wolhess
+AtariAge Subscriber
    427
Posts posted by wolhess
  1. Yuppie!!,
    my CorComp FDC controller is up and running!
    The WD1773 chip was defective. Today I replaced the chip and also changed the two eproms to the version of Millers Graphics DOS.
    Now the card is working with two drives, the standard TI drive SSSD and the Mitsubishi 5.25 "MF501B-312M" in DSDD mode.
    On page 48 of the manual it says that there is a Disk Manager floppy disk with some tools for the controller.
    Do we have this disk somewhere for download or can someone provide me with such a disk?
    Thanks in advance,
    Wolfgang
    • Like 5
  2. Today I had some problems with my BBS system to write a message. After I made a fresh SD card and copied all the files back the BBS works fine also with long messages. The problems comes only when I had a power loss without doing a shutdown.
  3. 3 minutes ago, Vorticon said:
    Quick question: Do I set up backspace in telnet?
    Hi Vorticon,
    in the tipi Telnet the backspace is working without any configuration.
    If I use the PC Telnet client also, but in putty I configured Backspace to ctrl+H.
  4. 54 minutes ago, Ksarul said:
    Based on your smptoms, I would look at the signals between the disk controller chip and the disk connector. It looks like some of the control signals are making it through--but not all. I put the CorComp schematics up in the schematics thread last year (just find the one that matches your card), which will show you which signals show up on each pin.
    Thank you for your suggestions, I found the right schematic I think.
    I will check the WD1773 on PIN 16, 17, 21, 22, 19, 23, 24 and 25 and the signals on the bus after the 7406.
  5. Hi,
    I have a CorComp floppy controller, which unfortunately does not recognize a floppy disk drive.
    I've tested several floppy drives and none of these drives work with the CorComp controller.
    1. Standard TI drive 5.25 "SSSD 90KB   works with TI controller (standard)!
    2. Mitsubishi 5.25 "MF501B-312M          works with TI controller (standard)!
    3. Matsushita 5.25 "JA-551-D17            does not work with TI standard controller, works with TI controller and 80 Track mod.
    4. Sony 3,5” MPF520-1                         does not work with TI standard controller
    The controller starts the CorComp menu after switching on the TI system.
    image.png.ecb366b2380cadd0da470144bf16234a.pngimage.png.0710a3872d0bc920bcdfedbce7ed6d1e.png
    I tried to initialize a floppy disk: Disk Manager 2.1 shows an "ERROR 16" -> No Disk or No Drive.
    DU2K shows Device found at CRU 1100, but then it shows a device error 6
    The Device list shows DSK1 to DSK4 and more.
    The drives are addressed by the DU2K or DM2.1, the motor starts and the LED lights up. After the error message everything will go back to normal.
    After reading a lot in the forum, I replaced the TMS9901 IC. However, this brought the same result.
    Next I wanted to swap out the ICs 24LS123P, DM7406N and SN7438N or the WD1773-PH controller. However, since I have to search, find and order these, I thought I could get some tips here.
    Maybe with a few measurements I can find out what's going on. Since the card reports with the menu, I think the communication with the PEB bus works. Therefore, I think the controller or one of the following IC's is defective. However, the floppy drives work with the cabling on a standard TI controller. Maybe something else is wrong!
    Does anyone have a idea what else I can do?
    Wolfgang
  6. I have a similar question. Will the compiler work with T80XB?
    I‘m still working on my Mega Menu program. For this I‘m using XB and compile it with the XB compiler and the option for large programs, so most of the lower RAM is used by the compiler library I think.
  7. Hello,
    Here is the next version of the Mega Menu program. Again Vorticon gave me some recommendations for expanding the program.
    MEGA MENU v2.52 – New version:  Aug / 12 / 2020
    New in version 2.52
    - New command CTRL+4 to map DSK4 to a TIPI path.
      You can change the mapping of DSK4 for the tipi system. The menu screen still
      shows you the DSK1, DSK2 and DSK3 mapping.
    - Select a menu item to configure from the displayed menu screen.
      To make it easier to configure a free menu item or to find the name of a menu item
      to be changed, you can now select the menu item to be changed from the menu screen.
    - Exit the menu item configuration screen without changings.
      By entering the dot character "." at the first entry position you can cancel the
      configuration of a menu item at any time without making changes.
    - Support for a directory length of up to 28 characters + 10 characters for the
      program name. The disk mapping commands CTRL1-4 now support the entry of
      directory path lengths of up to 28 characters.
    The complete program package for new installations
    MM252.zip
    The manual for Mega Menu version 2.52
    MegaMenu_252.pdf
    Only the updated files to copy in your TIPI.MM folder
    MM252_UPDATE.zip
    The Game Shelf book updated version
    TI-99 GameShelf_2020-08-06.pdf
    Now without the device name and without the program name you can map a directory up to 28 characters long.
    To configure a menu item, now you can select it on the dispayed menu screen. So it's much easier to remember the item.
    Update Mega Menu from version 2.50 to 2.52
    If you want to update your existing Mega Menu system from the version 2.50 to the version 2.52 you can easy unzip the file MM252_update.ZIP in your TIPI folder TIPI.MM.
    This change seven files in the Mega Menu root path:
    TIPI.MM.MM
    TIPI.MM.MM-X
    TIPI.MM.MM-Y
    TIPI.MM.MM-ENG
    TIPI.MM.MM-GER
    TIPI.MM.MMHELP-ENG
    TIPI.MM.MMHELP-GER
    That’s it, enjoy the new version!
    • Thanks 3
  8. Hello everybody,
    A few months ago I started a small Bulletin Board System (BBS) project.
    Beery Miller had already announced in January 2020 that he would convert the After Hours BBS system to Telnet communication
    for the TI-99/4A home computer with Tipi extension. Even then, I thought it was a good idea to use my TI with this application.
    In mid-May, Beery Miller made the BBS software available in the AtariAge forum. That was when I installed the software on my
    second TI-99/4A with a Tipi extension. After all, the BBS system should run around the clock, 7/24 hours.
    In addition to the BBS program, Beery also provided all source files. That gave me the idea of gradually converting my BBS system
    to German. The changeover has not yet taken place in all areas, but the basic text information and parts of the menu control are
    implemented in German. I set up the system texts in English and German.
    The TBOX99 BBS system can be called with any Telnet client. A file transfer is possible with the XMODEM protocol.
    The TBOX99 BBS system has been available since 05/20/2020 at the following address:
            URL:  mytbox99.ddns.net
            Port: 61643
    In addition to my TBOX99 BBS system, there is a second AFTER HOURS BBS, which Arcadeshopper operates in the
    original English version. The “THEKEEP” After Hours BBS can only be called from the “The Keep BBS”.
    After logging into The Keep BBS, the After Hours BBS can be reached with the following two commands:
    /go dialout + enter
    then
    d 19 + enter
    Beery Miller has further developed the After Hours BBS system over the past few months. He has implemented a huge
    download area with a very extensive menu structure and more than 3000 files available for the TI-99/4A and for the
    Geneve computer. He has also implemented a search function that searches all files and brief information in the entire
    download area for a specific term and lists the files found.
    In addition to news and information in the message area, the BBS can now also be used as a program source for the
    TI-99/4A and the Geneve computer.
    For me this is a very good example of the practical (hobby) use of a retro computer!
    For everyone who has not yet created an account in the TBOX99 BBS, I have converted the current TBOX99
    newsletter #3 to pdf format. This issue explains how to download files from the BBS system.
    The example uses the "Mass Transfer" (MXT) program on a TI99-4A.
    The TBOX99 newsletter is a pure text file that can be displayed on practically any terminal.
    TBOX99_#03_Newsletter.pdf
    Here are also the previous editions of the TBOX99 newsletter:
    Issue 2 contains an overview of the currently available hardware and software extensions for the TI-99/4A
    as well as an illustration of the menu structure in the TBOX99 download area.
    TBOX99_#02_Newsletter.pdf
    Issue 1 contains brief information about the start of the BBS system
    TBOX99_#01_Newsletter.pdf
    If you feel like it, you can log into the TBOX99 system and simply take a look at the system or leave a message.
    Wolfgang Hess (wolhess)
    • Like 6
  9. This is a list of all files I added to the download area of the BBS system:
    BBS_DL-Files_List.zip
    For the games I made a new revision of the game shelf book. All program descriptions and if available the manuals are included in the pdf.
    With the BBS_DL-Files_List and the game shelf book and with the search function in the BBS system, it is very easy to find a specific game or program in the download area.
    Happy downloading and happy gaming!
  10. Hello Beery,
    I have added 300+ games from the Gameshelf website to the BBS download area and to the Excel tool.
    BBS.zip
    I used the following categories for this:
    BBS Menu: [D] ata Library,  TI-99 / 4A, Games, [A] Basic
    TI BASIC Games: CAT42 -> Filenames: GBnnnn-ARK
    BBS Menu: [D] ata Library, TI-99 / 4A, Games, Extended Basic
    XB games: CAT19 -> Filenames: GXnnnn-ARK
    BBS Menu: [D] ata Library,   TI-99 / 4A, Games, [C] Compiled XB
    Compiled XB games: CAT20 -> file names: GCnnnn-ARK
    BBS Menu: [D] ata Library, TI-99 / 4A, Games, [D] Assembly
    Assembly games: CAT24 -> Filenames: GAnnnn-ARK
    BBS Menu: [D] ata Library, TI-99 / 4A, Games, [E] GPL, c99, Others
    GPL, c99, Other games: CAT16 -> Fileman: GOnnnn-ARK
    I also have added the files for my Mega Menu system and all demo programs configured in the MM-System.
    The Gameshelf games are listed again with a different name and these files includes an additional LOAD file for the mega menu system.
    BBS Menu: [D] ata Library, TI-99 / 4A, [D] Utilities, [E] Menu Programs
    Mega Menu Program system: CAT21 -> file name: MM250-ARK (Mega Menu Version 2.50)
        MFnnn-ARK (Mega Menu Demo Programs)
        MGnnnn-ARK (Game Shelf games)
    I have used the tool 50+ times to update and test the lists in the BBS system.
    In the zip file above the file listings in the BBS system are all working fine, but if I add one file in the category "CAT24",
    the file list breaks with an DSR error and I have to restart the BBS program.
    The error can be reproduced if you copy the file MUMMY3-ARK from "CAT08" (line 20) to CAT24 in the Excel tool
    and then execute "Create Files".
    If the file list is then called in the BBS system ([D] ata Library, TI-99 / 4A, Games, [D] Assembly), the following error occurs:
    The problem occurs only in the category "CAT24" and it depends not of the example file MUMMY3-ARK".
    It does not matter whether the file list is displayed page by page or continuously.
    I have tested all the file lists in the download arrea to check the DSR error and
    the Error occurs in three more file lists:
    1. TI-99/4A - Applications   - Music (CAT13)
    2. TI-99/4A - Programming - Extended Basic (CAT30)
    3. TI-99/4A - Programming - Assembly (CAT17)
    Maybe you have an idea to find this bug?
  11. 4 hours ago, Ksarul said:
    I have loaded the cart pretty regularly on my TI system with AMS memory. I've had good luck with some copies finding the AMS memory and configuring the system to use about 64K of it. I demonstrated this at the Chicago faire a few years ago. . .
    What is curious though, is that all copies I've made have the same code base, but only some of them actually recognize AMS memory consistently.
    Hi @Ksarul,
    how does xb3 indicate that it found sams memory?
    Is it in the size command?
  12. Hello @BeeryMiller,
    I have changed some menu files for the download area to avoid the query 'Press any key - ^C to abort'
    and to display the query "Your database menu selection - =>" directly.
    I deleted a blank line in the menu files: TEXTFF, TEXTFG, TEXTFH, TEXTFI, TEXTFK, TEXTFL.
    The files are in the following zip file:
    TEXTXX.zip
    In the BBS source file BBSSUBS, I changed the German text "Weiter mit beliebiger Taste - ^C zum Abbrechen"
    to "Weiter mit beliebiger Taste, ^C=Abbruch".
    That is only 39 characters and it fits in one line (in 40 character display mode).
    BBSSUBS
    I tested a few downloads with the MXT program. So far this works very well and reliably.
    However, sometimes MXT writes the string "[2J" on the screen.
    If you feel like it, maybe you can take a look at it and correct it?
    From the PC in the Telnet client, everything looks good without the "[2J" string!
    I took some pictures of it to see what I mean:
  13. Right now I tested the file download.
    First search a file then change to the File Transfer menu and choose download with CRC or Checksum.
    Both is doing well!
    BUT!!!
    I used your MXT v4.E program and at the first try I discovered that the download hangs the system, but this was my own fault.
    What was happening?
    I entered the file name "TBOXNE-ARK" to download, change to the XMODEM menu and the program asks for the file name
    to receive. I entered again "TBOXNE-ARK". MXT shows there are 6 sectors to download and hangs.
    So I went back to the previous version with same result.
    I went back to the version from June, 7 2020, same result and then I remembered I forgot to enter the device for saving.
    Next time I entered in the XMODEM menu DSK1.TBOXNE-ARK and all works fine.
    It was a massive level 8 error!
    It seems all is working fine and stable.
  14. Hello Beery,
    I have just tested the new search function in the BBS system. I searched for "MXT" and immediately saw four results.
    The query to continue or cancel searching is very good.
    Then I searched for "aligator" to test how long the search lasted.
    With my PAL TI (50Hz) it took about 4 minutes. Not bad for a search over approx. 12,000 lines (approx. 3,300 sectors, 830KB).
    I then searched for "HRD", "Ramdisk" and "Stratego" and every time I got the first result after a few seconds.
    Very impressive! 👍🙂
    Here is my BBS system running the searching function:
  15. Hello,
    In the last few days I received feedback from Vorticon with some ideas to make
    the menu control in the mega menu a bit more comfortable.
    Here is the result:
    MEGA MENU v2.50 – New version:  Jul / 24 / 2020
    MM250.zip                  The complete package with all demo programs and the Gameshelf programs.
    MM250_UPDATE.zip     Only the files you need for an update of an existing menu system.
                                            Easy copy the files to the directory TIPI.MM.
    MegaMenu-250.pdf      The manual with the extensions of the new version.
    New in version 2.50
    This version contains some new commands for comfortable control of the menu system.
    - FCTN+3
    Deletes a menu item – The program asks for the item 1-9 or A-U.
    If the menu item is a submenu call with a menu configuration file, the program
    asks whether this file should also be deleted. You can answer “Y”es or “N”o.
    If the menu item is not to be deleted, press ENTER to return to the menu view
    - FCTN+9
    Always changes to the main menu 1/3.
    - FCTN+S
    Changes the main menu to the left.
    When the main menu 1/3 is displayed, FCTN + S changes to the main menu 3/3,
    a new entry to 2/3, the next entry again to the main menu 1/3.
    If a submenu is currently displayed, FCTN + S changes back to the menu from
    which the submenu was called. This function remembers up to 5 submenu calls.
    - FCTN+D
    Changes the main menu to the right.
    When the main menu 1/3 is displayed, FCTN + D changes to the main menu 2/3,
    a new entry to 3/3, the next entry again to the main menu 1/3.
    If a submenu is currently displayed the menu points to the next submenu if it has
    been selected beforehand. The function remembers up to 5 submenu calls.
    Now you can configure a menu item to run a program from a Ram disk or from a Hard disk drive.
    To run for example the program ARC3 from the Ram Disk Drive “DSKE.”
    The configuration shows in the picture below.
    The Device names can be DSK1 to DSK9 or DSKA to DSKZ.
    It should also be possible to use IDE1 to IDE9 or IDEA to IDEZ (not testet yet!).
    There are some more improvements about error messages for the file handling.
    See more info in the manual.
    Update Mega Menu from version 2.48 to 2.50
    If you want to update your existing Mega Menu system from the version 2.48 to the
    version 2.50 you can easy unzip the file MM250_update.ZIP in your TIPI folder TIPI.MM.
    TIPI.MM.MM
    TIPI.MM.MM-X
    TIPI.MM.MM-Y
    TIPI.MM.MM-ENG
    TIPI.MM.MM-GER
    TIPI.MM.MMHELP-ENG
    TIPI.MM.MMHELP-GER
    Coming soon:
    For the additional programs that are included in the package, I will conduct a separate
    workshop on using Stuart's Internet Browser and Force Command with the Mega Menu system.
  16. Hi @ralphb,
    there are very good news. You have the P-system running on your SDD99. I‘m definitely interested in your card.
    Are the other capabilities like 32K/SAMS,Wifi still available on your card?
    Wow, what a thing!
