tmp
    429
Posts posted by tmp
  1. while i agree that it'd great for the customer to know the total including any fee/tax his home country chooses to add to his order but it'd be quite a nightmare for the seller to manage such system for every country in the world and to track all the constant changes
    i could be a minority but i believe it's my job to know the local rules, not the seller's (he most likely wouldn't even be able to find my country on the map and that's fine)
  2. 23 minutes ago, x=usr(1536) said:
    That only applies to US citizens who leave from and return to the country with goods purchased abroad.  For items sent via post, courier, etc. the rules are much different.
    https://goglobal.dhl-usa.com/blog/shipping/what-changes-to-the-de-minimis-value-threshold-could-mean-for-your-business/
    Quote
    In 2016, the United States raised the de minimis value threshold from $200 to $800, meaning that most goods valued at $800 or less enter the U.S. duty-free.  As a result, more low-value shipments qualify for expedited border clearance and are not delayed by formal entry or payment requirements.
  3. 2 hours ago, zeropolis79 said:
    Now it's telling me it needs something called OSXEX2 in the route directory - have I forgotten to put stuff in>
    that would mean that the cable isn't detected anymore (or you're starting ATR with SHIFT-ENTER)
  4. 2 minutes ago, zeropolis79 said:
    Has anyone got a copy of the manual they could message me with please - the one linked to at the beginning of the post is off-line.. I'm having prolems loading most ATR and CAS files, even if I do turn it on pressing the OPTION button.
    Thanks!
    google de re avgcart and use cached version
  5. 15 hours ago, DjayBee said:
    This happens already if I only connect the inverter itself to the main board - without having it connected to the panel's backlights.
    What is more probable?
    - The inverter board is bad and pulls too much current (even without connected backlights).
    i think inverter will (should) shut down if there is no load connected, even if it's not a proper one (e.g. one tube is damaged) so testing it this way might not lead to the correct conclusion
  6. 1 hour ago, Mr Robot said:
     I wish the AVG had an on/off switch so I would never have to unplug it
    not sure at what times you need to unplug it but theoretically you could just enable auto side emulation and it should be almost invisible (aside from those side registers in $d5xx), you can go back to menu by pressing cart button and atari reset (and optionally disable auto side)
  7. 7 minutes ago, ijor said:
    Very nice @tmp . Good job, seems very powerful. I wasn't aware about AVG CART.
    But I understand AVG CART is not open source like Ultimate Cart, is it?
    correct, it is not
    Also, if you don't mind, I find the video a little bit confusing regarding the operation of this feature. Do you select a secondary (connected to SDX pass through) cartridge from the AVG CART menu? What I find it confusing is the presence of the [email protected] file in the D1: directory. I would expect the cartridge image not to be visible to SDX at all. Or that file image was there just by chance without a direct relation to loading Action?
    my random videos are always confusing although this one had at least some description (that is not visible when embedded)
    Quote
    Stock machine, both SDX and the stacked cart (Action!) emulated by AVGCART
    D1: is FAT32 on SD card
    CTRL-SHIFT-ENTER used to run Action! stacked with SDX
    the reason you saw ACTION CAR was that sdx was seeing the same directory as the avgcart browser (same fat32 partition on sd card)
    this is all W(N)IP so the final behavior is still subject to change
  8. 23 minutes ago, vitoco said:
    Thanks! I'm here because the one it was sent to me as a prize from this year's NOMAM contest got lost and never arrived.
    sorry to hear that, that'd be first cart lost in mail i (now) know of, i wasn't even aware avgcart was a prize in that contest
    i'll contact you after the holidays and we figure out something
