TIX
    1,018
Posts posted by TIX
  1. 18 hours ago, fantômas said:
    Hi,
    I finally found time to do what I talked about. So here is a new RC, based on the HomeSoft version of Bruce Lee.
    1. I imported the new sprites into the HomeSoft xex (TIX, I hope I did this job well 😰. I wrote a program to do that, but there can be errors),
    2. Changed the title screen:
    3. Changed the version (Ctrl+V):
    Thank you fantomas for everything, looks perfect  :D🤞
    Also thanks everybody for the encouragement !
    As for the problem you described, I'm not qualified to answer.. I'm just the pixel artist.
    Still pending the FINAL final version, with the new flying kick !
  2. 4 hours ago, fantômas said:
    Hi TIX, here's the XEX:
    Just three brief remarks:
    1. Philsan and I noticed some glitches on the title screen. It's not a big thing but that’s something I don’t recall seeing on another version of BL. So it might be better to use the XEX from Homesoft as a basis as Philsan recommends.
    2. You may not know this, but you can display the game version using Ctrl+V:
      Maybe we should put a special label like "TIX’s Spriteset" or anything else.
    3. If you want a different intro screen, you can send it to me, I'll try to include it.
    Finally, thank you for your hard work! 👍
    Thanks a lot fantomas !
    Unfortunately in Homesoft version, the sprites are arranged differently, so it's not an easy copy/paste job..
    A special label is not necessary.. but if you can fit somewhere "BRUCE LEE (C) 2019 DATASOFT SPRITES BY TIX" or something like that, it would be great :D
    As for the intro screen I don't know I have seen many beautiful converted images by Philsan and others.. there is also a nice one in post 163 here.. I leave the decision to you !
    We'll keep in touch ;)
  3. On 8/5/2019 at 10:38 PM, fantômas said:
    To avoid this:
    During the fall, when the lower body drops without hitting anything (PM0=Black PM) but not the upper body (PM1=Pink PM), the engine moves Bruce a little to the right or a little to the left.
    Let's move him a bit more: I changed tree bytes:
    • $00003C20: $1C -> $91
    • $00003C21: $18 -> $17
    • $00003C29: $DE -> $91
    Hello my friend,
    from the lack of feedback I understand that we have ironed out all the bugs !
    So when it is convenient for you, remove the infinite lives bit from the RC7 xex
    and we can wrap this up  :)
    Thanks for all your help.
  4. Can't leave it alone.. I keep experimenting with the flying kick, I really don't like the rectangular head (a result of the double wide black pixels),
    so in my tries to smooth it up, this came up ! The hand kinda smooths the corner of the head.. but I'm not sure 🤔
    is it better ? should I change it ? should I leave it alone ?
  5. 11 hours ago, vattari said:
    I just tried this on real hardware (firstly I must say, this is brilliant rework of the original) but found it was more difficult to collect the lantern highlighted in the screen below.
    Thank you my friend,
    hmm.. I thought I have solved the bumping of the head problem..  let me check again
    • Thanks 1
  6. 7 hours ago, ivop said:
    He used to kick you off laders before. A sprite change doesn't suddenly make him chase you more. But I think you already got that ;)  Yamo just has different collision points now. And I think his feet got bigger or reach a bit further, as it seems he is more likely to hit you than in the original if you don't duck in time or walk away. But his bigger belly might be an advantage for Bruce.
    actually the opposite happened, both have had their legs chopped by a pixel !
    So it's a fair fight..
  7. 7 minutes ago, www.atarimania.com said:
    Having issues with the lasers on the floor - or whatever they are - near the end as you hit the ceiling when you jump but, if you adjust your timing, it goes well
    hmm strange, I don't think he jumps higher now..  can you check with original version ?
    perhaps I can fine-tune the jump better !
  8. 4 hours ago, Gunstar said:
    I tried the latest RC2 version and I got stuck in the exact same spot as my screenshot above, but this time the death frame and stance frame flashed between each other, leaving no time for joystick input and I had to reboot.
    hmmm, the only solution I can see (keeping the standing frame as it is), is adding a pixel in the middle of the gap 🙄
    Ugly I know, but it works..    Hey, maybe he dropped his wallet  :lolblue:
    • Haha 1
  9. Hello,
    trying to get my mind off of Bruce Lee's hack, I hacked in a new run animation for HERO's protagonist !
    I had drawn this several months ago and I meant to inject it but other things got in the way..
    God it was bad.. much better now :D
     Roderick-old.gif.19332d1fed84d325b6a34ec47ce6fe76.gif             Roderick-new.gif.813f6fe72aaada7239429a1f87b11725.gif
    So here is the new version of Roderick Hero (I have also introduced a new little creature) !
    H.E.R.O. (new Roderick hack).xex
    • Like 9
