2,433 -
Blog Comments posted by cd-w
Have you optimised the sprites with D00d yet - I'm interested to see how much space that saves?
Dropping the attract mode to fit in more samples seems like a good compromise to me.
Chris
The new sample sounds awesome - I hope you will have enough space for the rest?
Chris
I'm wondering if it would be better to have the sprite data in C, rather than ASM. The problem with the ASM version is that the C compiler can't do anything to optimize all the references to the sprite data, and so a lot of the binary is just offsets into memory.
Instead of:
AsteroidA: .byte %00110000 ; 0 .byte %00111010 ; 1 ... AsteroidAHeight = * - AsteroidA AsteroidID = * - ImageHeights .byte AsteroidAHeight .byte AsteroidBHeight .byte AsteroidCHeightYou use:
typedef struct Asteroid { char height; char[] data]; } ASTEROID; ASTEROID asteroids[3] = {{12, {18, ...}}, {{13, {18,...}}, {14, {20, ...}}};This would require a lot of work and wouldn't necessarily result in a big saving.
Actually, that wouldn't let you overlap the data. I guess you'd actually need something like:
BYTE spriteData[] = { <all sprite data> }; typedef sprite { short start; char length; } SPRITE; SPRITE asteroids[3] = {{100, 12}, {112, 13}, {125, 14}};And then we are back to offsets that can't be optimized ...
Chris
The following magic will tell you which functions are using the most space:
arm-eabi-readelf -sW testarm.elf | awk '$4 == "FUNC" { print }' | sort -k 3 -n -rWhich shows the top 10 functions by size (3rd column is the size) are:
326: 00000d99 1200 FUNC GLOBAL DEFAULT 2 InitLevel 274: 00001299 936 FUNC GLOBAL DEFAULT 2 MenuVerticalBlank 294: 00001c41 808 FUNC GLOBAL DEFAULT 2 DrawSprite 233: 00001f69 688 FUNC GLOBAL DEFAULT 2 ProcessJoystick 415: 000019ad 660 FUNC GLOBAL DEFAULT 2 PrepScoreRadar 206: 000034bd 636 FUNC GLOBAL DEFAULT 2 MoveFormation 375: 00003bd5 632 FUNC GLOBAL DEFAULT 2 MissileCollisions 324: 00002219 588 FUNC GLOBAL DEFAULT 2 DrawMissile 316: 00003e91 564 FUNC GLOBAL DEFAULT 2 MoveEnemyShips 392: 00003739 536 FUNC GLOBAL DEFAULT 2 StationMissiles
InitLevel and MenuverticalBlank are taking almost 1KB each, so are probably good candidates for optimization.
Chris
Cool - have you considered adding a random element to the levels, e.g. randomly adding an small offset to the coordinates, or flipping the station orientations, so they are not identical every time?
Chris
I think you could save a lot of space by packing the level definitions into bytes. It looks like you use co-ordinates between 0 and 1023, but I suspect you don't need all that resolution? You could divide the coordinates by 4 to fit into a byte, and then multiply by 4 when you read the values? The HS and VS issue could be solved by having 2 lists, e.g: a level with 2 VS and 1 HS station:
typedef BYTE unsigned char; const BYTE alpha_1[] = { 253/4, 504/4, // ship starting X, Y location 2, 1, // station counts 320/4, 255/4, // station 1 X, Y location 224/4, 320/4, // station 2 X, Y location 96/4, 576/4, // station 3 X, Y location };Chris
The space optimization will be a major undertaking as I'll need to make space for the final samples. At the moment I have just over 2K free (1K in bank 6, the rest in the ARM code space). The two test samples currently in place use 2.5K of space.Feel free to upload the source to the CDF thread and I'll see if there are any obvious ways to save space. I'm sure Thomas will also be able to find a lot of innovative ways to reduce the size.
Chris
Great progress (again) - looks like spy ships and e-type missiles are really the only things missing?
Chris
This is coming along very quickly! Not sure how you find the time
Afraid I haven't had a chance to look at the 7800 CDF issue again - maybe next weekend.
Chris
Haven't tried it, but these mame invincibility cheats for bosconian could be useful for determining firing behaviours?
http://www.mamecheat.co.uk/forums/viewtopic.php?t=324
Chris
This is coming along great now - looking forward to hearing the speech..
Chris
Cool - I'm guessing the compiler was inlining the setPointer and setIncrement functions already.
Chris
You probably know this already, but the following command is very useful for figuring out where the space is going in your code:
arm-eabi-objdump -D main/bin/testarm.elf
Even if you don't understand the ARM/Thumb parts, the dissassembly give you a good idea of the length of each function. I can see that MenuVerticalBlank and SetGameDatastreams are taking up a lot of space. It seems that the compiler is not smart enough to optimize all those setPointer and setIncrement calls. You could probably save a lot of space by using loops, e.g:for (x=0; x<12; ++x) { setPointer(DS_LOGO_A+x, MAIN_MENU_GRAPHICS_RAM + x*LOGO_HEIGHT + ((x % 2 ==0) ? offsetA : offsetB)); }The setPointer seems to be particularly bad, as a separate 4-byte pointer is being stored every time. I suspect that using an offset from a fixed address may work better ...Chris
No problem - the in-game speech is going to blow people away!
Thomas has a cool graphics overlapping tool if that would be useful to save ROM?
Chris
Interesting!
What is left to do in the game now? I guess audio/speech still needs some work?
If you have a spare 4K bank then I could have a look at getting high score saving working? (The flash memory can only be written in 4K chunks so a whole bank is needed). Though it might be better to use the space for more speech data?
Chris
On level 1 station's are always open, levels 2 & 3 the stations open/close, level 4 the stations start to launch missiles (the guide says this happens on level 3, perhaps there's a dip switch in the arcade game which controls that).The Bosconian arcade manual references DIP switches to control the difficulty (Rank A,B,C, Auto), but doesn't explicitly define what effect these settings have.
Chris
That was a lot of effort for the cores, but they look awesome!
Nice work - is this the 4th or 5th rewrite
Hopefully you'll be able to reuse the code in another game as it is quite generic?Chris
Have you updated all the kernels to the new CDF/FastJmp method?
Chris
Back in the day people wanted a Gameboy because it was small, battery life was far better, it was cheaper, and it had better games. Those advantages were enough that people didn't care about the color.
Chris
Ah - I missed the RESxx, but it will still work before the HMP1 with a bit of padding.
On the VCS - if you don't rewrite the kernel at least 10 times then you aren't trying hard enough
. I lost count of the rewrites for star castle!Chris
CDF Finalized
in SpiceWare's Blog
A blog by SpiceWare
I'm writing a programming guide for CDF, but (as always) it may take some time for me to complete.
Chris
