DDLynx - sent
    120. karlozgil - sent
    121. NAMSS Gamer - sent
    122. Necro-M - sent
    123. joora - sent
    124. Brother_theodore - sent
    125. iBorg
    126. Kerberos - sent
    127. dalecousins - sent
    128. nascarbryant - sent
    129. Mike1978 - sent
    130. BenBoss - sent
    131. xrbrevin - sent
    132. Arno - sent
    133. baseball227 - sent
    134. Magnus1 - sent
    135. Barrakuda - sent
    136. Sega CD - sent
    137. pucpuc - sent
    138. bayshield - sent
    139. aztec-cat - sent
    140. retrofuture - sent
    141. gtranche - sent
    142. chrishunts - sent
    143. Quickie - sent
    144. agradeneu - sent
    145. Devander - sent
    146. IG-88 - sent
    147. VidyaGame
    148. cdoty - sent
    149. papapumpnz - sent
    150. Michaelpogi77 - sent
    151. Radiorob - sent
    152. wost - sent
    153. ohmslaw - sent
    154. RetroBrian - sent
    155. Steggs - sent
    156. Retroguy1978 - sent
    157. PetrS (2pcs) - sent
    158. Mijominmijo - sent
    159. dve - sent
    160. nintensive_care - sent
    161. kezax - sent
    162. Yakama - sent
    163. slydog43 (2pcs) - sent
    164. Manos ofi - sent
    165. PollekeT - sent
    166. McCarseat - sent
    167. subcon959 - sent
    168. Benb326 - sent
    169. Jsloubet - sent
    170. rwbivins - sent
    171. looney bin jim
    172. Terop (2pcs) - sent
    173. shiz - sent
    174. Barral (2pcs) - sent
    175. Flashback - sent
    176. tsukato
    177. Quickie - sent
    178. RadiATIon - sent
    179. professorkeith - sent
    180. uriazael - sent
    181. dogeymon
    182. Kris Gklavas - sent
    183. Tolust - sent
    184. sramirez2008 - sent
    185. opossumita - sent
    186. Genroo - sent
    187. Pabloku - sent
    188. Johnrh
    189. Alfanso Bundy - sent
    190. ozyr - sent
    191. AlbertoDolci - sent
    192. tonibmw - sent
    193. videofx
    194. Gori_PD - sent
    195. johncena1973 - sent
    196. flodi - sent
    197. jestar06 - sent
    198. generalgau (2pcs)
    199. RTL1896 - sent
    200. 3dbjorn - sent
    201. SenorRossie (2pcs) - sent
    202. LeedsRule - sent
    203. Kasreyn - sent
    204. Criosdaidh - sent
    205. Stiki - sent
    206. Darkjedimark - sent
    207. Fusspils - sent
    208. theundutchables - sent
    209. vetteguy112233
    210. TowerThursday - sent
    211. GamerDave01 - sent
    212. Peyo - sent
    213. takevin
    214. MacRorie - sent
    215. FlyingForStatus
    216. Cristiano Paris - sent
    217. lucifershalo
    218. student - sent
    219. uncle2223 - sent
    220. Zak919 - sent
    221. Megantonneke - sent
    222. hexcor - sent
    223. Ben M - sent
    224. dkml - sent
    225. Lamer Deluxe tm - sent
    226. Serrameade6 - sent
    227. SHARK - sent
    228. coverilla - sent
    229. sramirez2008 - sent
    230. yogi75 - sent
    231. supersnoopy996
    232. Wrathchild - sent
    233. Jurgen - sent
    234. Neonrazor - sent
    235. Aroci - sent
    236. ssmac - sent
    237. bdoi - sent
    238. ozyr - sent
    239. TwinFami - sent
    240. Fred Olivas - sent
    241. atariftw - sent
    242. Joran - sent
    243. koskis - sent
    244. Marcus Englert - sent
    245. cleoo - sent
    246. Cavancullen - sent
    247. seven-t6 - sent
    248. Stairre - sent
    249. Hasan Coskun - sent
    250. joeatari1 - sent
    251. troff - sent
    252. hansdc - sent
    253. koopa42 - sent
    254. Elysiom
    255. JerryBlade - sent
    256. Zaspath
    257. drbollox - sent
    258. joeatari1 - sent
    259. Makara - sent
    260. agradeneu - sent
    261. Vital15
    262. FiveJay - sent
    263. Evgeny - sent
    264. Tolkey AT - sent
    265. Johny
    266. rheffera
    267. BovineD
    268. Shanerx7 - sent
    269. Lukasz
    270. Kenneth - sent
    271. _shameless_ - sent
    272. Yellowman - sent
    273. Styrbjorn - sent
    274. nemaon
    275. actiongamemaster - sent
    276. crazycalow - sent
    277. dougal22 - sent
    278. Terorr78
    279. Atarifrank - sent
    280. Paulrichardson - sent
    281. Ludorian - sent
    282. fred
    283.kevates - sent
    284. vitinillo (2pcs) - sent
    • Like 15
    • Thanks 4
