VinsCool
    367
Posts posted by VinsCool
  1. 7 hours ago, emkay said:
    Is this a remake of an AMIGA MOD file?
    Nice arrangement btw.
    As it is a medieval tune, it might need medieval sounds.
    So I played a little with it.
    Real 4 channels and playing with wave forms
    That's a nice edit!
    Can you share your edited module? I would really like to see what you did to achieve these sounds.
    Thank you :)
  2. Hey everyone.
    Those of you who tried one of the recent versions may remember that there is a very rough attempt with porting the sounds to the game, and probably thought this was pretty bad. You can blame me for that, hahaha.
    I tried to remake the tunes again from zero, with hopefully a more consistent design, and hopefully not as many wrong notes and weird effects.
    These are very likely to be changed again, but the approach this time should already sound a bit better. For now they don't really sound particularily special, but improvements are always possible :)
    I'll include a .wav of what I did this time.
    pop v2.wav
    • Like 8
  3. 3 hours ago, emkay said:
    VinsCool
    Do you know this one? I always wanted to do this tune on the Atari, because it is very slow and allows a lot time to manipulate the generators.
    Particular the long played synths allow a lot "morphing" programming on the  envelope.
    Would this be a challenge?
    Sounds pretty interesting.
    I currently am busy on different projects that are not on Atari but I'll consider this one.
  4. 4 minutes ago, emkay said:
    Check the tune "One Man and his Droid" on the C64.
    I've known that one for years and honestly I don't thing it bears much resemblance, except for some parts maybe.
    Anyway, we're getting a little carried over now :D
    I do plan to make more PoKEY songs, hopefully some original ones that I have been working on but left unfinished.
  5. 1 minute ago, emkay said:
    The tune has become something "original" for POKEY. And that was MY goal.
    I see.
    2 minutes ago, emkay said:
    Btw. Have you ever listened to the tune of "Plastron". It is some very original tune on the POKEY. Is it?
    If it's the song by Richard Munns I did yes. No idea if it was based on another song but it was pretty good.
  6. 9 minutes ago, emkay said:
    Why is that "original" that noisy?
    This is how it is, given that it should run on a Fairchild Channel F. ;)
    My cover is basically taking the composition and port it to RMT. I know my ears are not 100% pitch perfect but I'm pretty sure I pretty accurately transcribed it.
    The reason why I used 2 specific instruments (The Distortion A SID filter and the normal Distortion A) was to get the full range of notes in the lead.
    C-1 using the filter is actually an octave higher than using no filter, so I needed to compensate that in a way.
    The only "special" effect I did was using another special filter instrument to create a phasing effect that sounded almost like ring modulation at certain sustained parts.
    Your changes are pretty cool, but sadly it turned a complete section wrong. It even has a sustaining note at the end of the loop that shouldn't have been there.
    Either way, some of your sounds were cool.
  7. 21 minutes ago, emkay said:
    Fitting to SID Styles :D
    Thanks VinsCool for this great template.
    This is nice! But half of the song is wrong now :|
    Assuming that my instruments were swapped, the ones that were used to compensate an octave using no SID filter makes the whole thing offtune by an octave when these notes are reached.
    Mind you share your modified .rmt? I really do like how the pulse width is handled otherwise.
    Also, this is the original song, for reference:
  8. 8 hours ago, R0ger said:
    Here are some first tests. It's just one channel for the bass.
    The first one is just the bass, 3 octaves bellow standard A distortion. It's very naive approach, simply handle only every 8th IRQ.
    The second one plays major chord, so you can see (hear) how it's all perfectly in tune. The bass is moved one octave higher.
    The color is changed during every IRQ, even those I skip.
    IRQ1.xex 715 B · 12 downloads
    IRQ2.xex 745 B · 14 downloads
    This is really damn cool! Looking at that PWM through an oscilloscope viewer is very, very satisfying.
