4,070 -
Posts posted by DarkLord
Well, this is an internal US, and I used the left slot as primary
when I prepped the 4 gig card. This is with the symbol on the
US board facing up. (it's actually turned the other way when
you install it in the Mega STe's hard drive bay).
Wonder which is primary on the US I used in my STacy? They
are stacked vertically, on top of each other and I used the top
slot.
I guess I should try the STacy later and see if 2 cards work with
it.
It's probably some settings that I've messed with (these things are
almost always my fault).
I'm gonna try something semi-radical and if it works out
I'll need another yellow LED.
I'll let ya know.
There are no dumb questions.
Seriously, yep, I did that.
Some more (probably) dumb questions:
Did you prep both cards with your driver software?
If you're using HDDriver, is hddriver.sys on both cards?
What do you have checked for bus/devices to be read?
Do you keep the primary (boot) card in the left slot or right?
Thanks.
Okay, is there a very clear, well defined guide for setting up
-2- SD cards for the Ultrasatan.
I've been playing around with my internal US and have failed
to get 2 working correctly together.
I've successfully setup a handful of 2 and 4 gig SD cards by
themselves, using HDDriver v11.01.
With my Mega STe's hard drive bay open, and the internal US
sitting with Lothareks' emblem *up*, I've been using the left
hand slot. Works fine, as I said no problems with any single
card. When I put another card into the right hand slot though,
I can't ever get HDDriver to recognize it. The US does flash
the right hand red LED once when I put the card in.
I tried just booting up from floppy with HDDriver and the 2
gig card in the left hand slot, then set it up with 4 >500 meg
partitions, then restarted with the 4 gig card in the left slot
and the 2 gig card in the right slot but it still wasn't shown.
Putting that 2 gig card in the left slot and booting up without
the 4 gig card does show up. Booting up with the 2 gig card
in the left slot and the 4 gig card in the right slot gives 3-4
bombs, requiring a physical reset.
Any and all help appreciated. As I mentioned at the start, if
there is a guide somewhere online, please point me to it and
I'll go from there.
Thanks all.
Okay, gonna start a new message thread for this, and not hijack LED's n stuff.
https://atariage.com/forums/topic/304895-using-2-sd-cards-with-an-ultrasatan/
I love v2.06 and much prefer it to earlier versions. However,
in the interest of compatibility what you may want to do is
install a TOS switcher - that way you can boot up into what
ever version you need/want.
PS Keep in mind, going from TOS v1.6 to v1.62 is a matter
of simply swapping 2 chips. It's a bit more difficult to install
a TOS switcher.
Not sure. I do not currently have 2 cards in play.
I don't think I've ever even used 2 cards at once - how far (gigs)
can you do that? I've got a 4 gig card in - can you still use another
4 or 2 gig card? Do you have to use HDDriver (or whatever software
you're using) on it as well?
Thanks.
So as long as you're powering it (as I did) with an adapter from the original
hard disk p/s to the internal US, the switch does nothing...except boot your
setup into low res.
Alright, thanks for the info guys, appreciated.
Well, I tried flipping the switch from its current position (the way it came when
I got it) and it did...nothing, apparently. My Mega STe still booted up from the
SD card/US but oddly, in low res.
Flipping it back caused it to boot up normally, in med res.
Thanks.
Hmm, off topic but what does the red switch on the back of the internal US do? I thought
it would be for power but it's not.
Thanks.
Are these devices considerably different in the way they behave compared to one of
Lotharek's Ultrasatans?
I'm using HDDriver v11.01 with a 2 gig and 4 gig Sandisk SD card. I set them to
TOS 1.04 and Windows compatibility and divided them up into 4 partition and 8
partitions, respectively.
I can transfer either card to my Win7 box and they are recognized there, although
it's only the first C partition on each card that is seen. That's good enough for me
though, make transfers very easy.
I also have a 2 gig card that on my STacy that I use with my Kubuntu Linux laptop,
using Mtools for easy access, but it is command line driven and that puts some
people off. However, using a config. file, you can access all the partitions on the
card. For example, C, D, and E on the card translate to S, T, and U at the command
line, so "sudo mdir s:" will show you the C partition directory, etc,...
HTHs.
Most of the time, I logon to Atari Age for great Atari content, witty conversation,
and lots of camaraderie.
Today, I got the above... /sigh.
Well, I've got a US in my STacy, which has the opening on the right side so it's
easily accessible.
In the case of my Mega STe, the hard drive cover houses the internal US
mechanism, so if you leave the 1 single screw loose, you can easily raise
it up and access the US, which has the card section pointed right at you.
I thought about running a SD card extension cable to the VME cover on
the backplane but it was posted that there are errors with the cards when
you extend them too far so I kind of abandoned that idea.
I can see where it would be problematic on standard ST/STe cases though.
You'd have to modify the case to have access, I'm assuming most people
use the floppy bay.
Okay, update.
I went ahead and purchased HDDriver v11.01 from Uwe.
The English manual will come later but I was allowed to
download the ZIP file almost immediately.
Using HDDriver v11.01, I was able to setup up a 2 gig
Sandisk card with four partitions of 490 megs + and
access them all with no problems.
<shrugs> Still don't know what I did with version 8.46,
but it's all good now.
Thanks all.
Well, that's an interesting app. Card needs to be formatted first, and they
advise you in the docs not to use it on a card with files on it already.
So as you mentioned, good for new cards that you've just set up. Not so
good for cards already in play, with lots of files on them.
I'll be using it on any new SD cards I get. Thanks again for pointing it
out.
Downloaded this and will try it out.
Thanks for the link!
Well, it's possible but these are cards that have been bought from several different
sources, so...
Anyone else having any problems with the v1.2 internal Ultrasatan from Lotharek?
It's probably me, doing something wrong but I can't seem to get around it...
I've got a handful of 2 gig Sandisk cards and it's doing the same thing on 3 that
I've setup.
I'm using HDDriver v8.46 at the moment. I boot up with a floppy on my Mega STe,
and do a minimal install on the cards. TOS/WIN compatibility, 4 partitions, around
4xx megs each. The partitions are C, D, E, and F.
All seems good at first. 4 partitions show up, Show Info says they are the right size,
etc.
Then, when I reboot, the last partition "F", disappears. I add it back manually but then
TOS says it doesn't exist anymore. Also, on at least 1 card (I've not tried the other 2)
the last partition now E, won't hold it's reported size in space.
Anyone else had these problems and if so, know what I'm doing wrong?
Thanks.
PS Checked the 2 gig Sandisk card I'm using in my STacy and for whatever reason I
set it up as 4 partitions of 256 megs each, with only TOS format checked. It will boot
up in the Mega STe with this card and the Mega STe's card will boot up in my STacy
(resolution differences aside). Odd - I remember using the whole 2 gigs <shrugs>.
So I'm thinking there's nothing wrong with the internal US, I'm just setting something
wrong... Any ideas?
13 hours ago, ParanoidLittleMan said:I worked on Phantasie 3 earlier, and somehow it got forgotten (probably because move). Will look for those, but not so soon.
And pls. don't turn this in game wish thread - there are other ways and places for that ...
My apologies, never meant for that to happen - should have PM'ed you instead.
Now that I've got my Mega STe back up and running, I'll be going through the games I have,
time notwithstanding, shared between work, family, life, etc.
If you've got extra time on your hands <nudge, nudge, wink, wink> how about adapting the
Phantasie RPG games (there are 3 of them), and Legend of Faerghail?
I don't remember seeing them on your impressive list of already converted games. (if they
are, apologies).
Thanks, and thanks again for all the hard work on these wonderful games!
Will look at it closer when I've got some extended time off.
Thanks for the advice/info.
Ugh, not sure I've got the soldering skills to do this. I surely don't have a heat gun.
Mega STE original hard disk problems
in Atari ST/TT/Falcon Computers
And I'd recommend dumping that old clunky hard drive for one of
Lotharek's internal Ultrasatan SD card readers:
https://lotharek.pl/productdetail.php?id=49
https://lotharek.pl/productdetail.php?id=47
HTHs...
