blakespot
    204
Posts posted by blakespot
  1. I've read through this thread and it's great seeing how this has evolved over the last few months. I'm another Tipi newbie, having just installed my TipiPEB in my F18A-equipped '99 and I'm loving it so far! But I have a few questions that I don't see directly answered in the wiki or other docs I've looked at, so I thought I'd air them here.
    For a while now I've been using the FlashROM99 cart to load things into my TI. I've grabbed both cartridge files as well as TIFiles off of TI-99/4A Game Shelf and I _believe_ that I've gotten most of the latter (and all? of the former) I've tried to work, which makes me wonder if cartridge files and TIFiles formats are overlapping or the same, perhaps one having > 32K size potential. I'm not clear on this. I know that the Tipi wants TIFiles format images and presumably can't take cartridge format files.
    Format aside, I'm also not clear on how to load these images. I know that I can issue CALL TIPI("TIPI.NET.TELNET") to load the telnet client, and I assume the dot notation is speaking of directory structure. I have several dirs sitting beside the NET/ dir on the system: MAIN and DSKS. (I saw the lengthy video where Wagner walks through his setup - helpful, and I followed his dir lead.) If I go through the web-based admin upload process (as I know it converts T9V9 files if needed) and move a TIFiles image called CAVE into MAIN, do I execute it using CALL TIPI("TIPI.MAIN.CAVE")? I've done this very thing (I removed .bin from the CAVE.bin filename) and when I do that, I just get back to the startup TI screen (as if I reset). So that's not working. There may be another process, then, it seems.
    And, for disk images -- I import disk images to my DSKS dir thru the web admin on Tipi and I understood that MYIMAGE.dsk would turn into a directory called MYIMAGE in the DSKS dir, but it doesn't. Is this not the process? I understand some disk images are ARChived and those won't work in that state. But, once I one way or another end up with DSKS/MYIMAGE/ containing the contents of MYIMAGE.dks, would that be mapped in the CALL TIPI config screen to, say, DSK2 (I have a physical DSK1) by entering the value DSKS.MYIMAGE as the mapping string? (I am aware there is a handy mapper written in BASIC a few months ago that makes this easier, and will get there after I get it working the "hard way".)
    Also is it possible to run large items like the Don't Mess With Texas demo, simply by mapping to a dir containing it? I assume so as this is effectively a HD system, volume and loose-file based.
    So, I've gotten things running and done some online gaming and BBSing with the bundled things, but I've yet to install something in the form of a TIFiles program or disk image and have it successfully load. Hopefully a few pointers here will get me pointed in the right direction. Many thanks!
    bp
    ByteCellar :: http://bytecellar.com
  2. My guess is the printer port is memory-mapped in the cartridge space, something simple. DBT used CRU bank switching in its cartridges but, with the exception of later models, the circuitry does not look complex enough for that.
    Do you imagine that outputting to the printer was writing to that address space and that data was the datastream for the printer? Or do you think somehow reading a certain section of data was what caused the data stream -- where a read access is handled as a signal to output data. Doesn't looks complex enough for me. I guess I'm just coming from the notion that you can't write to the cartridge port. But then, I guess there's MiniMemory, though, right?
    bp
  3. This thing is pretty interesting.
    http://www.hexbus.com/TI-99_4A_Home_Computer_Page/Cartridge_Pictures.html#16
    Does anyone have a photo of this cracked open? Id love to see how its pit together. Can the TI write (output) to the cart port? Hmmm....trying to recall if MiniMemory is a command module or a side attach cart. Maybe the whole bus is exposed on that cart connector.
    Im intrigued.
  4. I belonged to P.A.C.E., the Peninsula Atari Computer Enthusiasts covering the Virginia peninsula (south east Virginia) in 1986-88 or so. One of the places we would meet at night was this Lutheran school in Hampton, VA. I just got in contact with someone there who was able to provide me with photos of the Atari 8-bit lab we would do our meetings in from that period. I am going to write it up on my blog, soon.
    I talk a little about that group and others in my blog post from a few years ago.
    http://www.bytecellar.com/2014/02/11/computer-users-groups-of-my-past/
    bp
  5. _The Doctor_
    Umm, I am new to the A8 scene and as such hadnt seen years of posts about clipping the caps. Seeemd the machine had a serious issue with the SIO2SD and I decided to take Lotharek as an authority. I tried several max speed settings with no luck. Are you suggesting clipping the caps was a bad move somehow? Not sure where youre coming from. ?
  6. I emailed Lotharek to day asking about this, sending the video and description and he said the solution is simple: "remove old capacitors from READ/WRITE SIO lines."
    He said remove and not replace. Lost in translation? I assume I need to replace them. Anyone have a good source for new caps? Thanks.
    He also sent this: (attached)
    bp
  7. lower soi2sd divisor speed... make sure folders are emptied, delete .cfg files.
    check power supply voltage under load, so2sd's a power hungry beast in operation, a supply may not work on a more power hungry Atari in combination with a power hungry device...
    I have a second 1/2 brick and tested it with the 800XL -- same issue.
    Can someone tell me what the default value for the SIO2SD's Sio high speed setting is? Thanks.
    bp
  8. Ok this is happening:
    The file tree from the eBay bundle on the SD card is:
    /atari/
    SIO2SD.CFG
    Sio2SD.xex
    going in further:
    /atari/__Anim
    /atari/__DEMO
    /atari/__GAMES
    /atari/__Tools
    /atari/__Vbxe
    /atari/__Ziny
    Sio2SD_CFG_PJ.SET
    and looking at the __GAMES dir:
    /atari/__GAMES/__Executables
    /atari/__GAMES/__Floppy images
    /atari/__GAMES/__Trained
    and looking at __Trained dir:
    /atari/__GAMES/__Trained/AllCat.xex
    /atari/__GAMES/__Trained/Arkanoid.xex
    /atari/__GAMES/__Trained/Artefakt.xex
    What is happening is that the first (alphabetically) file in __Trained is loading after the SIO2SD loader menu loads. I looked at SIO2SD.CFG and AllCat.xex is mentioned in there. So, I deleted SIO2SD.CFG and deleted (moved off SD) AllCat.xex. What happens then is that the same thing happens but with Arkanoid.xex now, and looking at the re-created .CFG file, Arkanoid.xex is named within.
    Why in the world is this happening? And more importantly, how can I stop it?
    Thanks.
    UPDATE: I see that as the file list first appears each dir is quickly selected one after the other drilling down until the .xex is encountered then the system reboots -- very fast. Just as if a key is stuck -- but it's not; I go into BASIC and no repeat key is happening. If I interfere with the situation by wildly keying arrow keys, I am able to get into a situation where no file is selected but there is a repeat pinging sound as if a key is stuck. Again, in BASIC I can type fine.
    ANOTHER UPDATE: This only happens on my PAL 800XL, not on my 130XE. So it's specific to one of my machines. How could the system appear ok in BASIC but not under the menu?
    YET ANOTHER UPDATE: peek(53279) returns 7 (no function keys being pressed).
    bp
  9. I just got Lotharek's SIO2SD device and did so thru eBay so got the lower price bundle loaded with his SD card full of games and demos.
    Sadly, in this setup, the menu program starts to load --- I see the folders listing, and then it boots into the first (alphabetical) item in first folder on SD card -- mid listing. It used to list more of the menu before this happened, now I just see three folders and boom. I am hoding OPTION and SHIFT on the SIO2SD to get menu.
    Anyone have any help? Thanks. Using with a 800XL PAL.
    bp
  10. LittleMan, I am not using a floppy drive - you guessed wrong. HxC2001. And I contacted the author of SLIDE.PRG it only supports .SPU files, not the compressed .SPC files. Youre wrong again, it seems.
    Does any one else have any ideas re: NTSC Rainbow TOS 4MB 520ST showing garbled Spectrum 512 images? Thanks.
    bp
  11. You need to test your computer first. If it can not display properly hi-color formats no sense for seeking SW what can display Spectrum 512 images (if there is at all some except Spectrum 512 self).
    Your "it seems just to convert TGA, IFF, etc. into Spectrum" was misleading - why should it convert into Spectrum 512 format, when it uses more advanced formats ?
    And of course, you can look those images with some emulator. And you could post here those 3 slideshow disk images ...
    P.S. It's fascinating how little googling can find things in seconds: https://www.yaronet.com/topics/186587-spectrum-5124k-image-converter-for-the-atari-stste
    Why they call it converter is not clear. As I see it only displays ...
    This < 2K SLIDE.PRG does view a .SPC image successfully. I put it on a floppy full of .SPC images and it loads and reloads just one image over and over and quits with any keypress. I wish it acted more as I might expect it to. :-/
  12. Really ? Before writing such things should check better what some SW can. Photochrome is capable for much more than Spectrum 512, and was developed in last years too. I had some mailing with Douglas Little (man who did that SW), and he made it really well usable and configurable. Spectrum 512 was done before Atari STE, so can only 512 colors. Newer ones can 4096 colors, and even more using 2 alternating screens with slightly different palette. I used Photochrome images with game adaptations. You can try many of them without hard disk, from floppy, like: http://atari.8bitchip.info/SCRSH/moonpatr.html
    Later I started to use Cyg's hi-color system, what is similar to Photochrome, with even more overscan. http://atari.8bitchip.info/SCRSH/p47.html
    By later there are separated screens for ST and STE (file *.HST what starts with L is for ST) . There is compensation for USA ST timing difference (slightly diff, CPU clock) in later .
    I think that your ST is just in not good condition, and that's the problem. Waiting your test results.
    It seems capable of much, but I don't see it being capable of loading Spectrum 512 images and displaying them. At least according to the filetypes that it indicate it loads on the file prompt. What am I missing? I want to look at Spectrum 512 images, not convert Targa, RAW, GIF, or IFF files to Spectrum, etc. It prompts with those options -- does not offer the loading of .SPC images that I can see. If it does support this functionality -- can you point out how to access it? Thanks.
    bp
  13. I never got this working. I have 3 Spectrum 512 slideshow disks and all show garbled images on my 4MB expanded 520ST (no CPU accelerator or anything wonky like that).
    I tried Photochrome app, but it seems just to convert TGA, IFF, etc. into Spectrum vs viewing Spectrum images.
    Does anyone have a viewer that can render S512 images on this ST? Thanks.
    bp
  14. I've spent too much time solder repairing in the past few months (dead iMac screen -- damned SMT microscopic pads, TI-99/4A keyboard cable disintegration, etc.) so I went and eBay'd a decent looking 130XE with "the box" PSU ( top right ) along with a second (separate auction) "the box" PSU for the incoming 800XL PAL that's on order. I've got my 15yo SIO2PC cable going on an old P3 with APE and an SIO2SD arriving any day. So I want to keep rolling while I have some time off (laid off 3 months ago, but new job starting in a week or two). I will work at fixing the dead 130XE at some point soon and decide where to go from there.
    Thanks folks.
    (And if anyone has heard to the contrary, that "the box" is also a death brick, please do whisper it in my ear.)
    bp
  15. OH no.
    I just plugged the 130XE back into its old composite cable on the other CRT here and there is no solid video signal anymore -- I see the TV's blue screen (shown when no solid signal) and it's jittering about. I plugged the 800XL in also and it's the same.
    What has happened here? Something has killed both of my Atari 8-bits I've been using all week. Was it the PSU? It's not oddly warm. Or was it something about the s-video cable?? This is tragic.
    Not sure what to do next. I should check voltage out of the PSU to see if it's above 5. It had been working for nearly 2 weeks fine, and here the 800XL died after 30 mins attached to the PVM via the new cable and the 130XE when attached was immediately in the same state it would seem -- instantly killed?
    I have a 800XL PAL board incoming next week. Obviously won't touch this PSU or that cable to it until I get this sorted.
    Not a happy Christmas present. Ugh.
    bp
