cd-w
    2,433
Posts posted by cd-w
  1. Hi Folks,
    I have now created a new version of the maze demo, based on the comments posted here. The old version calculated the entire screen on every frame, which was clearly sub-optimal. The new version shifts the existing screen data, and only calculates the new data at the edges. This change required a big rewrite of the core code, but that is life! The result is an amazing improvement in speed, and the scrolling routine now fits comfortably within the vertical blank region, without the need for double-buffering.
    I am quite pleased with some of the tricks employed in the new code. For example, the screen is represented as a circular-buffer, so we don't have to shift the data when scrolling vertically. However, there is still plenty of room for improvement, and I will welcome any suggestions. The scrolling doesn't quite work in the diagonal direction, but I don't think this is particularly useful in any case. I will probably remove this possibility from the code unless I can find the source of the problem. It is probably just a stray carry, which seems to happen to me all the time!
    On that note, does anyone have any debugging tips for 2600 code? Since there is no printf, I usually write the data into PF1 to see what is going on, but this gets to be a real pain. Something like a memory monitor would help enormously!
    Anyway, feel free to copy this code and modify it for your own purposes.
    Chris
    maze03.zip
  2. Cool demo. :thumbsup:
    Probably something like Cyclotron from last years Minigame Compo would be pretty doable by using this. It was one of my absolute favourites.
    Thanks for the suggestion - it took me a while to get the Oric emulator running,
    but it seems like a rather addictive game to me. I was originally planning some
    kind of adventure game (collect the objects, avoid the baddies), but this looks
    like it would make for a better game. Also, the maze could be generated by a
    pseudo-random sequence to save on ROM space. The only thing that worries
    me at present is that it would be necessary to store the "trail" of the player as
    they move through the maze. In theory, you could loop back and forward several
    times through the corridors, leaving a rather complex trail. It might be rather a
    push to fit this in the RAM?
    Chris
  3. Are you shifting the whole maze from scratch each frame?
    If yes, then you could save a lot of time, by:
    A: only shift the visible parts
    B: shift the maze relative to the last frame
    Aha, that makes a lot of sense. At the moment I am redrawing the
    screen from scratch every time, but it should be possible to reuse the
    existing data with something like the routine by batari posted above.
    Of course, this is going to require a fairly major redesign of my scroll
    engine, but I am rapidly learning that it is necessary to rewrite all my
    code several times on the 2600! I will keep this group posted on my
    progress.
    Many thanks,
    Chris.
  4. Hi there!
    Weird. The scrolling looks better on the horizontal axis than on the vertical. I'd have thought it should be the other way round... :)
    Greetings,
    Manuel
    The vertical axis scrolls by 9 lines in each step. It should be possible to make it smoother by adding more scroll steps.
    Chris
  5. Hi Folks,
    Thanks for all the positive feedback! I now realise that I need to
    calculate the length of the overscan properly. For some reason I was
    assuming that the vertical blank would automatically be triggered at
    the correct time. Unfortunately, this means that the code uses about
    twice as many scanlines as it should in the overscan region :(
    I have now coded up a modified version which calculates the screen in
    2 passes. The calculations are now performed entirely in the Vertical
    Blank region (37 cycles), which leaves the Overscan region free. The
    calculations could probably be done in a single pass by using both of
    these regions, but I hope to make a game out of this demo, so I need
    to leave some space for the rest of the game. Because I am calculating
    in 2 passes, the screen is double-buffered, as only half of the screen
    would be displayed in the first pass otherwise. The scrolling is now half the speed, but I think it is still fast enough for a decent game.
    I have attached the new version of the code to this message. Note: I didn't include the .h files again as there is a note in these
    files that states that they shouldn't be redistributed. However, as
    pointed out above, they are available from the
    DASM site.
    Unfortunately there are two problems with modified version, and I
    would be grateful for any suggestions:
    1) The code overflows the vertical blank region when there are too
    many blocks displayed on the screen. I think the code would be stable
    with only 2-3 more scanlines. As the screen only uses 189 of the 192
    available scanlines, I think this problem could be fixed by extending
    the vertical blank to 40 cycles, and shrinking the screen to 189
    scanlines. Is there any problem with this, or will it fail to work on
    real Atari hardware? Alternatively, I think some work could be done
    during the three vertical sync scanlines? However, most of the sample
    code on the web avoids this region. Is there any reason for this, or
    is it possible to do work here?
    2) The code is now using too much RAM (60 bytes for the screen). I
    would like to reduce this significantly as it doesn't leave much spare
    space. Only 4 bits of each byte are actually being used, so
    theoretically we could fit both screens into 30 bytes by using the
    unused 4 bits. However, there are not enough spare cycles in the
    kernel to do the required masking and shifting. Are there any tricks
    that I can use to make use of these wasted bits?
    Many thanks,
    Chris
    maze02.zip
  6. Hi Folks,
    The "Retro Gamer" magazine in the UK had a feature on the Atari 2600
    last month (issue 12). This feature covered both the gaming side, and
    the programming side, including a pitch for the Atari Age website.
    After reading about how difficult it was to program the machine, I got
    motivated to have a shot myself. My main programming these days is
    done in Java, so it was a bit of a paradigm shift to start programming
    the 6502. Actually, this is the first time I have ever touched real
    assembly language.
    Anyway, cutting to the chase, I have now read through the various
    tutorials on the web, including the excellent material on this forum.
    I decided to get started with playfield graphics, rather than tackling
    the sprite hardware straight away. To get to grips with asymmetric
    playfields, I have coded-up a small scrolling maze demo to test my
    understanding of the principles. The demo and source code should be
    attached to this message. The code is GPL licenced, so anyone is free
    to take it and modify it should they wish.
    My maze demo displays a 6x5 window which can be scrolled around a
    32x32 maze using the joystick. The maze wraps at the edges, so you
    can scroll indefinitely in any direction. It also uses the full
    screen, except for 3 scanlines. I think this demo will make a good
    basis for a number of different maze-type games which I hope to write
    soon. I still have plenty of spare cycles in the vertical bank
    region, and spare RAM to play with. I would be grateful for any
    suggestions on how I can improve the code, and any flaws in my
    programming technique. The scrolling appears to be stable in both
    Stella and Z26, but the line count in Z26 fluctuates between 270 and
    290 scanlines? Any pointers on what I am doing wrong would be most
    appreciated.
    Cheers,
    Chris
    maze.zip
