Macross_VF1
New Members
    93
Posts posted by Macross_VF1
  1.
    So I have an issue with my Philips Videopac G7400. It outputs a piss poor RF signal, no matter how much I try to tune the TV. When I started digging around the net I saw that it was easy to convert to RGB, just a matter of installing a number of components.
    https://www.the-nextlevel.com/odyssey2/articles/g7400guide/rgbmod.php
    Unfortunately, nothing improved. As can be seen in the attached image (the image was taken while using RGB), the signal is still distorted and it does not matter if it is RF, composite or RGB. Anyone have any idea what the problem might be? I have tested the internal AC adapter and it outputs pretty much the correct voltage, 4.95V on one line and 11.43V (should be 5 and 12V respectively) on another.
  2. Just managed to acquire a really old console; A Philips Odyssey 200. Unfortunately, it behaves strangely. The picture is warped and it does not seem to start as intended.
    As the first picture below shows, I get some strange results. I can manipulate the two darker icons with the controls but the game doesn't seem to start, the "ball" is missing and nothing really happens. And before anyone asks if it's the TV coulnd't tune into the right channel, what is shown is actually composite since I have connected an external composite circuit. When using RF the picture remain the same though obviously blurrier.
    What I primarily wonder about is whether this can be due to low voltage. The original battery holder is missing (second picture) but it's supposed to accommodate 6 C batteries for a total of 9V. Instead, a previous owner has soldered an external AC adaptor that can only handle 4.5V (is tested and gives 5V so well within tolerances)
  3. I'm afraid wire colours may have different from week to week so your best bet is to look and measure the wires. As for the extra GND, the old 1530 had a separate ground wire ending in a small ring of the kind you would screw onto a metal case. Many users cut off that wire so it wouldn't trickle into the userport and cause random damage. Perhaps this wire lives on as a separate pin in the mini-DIN of the 1531?
    The extra/external ground wire you are referring to is present on the 1531 but it has been fully integrated into the cable. It's called 'shelled wire' in the schematic.
  4. I'm hoping the hivemind might help me with this. I have a 1531 datasette that lacks a plug, just bare wires at the end of the cable. I also have a dead 1530 from which I can scavenge a plug from. Of course I first have to figure out which wire goes where.
    First of all, a 1531 have an extra wire, yellow, compared to a 1530. From what I can see of the 1531 mini-DIN pinout, the extra wire should be an extra GND not found in a standard C64/128 cassette plug. I've also managed to figure out that the PCB on my 1531 is a #017-5001-01 by studying the service manual but the order of the colours in the schematic does not match my 1531 as I've noted in the attached image. Curiously, the dead 1530 does not have a corresponding PCB revision in the service manual.
    By carefully tracing where each wire enters the PCB, what it connects to and comparing to the schematic I think I have the proper order but I need confirmation, particularly on the +5V line so I don't fry the entire thing.
    White - + 5V
    Black - Motor
    Green - Sense
    Yellow - Read or Write
    Blue - Read or Write
    Red - GND
    Brown + shell - GND
    I'm almost 100% sure about the black, green, red and brown wire. The same cannot entirely be said about the white, yellow and blue.
  5. Considering the game was brand new and sealed in the box when I got it, it shouldn't be possible that the cartridge connectors are dirty. Of course that does leave the console connector. Still, I'm inclined to believe that it is the game that's defective. When I put it it into the console and power on, it takes about three seconds to get a red screen. If I instead deliberately insert the game improperly, for instance at an angle or not fully pressed down, I get the red screen immediately. To me it would seem that, when fully inserted, the game tries to load but fails. Anyway, thanks, you guys have at least helped me with how to identify EU and US games. Turns out that my Raiden game and one other in my collection are indeed the US version.
  6. So I've had a Raiden cartridge for my Jaguar since I bought the machine back in 2005 or so. However I've never gotten it to work so I always thought it was broken or something. However, I recently found out that this particular game, while not specifically being region locked, was optimized for the region it was supposed to be sold in, ie the US or Europe. Could this be the reason that I've never gotten it to work? That I might have a US version when I have a PAL Jaguar? Also, is there any way to actually tell if a game is the EU or US version?
  7. Exactly, I would test these points again with it connected to the main board and with a game running.
    Tested again while connected to the main board and a game running. TP-4 is still a bit high, though perhaps not overly so at 19V, and TP-6 outputs a far more reasonable 5.85V. So probably just a false alarm then. Oh well, better to be safe than sorry with electronics that are this old.
  8. So I'm currently doing some maintenance and cleaning of my Intellivision console and while doing some research on the machines schematic I came across the chart below and figured I might as well give it a try. And I'm pretty happy that I did for I got some readings that I hope you guys might be able to help me with.
    Intellivision-I-Power-Supply-Test-Points
    So, using the above chart I mapped out the suggested test points. TP-1,2,3 and 5 are all good but TP-4 gives +25.6V and TP-6 outputs +13.8V. Since TP-4 is directly connected to C3 I figured I might as well replace it as I have a decent number of 2200uF/50V capacitors lying around, however the TP-4 and 6 voltage levels remain the same. Unfortunately I don't have any to replace C1 with (10000uF/16V).
    Normally, voltage that high above their suggested levels are not good for a console though I wonder, could this be due to me having a Pal console, a different revision or any other possible reason? Also, I suppose I should add that I tested it while unconnected to the console.
  9. I forgot to add that I've also replaced the RAM chips and the OS chip as well. I kinda wonder what could cause this much damage. I suppose it is likely the original PSU might have died and damaged the system with it, or it might have been connected to a PSU with the wrong specs.
    Anyway, thanks everyone who helped bring it back to life. I couldn't have done it without you. Extra kudos to ChildOfCV who just didn't quit even after the colour problem was found.
  10. Ok, here's the good news. With C53 replaced I get a rather different set of readings at Q6:
    Q6 C 1.6V
    Q6 B 0.5V
    Q6 E 0V
    I've also replaced 74LS74 and now I finally get colour!
    Just for shits and giggles, here's all the repair timeline.
    • Bought it several years ago and it didn't function at all.
    • Started tinkering some months ago with the capacitors and finally got it to power on, though only to a black screen.
    • Replaced all the electrolytic capacitors. Still black screen.
    • Replaced all the transistors. Still black screen.
    • Started removing the major chips except Pokey to test them in a 600XL. All major chips worked fine.
    • Removed Freddie to test in a 130XE. Finally found something faulty.
    • Borrowed the working Freddie from the 130XE to the XEGS. Got a picture but lacked colour.
    • Ordered a new Freddie while asking you guys for help.
    • One resistor connected to the colour trimpot found to be of the wrong value. Replaced though still no colour.
    • 4050 chip tested in 130XE, worked as intended.
    • Colour issue finally traced to faulty 74LS74.
    • Ceramic capacitor C53 closely connected to transistor Q6 found to be faulty.
    • 74LS74 and C53 replaced and the machine works as intended!
    Here's some pictures to celebrate:
    • Like 6
  11. This is a long (and growing) thread and I may have missed it along the way, but have you tried replacing the 4050? I've had one go bad and leave me with black and white video before. They're rather fragile chips all things considered, but modern equivalents are still being made and they're cheap.
    No need, it's already been tested and found to be working though it's a good suggestion none the less.
  12. No, I meant the packaging of the crystal. Those packages always looked like metal cans, though looking into it some more, perhaps they're surrounded by glass or resin and painted silver. Anyway, if the crystal isn't shorted, you're okay there.
    Anyway, the 4.7K ohm reading is much nicer.
    Well, let's get rid of some pronouns to make sure we're talking about the same thing.
    By "it" did you mean that you pulled the capacitor and measured the resistance of the capacitor at 36 ohms?
    Or did you mean that you tested the junction at R72/Y2 and still got 36 ohms even after pulling the capacitor out of the circuit?
    If it's the former, then definitely replace that capacitor! Burn it with fire, destroy it beyond recognition, eradicate its existence, etc. Capacitors should NEVER have a DC resistance reading across them, especially not one in the 2-digit ohms.
    If it's the latter, then there's something weird with the traces in order to get your situation, and it's apparently somewhere near C53's connections.
    My particular crystal is mostly covered in some kind of shrinkwrap so it severely limits the possibility of a leg touching the case. Still, I checked just to be sure and the legs do not appear to touch the case.
    Anyway, yeah I got 36 ohm when testing the actual capacitor when it is pulled from the circuit. When testing R72/Y2 junction with C53 pulled I get 4.6-4.7k ohm.
  13. With capacitors, look for a string of 3 digits. Two will be significant values, and one will be the power of 10, just like a resistor. So in this case, 100000pF, which also means 100nF or .1uF.
    Well okay, 738 also technically fits that description, but the numbers are out of the typical decade values for capacitors, and the exponent is way too high for a ceramic capacitor.
    As much as I hate to say it, the next logical failure point is the crystal. Could you disconnect it and see if the short goes away? And after disconnecting, see if there's conduction between a leg and the case.
    I've disconnected the crystal and taken another resistance reading between R72 and where Y2 would connect. At first I got 4.6k ohm but then I remembered that I had not resoldered C53 and with that returned to its rightful place I got 37 ohm again.
    Conduction between a leg and the case? Do you mean the metal shield? If so, that's impossible, all this time I've tested the machine without the shield.
  14. ...and the plot thickens. I redid the DC analysis out of curiosity, assuming that the other side of R71 is shorted to ground. I got 0.2V at the base of Q6... just as Macross measured. With the base voltage this low, the transistor would be off, so that leaves about 4.56V at the collector (which is also close to what he measured). This is significant because it should be nothing but capacitors between R71 and ground, which means there's no normal way for that short to be there.
    Could you take a resistance measurement from that 470-ohm resistor (other side from Q6 base) to ground to confirm whether or not there's a short here? If so, "C61" is suspect. On the good side, that would also mean that Q6 is good.
    Ok, so this turned out to be a lot more difficult than I had first anticipated. It seems that my XEGS is vastly different around Q6 than compared to the schematics. I've tried to do my own diagram, though I fully admit that I might have missed something.
    *Edit* Just saw that I missed marking which leg is the emitter on Q6. It's the leg connected to ground.
  15. Paydirt indeed!
    Since you guys suggested that U10 (LS7474) might be a possible culprit I promptly desoldered it and tested it in my 600XL as every chip is socketed in that machine. And sure enough, no colour when using my 600XL with the XEGS LS7474! Finally!
    Unfortunately I don't have a 14 pin socket to put in my XEGS though considering I have to order a new LS7474 anyway, that's not much of a problem.
    While I feel it's unlikely that this particular unit will have more challenges to present to us as just about every part of it has been scrutinized under a magnifying glass and/or been replaced, I will hold my breath until I have the new parts. Still, it has been a pleasure to work with you, and I've learned more about troubleshooting and reading schematics than all of my previous 37 years of life combined. I'll be sure to return if I have any other problems.
    • Like 4
  16. +1 on flashjazzcat. Also, resistors have a tolerance spec of some percentage from the stated reading (that's what the red/gold/silver/brown band at the end is). In short, if the actual reading is within a percentage of the resistor's stated value (based on the final color) then it's okay.
    Anyway the resistance from +5C to Q5 base should be about 6.6K. If so, then that's apparently good.
    Now, on the PAL pin... On the 130XE, this pin is connected to pin 20 28 on NTSC versions, or a separate PAL oscillator on PAL versions. So that answers what that pin is for: The color clock. I think you determined that yours is a PAL version, right? Anyway, proper color depends on getting clocks on GTIA pin 16 too. If you take a DC reading, it ought to be in the same mid-range you saw on Sally 3. An AC reading should be significant too.
    In most cases I certainly agree with you on the resistors. The only one I would find any major fault with is R80 and even then, I don't think it's serious. I just figured it would be better to include the values, instead of leaving them out.
    Speaking of resistors. I've changed the 680k resistor to a 1k and the voltage across the trimpot now go from 0-8.7V. Sadly no colour despite that bit of improvement.
    Resistance from +5C to Q5 base is indeed 6.6k Ohm. Spot on.
    Oh yes, this is most certainly a PAL machine. Pin 16 gives 4.5V DC and the same low 0.01V AC. I saw that Q6 is also closely connected to pin 16 so I figured I should take those readings as well.
    Q6 C 4.5V
    Q6 B 0.2V
    Q6 E 0V
    Also part of this particular corner of board is Y2 which I suppose is the oscillator you mention. Any tips on how I should measure it?
  17. I have at least one bit of good news, I've received my new Freddie chip so I no longer need to borrow one from my 130XE.
    All the chips I've desoldered (GTIA, PIA, Sally, ANTIC, Freddie and 4050) have been tested successfully in other computers. The only major chip I haven't desoldered is Pokey but that chip really shouldn't be an issue here.
    It turns out that Jerzy's schematic of the XEGS is pretty darned accurate when it comes to the video output from GTIA so I've used it to visualize my findings.
    Red are resistors with a faulty value, though I haven't checked yet if the rings on the resistors match the value I'm getting from my multimeter.
    Yellow is just a typo, the resistor is named R78 instead of R53.
    Blue are the voltage readings I get from all the transistors
    Green are other voltage readings, DC if nothing else is written.
    I also used red to show the resistance across L5.
  18. O1 is the output from pin 3 of Sally on the schematic, into "C44". It's going to be a clock signal. The proper designation is φ1 or ϕ1 depending on who's writing it, but try to do either with an American keyboard.... Anyway, it's constantly flipping between 0 and +VH so your meter will always see something in the middle on a DC reading. Or an AC reading for that matter. (VH is the voltage output of a high, which depends on logic technology... may be about 5V, may be about 3.4, etc). And yeah, I am placing the component designators in quotes due to the mentioned inaccuracy of the schematics. By the way, do you get AC voltage on pin 17?
    Does an AC mode measurement of "R54" give you any appreciable voltage? 0.23V (DC, I assume?) is really low and may even be bleed-off from the luma signal. If the 130XE is a good model, that should be closer to 2V (and looking at the schematics, they are pretty much identical there). Note that the voltage across "R54" should be just a little less than the voltage on the base leg of "Q5 east". Both AC and DC readings of both of those components might shed some light on the problem source (GTIA or "Q5 east")... that is, if it's being told to turn on but it isn't, vs not even being told to turn on.
    I've done some further measurements based on your suggestions though I admit that I'm not well versed with AC voltage. I pretty much only get 0.01V AC no matter where I take my readings though it just might be that I don't know how to do it properly.
    Pin 3 of Sally gives 1.5V DC
    Q5 Collector - 5V DC
    Base - 0.73V DC
    Emitter - 0.23V DC
  19. O.o What is your replacement transistor by exact number
    as read off it? Who made it as well if known. Sometimes
    they don't put the base in the middle which can lead to
    another round of calling one's self unsuitable names.
    Wrong setting will plague us all among many other
    foolish things. It's ok - we are just going to grin a
    little bit - any more than that is tempting our own fate.
    -0.6 volt to me might be the base instead of the collector?
    Replacement transistors will state they are suitable
    but don't go into details of how they moved the base
    from the middle leg and now it's opposite #1, the emitter.
    As counted/read left to right.
    Here's the thing with all the transistors. Before I started this topic I had already replaced the old ones. When we started to discuss the possibility of Q1 being faulty, I actually switched back to the original one. I had kept them just because I'm aware that the leg order sometimes change despite using supposedly perfect equivalents. The old Q1 is marked as 751 2N3904 and the replacement as 2N3904 R1 C. Unfortunately I don't know who made the new ones.
    As for the 680k resistor, should I simply replace it with the correct one? Unfortunately I don't currently own a 680 ohm resistor, the closest one I have is 1k.
    I don't know if this is in any way relevant but I checked all the diodes as there are only four of them. I don't know much of the inner workings of diodes but two of them gives of a strange reading. All of them gives 0.6V in one direction, which is pretty standard. CR4 and CR3 however gives 1.8V and 1.5V respectively in the other direction.
    O1 is a clock, so it won't give you a constant voltage. If you're taking a DC reading, the multimeter will likely give you an average of its on/off time unless you have a MAX function. But all you need to check for working at the moment, is the voltage at both pins of C46, which ideally would be 10V, but practically 9V or better should be awesome (due to loss of voltage at the diodes). R37 will decrease that a little at the trim pot.
    You mentioned that C48 is dodgy. I don't know exactly how the delay line works, but intuition says that the TIA (or GTIA) will discharge the capacitor when it's ready to start counting for output, then let the trim pot charge the capacitor until it reaches a threshold voltage, then start its internal quadrature oscillator. So C48 must have a good connection to ground on one leg and a good connection to the trim pot and pin 17 on the other leg. And of course the capacitor itself must not be internally shorted.
    If you have any voltage at all at GTIA pin 17, you're probably good enough to get SOME color, even if it's the wrong color.
    The color output goes from 21 to the other "Q5", and that's about the only thing blocking color output (unless that capacitor "C44" is bad or broken). Did you verify whether there's any color output from pin 21? Does "R54" have DC voltage across its pins?
    O1? I honestly can't find anything marked 01. I have checked C46, which gives 5V, unless you refer to C46 on my board, which would be C14 and that gives 7V.
    I most certainly get voltage to GTIA pin 17 and it varies with the trimpot.
    How do I verify if I get any colour from pin 21? R54 gives 0,23V
  20. Of all the boneheaded, stupid rookie mistakes one can make... Not only did I set my multimeter to the wrong setting I also put the common probe to the wrong place!
    Here's the updated and correct measurements.
    Between Pin 3 of Sally and C44 I'm getting about 1.6V and should be 4.8
    The trimpot's range should be between 0-8.5V but is between 0-7V
    I should be getting 5V between C45 and CR3 but instead I get 5.5V
    Also, directly after the collector leg on Q1 there's a 2.4V indicator. I don't know if it's relevant but the voltage I got from that point is -0.6V.
