Jetboot Jack
    1,957
Posts posted by Jetboot Jack
  1. I tried to use JzIntv and I kinda failed.
    If I used the standard z0-7 screen settings I cannot find one that is either sharp and centeted full screen (or 4:3) or non blurry because it's not a good pixel match to my screen.
    Trying to use a custom resolution in z????x????,? format just made the emulator crash :-(
    I did not get to creating config files, that seems quite easy had I got a screen display that was acceptable.
    I took a look into the custom keyboard layout - it seems rather baroque as a way of doing it, but there were some examples that I think if was happy with the display I would pursue.
    So I am now looking for some more information with regard to the screen resolution settings or investagting other emulators like MESS (gulp)....
    sTeVE
  2. righto - that makes sense, seems easy to extend and eliminates the separate per rom files so that makes it quite tidy.
    I will do some windows experimentation with JzIntv this weekend to see if I can get things working better - at least try some cfg files and get those non-standard games working and try and sharpen the output if it is to replace Nostalgia in my setup
    Is it easy to create custom keyboard mappings - I like to use Xpadder to parse joystick to keyboard from non-retroarch emulators?
    sTeVE
  3. All Intellivision emulators have to be told each game's memory map. Some like Bliss, Nostalgia, and MAME have a database of game memory maps. But for newer games it would have to support .cfg files or memory map embedded .rom files otherwise you'd have to manually update the database. Jzintv defaults to the Mattel standard memory map if no memory map is given. All Intellivision games should come with a memory map .cfg file or an embedded .rom file. Not sure about your jzintv smooth scaling issue unless you are using the --prescale switch. Openemu's Intellivision emulator core is Bliss. You can also get Bliss for Windows, but jzIntv and maybe MAME are the only emulators that I know are actively maintained by the programmers.
    One issue with jzintv is that the border is too thin. But when I looked at Bliss it has no border at all. MAME has a decent Intellivision border.
    OpenEmu does indeed use a memory map cfg file, it's just a little different than the JzIntv ones - one file called "knowncarts.cfg" which is inside the "Bliss.oecoreplugin" package - which selects memory mapping settings based not on file name:
    C047D487:Info:Beauty and the Beast:Imagic:1982
    C047D487:ROM:4800:2000:16
    Which does not look like the md5 hash for the rom...
    sTeVE
  4. I have tied JzIntv, Boss and Nostalgia under windows I find all ahem problems that make them problematic
    I see poor image quality with JzIntv - perhaps I am not configuring it correctly, but it always appears slightly smooth scaled whatever resolution I set, which I dislike...
    Also with JzIntv the non Intellivision carts require individual ???.cfg files to set the memory mapping correctly which is a bit of a pain too - makes it fiddly.
    I have great picture quality and no need to setup the mapping files with OpenEmu - it just works...
    However I need it under windows so I will have another go with JzIntv mr_me!
    sTeVE
  5. I can't really supply definitive information - I use Splashtop for all my general remote desktop access across my devices. I am satisfied with it's performance - it is much better than M$ remote desktop in my experience, less lag, better screen refresh, better image quality. But I have never stress tested it as a games solution, at best I have dabbled with it, and was impressed with the results.
    But if games/emulation is the primary use, I would recommend investigating software designed to achieve this such as steam in home streaming or nvidia gamestream solutions.
    I have used Steam Streaming from my PC to my Mac Laptop to play a fair few titles, both steam specific and those non steam games installed and added to the steam menu - but I cannot say I have done more than try a few emulators like Stella.
    It's good, really good, but I cannot say 100% perfect - it's streaming, it is affected by network bandwidth and interference - even with my rather over spec'd PC (Kaby Lake i7, 32GB and GTX 1080) it's not perfect - nearly perfect wired, less perfect on WiFi...
    I have not used, but hear Moonlight works well for NVIDIA equipped systems - it can stream specific apps, it works with controllers, you can add any app to it, it can also stream your whole desktop...
    sTeVE
  6. Just to add to this - there is no emulator that makes this more simple than OpenEmu - especially as Intellivision emulation is pretty dreadful on all other platforms, I've been trying to get good coverage under Launchbox front end on Windows and it REALLY not fun :-(
    SpiceWare's exhaustive guide is 100% accurate, but just for completeness this is the official information:
    https://github.com/OpenEmu/OpenEmu/wiki/User-guide:-BIOS-files
    sTeVE
  7. Brain,
    I've been using kat5200 even more over the last few days, on both Windows and OSX, and it is very solid and stable - nice work, great to see another multi-os emulator being developed!
    One thing I have found is that I get some odd palette behaviour.
    • If I use the default NTSC palette then I get good colors in all games, but weird colors in Pole Position - mint green sky and purple instead of red.
    • If I use a PAL palette I get good colors in all games, but weird colors in Ballblazer - blue grid and dark sky
    I have tried several versions of each game and the results are the same for all
    BUT - using the Nabuko52 palette all games look correct-ish - I find that palette is a bit "bright" in the dark colors, but it works and I'm not a cycle exact perfectionist, just like playing old games on my big TV :grin:
    sTeVE
    P.S. I also see weird colors on the mario sprite in the updated versions of Donkey Kong that have been created by darryl1970 - http://atariage.com/forums/topic/249885-atari-a8-donkey-kong-hack/
  8. Are you still having problems?
    If so it sounds that somehow you are losing files - you could see both "._????.bin" as well as "????.bin" files in the same folder, both the ???? bits will be the same name.
    If you see just "._????.bin" files and no matching "????.bin" file, you or some program you are using has deleted the original.
    sTeVE
  9. Brian,
    I've just started using kat5200 - and I am really liking it - especially as I game on both OSX and Windows, since there are no native OSX emulators with working audio for the 8bit computers!!!
    The only addition I would like is a little more support for OS selection and extended memory configurations - that aside the automatic cartridge recognition makes this an emulator of choice when used with front ends like lunchbox or attract mode!!!
    sTeVE
  10. I'd just like to re-iterate what Flojomojo said - I use Splashtop to stream to laptops, i-devices etc etc.
    It is massively superior to using M$ remote desktop - no configuration, games are full playable with a good network and I have found NO software that won't work so far - all emulators etc.
    Moonlight is also around, which is a great alternative to official steam streaming if you have the right hardware...
    I would give Splashtop a try, it works great for games and is likely better supported. Alternatively try Steam streaming to other computers. I think either of these will have native h264 support, something that MSRDP is working on but might not be as far along --especially on iPad.
  11. learning that so many assets in DK were ripped straight out of Radarscope, it's sacrilege. Everything felt like it was made for Donkey Kong, not some lackluster space title, and 37 years of classic arcade reference ingrained into my head was all a lie
    That Radarscope became Donkey Kong is rather well known - it's not a matter of ripping, they were re-purposed deliberately as the many dozens of accounts describe....
    sTeVE
  12. I always wondered who in "Gremlin" programmed Zaxxon, because I read that SEGA hadn't coded it themselves. So this is saying that the team who made Donkey Kong also programmed Zaxxon, and Congo Bongo too? Huh. They really lit the gaming scene on fire in the early 80's with DK and Zaxxon!
    Designing and programming are two different things - coding duty does not conflate with creating the idea or the gameplay beats always...
    sTeVE
  13. Sorry to not follow this up earlier and seeing all the theories, sad to see that it's a bum cart, but like I said in post 2 the Thunder Fox cart is NTSC or PAL compatible, the tape version is not - just to avoid confusion as the original post said:
    "Is it possible that this is a PAL version? This game was released as NTSC, right?"
    The cart version is the same sold in all territories and works on standard and U1MB enhanced hardware PAL and NTSC - tested as I have a couple of copies and various ROM files via SD2SIO, all work just fine...
    sTeVE
  14. The cart is the NTSC conversion, the original tape was PAL only - Noel did not do the NTSC/Cart conversion himself I seem to remember, that was handled at Atari's request by a third party..
    My cart runs on my PAL (stock 130XE and 800XL) and NTSC (1200XL with U1MB and stock XEGS) systems just fine...
    sTeVE
  15. As a Mac fan it pains me to say I would recommend Windows for those systems Keatah...
    • Altirra is a wonderful emulator for 400/800/XL/XE/5200
    • FSUAE for Amiga
    • VICE for Commodore 8bits from PET to 128D
    I use LaunchBox as a FE and it is super slick and hides the mess that is Windows 10 from view!
    And I recommend a PS4 controller via bluetooth for controls - just the best D-Pad!
    sTeVE
