Milli Vee
230 -
Posts posted by Milli Vee
Thanks Milli, and well done on the information and video production!
Perhaps if the video were abbreviated into a 15 minute segment, it would catch more interest. As informative as it is, it is difficult to sit through a one hour video unless you have dedicated time on the weekend. I think it would be great to have some bullet points highlighting how we could do this ourselves.
The questions I come away with:
- Where do I get a fully patched copy of T-DOS or CP/M?
- Can I easily run one of these OSs from DDP or from my CF card rig?
- Can I make my Adam boot into T-DOS easily, or is there another setup piece for that?
Thanks for all you do! I have an F18a modded Adam with Rey’s Adam power supply, the MicroFox CF card hard drive rig, and 1 DDP drive. So far, the only thing that’s come easily is playing Adam Bomb 2, but I haven’t set it up in a while.
You have TDOS on the CF system - press WildCard at the boot menu on the CF and you are in TDOS with 4 drives total of 32mb.
No comments? OK
BTW, T-DOS and CP/M 2.2 do not have these kind of limitations... to the best of my knowledge of these alternate ADAM operating systems.
Well CPM and TDOS do suffer from the maximum disk size being 8mb, though you can have multiple drives and since each can have 16 user areas you do have more leeway in the directory
Milli
Thank you NIAD for answering these for me.
As stated the 64mb Smart Basic image was a test case, the actual goal of this is a new OS for the Adam named Wedge. I named it Wedge because that is actually what it is doing. Besides providing a new platform to develop on for the Adam it will also contain a number of utilities more inline with modern operating systems in methodology and usage. Wedge will also do what its name implies, it will wedge itself into EOS and by doing so it will allow you to import hundreds of disk images into the larger Wedge image and have them available with just a few key strokes. Since for the time being Wedge will run on the VDD this eliminates having to mount and unmount images and it eliminates the 100 image limit of the VDD. In actuality it would allow you to have 100 64mb wedge images on the VDD which could contain 40,000 (!) individual disk images on a single microSD card.
Wedge on the VDD is just the start, once the hardware hurdle I have encountered is overcome Wedge will be a perfect interface into CAPE (Coleco Adam Peripheral Emulator). With CAPE you would be able to plug a PC into a barebones Adam, no printer, no data or disk drives, just a keyboard, and have a full system with printer, 2 data drives and 2 disk drives. These would be emulated by the PC. Wedge would then access CAPE and let you load and save files natively into folders on windows.
But for now I am designing Wedge to make the maximum use out of the VDD, so a 64mb Smart Basic image is a great start.
Milli
I did a write up on how to have a 64mb smart basic disk image on the adam or in the emulator:
http://smartbasic.net/2018/08/10/64mb-smart-basic-disk-image/
Milli
Based on recent history, I'm predicting this leads to an Adam Net to USB cable being sold on eBay very soon.
Wont work - too much of the processing on peripherals is done on the PC now - there is no stand alone printer that can be accessed with a USB. Also USB does not like the 62.5 baud combined read transmit line - I know - Ive tried to use it.
Milli
I have 9 confirmed emails so far saying they would order the power supply and there about 1/2 dozen more that said they would on the blog that I would like to get a "confirmed" email from to bring it up to 15 (see the blog for the form to fill out) http://smartbasic.net/2018/08/02/coleco-adam-replacement-power-supply-project/ - I am hoping to get 30 "confirmed" emails by the end of this month so I can order the parts.
Milli
On facebook I posted that I have converted the data image to an interleaved disk image that you can use in an emulator or with the VDD so you do not have to use a real data pack to see this:
http://smartbasic.net/2018/07/31/data-pack-image-to-disk-image/
Milli
It looks like you are using the Mean Well RT-50A and then placing that power supply in a professional neat looking case.
Here is the PDF specs and manual for the Mean Well RT-50A if anyone is interested.
Yes - if read my blogs (or previous posts here or on facebook) you would have found the link for it.
Milli
I would be interested because that custom case looks awesome. Also besides being able to plug in the ADAM Printer to the power supply for ADAMNET data pass through, to my knowledge this well be the first ADAM power supply that has the standard 6 pin in/out ADAMNET connection cables.
Well this be a power supply you are custom making from scatch for the ADAM computer? Or well you use some type of PC power supply that is placed inside a ADAM case?
How many watts well this power supply be? Also even though all ADAM systems were sold in America on a power system that is 120 volts 60Hz, in the ideal world the power supply should be able to handle around 100-240 volts at 50-60Hz so that anyone in the world can use the ADAM if they want too.
The power supply is an off the shelf one - it has 45.5 watts and can handle 100 - 240V input. I have been using this one for over 2 years and a few others have also made their own using the same supply. On the website is more pictures and details.
Most and perhaps all 3rd party power supplies for the ADAM computer did not actually power the ADAM printer. Instead after testing what actually occurs is that the DB9 connector on the side of some third party ADAM Printer power supplies is for connecting of the ADAM printer for data communications only, and the printer remains off as long as the power switch on the back of the printer is off. However, as soon as one turns the printer power switch on (located on the back of the actual printer), what actually happens is the printer well not work unless the power cord is also plugged into the electrical outlet. Therefore, the ADAM printer still uses its own internal power supply when connected to a third party ADAM memory console power supply. Therefore, when one wants to use the ADAM printer they have to still turn it on and use the power supply built into the printer. However, the printer does run cooler when connected to a third party ADAM memory console power supply, because the internal printer power supply is only powering the printer and not powering the entire ADAM computer system.
There is a bug or unwanted feature in the SmartWriter program and/or all ADAM Printer firmware (This bug or unwanted feature occurs with all Coleco ADAM printers released). Every time the Coleco ADAM memory console is reset the printer advances the paper feed one space. Therefore, after one does several resets of the memory console the paper needs to be reloaded in the Coleco ADAM printer. I did notice one nice improvement about the ADAM printer when connected to a third party power supply. The DB9 connector on the power supply is wired in such a way that the bug or unwanted feature where the ADAM printer advances one space after each memory console reset no longer occurs anymore. This is a very nice improvement not to have to reload the paper after several memory console resets. I hope this new power supply for the ADAM computer you are developing well also stop the unwanted ADAM printer line space advance issue everytime the memory console is reset.
Thanks for pointing this out, I can leave the reset line unhooked.
I am currently in the process of finishing up a replacement power supply for the Adam. It uses a proven power supply that I have been using on the Adam for the past 2 years and other off the shelf components to make a very sleek replacement power supply for the Adam.... http://smartbasic.net/2018/08/02/coleco-adam-replacement-power-supply-project/
Milli
Oh, wow! Another Coleco ADAM website I didn't know existed. Great work!
My other sites:
and my Adam store:
Milli
I recently found myself needing to create a few CP/M data packs for customers. This is normally no problem, but I needed to load them with programs. Since I normally use the VDD all of my files are in disk images, and a CP/M disk image is limited to 160kb, where as a CP/M data pack image is 256kb. The total amount of the programs was around 200kb so I would...
Milli
I used an old joystick cord for my power cable.
That seems a little dodgy but will see
If it is the power supply I am thinking of, I might be interested in just a case for it. Will you be selling the cases by themselves or the power supplies and cases together?
The same one - has never failed me yet
I will probably be doing just the case too - am trying to make it as off the shelf as possible, only issue I have is the cable - wishs I could find a supply of original adam power cables or a pile of old printers that can not be salvaged.Milli
Congratulations! That's an awesome achievement!
Thank you - I still have some available
Milli
I am working on a case for a replacement power supply for the Adam that I will be selling soon. It is based on a replacement PS that I have been using for over 2 years that has never once given me issues in multiple Adam's
Milli
okay, so quick question. does the magnetic burst affect just tapes or will it ruin CD's as well? i ask this because i am afraid it might harm my PS3 or Xbox One.
If the magnetic pulse was strong enough to modify the molecules on the CD that have been modified to hold data then that pulse is enough to fry you too.
As for frying a data pack if you leave it on when turning on I have never had it happen but I have had data drives ruin tapes because the head is not in alignment. Someday I hope to figure out how to align the heads.
But a serious question about the "EMP" that the coleco adam makes, is it printer only, ie if I have a different power supply and no printer do I have to worry about any of that? I would think not, the power supply is 2 years old and designed to sit inside a PC next to a HD and floppy drives with no thought of it causing issues.
Milli
This probably helps avoid that fine line between softening and melting the plastic. Although, with boiling = 212 degF, I wonder if you could just stick the can in the oven and set to 200 degF. Of course, your next casserole may taste like colecovision controller from out-gassing.
The boiling water will never really heat it up to high as it cools fast and heat rises - not outwards as much - in an oven I think it will stick to itself
I just did this - here is how:
1. Get a metal can, vegetable, soup etc - the bigger (wider) the better.
2. Remove the label and one end and the contents
3. Clean it
4. Wrap the wire tightly around the outside of the can, bending and twisting to remove the twist
5. Use tape to hold both ends
6. Fill can with boiling water and allow it to sit for an hour
7. Empty and repeat 6
8. Empty and remove wire - if it still has some twist rewrap and repeat #6
Milli
Coleco Adam: Access the internet (not wifi modem)
in ColecoVision / Adam
I didnt like the look of it and the VDD kept crasghing on my so I would have to mount, unmount etc. It didnt crash because of the movign it, it crashes because it is the VDD (you learn to live with the crashes)
