Taijigamer
    141
Posts posted by Taijigamer
  1. This gets me right in the feels. Knowing what I know now, I would have kept all my games and consoles. I lost a model 1 mega drive with 32X, 2 x Sinclair Spectrum 128k, a ps1 and N64 to the void. I sold it gave away a lot of my mega drive and ps1 games in a move towards emulation and modern gaming. Now prices have rocketed and it's not as easy to re-buy everything.
    I have started to rebuild my hardware and hard copies again in a bid to reconnect with my childhood (mid life crisis looming). I have a megadrive model 2 with 32X and Mega CD, 3DO and Dreamcast from the pre 2000 era in my collection now. Still need to get a Colecovision, Saturn and Jaguar, and re-buy a Spectrum 128k.
    I would also mod my consoles for optimum video/audio out and any other enhancements.
  2. YCbCr refers to the digital format. YPbPr refers to the analogue format. As previously said, when talking about video games consoles, YPbPr is used. Digital YCbCr is probably only seen in industry use, ie filming, medical imaging etc. Our medical monitors used for key hole surgery have all the inputs (RGBS, YCrCb, RGBHV, DVI, HDMI) in individual BNC connector format (except DVI and HDMI).
  3. That product is probably good for a cheap option but it only upscales CVBS and S-Video. When we refer to Frameister and OSSC we are looking at upscaling Component video (be it Y,Cb,Cr or RBGS/HV) for best possible picture quality.
    The OSSC is a good product from my point of view. Half the price of Frameister, open source, well supported and offers many input options (Scart, Component, VGA). It also offers a lot of settings to get the maximum picture quality out of your favourite consoles.
  4. Yurkie and citruspsi3000 mods both take Y, R-Y, B-Y signals directly from the VDP and convert them into RGBS using timing pots, op-amps and discretes. The designs are based on this application note http://spatula-city.org/~im14u2c/vdp-99xx/e3/SPPA004A_9928-29_9118-28_Interface_to_Monitors.pdf
    There isn't a complete IC based mod available yet. Check out citruspsi3000 RGB mod, comes as a diy kit, easy to install and it's better supported.
  5. The Colecovision TMS9928 VDP naturally outputs a type of Y, B-Y, R-Y (Y, Cr, Cb). This thread https://www.classic-computers.org.nz/forums/viewtopic.php?f=11&t=960&sid=94cad79b4533d005683a0ce186363544explains a few different ways to transmit that to a TV over Component video.
    For a ready made solution check out citruspsi3000 RGB mod http://atariage.com/forums/topic/274474-new-coleco-rgb-board/
    This should solve your B/W picture problem.
  6. I thought the kanji rom needs to assigned to 'Font ROM' and then a known bios rom used for Bios, in phoenix. Maybe the same for SAOT. Phoenix may treat anything from ROM2 as the 'FONT ROM'.
  7. Check the power connector at the back of the console, the plastic housing will tell u what revision it is (check online). A jasper psu won't connect to a Falcon board because of the connector housing. If u are having to throw so much cooling at it then there is something more going on. What heatsink paste did u use, are the heat sinks making good contact? Are the x-clamps still in situ?
  8.
    I found the identity of some pins (Vcc, Gnd, NC) by looking at the board, and tried all ICs with that pattern brute force. None are direct swap, as the identities which allowed me flawless reading all assumed 3.3 V while the real chip is run at 5 V.
    I have to take a look for a header^^
    On the decryption: That's why I read the chip. I remove the code part that prevents encrypted data to be read by the console. I think my 44SOP PCB would have been the next step, made for arcades. As with the Japanese PCBs you had to decide for Kanji OR Arcade Bios, while the 44 SOP PCB has the 32 SOP solder pads free for future add ons.
    Wow that is dedicated. That's a cool project. I've PM'd you some info that may be of use. If I have any more info I will post in your hardware thread so as not to digress this thread.
    I can't find the photo right now but the testing system I saw had the retail bios in one spot and the testing bios in the normally empty / Kanji spot. The switch enabled one at a time.
    Thank you for the really useful information. It would be interesting to see inside the console to see how the switch connects to the ROM chips. Is CE lifted or does it use the connector pads in between the 2 chips?
  9. Glad you were successful. How did u find the pinout of the chip? I can't find a datasheet online. Which chips did u find as direct swap?
    Interestingly, the FZ-10 has a 6 pin header near the bios rom which may allow ICSP programming of the bios or Rom2 at factory. The FZ-1 has some solder points as well which seem to connect to the ROM1 or ROM2.
    If you are successful then it will be possible to flash any rom we want to the 3DO. There is a 3DO testing station which has a switch on the back for switching between encrypted and decrypted code. I haven't been inside one to see but I would guess it has 2 Roms piggybacked with a switch.
  10. Hey you 3DO enthusiasts. Has anybody of you read the 3DO FZ-1 SOP44 Bios? That's the one with the Kanji included. I tried today, but a leg broke off :-(
    How were u trying to read the ROM chip? I tried to find the datasheet on the ROM chips but couldn't find anything. I found a Kanji rom online which I use with phoenix emulator. I'm assuming its the same SOP44 compatible rom. rom2.rom
