4,392 -
Posts posted by José Pereira
Just curious... will you release all the stuff to public or just running file(s)?
On 10/18/2018 at 5:35 PM, José Pereira said:A first possible looking that is Antic4 (seems to fit in: 1charset for text at the top in hi-res, on that pink place the hi-res white over black and playing area 2:1 ratio the other):
This is:
BAK: Black;
PF0: Light colour;
PF1: Blue;
PF2: Pink;
PF3: Green / DLI / Blue;
So this way there isn't PF2&PF3 clashes;
All guys are software sprites and PMGs are on Mappy.
Of course that this was just a 'quicky' so gfxs must be improved...
Get it?
On 10/19/2018 at 4:27 PM, José Pereira said:Some update for today...
All PFs / DLIs the same as before but now the top scores is showing.
It's better having it, like I said in a own charset but to also to save Memory it can be in GR.1 mode because 64chars are more than enough though it is redone to 7scanlines high instead of the original 6.
On the game-playing area the windows on the roof are now redone and I think that's the best we can have.
Now will go to other objects and then the guys sprites...
Here's the current looking:
On 10/23/2018 at 1:23 PM, José Pereira said:It seems that in some is green and others red: http://www.mobygames.com/game/mappy/screenshots and it is on my in green but it can change to any colour like is in the arcade version
On 2/26/2019 at 6:38 PM, José Pereira said:Not that I know but I could go more further with the gfxs if anyone is interesting in coding it.
Yes, first @Synthpopalooza then me but sadly no ones takes it 😞.
It would be fairly simple as is described by me above with our guy PMGs then others soft sprites and using charmode on an Antic4 screen.
18 hours ago, José Pereira said:Just to inform the all Team members are still alive and well.
The top two are fighting with bit & Bytes, cpu, Memory and all these kind of stuff while the other two were battling last weeks to get a pixel perfection picture boy and girl:
And the other one? He's also ok and listen music while doing some more sound notes but he prefers to work alone.
Forgot to post that we have a doll on the Bonus screen (😏 and in-game also😞
15
On 4/3/2020 at 12:24 PM, José Pereira said:So following this have a look at the NES version maps of the levels:
https://www.nesmaps.com/maps/KungFu/KungFu.html
Here we have Background (just gfxs) and Labeled (with enemys) maps so is all we need 😄...
So as I said above is just a question of adding the enemys as soft sprites. Just have a look on a quick example with 2types of enemys:
What we have and can be is DLIs of PFs colours across the screen so is BAK colour register on top roof black, then blue, next brown/orange and black lines on the floor and finaly again black.
On that red and light brown and black (gfx chinese symbol) top will be PF0/PF1 and red & lightest around symbol as PF2/PF3.
Enemys are also trivial: skin as PF0, purple (one of the clothes) as PF1 and then one have PF2 (cyan) while the other has PF3 (white)
At least the PF2 and PF3 can change according to wich type of enemys are on screen (also one, like PF2, when shows the steps to go for the upper/next level/fllor).
This way we can even try and have the game in 48Bytes wider Mode.
Just a quick similar to A8 colours using P.C. program Paint but you get the idea.
The top panel is also not difficult and can be done also with DLis with our guy and serpent maybe using just PMGs.
And the 4Missiles are still left to use somewhere...
P.s.- I'll leave the gfxs and sprites for @TIX 😁
On 5/1/2020 at 3:38 PM, pseudografx said:On 5/1/2020 at 4:22 PM, Yaron Nir said:@Yaron Nir the way to go and follow what we're doing on Wonderboy is having it, like I posted, similar to NES so that enemys can use PFs/soft sprites.
It can then/after maybe adding some things on walls, even the pillars.
We can improve the roof and floors because they're on another lines as we can also have the left and right side end of the building like @pseudografx posted here.
His screen looks good but from there we'll never get the guys because there's already the 4colours on wall and if this then there's no colour for guys skin, a 2nd colour of the clothe (and 2x because can be 2types of enemys each time on-screen). From him we'll only have white and black to use so it'll always be missing, at least the skin colour...
Lets just think in WonderBoy by now 😉.
On 4/12/2020 at 1:26 PM, rensoup said:The fire pits on different frames once is yellow and other is pink. As is, I think, form the conversation that their're Missiles 5th Player mode/PF3 it would be better always same colour, right? And yellow the best...
And the bottle, why is it flickering? Is it same using Missiles 5th then maybe a DLI to set other colour(s)?
15 minutes ago, pusakat said:Was Nyan Cat for Atari 8-bits ever finished? With random endings?
No, the coder @PeteD did that and disapeared a long time ago...
P.s.- Thanks to some 'haters around here'... And he was trying and maybe had some code as he said me for we have Exploding Fist. I tried back then to contact him but he didn't answered so I hope is still fine 👍.
21 hours ago, José Pereira said:From talkings we (Team HOAXERS 😀) had here's my quoting from there:
And to add more is getting the NES gfxs so it the back wals/main colours lines are DLIs of BAK colour register across the screen.
Enemys have 3colours all equal at the same time but sometimes there's a 2nd type one so is here where the change of PF2 in one and the other PF3.
The NES version our guy is on A8 (even wider like kicking) possible in ours 2:1 ratioo 16pixels so is the 4Players but in Multicolour mode (2+2) while Missiles are free for anything else, have to see and/or remember where...
Taking @TIX here's it in the A8 possible colours (similar buit not exactly as did it on P.C. Paint program but you get the idea):
P0/P2: darkest brown (10);
Oring
P1/P3: white (0E);
3rd colour: lightest brown (1E);
Lets finish Wonder Boy then we'll go this one, maybe... Have faith!...
Hree we have Background (just gfxs) and Labeled (with enemys) maps so is all we need 😄...
QuoteI have it already some things done and yes, is exactly like Wonderboy: Antic4
Interleaved charsets, colours DLIs, our guy the 4 Players (2+2
Multicolour mode) and Missiles I don't remember where, enemys soft
sprites (3colours: PF0 (skin), PF1 (one of the clothes colour) more other(s) shirt or trousers PF2 and the
other PF3).And to add more is getting the NES gfxs so it the back wals/main colours lines are DLIs of BAK colour register across the screen.
Oring
P1/P3: white (0E);
I didn't had web on the last days so I already contacted who was expecting.
I also had been out of here for the Wonderboy port and only today posted the things people expecting from me.
Yes I know that I've not been well to Fred_M but I'll pay probably it'll take Months but I will.
And just for you all know there's all true in what I said and yes the teeth are in the situation they are but no I never take any drugs in my life bbut you can go inspecting why because here in Portugal there's many like me because the public medical care doesn't include mouth, teeth,...
As for asking help yes I did and have but here rents are coming so high they are constantly dropping help.
I've all in place as a citizen without any drugs, police, states all is clean and was never thinking in asking here.
Yes, maybe life problems will continue but you can all believe or not but all this was just when I came into a situation that I really hadn't nothing more. It may sounds difficult to understand but is the true.
To be here answering you and contacting team behind Wonderboy I had to go out and do some travel because I don't have Net at home nor I have IPhones, just and old mbile phone and a small payment of 3,30€ per week that is the least I could get for net on the phone.
I know that I didn't do tjings the best way and it seems so but had been here for years so I wouldn't go away or had been for so long waiting yers after to take money from people.
I need you much as A8 and things I do and/or try to do are what sometimes can keep me alive and having things to do, keeping me as is doing something.
Thanks.
38 minutes ago, tane said:PAL: 😀
Hey PAL doesn't have Artifacting, right?
Who posted this and where?
I just wanted to answer and help because if I'm not mistaken it was by @Creature XL that seems is out of here for some time May 31st last year and I hope he's fine (or @Eagle maybe not).
Wasn't it?
It was the screen divided in 2 where one is using, I think said by him a hardware horizontal scrolling while the other is 'above this and scrolls in software.
It was a nice effect and I think it was using Bitmap mode GR.15. Maybe if the two have a black 'over' division it could be using Char mode GR.12 or GR.13 because it'll prevent a PF2/PF3 clash, wouldn't it?
Just now, Lost Dragon said:Oliver The Elf character
Who, Atari? Don't know who is, can you show?
On 12/30/2019 at 2:57 PM, José Pereira said:Don't worry has first you have it all black&white because then and after there maybe a solution using A8 PMGs to colour it. I don't know of Mariuszw lately but I, him and maybe Tezz can give you the colourings help you need.
Just convert, port whatever you wanna do in black&white hi-res that for sure on A8 will need to be better a Bitmap mode GR.8 320x then for sure colours will come...
I'm sure 😉.
So I'm used from Mariuszw,... conversions/ports that normally guys pixels (white) are bit_1 (ours PF1) and black/darker/sky colours are bit_0 (ours PF2) so just seeing that tiles of map1 in about 1hour I turned them all to black&white (PF2&PF1):
That's because I just replaced ZX's .png using same name Tiled just automatically produced it for A8:
The exactly objects, information, enemys,... on the .tmx(for also later turn into black&white) are there also.
If you can use Tiled and port Z80 code directly (@Mariuszw, @Tezz, @shanti77 if have time can be a great help if you aren't used to) and we have already level1.
In a couple of days I can do all the levels so after what it'll take more time is to PMGs colour each screen (like, for example, we did at Highway Encounter, Skool Daze,...) if there's enough Memory for it...
P.s.- No scrolling and screen per screen like ZX and Bitmap mode GR.8 so no worries for the number of chars.
@explorer how can I remove these colourings, anotations, etç... and just show the map as real looking screens that is using the tiles just like they are?
P.s.- I'm used to create the chars/tiles using A8's G2F then with the .png I just simply build the map and coders so the rest:
Why I'm asking is that I just wanna try to turn and post how it'll look in 2colours for a later possible or not see if the PMGs colourings could look anything good screen per screen...
Just now, xxl said:The Gauntlet characters?
But it is not from the Atari of computers, but the arcades Atari Games company after the split, isn't it?
I'm familiar with Tiled because I did some A8 stuff for coders using it but wanna need to download the .tmx(s)...
Yes, and how I can I download the .tmx of the levels?
P.s.- I already opened an account but entering there is only th ecode listen and no download button...
It was just because the certain person and the way he reacted to this today after all these pages and posts and that I always posted here, never been out or trying to not be seen. It was just this and with him.
One of the many examples in the games and projects where I'm in, this one before a weekend:
QuoteSo we have on all screen 20colours, not bad for an A8 game 😉...
Going out in minutes for the weekend, so cannot post here but can read and see. For anything my mail is [email protected] no problem to contact me if anything urgent comes.
Just now, Irgendwer said:No it isn't just go and see the posts @Popmilo did and wich days were and hours.
I don't have net at my room because computer is broken and at night, weekends and holidays like was yesterday, Christmas,... I can't answer with the phone that's the reason.
Today and tomorrow I have because I'm on a public institute untill 5p.m. that's why.
I never been out of here as you go to my personal pages and see my posts like I also did a week or two ago the Laser Squad screen as you can see on top of this post photo:
I also posted about my current work on a Wonderboy level and stuff for it 2days before New Years day:
Or even there at Ianna's topic:
Your only answering this because you and me had some problems years ago and that hadn't nothing to do with money just a different opinion and what I did seems now whatever was the best because the person sadly never came on here after that (just hope that whatever happened to him he's ok), that's why you just answered without even going to see if I were here before or not, that's why and with Fred_M I resolve my problems soon not with you.)
I thought you simply had put me on ignore though I didn't put you nor anyone here before.
Please don't put flames into a conversation where you have nothing to do with it.
Thanks and have a nice day.
Just a level finished map and items of it as a end of the year gift 😀:
This is how a screen will look (enemys to follow...):
13
Unicorns season: Prince of Persia for the A8!
Posted · Edited by José Pereira
Aded comment for the windows and stones design...
I have to agree with @Jacques because also don't like the purple/violet.
Here's ours team back then Palace looking (adding just the vest from you):
It's brown (16) or (F6) then a yellow but more sand like (EC) not real yellow (EE).
Edited: Also please notice the difference on the windows, I think that is better looking ours having the brown around then inside light colours caming from the outiside (white and yellow) but also the [x] metalic lines inside. It makes much more sense and as in the reality...
Of course that yours stones look much better though 😏.
