427 -
Posts posted by wolhess
34 minutes ago, FALCOR4 said:When I started with your files I also got the same DSR errors. Another clue, maybe, is that each one of the files generated an error when I loaded them using the E/A editor but, they loaded. Then I saved them back out which was successful. Let me try again this weekend and I'll be a little more methodical this time. This shouldn't be happening. Question, what did you use to create the source files?
So, I tested right now to load the source files from the tipi device and stored it to the HRD with an original E/A cartridge and the EA disk in DSK1.
And now it works seamless!
Then I put the FG99 in and made the same with the TI E/A.bin and it works too.
Next I used the E/A version V to load the files from tipi and stored it to the HRD and this now was also working.
In the last day's I used DM2K v3.0 to copy the files from tipi to the HRD. So I did this now with my original long file names and I used the E/A V .bin. In this try the ERROR appears again!!!!
Then I edited the long DSR file name to 8 character and tried it again and the DSR ERROR was there.
Next I edited all the files with EA-V. and got an error while saving the file "99SUB2-S", so I saved it to 99SUB3-S and changed the main source file too. Now it assembled without an error!
All in all my problem is fixed.
I think I had two problems.
1. File names with more than 8 characters could not be assembled on the HRD.
2. Maybe DM2K v3.0 cannot copy files from a mapped tipi folder to a HRD drive with 3.200 sectors.
Anyway: Thank you to all for your suggestions and thank you @FALCOR4 for the right idea to check the source file itself.The files from post #1 contains the wrong files, if anybody will try it again. After editing and saving with EA editor, the program can be assembled without errors.
@InsaneMultitasker should I try the ROS814F? I think the ROS is not the problem I had. It is possible that two files were damaged when copying from the tipi folder to the HRD drive formatted with the 3200 sectors.
Thanks again!
2 minutes ago, InsaneMultitasker said:would you mind formatting your RAMdisk with ROS 8.14F then trying the same test?
Yes, I can do it with the ROS 8.14F.
1 minute ago, FALCOR4 said:Question, what did you use to create the source files?
I'm using the EA version V cartridge bin (the FG99 version) to edit and to store the files.
I will edit and save all with the EDIT of the original E/A cartridge and then test again.
I can also use the TI Writer and save with PF to disk.
So I will test both!
On 10/25/2020 at 3:33 PM, GDMike said:Just FYI...
What I do when I'm assembling on real steel. I don't.
What I mean is, I like writing my code using the TI but not assembling with it.
I'm mapped on my laptop to my share on tipi using classic 99, and I place CL99 in overspeed and assemble that way.
Just my way...
Sometimes I use my PC to compile or assemble some stuff, but mostly I will use my little old TI computer even for some serious program developing and learning assembly.
It's my hobby!
On 10/24/2020 at 8:52 PM, FALCOR4 said:I renamed your source files to have 8 chars or less in the filenames and they assembled ok. I put my HRD4000B at CRU >1000 and assembled your RFILE_S9 (I changed the name slightly) and it assembled, with list and cross table, in 1m 15s using the E/A assembler.
Hi,
I renamed my files to a three letter name but always get the DSR ERROR:02F4!
I tested some ROS versions 8.41, 8.42 from 2/16/20 and 8.42c from 3/14/20 but with the same DSR ERROR.
So yesterday I made all the three RAM tests provided with the HRD4000B card. All tests passed without an ERROR.
Then I configured the HRD completly new and configured the RAM Disk DSK9. with 3200, 1600 and 800 sectores. In any case I got the DSR ERROR.
So it seems on my PEB configuration the HRD DSR has this problem all the time.
My PEB configuration is:
CRU:1000 TIPI Device
CRU:1100 TI Floppy Controller with 80 TRACK mod.
CRU:1300 RS232 and PIO
CRU:1700 HRD 4000B with RAMBO RAM
CRU:1E00 SAMS card 1MB
I used the original E/A cartridge, the E/A complete cartridge from Tursi, the EA version V from Fred KAAL and the RAG Macro Assembler.
All Assembly is working on the tipi device or on the real floppy drives.
The assembler process begins on the HRD up to the point at which the first COPY command is to be executed.
At this point I am getting the DSR ERROR:02F4 (refers to an error reading a display variable file = the COPY source file I think) -
1 hour ago, FALCOR4 said:That's interesting. I wonder what's going on, I assemble source code using the HRD4000B with COPY commands all the time. I have used both the TI assembler and the RAG assembler. This deserves some sleuthing.
maybe it is because I have a tipi card on cru = 1000?
Hello,
In the past three weeks I've started to write a program in TI Assembly language.
Now that some routines work, I wanted to know which system configuration on a real TI is the fastest for assembly.
I tested on two different sysytems:
System 1:
TI Console mit FG99
PEB mit TIPI/RPI (CRU:1000)
TI Controller mit 80 Track mod (CRU:1100)
DSK1.= 5,25" Drive DSSD 360KB
DSK2.= 3,5" Drive DSSD 360KB
DSK3.= 5,25" Drive SSSD 90KB
HRD4000B mit ROS842c v. 14.03.2020 (CRU:1700)
1MB/32KB SAMS
Speech SynthesizerSystem 2:
TI Console mit FG99
PEB mit CorComp DSDD Controller
DSK1.= 3,5" Drive DSDD 360KB
DSK2.= 3,5" Drive DSDD 360KB
DSK3.= 3,5" Drive DSDD 360KB
DSK4.= 5,25" Drive DSDD 360KB, compatible with SSSD 90KB
32KB RAM
RAVE99 Speech Adapter with TI Speech card in PEBFor a total of 22 tests I used the following test program:
My test program is a simple DV80 file viewer. You can input any DV80 file name
like "DSK1.TFILE" and the program shows the file page by page in 40 column text mode.RFILE1-S contains three copy commands for the files DSK2.99DSRLNK-S, DSK2.99SUB2-S
and DSK2.99VDP4-S. DSK2 is my TIPI directory!RFILE1-S1 loads the copy files from DSK1.
RFILE1-S4 loads the copy files from DSK4.
RFILE1-S9 loads the copy files from DSK9.RFILE2-S contains all copy files in the main source file.
I gained the following findings from these tests:
1. The TIPI / RPI device offers the fastest working environment on a real TI system.
2. Compared to a floppy drive, the TIPI device is 5 to 7 times faster, depending on the controller!
3. Dividing the source files into several files increases the assembly time.
4. Splitting the files over several drives increases the assembly time.
5. A 5.25 "drive is slightly faster than a 3.5" drive.
6. The Ramdisk HRD4000B with the ROS842c cannot execute source files from a COPY command!
7. With the Ramdisk HRD4000B, the assembly took 1.3 to 2 times longer than with the tipi device.8. And of course, on a PC, assembling a simple program takes seconds!
My test program disk:RFILE.dsk
EDIT: Many thanks @FALCOR4 and @InsaneMultitasker, they found out that the problem with assembling on the ramdisk is due to a defective file header in the source files.
After the correction I can now show the complete results.
On my real hardware I can run the game also with CALL TIPI("DSK1.LIVINGTOMB").
I can also run it with CALL TIPI("TIPI.mypath.LIVINGTOMB")
If I run any EA5 game from a tipi maped drive I always see a floppy access on the real DSK1.
I‘m still waiting for the F18A mk2 to use 80 column on my TI.
If the SDD99 will be available, this is also an interesting expansion.
21 minutes ago, Casey said:There’s an excellent beginners assembly language book I just happened to read through that specifically brought up the subject of sound generation and the need for an LIMI 2/LIMI 0 pair in the main loop to make sound work. It’s aimed at the Mini Memory cartridge with the Line By Line assembler, but it had a lot of good information for a beginner in it. COMPUTE!’s Beginners Guide to Assembly Language on the TI 99/4A. You can find that I think on archive.org as a PDF. It might be worth taking a look through, even if you are planning to use Editor/Assembler.
Thank you very much ,
in the book the subject of sound is described in great detail. On page 167 it is also stated that the VDP interrupt should be switched on and off quickly.That was the secret that I didn't know.
I did not find this information in the EA manual. Neither with SOUND or KSCAN nor with SCAN or LIMI.
However, LIMI says that LIMI 0 is the normal state of the computer.
Your suggestion works.
Wow. I would never have figured it out on my own.
Thanks alot!
I will check this, Thank you.
Yes, you are right, that's how I did it, but then the program behaves exactly as I described it.
--> I changed it in the first message!
Hi,
maybe an assembly expert can help me, I'm just taking my first steps in assembly language programming.
I don't really understand the sound output. I have tried the example program "A CHIME" from the EA manual on page 321 and it works as it should.
Then I changed the program to produce a BEEP. This also works as it should.
However, if I include a keyboard query to repeat the BEEP with "REDO" and to exit the program with "ESCAPE", then my program only works for the first BEEP.
I come back to the EA with "ESCAPE". However, with "REDO" no sound is played and the TI gets stuck.
Even if I then reload and start the program in the EA, no sound is played. Only after a reset via the TI title screen the program is working again at the first run.Spoiler*
* Example program to play a chime
* E/A page 321-323
* Modified for playing a BEEP
REF VMBW,KSCAN
DEF BEEP
KEYVAL EQU >8375
STATUS EQU >837C
BUFFER EQU >1000
SAVERT DATA >0000
H01 BYTE >01
REDOV BYTE >06
ESCPV BYTE >0F
EVEN
BEEP MOV R11,@SAVERT SAVE RETURN ADDRESS
LI R0,BUFFER VDP-RAM BUFFER ADDRESS
LI R1,BEEPST BEEP SOUND TABLE
LI R2,8
BLWP @VMBW LOAD VDP-RAM
LOOP LIMI 0 DISABLE VDP INTERRUPT
LI R10,BUFFER LOAD SOUND TABLE ADDRESS
MOV R10,@>83CC LOAD POINTER TO THE TABLE
SOCB @H01,@>83FD SET VDP-RAM FLAG
MOVB @H01,@>83CE START SOUND PROCESSING
LIMI 2 ENABLE VDP INTERRUPT
LOOP2 MOVB @>83CE,@>83CE READY CHECK?
JEQ KEY YES, LOOK FOR A KEY PRESSED
JMP LOOP2 NO, WAIT UNTIL FINISHED
KEY CLR @STATUS CLEAR STATUS
BLWP @KSCAN PERFORM A KEY SCAN
MOV @STATUS,@STATUS A KEY IS PRESSED?
JEQ KEY NO, CHECK AGAIN
CB @KEYVAL,@ESCPV ESCAPE?
JEQ ESCAP YES, ->
CB @KEYVAL,@REDOV REDO?
JEQ LOOP YES, ->
JMP KEY NO, CHECK AGAIN
ESCAP CLR @STATUS
MOV @SAVERT,R11
RT
BEEPST BYTE >03,>8E,>0F,>91,>1E
BYTE >01,>9F,>0
END
What do I have to do so that the sound is also played on the second run? -
Hi,
are topics related to the TI-74 also a part of this forum?
I think the TI-74 is similar to the CC40. -
On my primary peb system I use mostly the tipi storage device, but also my attached two 5,25“ floppy drives and one 3,5“ floppy drive.
Sometimes for archiever stuff I‘m using the HRD4000B Ramdisk.
On my second peb system I use mostly my three 3,5“ floppy drives and sometimes the fourth attached 5,25“ floppy drive.
On my 7/24 running bbs system I’m using the tipi storage device too.
Today I registered for a SSS version of the game too.
I hope I can get one!
22 hours ago, Keneg said:It worked! I can even run it with CALL TIPI(“DSK1.TEST1”). Is there a way to suppress the message about runtime errors at the end? I also noticed there are programs named ASSM1 and ASSM2 in the TP3 directory. Can they be used instead of the editor/Assembler cartrigpdge?
The E/A cartridge use the files ASSM1 and ASSM2. So you will need the cartridge.
I didn‘t remember a runtime error for my test progrmams. Could you please post yours?
I will try it myself in my system.
Wolfgang
9 minutes ago, Keneg said:I finally got Turbo Pasc99 running. I created a small program to print “Hello World”. It compiles fine so I compiled It to DSK1.TEST. So how do I convert this to a program and run it? I would prefer to create program files that can be used with just TIPI, I think that is an EA5 file? When I load “test” into the editor, I can see what looks like assembly language to me. Do I use the Assembler next?
Yes, next step is to assemble the compiled file with the Editor Assembler.
You can read the document TurboPasc99_first steps from post #80 in the following thread:
17 hours ago, dhe said:Does anyone have a preferred vendor of TMS9901's?
I'd like to put back a few for a rainy day, but it seems it's gotten increasing easy to purchase bad chips, or chips, with new silk screens - that aren't even the chip you ordered (counterfeit).
I bought 9901 from chipsgate (china) some time ago. They worked.
Hi @matthew180
I'm looking forward to a mk2, even if the output is only in VGA.
Thank you for your effort on this project.
Wolfgang
On 8/31/2020 at 11:25 PM, Keneg said:I downloaded Turbo Pasc’99 today, but can’t get it to run. Computer seems to freeze. Does this require the Assembler/editor cartridge to work? If not, what do I,need to do to run it? If not, what compiled program language can I run with just my TIPI/32k?
Yes, Turbo Pasc‘99 only runs with the original Editor/Assembler cartridge or FG99 version.
I tested the versions 2.0 and 3.0. You will get more infos in this thread:
see post 2, 52, 63, 64, 67 and 79. -
2 hours ago, sparkdrummer said:I think this was Corcomp's final version.
The manager can be accessed from basic command line with CALL MGR.
Thank you for providing this disk, I didn't found it on AA or whtech.
Assembling a program on real TI hardware - interesting results
in TI-99/4A Computers
I copied with DSK2. (maped to a tipi folder) to DSK9. (HRD drive).
I put always DSK2. in DM2K and it finds the 1000.DSK2. on the tipi.
I will try the ROS814F and report the results here.
