mksmith
+AtariAge Subscriber
    1,152
Posts posted by mksmith
  1. 1 hour ago, Gandor said:
    Thanks for your help.
    Was able to bring up the sprite editor via the welcome page.
    My Status Bar Commands setting were set to full but no icon which will open the sprite editor.
    Besides the play icon (compile source code) and rocket icon (compile source code and run in emulator) I do have an icon which looks like an open book and if I hover my mouse over is says: "Sprite Editor Right (Ctrl+\)" but all it does is open a second duplicate window of the current window.
    Hmm very strange - which version of VS Code and the Extension is running?  And the Developer Tool logs there was no error/strange messages?
  2. On 1/26/2021 at 1:47 PM, Gandor said:
    Question: how do I start the sprite editor?
    Was trying to load a sprite from the multisprite sample code in the sprite editor but I see no way to start it.
    The github page mentions short-cut buttons on the status bar but mine doesn't show anything.
    Tried uninstalling/installing but didn't work.
    I'm running windows 10.
    Any suggestions?
    Hi Gandor - apologies for not replying earlier I just haven't had much time around the forums the past week!!
    There is potentially an issue with the extension not starting correctly if you don't see the status bar shortcuts on first install.  To do an initial check to see if it's loaded start VS Code and open the Developer tools via the Help menu. Once the Developer Tools are open, click on the Console tab and review the log.  It should state that Extension 'Atari Dev Studio v.x.x.x is now active!' and also display the path.  If not it may display some sort of error.
    Hopefully it has started and if so you can try activating the Sprite Editor via the Welcome screen.  To do that open the Command Palette (Shift+Ctrl+P) and type 'ads' which will provide a link to open the Welcome page.  From there you will see the shortcut on the Welcome page.
    If everything is working but the status bar link is not available you can check that via the Settings (File > Preference > Settings):
    Hope that helps!
  3. Well done everyone! (sorry Lewis at a basketball tournament ATM)
    I did a bit of a search for how showing these type of characters might be done in VS Code.  There was quite a few requests for something built-in but there are a few extensions that were recommended:
    https://marketplace.visualstudio.com/items?itemName=wengerk.highlight-bad-chars
    https://marketplace.visualstudio.com/items?itemName=nachocab.highlight-dodgy-characters
    https://marketplace.visualstudio.com/items?itemName=nhoizey.gremlins
    I might add an appendix to the main post for useful extensions.
  4. All of the originals run the pokey @ $4000 with all the modern ones running @ $450.  Fred initially indicated base support was @ $4000 with the return to development and I think he and Mike may have discussed the move by modern homebrews to the new location and preliminary support was added.  The initialisation routine in 7800basic has caused some issues and a bypass has been determined (Darryl has manually implemented for Popeye currently). I'm trying to add it into our pokeysound driver but testing has been very slow at my end 😓 (so busy!!)
    • Thanks 1
  5. In relation to 160A/B definitely the background is best to stay as 160A as that is covering the full screen. The bomberman would be fine at 160B - being the main character using the full range of colors would really pop (Millie & Molly does this). The enemies if you can get away with 160A would be ideal but you could certainly try 160B with those.
  6. 2 hours ago, SpiceWare said:
    I'd mentioned it to @mksmith about a year ago.  He looked into it and said the background colors could not be set. I told him that even just different foreground colors would help, as that's how I'd originally implemented it. Don't know if he looked into it anymore after that.
    I've been using that since I started doing DPC+ projects. I thought I got it from the wiki page I linked to, but don't see the code - possibly the page was edited, or I found it somewhere else. The ARM has an inline barrel roller so bit-shifting is done for free. I cover that here in the comments of Part 3 of the CDFJ tutorial. So I tend to use different bits, such as this snippet of the robot initial position routine in Frantic:
                    gSpriteX[spot] = 12 + (x * 28) + (((getRandom32() & 0xff) * 18) >> 8);
                    gSpriteY[spot] = 10 + (y * 60) + (((getRandom32() & 0xffff) * 43) >> 16);
                    // start each robot's eye in a different position
                    gSpriteAnimFrame[spot] = (6 * (getRandom32() & 0xffffff)) >> 24;
    Hi guys, still on the list at this point as the way the rendering engine works in VS Code make's it almost impossible.  It been 10 months since I opened an item in Github and VS Code has made some changes (I believe) around rendering so they may have some enhancements in this area (there has been a lot of feedback to allow this sort of thing).  I'll take another look shortly and see if it might be possible.
    • Like 4
  7. 7800 Pokey Engine
    Welcome to the 7800 pokey engine for music and sound effects playback on the Atari 7800 Console. This engine was initially developed (based on the disassembly and reverse engineering of Ms. Pac-man by Atari) by Perry Thuente (tep392) and Bob DeCrescenzo (pacmanplus) for the purpose of providing pokey sound playback for the Pac-man Collection. The engine has since been enhanced and is now also being used for other homebrew titles such as Millie & Molly 7800 (Matthew Smith), Popeye (Darryl Guenther) and Danger Zone (Lewis Hill) thanks to the awesome music abilities of Bobby Clark.
    The 7800 pokey engine has been kindly open-sourced by the contributors and is freely available to the AtariAge community for use within any project.
    The source is currently maintained by Matthew Smith (mksmith) and is available to download from Github.
    Contributors
    The following people have contributed to developing the pokey engine:
    Additional Testing
    The following people have contributed to testing the pokey engine:
    Titles using the pokey engine
    The following titles are using variants of the pokey engine:
    • Pac-man Collection
    • Millie & Molly 7800 and Arkanoid
    • Popeye
    • Danger Zone
    Music development
    Bobby Clark is the first and foremost expert in developing music and sound effects using this engine and has produced some outstanding compositions.  I'm sure he would be happy to help you if you ask!
    Compiling for the Concerto Beta
    When compiling builds for use on the Concerto beta there are a couple of things you need to be aware of:
    • Enable the SKIPINITFORCONCERTO flag in pokeysound.asm
    • 144k ROM is the best supported ROM size and should work without additional change
    • 128K+RAM ROM will work but the ROM header will need to be manually changed to remove the pokey @ $450 flag
    • 128K ROM does not produce any pokey sound
    These notes will be updated as batari makes enhancements and changes to the Concerto firmware.
    Changelog
    v1.03 (18 Feb 2021)
    • v1.03 - re-implemented CHANNLSKCTLS lookup (mksmith)
    • v1.02 - renamed SKIPCHECKFORPOKEY to SKIPINITFORCONCERTO and verified changes work (mksmith, trebor)
    • v1.01 - updated SKIPCHECKFORPOKEY process to better handle $450 detection (playsoft)
    • v1.00 - open sourced to Github (mksmith)
    • v0.11 - added queue scheduling (playsoft) and SKIPCHECKFORPOKEY flag Concerto issue). Added RESETPOLYON and CHANNLRESETON table flags (mksmith)
    • v0.10 - removed number of channels (not required) and added a tune-by-tune reset table (mksmith)
    • v0.9  - removed SKCTL set and added ability to set number of channels to activate (mksmith)
    • v0.8  - added MUTEMASKRESTFLG const so rest value can be customised (mksmith)
    • v0.7  - re-implemented MUTEMASK change (reveng)
    • v0.6  - fix 16-bit mode, SKCTL, or any mode requiring one channel be silenced and stops popping noises (sythnpopalooza)
    • v0.5  - 7800basic Pause Support (mksmith)
    • v0.4  - 7800basic PAL Support (mksmith) [suggestion on how to implement by reveng]
    • v0.3  - Reset poly support (sythnpopalooza)
    • v0.2  - Added PLAYPOKEYSFX enhancements, STOPPOKEYSFX (mksmith)
    • v0.1  - Initial version provided by pacmanplus and sythnpopalooza
    Using the pokey engine in 7800basic
    The engine itself is reasonably straight forward to integrate into 7800basic and there is a detailed example for how to properly setup and configure your game to use it.  Saying that it can be tricky at the beginning as you will need to determine the required features to be activated and also configure and locate the music itself potentially across various banks.  The basic process is as follows:
    • copy file pokeysound.asm into the base root folder of your game. 7800basic will automagically replace the base file in 7800basic during compilation.
    • inline pokeyconfig.asm into your game source (this should be the end of the last shared bank so it can be accessed at all times)
    • inline your musicxxx.asm file(s) into your game source. There can be one of more of these spread across multiple banks depending on how you game is structured but in reality as with bank sharing the tune data MUST be available to be currently active bank.
    Other changes to your source
    The following changes are required to be made to your 7800basic source:
    1. Insert the following vars:
     dim POKEYADR = $450   ;$450 (modern homebrew) or $4000
     dim TUNEAREA = $2200  ;range $2200-$2246 (46 bytes)
     dim SOUNDZP = y.z     ;all pointers must be located in zeropage
    Note: The TUNEAREA location or SOUNDZP vars can be changed to suit your requirements.
    2. Include the following to service the player each frame (this should be in the last shared bank so it can be accessed at all times):
    topscreenroutine
      rem call the pokey servicing routine
      asm
        jsr SERVICEPOKEYSFX
    end
    return
    Examples
    • example1.78b - basic implementation showing how to integrate the 7800 pokey engine into 7800basic including adding pokeyconfig and music data assembly files via the inline feature, calling and playing multiple different tunes and sound effects.
    Additional notes
    • tunes can be moved into RAM and played from there if required (example coming soon)
    • an release for assembly users will be added soon
    Need some help?
    Contact Matthew Smith (mksmith) if need any assistance implementing this engine into your game.
    • Like 12
    • Thanks 2
  8. Hope all is well with your daughter Anthony!
    Using a sprite based process is quite a good way to do it (Mike did a great job coming up with the process).  Millie & Molly uses (12x24pixels - but effectively 3x 12x8) and Arkanoid (12x8) tiles - Marco appears have that covered with the above and you loss that stretchiness that comes with 16 wide.
    So the process works like this: the background is configured by plotting the tiles (I use data tables to do that) then from there Mike's code takes over and you effectively update pointers to change tile images or palettes - nice and quick.  For Millie & Molly I overlay a sprite for the girls but everything else is done using Mike's code. Animating tiles is very easy using this process as well - effectively no different to animating a sprite now just replace the plotsprite call with a call to Mike's code.
    You can mix 160A and 160B for backgrounds but it can be a fair bit of work to make sure it is setup correctly and the images are in the correct gfx blocks (The Doh level in Arkanoid is does this but it was very tricky!).  I would definitely recommend 160A only for the backgrounds - your moving overlaid sprites could be 160B if required but you still have potential to run out of render time very easily even with this method.
    More information about this process is here:
    7800basic, under the hood - Atari 7800 Programming - AtariAge Forums
    Doing larger data tables:
    7800basic Tips, tricks and examples - Page 2 - Atari 7800 Programming - AtariAge Forums
    I'm more than happy to help in anyway if you need a hand to setup this process to see how it goes 👍
    • Thanks 1
  9. 2 minutes ago, Synthpopalooza said:
    Let's see what I can knock out tonight.
    There's been some mods made to your sound code, thanks to some help from @RevEng and  @mksmith
    1.  Sounds will now play at same speed in PAL or NTSC
    2.  A MUTEMASK kludge has been implemented for note rests (not needed here, but we had discussed this in other projects)
    3.  A RESETPOLY routine, for stabilizing sounds if using $Cx mod 3 settings (also not needed here).
    I'm check-over the changes from Darryl for the MUTEMASK/RESETPOLY (one of those!) and I'll send you the latest source Bobby.
    Nice work again Bob!
  10. 1 hour ago, Gandor said:
    Any idea when this game will get a physical release?
    Played the demo this afternoon on JS7800 and loved it.
    That rewind effect is just so cool.
    Thank you @Gandor for playing. We are hoping to be in the next round of releases in the first half of this year here at AtariAge 👍
