cd-w
    2,433
Blog Comments posted by cd-w
  1. I should have pointed this out before you rewrote all of the kernels yesterday!
    One final suggestion is to move the HMP1/ENAM1 writes to the end to free up the Y register and 3 more cycles:
    lda #<DS_HMP1_ENAM1     ; 2 71
    sta HMP1                ; 3 74
    sta HMOVE               ; 3 1
    sta ENAM1               ; 3 4
    stx ENAM0               ; 3 7
    lda #<DS_GRP1           ; 2 9
    sta GRP1                ; 3 12
    jmp (Next)              ; 5 17
    Chris
  2. I would be tempted to inline the R76 code in ever single kernel. Also, the few kernels that are really tight for cycles could probably go in the same bank as the JMP table and avoid the initial JMP?
    Trying to find you enough cycles to do digital audio during the kernel icon_smile.gif
    Chris
  3. I guess this won't work because the HMMx need to come before the HMOVE and the ENAMx need to come after.
    I wonder if you could do something like this instead to eliminate the LSRs and allow the GRP1 to be a fast fetch:
            lda #<DS_HMP0
            sta HMP0
            tax
            lda #<DS_HMP1
            sta HMP1
            tay
            lda #<DS_HMMB
            sta HMBL
            sta ENABL
            lda #<DS_GRP1
            sta HMOVE
            sta GRP1
            stx ENAM0
            sty ENAM1
    Chris
  4. I see this pattern a lot:
      lda #<DS_HMMB           ; 2 58 <- just to keep stream in sync
      lda #<DS_M1M0BL         ; 2 60
      sta ENABL               ; 3 63 <- on VDEL, for next scanline
      lsr                     ; 2 65
      tay                     ; 2 67 <- Y has enable for M0
      lsr                     ; 2 69 <- A has enable for M1
      ldx DS_GRP1             ; 4 73
      jmp R76                 ; 3 76
    Could you use the DS_HMMB fetch to eliminate an LSR and save 2 cycles, e.g:
      tay                     ; 2 60
      lda #<DS_M1M0BL         ; 2 62
      sta ENABL               ; 3 65 <- on VDEL, for next scanline
      lsr                     ; 2 67 <- A has enable for M1
      ldx DS_GRP1             ; 4 71
      jmp R76                 ; 3 74
    Even where the HMMB value is used, I think you can still use this trick. It looks like the Y value is only used for ENAM0, which won't overlap with the bits needed for HMBL, i.e:
      lda #<DS_HMMB
      sta HMBL
      tay
      sty ENAM0
    Or even better if you can put the HMBL and ENAM0 together you could free up the Y register entirely:
      lda #<DS_HMMB
      sta HMBL
      sta ENAM0
    You could possible combine one of the other HMMx values with ENAM1 and save a fecther ...
    Chris
  5. Thanks for the explanation - I played with some ideas for the score kernel but I'm not getting anywhere. Using RESPx doesn't work because P0 and P1 need to overlap. The only way would be to display on alternate frames with flicker, but I suspect you don't want that. Given a choice of chunky PF text or flicker, I'd go with the chunky PF text.
    Chris
  6. The console detection is cool - I never expected it to work :)
    I'm not keen on the chunky PF text at the bottom - it is probably possible to do better using RESPx tricks. What are the constraints, i.e. how many digits do you need for the score & lives, and what is the width of the scanner?
    Chris
  7. Thanks for posting the link - that is a really thorough analysis of Tetris! I did attempt to duplicate the gameboy timings and distributions for Chetiry, but there are probably lots of subtle differences. I haven't seen such obsession with the game since I saw this video:
    Cheers,
    Chris
  8. For Chetiry, I used a customized version of the DCP+ fast fetchers to update the audio in 5 cycles, i.e:
    lda #<AUD0
    sta AUDV0
    However, if you are already getting tight for cycles it is probably best to save them for the actual game :)
    Chris
  9. Nice work - this has to be for a Robotron kernel :)
    It feels like it might be possible to optimise further by removing the following two lines:
    lda #<DS_JUMP ; 2 30
    sta NextKernel+1 ; 3 33
    If you could arrange all the kernel entry points to be in the same bank, and repurposed the cycles for the jmp R76, i.e.:
    KernelEntry1:
       jmp ActualKernel1
    ActualKernel1:
      jmp (NextKernel)
    But those 5 extra cycles are probably not enough to update the PF or anything useful ...
    Chris
  10. Good to see you back on AtariAge. I'm also taking a bit of a break at the moment for family reasons.
    I was always hoping that Delicon would return at some point with a completed Chimera cart - I guess he just lost interest. The Harmony has now been pushed to do many similar things (e.g. Space Rocks is a combined ARM/6502 game), but the Chimera had some advantages.
    Are you planning to pick any of these projects back up? It would still be good to see the Cybertec mod improved (ideally with HDMI output), Death Derby is still an interesting project, and I hope to see [email protected] re-released at some point.
    Chris
