Allas
    1,102
Posts posted by Allas
  1. G2F is a great tool, it helps a lot on many ways on developing new software.
    On the other way, it's hard to manage all the complex ANTIC/GTIA graphics modes. With time, i'm sure this tool will increase with interesting options.
    As a game programmer I always need some little features on G2F:
    - In BMP mode I can crop areas, copy or move on other places. This copy/paste feature only work with char offsets (4 pixels), i usually miss there is a option to move easily the crop zone on 1 pixel by 1 pixel.
    - On EDIT CHARSET (ALT+H) window, i usually want a line the show the 8 hex values for the character selected on screen. Usually I want to select the values to insert on my programs. Actually I have to find on the fnt file, but it's tedious.
    - Another great step would be to support SuperIRG+ modes, this needs 2 G2F screens alternating by VBI. I think it should be easy to support, really it's hard to do without the appropriate tool.
  2. You need to use another layer of graphics with his own DL with new colors and set font.
    Example: MONEX
    I checked MONEX (nice game by the way :) and other examples based on flipping screens... MONEX looks nice on emulator... How clean is picture on TV ? Does it flicker?
    Checked Master of Lamp - where is that horizontal split ?
    Interlaced modes works better on Atari systems than others. Using the combination of colors with same luminance you reduce the flickering practically at nothing. There are some good examples of interlacing screen as CAPTURE THE FLAG (yes the 3D maze game, look the sky), VULCANO.... not really SuperIRG mode, because there isn't a editor for this type of screen still. However, I'm sure there are many examples that use interlaced effect and nobody can suspect when playing.
    To get a G2F Editor capable to work interlaced screen will be incredible. On the other way, we have a great tool to paint interlaced screens called LEPIX (http://lepix.sourceforge.net/)
    So basically, there is no way to show more than 5 colors in one row without interlacing (mixing frames) or using player-missile graphic over background ?
    If you refer to a Basic Atari Graphics 12 screen mode (Antic 4), then yes, only can get 5 color per horizontal or vertical line. Off course, without using poke commands.
  3. Is there a "better" mode or a trick that can show more colors in one line (but with the same resolution - 80 pixels in line is to ugly... )
    http://www.newbreedsoftware.com/sife/
    That is a charset editor for "SuperIRG" mode. This mode is a relatively low-demand software charmode that allows 10 colors per line without resorting to DLIs. It uses a VBI to switch between two "graphics 12" IRG charmode screens.
    Actually, 15 colors if we consider the 5th color on combination.
    And 17 colors if we use another 1K map for screen.
  4. ... Truth takes no sides. It is what it is. If you follow the truth, then it appears truth is on your side. Fanboyism comes out of people when they find out truth is different from what they thought and they don't want to change but somehow use some way to defend themselves.
    You can find a lot of factual remarks in this thread from many people.
    I would like to know one more fact from the people who know Atari hardware ...
    I spent more than few hours reading about Antic,Gtia and whole atari graphic subsystem, and I would like to know if I got it right:
    As I'm thinking of making something nice for Atari I would like to use 160x192 resolution in as much color as I can get.
    Char mode (Antic 4) in multicolor looks like the most promising candidate.
    "So the four-color character modes treat the bits as pairs, so that two bits control each dot on the screen...
    The five colors. Each bit-pair has four possible combinations: 00, 01, 10, and 11. These correspond to the decimal numbers 0, 1, 2, and 3. A bit-pair with the value of 00 will cause the background color, stored at memory location 712, to be displayed. A bit-pair with the value of 01 will display the color stored at location 708; the bit-pair 10 (decimal 2) will display the color at location 709; and the bit-pair 11 (decimal 3) will display the color stored at location 710.
    There is a fifth color available. If a character is entered into screen memory in inversemode (the character number plus128), then any bit-pair 11 (decimal 3) in that character will display, not the color at 710, but the color at 711. This means that if you plan your character set carefully, you can have five colors on your screen at one time."
    so colors behave like this:
    1. 00 - color1
    2. 01 - color2
    3. 10 - color3
    4. 11 - charno <128 - color4
    5. 11 - charno >127 - color5
    So no character can have color4 and color5 inside the same byte ?
    And in one whole screen line I can use only those 5 colors ?
    Can these colors be changed in the middle of line and how much cpu intensive it is if it can ?
    I guess they can be changed using interupts after every vertical line... Thats how games get those shades of sky....
    I looked at screenshots of "Crownland" and I counted only five colors in one horizontal section.
    Example: MONEX
  5. Well, my way to do the last scene is:
    1- Main character Turrican use sprites
    OK.
    2- Grand Boss Enemy is done it with chars at 4 colors, i use the scrolling the Atari Hardware scroll to move the chief across the screen with fast speed. I don't remember, but if the boss moves, then i change the pointer of font set to give fast animation.
    OK.
    3- The background are the rest of screen with chars, and I use ROL/ROR and move vertical lines on those chars to get a scrolling that neutralize the main scroll of the boss. In this way the background stay quiet and you have the illusion the boss only moves across the screen, fast and easy. I use the 5th color for background to give a smooth color.
    It's a first approach, but I think it could work.
    I just checked the boss scene on youtube and it looks like this:
    Big boss (15 chars wide and more than a screen high) made out of sprites (3 colors).
    Background made of chars (couple of colors - not so important - a pattern made out of 4x4 chars.
    So you can do the rol/ror, move thing on that pattern and background is done... but for the chars that boss sprites are not covering...
    You could make "Occupied by boss chars" black... (like a shadow to avoid color clash on speccy) and that would be it.
    Or you can (rough estimate) mask out the char on the left side of boss and the far right char of the boss correct (proper masking, or sprite data ...etc...).
    That would make 20 rows times 2 chars =40 chars or more of data processed with shifting and proper masking....
    I think Atari could do that.
    But what about the scene in wich the boss shows up for the first time?
    Hero is flying upwards across background (some kind of a tower with a "fence" behind him) and than this gigantic robot comes from the bottom and flyes past you behind that fence !
    http://www.youtube.com/watch?v=veR1q3bhBms...feature=related
    (look at 6min 48 sec)
    Than you would need to properly draw 20 rows of aproximatly 15 chars = 300 chars ... fortunately no shifting needed :)
    Just the lda and ora sta ....
    I think some of you coder guys could calculate it or compare it with some demo or game that is doing the same thing (if that kind of thing was ever done)....
    So how do we do big characters over background on Atari?
    Is there a game or a demo that shows it ?
    It's a different challenge, but not more difficult. The borders are tiles that could move down changing set font pointers. Boss moves up thanks to hardware scroll, and the narrow fence could be Atari sprites to give the appearance boss is behind. As I can see Turrican character doesn't move, so it could be a software graphic for this effect transition. Rest of the level is the same.
  6. atarksi: You don't need to touch DMACTL.
    Since you have a scrolling region, the VScrol tweaking just makes Antic think it has to keep displaying the same data. The trick is to not let VSCROL equal the Delta Counter.
    Interesting. This Delta counter is a internal register on ANTIC? I suppose it can't be changed with a program.
    This trick affect the data sprites too?
  7. The Atari 65/130XE are fine machines. The Commodore 64/128 are fine machines. I grew up on CBM and so naturally prefer it. But even now, all to me that matters are the results that I can obtain on a retro machine (real or emulated). For example, I could play Snow Bros. on the emulated Sega Genesis/Megadrive, but I'd prefer to play it on MAME. If I wanted to get into Elite (which I may one day), I'd play the best implementation on whichever machine provided it... "loyalties" aside. The point for me is looking at what software is available on a machine (from any manufacturer), not theoretical capabilities.
    That all being said, I couldn't resist contributing to the Pencil Wars :-D
    Standard multicolor mode, 160x200x16.
    Good work!
    I love all pencils examples.
  8. Good work, just what is need to start a good port of tetris.
    The PM overlay consist on 4 layers of Player+Missile (10 pixels wide) at the maximum wide. You need an OR effect of player + background and you have 6 colors per block (with his own 2 extra color for border shadows). On the graphics you waste 3 colors for black background+grays for shades, and finally you have 2 colors free (for background, or additional color blocks or a mix of both)
    Maybe you could start to add on you own graphic the 4 layers of sprites covering all the ingame area.
  9. @atariksi: Sorry for misunderstanding :P
    Take a time to think, the last boss on Turrican II could be done with chars on Atari with the background.
    What do you mean with "Chars with background ?"
    Just to clear out - this is a tech question and there are no hidden meanings in it :)
  10. "Atari strength over C64: Larger palette and ability to put a boatload of colors on screen: Argued useless."
    I asked simple question "example of a game that would suffer in terms of playability with less colours" and even stated that Im not looking for Atari game... Any game... Be it on XBOX, SONY or PC or Flash or on Paper or with sticks and ropes if you like....
    Maybe wrong place to ask it, but I expected people can read that one row as a question and answer if they know...
    In my language if sentence is finished with "?" it is called a question and not a statement. Please don't search for hidden meaning. I think Im honest man and wouldn't try to mess with anybodies feelings.
    If quantity and quality of colors are not important on a design game, then Sinclair ZX Spectrum is the #1 of all 8bit computers, because their games were very advanced for his time.
  11. THE CITY is the best version of both. There are more factors inside the game, the music is better on THE CITY, really I remember those detailed graphic effects and the music create a Terrific ambient.
    On DUNGEON version the game was a port, so colors were reduced to 4,5 on screen. The game overall was convert to a "arcade style". I think is an excelent game but not as brutal as THE CITY (on Atari computers I said), maybe other computer found DUNGEON the best game. However the DUNGEON Atari version looks as the C64 version, nothing more, nothing less.
  12. I don't understand the point of asking to see a game that couldn't be reproduced on the Commodore 64, then being shown some that are obviously too colorful, then saying that the gameplay wouldn't be affected by the Commodore's restricted pallette. WTF?? Colors ARE the Atari advantage. What kind of sense does this questioning make?
    English is not my native language so maybe I should use whole sentences instead of one word.
    "reproduced" in my vocabulary does not mean 100% correct replica.
    For example if you would show me on Atari, Turrican made in 4 colors, but with the same game mechanics, weapons, enemies, speed... I would be cheering! :D
    Have you seen boss at the end of C64s Turrican 2 ? its 2 screens tall, 15 chars wide. And its not made of characters... Its made of sprites so it flies over and under colored background. Is there a boss like that in any game on Atari... I haven't seen one.
    But if you show me a game that has 256 colors and plays like poo... :ponder:
    And than reduce number of colors to two.... and it still plays like poo.... well thats a difference Im ready to ignore...
    Guys..... maybe Im just saying gameplay is more important than number of colors on the screen.
    Yoomp is a great example of this.
    Take a time to think, the last boss on Turrican II could be done with chars on Atari with the background. Always there is a solution to do some things. Don't expect that should be done at the "C64 style"
    Colors and gameplay are important on games. And the color experience not only has perceive counting the amount of colors per frame. It count too, the variations of colors along the gameplay, borders, change of colors between levels. If you count all this, for sure Yoomp have to count more than 64 colors for all gaming experience. A C64 gaming experience only give me 16 colors per game, so I finish the game and don't feel I have a great experience about the colors.
    As I said before we Atarians looks some C64 games as tha smae way you C64 users look the Spectrum games. The palette is not enough, and most of the games have ugly colors, if it not, there are combinations that has been used thousand of times before.
  13. Parallax scrolling on Flimbo's Quest is simple, even there is a demo on Atari replicating just the Flimbo screen with the parallax effect. There is nothing there (and on other parallax effects) that cost any cycle more on Atari. Is a technical resource perfectly viable for both computers at the same cost. And I'm referring to the parallax scroll with shift fonts. If you are trying to talk about multiple scrolling of different lines, Atari is a clearly winner there.
    Could you please point me to that demo. Would love to see it.
    It was a quick test from Heaven if i don't remember bad.
    But, what's the point? What do you expect to see there?
    Any computer that have ROL or ROR assembler command could do Parallax scrolling. Other programmers use banks to change the set font and do more complex parallax scrolls.
  14. As for those pencils (either vertical OR horizontal) - try adding a sprite that doesnt merge into any part of it as it crosses the screen on the C64 (and no, drawing a big ugly black outline around it won't cut it here)
    lol. Try adding sprites flying around on top of the Atari vertical pencil image, full stop. It's already multiplexing a bunch of PMGs to get those colours (with only 10 pencils, might I add). Meanwhile the c64 one could have a whole flock of sprites flying round the screen... but oh me oh my... at certain points one or more of the colours in a sprite might be the same as a line of pixels in the background under that sprite, so it is all ruined. Ruined I tell you! I'd rather have no sprites left than have to put up with that!
    Obviously an Atari game designer use the horizontal pencils as background, is ridiculous to choice the vertical pencils design for a game on Atari. However, the sprites on C64 easily mixed on the background, so you need to reduce the 16 colors of you background at least at 13 to avoid this problem. Less colored pencils, but work still.
  15. You have to read the first 2000 posts
    Im not going to read those, thank you.... :) Want to finish Yoomp for c64 this year thank you... ;)
    What's improved with more colors in these games?
    Why did you show basketball? does it have more than 16 colors? I counted 8-9...
    Sky fading effect is nice on three pics... but does it have important influence on quality of the games?
    Im more impressed with 3d wolfenstein like graphic on the far right pic.
    And what's with two pics on the left? what is it...
    My question still stands. Is there something like parallax scrolling from C64 Flimbo's quest or Hawkeye on Atari ?
    I found this:
    But its rather simple...
    p.s. This is response I like. Show me pics, show me vids of something that I haven't seen so far...
    p.p.s. Excuse me but I really don't have time to read all plus 200 pages of this... :)
    oh sorry, but, you arrive too late. Actually Atari->10 C64->1
  16. LOL?
    Lets focus on palette and clarify that what I tried to say:
    Show me a game on Atari that used its color palette to improve gameplay in such a way that it couldn't be replicated on Commodore gameplay wise.
    You have to read the first 2000 posts.
    But, I can put little examples that cant beat on C64:
    Basketball
    4 players every one with his own joystick can play simultaneously
    Bumpomov's dogs
    Has a nice split/join screen ingame. Every window with his own scrolling 4 direction.
    Triple screen shooter with many colors
    Capture the flag
    Nice dual window for 3d game for 2 players
    Alternate Reality
    The best 8bit adventure 3d with lot of colors
    Midi maze
    First fps on 8bit computers. Could be connected on net with others Atari computers, including 16bit Atari ST.
  17. @MaPa: Very nice indeed... :)
    ...but someone has stolen one of your pencils! Well, you can borrow some of mine if you like.
    It's OK... I have plenty! ;)
    Still standard multi-colour. If I was doing this seriously, I'd consider switching to FLI mode to let me handle some of those shadows with greater flexibility.
    This picture is out of the possibilities.
    If a background of pencils would be necessary on a game, for sure C64 choose this picture and Atari his first horizontal background. Both look nice, and every one have his own advantages against the other. Every computer has his own advantages according his internal design, this test not show how good is Atari or C64, also show how insufficient are both systems.
  18. Good work Mapa, looks very colorful.
    Well, Archon on C64 is not like the Atari version, but it a reasonable porting. Really, I don't think there is a game that can be do absolutely only on a machine. Every piece of software, can be enhanced on certain areas according to the specs of the machine.
    Enforcer II is a production created for a C64, and is well brained for his features. It's a good game, but I don't see why it couldn't be ported on Atari. Most of the details are tricks well known. Despite some technical difficulties on emulate sprite, rest of game was easy to emulate and can be enhanced with more colors than the C64 version. Personally I think C64 did a bad choice to work this game on hi-res because loose quality, maybe is good to see a game shooter at hi-res on a c64, but looks like a spectrum shooter. It could be valid because there are not many shooters at high res on C64, but I think it could be done with better aspect on mid-res.
    Maybe someone could say what is the spectacular thing on enforcer that did the difference with others C64 shooters. The multiple parallax? the giant rock moving? the overall hi-res graphics?
  19. Not exactly paddles, but this fun game can be played with an Atari ST mouse. It feels better.
    padnoid.zip
    Padnoid
    Do you have to press anything to select the mouse or is it auto-detected?
    On a real machine, you need only to connect the st mouse. But i have not tested.
    On a emulator\, you need to configure the PC mouse as ST mouse. ONce enter the game you should press F12 to active/desactivate ST mouse simulation
  20. Not exactly paddles, but this fun game can be played with an Atari ST mouse. It feels better.
    padnoid.zip
    Padnoid
  21. Here's one for you to convert to Commodore 64 colors:
    How would this one look on C64? Someone proceed!
    Oh... I remember years ago this demo, thank you for posting!
    If you have the xex file, it would be welcomed to my collection.
  22. I use GTIA modes mostly and original argument of color depth favors Atari since it offers 16+ colors for more pixels than C64. Here's a sample executeable that will put up different color for every pixel in the scanline for GTIA modes. Theoretically, this does 7 different 16-shade palettes per scanline with player #5 for another 16 shades, 4 players for another 6 colors = 134 colors/scanline from palette of 256. Since there are only maximum of 96 GTIA pixels/scanline, you end up with a different color for every pixel. You can also switch to other GTIA modes or Graphics 8 at any of the 7 points where modes are switched. There's the fifth player scrolling around on top of the 112 GTIA colors and 6 colors of 4 players in the overscan area:
    Hi, I'd like to take a look at your file... but I'm not really familiar enough with the A8 to know how to run an IMG file. I tried changing the filename extension to XEX or ATR and running that in the emulator, but no luck. What do I do? Thanks...
    It's just a boot disk with sectors saved as an IMG file. It should boot right up if you can write it to a floppy disk or run from a disk simulator. It does not have any header so don't rename it to ATR. I don't use emulators so don't know what it's problems are but CrazyAce was able to run some previous image disk I posted with an emulator.
    By the way, the above shows the 9 of the 16 chromas with up to 16 shades without dithering or interlacing. Those are solid colors in that program.
