164 -
Posts posted by Lavalamp
Depends on whether "map1" is a ROM data statement, or some bytes of RAM. plotmap works with both, so I can't tell what you're doing from just the plotmap command.
If it's ROM (ie. "map1" is the label from a data statement) then you can't pokechar. If it's RAM, then sure.
For a ram-based plotmap example, there's a "ramcharmap" in the 7800basic sample directory.
I'm using the below is this RAM or ROM?
incmapfile level_1.tmx
Im thinking about swapping to using data statements so I can have colored tiles and tiles I can modify.
Assuming "map1" is a ram location, you don't have to re-plot. You can just restore the ram contents however you populated them in the first place. e.g. plotchars, memcpy, etc.
This was with the plotmap map1 0 0 0 20 12 can i not use pokechar map1 TileX TileY 20 12 $30 to flip a tile?
resolved my missing rat issue
Another question the if you use the POKECHAR do you need to then re-plot the screen and save it again for the restore command? this is to change a tile.
Have you imported multiple 'rat' images? The frame parameter is optional but depending on what's in the ratFrame array it might be drawing an empty image.
Also keep in mind that large x and y values will 'draw'the sprite outside of the visible screen area
Its a bit weird, yes has multiple images, I only briefly looked at it last night, Ill do some more troubleshooting over the weekend.
You can use plot any given sprite image as many times as you like.
In your example you don't modify the x and y in the loop, which would result in 5 "enemy" images at the exact same location. Maybe that's your issue?
Thanks was just a quick type up, i'm not seeing any turn up at this point.
code is:
for check = 0 to rats tempX = ratX[check] : tempY = ratY[check] tempFrame = ratFrame[check] plotsprite rat1 4 tempX tempY tempFrame next
Works for me. I did a quick sanity check...
a=5 b=0 if a=5 then for x = 0 to 3:b=b+2:next displaymode 320A main clearscreen plotchars 'b=' 0 5 0 plotvalue ascii 0 b 1 16 0 drawscreen goto mainWhich spits out "b=8" if a=5, and "b=0" otherwise, as expected.Thanks for checking
Also with sprites I have made an assumption that maybe wrong....
For num_enemy = 0 to 4 plotsprite enemy 0 x y frame next
Can you only use the image once? The guide doesn't specify this. cheers.
Can you not have a FOR NEXT loop after a THEN statement with 7800 basic?
The "soundtest" program in the 7800basic samples directory has 25 different sound effects. You're welcome to use them as-is, or modify as you see fit.
I don't believe anybody else has released a TIA sound-effect library, for the 7800 or 2600.
Fantastic, Ill check this out. Thanks!
Has anyone created a sound effect library for use in our 7800 Basic projects?
thanks SmittyB that makes sense, so the below gives me five instances of enemyX?
dim enemyX[0] = var1 dim lives = var6
Hi, I'm having issues with implementing arrays in 7800Basic, the online manual appears to have an example that makes no sense to me, it doesn't show how to declare an Array?
http://www.randomterrain.com/7800basic.html#dimensioning_variable_names
Variable ArraysRegular variables can be accessed as arrays in 7800basic. Doing so will access memory locations next to the variable in question.
The following sets variables "a", "b", and "c" to 0.
a[0]=0
a[1]=0
a[2]=0
Using array notation will allow you to loop through elements without a lot of duplicated code, providing you've used dim to place the elements side by side in memory.I assume to declare its like my example below?
dim enemyX[0] = var1 dim enemyX[1] = var2 dim enemyX[2] = var3
this means I can loop through them like this?
for temp1 = 0 to 2 if enemyX[temp1] >160 then enemyX[temp1] = 0 next
Also...getting the _length of data appears to be unclear to me, I get an error about it been before the data statement or something...
Hi Mike, could you add "and" and "or" for the interpreter?
You are correct in thinking that drawscreen should be called after you've finished plotting everything for the frame. It does a bit of setup and waits until the screen finishes drawing which is where your delay might be.
I think what might be actually happening is that the rest of your code takes slightly too long so that the 7800 is already drawing the next frame before drawscreen is called, so drawscreen would have to wait for the screen to finish, wait for vblank to finish, and then continue at the start of the NEXT frame.
A strategy to make the most of the time you have on each frame is to have all of your logic at the start of your loop, then restore the screen, then do all your plotting, then drawscreen. What you don't want to do is have anything graphics related near the start because 7800BASIC will wait for the screen to finish drawing before making changes to prevent the display being scrambled while it's being drawn, meaning all your code has to finish within the small amount of time that vblank takes.
For example, if your drawplayer routine does anything not directly related to drawing then that code can be run earlier in the loop during the visible screen time leaving just the plotting to be done between frames.
Thanks I will re-engineer the code based on your recommendations, makes sense. I'll introduce you guys to my game Morph once I have the basics controls and collision detection working. Thinking about it I think my STOS Game Makers manual has a good example of this.
If you're just using plotmap then unless you're redrawing the display over and over it shouldn't have much of a noticeable difference. If you're using plotmapfile then that's another story, because plotmapfile allows drawing tiles with different pallettes it has to manage a new object for each pallette change.
It's hard to say what the problem is without looking at the rest of the code but it shouldn't just be because you're using a tilemap.
The DRAWSCREEN command below was the culprate, I thought this needed to be called after plotting sprites?
main_loop BACKGRND=$00 restorescreen globalFrameCount = globalFrameCount + 1 if globalFrameCount = 30 then globalFrameCount = 0 if globalFrameCount = 15 then gosub moveplayer gosub drawplayer rem drawscreen goto main_loop
Thanks that's what I conlcuded, but its performing badly with the tile code removed so something I have introduced has done something. But its pretty clean early code so dunno. I got the map to appear so CHARACTERSET was the missing piece thanks! I didn't know that PLOTMAPFILES allowed the multi pallette support, nice!
Awesome thanks guys. Also can I expect a huge performance drop when using a tiled background? I only mention this because I had the global frame counter drop from 60 to 10 to get the speed up again :/ might be my code though.
Hi Peeps, having issues with getting tiling to work, the below results in a black screen...what have i missed? The Map has tiles set to emended and is XML, 8x16, and 20 x 12 in size. Thanks guys.
set doublewide on set basepath gfx_morph set romsize 48k set tv pal displaymode 160A rem Color Palettes P0C1=$02: P0C2=$06: P0C3=$0F : rem grey, light grey & white rem Graphics Import incgraphic tileset_level_1.png incmapfile level_1.tmx main_init clearscreen plotmap level_1 0 0 0 20 12 savescreen drawscreen main_loop BACKGRND=$00 restorescreen drawscreen goto main_loop
Your dim of ufoFired is "Var11", but it should be "var11"
thanks RevEng, the common issues above also helped me track down another issue. Still have something else wrong it now boots to a black screen. -
Thanks guys, I do have one perplexing issue, Ill try to get to the bottom of it and post what I find, after copying all my code to a test file and removing blocks of code out one by one, discovered doesn't like the line highlighted with <<<..
rem Invaders set doublewide on set basepath gfx_invaders set romsize 48k set hssupport $7272 : rem temp UID for Game. displaymode 160B dim frameCount = var1 dim invaderX = a.b dim invaderY = var2 dim invaderFrame = var3 dim invaderCount = var4 dim invaderMove = c.d dim playerX = e.f dim playerY = var5 dim playerShotX = var6 dim playerShotY = k.l dim playerFired = var7 dim playerSpeed = var8 dim moveX = g.h dim tempX = i.j dim ufo = var9 dim ufoX = m.n dim ufoSpeed = o.p dim ufoFrame = var10 dim ufoShotX = q.r dim ufoShotY = s.t dim ufoFired = Var11 dim midX = var12 dim midY = var13 const true = 1 const false = 0 const screenH = 192 const screenW = 160 P0C1=$02: P0C2=$06: P0C3=$0F incgraphic player.png incgraphic player_shot.png incgraphic space_invader1.png incgraphic space_invader2.png incgraphic ufo1.png incgraphic ufo2.png incgraphic ufo3.png incgraphic ufo_shot.png incbanner paused.png maininit clearscreen midX = screenW / 2 midY = screenH / 2 playerSpeed = 0.1 playerX = midX - 8 playerY = screenH - 16 invaderX = 0.0 invaderY = 16 invaderMove = 0.2 invaderFrame = 0 frameCount = 0 moveX = 0.0 invaderCount = 4 playerFired = false ufo = false ufoSpeed = 0.6 ufoFrame = 0 ufoFired = false <<< ufoShotX = 0.0 ufoShotY = 0.0 savescreen drawscreen ...
A
There is no physical difference at all.
..Al
Awesome thanks!
A question on timing of sprite movement in 7800Basic, I traditionally use decimal for controlling speed. 7800Basic supports this, but is it better to use a frame counter to trigger a move? Recommendations welcome! Thanks.
Speed = 0.2 X = X + Speed
Apart from the ROM code is there any other difference between a NTSC and PAL 7800 cartridge? I can use NTSC donors for my PAL projects?
I was pondering on a wireless solution (think WiFi antenna). Bunch of work though, both hardware and software, hard to justify for less than 10 people who actually use it.
Would be 11 if you still had some...
7800 Basic
in Atari 7800 Programming
Thanks heaps that makes things a lot clearer
I need to re-look at maps and re-engineer my game, there was a PLOTMAPFILE.BAS sample that shows three tilesets being using for multiple colours which appeals. I saw that SCROLL.BAS too which is amazing and would match my platformer well.
