DarkLord
+AtariAge Subscriber
    4,070
Posts posted by DarkLord
  1. Wow, you got quite a bit accomplished there!
    What's your budget? If it's upper range/few limits I just bought a very large desk from
    here:
    https://www.versatables.com/educational-furniture/classroom-desks
    They are expensive but built like tanks. I meant to order mahogany (like in the pictures)
    but accidentally picked maple. It's grown on me though. My desk is 6' x 3' and I've got
    a Win PC in the right hand side with the tower monitor and my Mega STe on the left
    side, with room for my STacy snuggled up in between. I love it.  :)
  2. Does anyone know if there is an extension cable that will let you plug into
    the second SD card slot and bring it out, to say, somewhere on the back
    VME panel or a modified HD cover?
    That way you could run with one card as your main HD, so to speak, and the
    other one accessible externally. I know that both are hot swappable, but I
    don't feel like having to lift the HD cover every time I want to access a card.
    Thanks.
  3. 2 hours ago, remowilliams said:
    Okay, J8 is most assuredly not 'between the sd card slots' on the 1.2 board as far as I can see  : D
    However, I've installed a header to J8 and it is indicating HDD activity on slot 1 (pins 1/2) and slot 2 (pins 3/4).  Black is pins 1 and 4 for the curious (as the LED is wired)
    Next question - how do we use just 1 LED for those four pins...  I'm assuming a small circuit of some kind would be needed.
    Ha! I like the way you mounted yours.  :)
    Been trying to figure out how I'm going to do mine...
  4. 3 hours ago, leech said:
    Bah, those are a pain in the ass to get just right.  Most of the first initial ones I tested all on the TT's power line, and they were fine and stuck in the thing, then I went with the smaller gauge wire, because trying to crimp those things on the larger wires are a pain in the ass.  But I use the smaller  push pins on my test battery than I think maybe the header pins are, so maybe that's why they stay in when I test them, but may pop out when connected to an actual header.  Some of them I know should work right, there are little flaps on the black plastic that SHOULD be flat when the pins are inserted all the way, but because the way the crimper works, I still have to squeeze the top part a bit, so that it'll slide into those and hopefully click in place so they don't slide out when it is attached to a header.
    If you don't already have a header on your US, then maybe just put some thinner pins onto it?  If you can find a tool to push the dupont connectors further into the housing, until it clicks in, they should work great.  Sorry about the muck up, I'll make some tonight and test them on the actual headers to see if I have better luck.
    Have you played with the multicolor one on the HDD yet?
    Please don't take that as criticism, it wasn't!
    I've got fumbly (is that even a word?) fingers and these things are usually my fault.
    No header on the US yet, have to check out all the options there and get everything together
    before I install it.
    Negative on the multicolor LED, was trying to get everything else sorted out first. Not to fear,
    it's lying right beside the green and yellow, next to the hard drive cage.  :)
  5. I think the length will still be fine.
    Okay, about testing. As it turns out, once I got the hard drive cage apart and cleaned
    everything, the original holder is still solid on mine. It appears that the goop/paint/insulation
    that they put on the holder did its job - mine isn't rusted at all (although the original grommet
    is rotted badly, and that made me think the whole thing was kaput). So I was able to just take
    one of the black grommets you sent and replace everything and it worked fine. I'll hang on to
    to the new holder replacement in case it ever does rust out.
    Now, from what I could judge, it certainly looks like if the encircling end of the original holder
    was rusted away, that your new holder would slip over it and function fine. I did slide it on mine
    just to see, but of course it wouldn't go far enough because the piece was still whole.
    My humble opinion is that it will work great with Mega STe's where the holder has rusted away.
    If I had to gripe about -1- single thing (and it's not really a gripe, more like a vexed observation),
    that would be those darned connectors. I'm having a devil of a time getting a solid connection
    with them. I have to manually push the red and black wires just as far as they can go, as hard as
    I can, to the ends of the black piece, trying to get them to work. Even then, they feel so loose
    that I think if I turned them over they would just fall right off. The power LED one was the same
    way.
    Seriously thinking about removing the black piece and just tack-soldering them in place.
  6. On 2/8/2020 at 2:38 PM, swatcop said:
    I soldered headers to J8 on the UltraSatan, doesn't work with my original LED in the HD bay, but I'll figure it out.  Just let me know where to send payment (PayPal work for you?) for everything.
    Hmm, looking at my internal US from Lotharek - it seems the layout is different. I must be blind because I can't find J8 anywhere. I do have an S2 where your J8 is.
    Oh, just noticed your board says 1.1, mine is v1.2 so....
    EDIT: Never mind - found J8, it's in between the SD cards...
    EDIT2: I do need to find out what everyone else is using to mount
    their internal US's with, to the hard drive cage. Straight bolt up, or does the US board need
    to be shielded from the hard drive metal cage? How much space between, etc, etc... Also
    need to know what adapter was used to go from the larger molex to the smaller one for the
    US's P/S. Would be nice to see some pictures, including the header that was put on J8, and
    it connected to the LED (BTW, did you get it working?)
    Thanks much!  :)
  7. I sent a PM to PPera. It looks like he's going to do the conversion.
    He was asking about copy protection - the only thing I remember is
    the first disk, you could copy the Play disk, IIRC and I don't remember
    anything else?
    Thanks.
