Posts
1,202 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by mr-atari
6 hours ago, _The Doctor__ said:
litedos xs?
litedos ro?
dunno, about apeloader as a standalone but why not? and lots of 3 sector loaders out there... wasn't this already covered
during some talk of loading disk stuff with a 400 etc...
food for search and thought in any case
what's the memlo of xs and ro?
But they are still handler based, so it installs D to the device-table.
-XS $BD0
-RO $9FF
Doing a destructive load, you can start at loading $8F4In theory, a loader, can be much smaller....
- 1
The later productions of MyIDE-1 have power on pin 20, yes.
So you can plug it in just like that.
No need to use the power-header.Pin 20 is on the label side, you can have a peak inside with a light.
Latest firmware etc, please vidit the atarimax forum.
12 hours ago, tschak909 said:
* People that don't use SDX
* People that use SDX
The problem is more who use Fuji as stand-alone or not.
I have the same 'issues' when booting over SIO, I have a executable that loads and mounts the last stored Fuji-config.
I would suggest that FujiNet should restore the last configuration by it self when something else takes boot-control.
That works for any DOS or any one who uses Fuji as device (not stand-a-lone)
Is that workable Thomas?
So during powerup:
-if Something else boots, restore configuration.
-if Fuji boots, do the config stuff and end with OPTION to boot.
I really hope this can be done.
Later!
- 1
14 hours ago, ivop said:
I have the feeling that you are not on the same page, so to speak. @xxl an unmodified 800XL can reach divisor 0 if either the device has proper Schottky diodes in place (I have seen that working on a prototype of @mr-atari, even higher bitrates when Pokey is externally clocked), or if you run your device through @lotharek's SIO hub, which has similar signal clean-up in place.
Edit: yes, SIO2SD should be able to reach divisor 0 with above mentioned solutions.
Maximum external clock speed is 4 cl/bit for POKEY to accept serial-data in the shift-registers.
That is what I found by trail and error.
That is a whopping 443 kbit/sec (or 44 kByte/sec) !
Called "project Warp-factor 4" back in the days.
My experimental device is a SIO2SD-arduino, with attached clock-lines.
FujiNet currently has the external clock enabled with programmable Khz.
But you need to remove the caps to make this work.
https://github.com/FujiNetWIFI/fujinet-platformio/wiki/SIO-Command-%24DF-Set-External-SIO-Clock
The code is a bit tricky, since switching from asynchronous to synchronous is not that straight forward.
Grtz,
Sijmen.
- 1
One of my early production IDE interfaces.
Interface only, no boot-rom.
Should come with 2x 5.25"discs with software/drivers and a 3.5" disc for SIO2PC.
I don't see them often pop up.
Nice though, was fun times, using pole position cartridges and converting them.
Currently Atarimax has the rights to produce MyIDE-interface based hardware.
Later!
Update to MyIDE_Only #7 ?
That could fix some issues with the stock flash-content.
http://www.mr-atari.com/Mr.Atari/MyIDE-ONLY/
Grtz,
Sijmen.
P.S. you do know atarimax has it's own forum, right?
- 2
It there a all-in-one zip file with the patched versions?
2nd : is illegal in LiteDOS, but also in SDX.
Please use another separator and it's ok.
Try my new LiteDUP, I mail it to you.
- 1
Check the door-switch.
Why the question about a fuse?
Here it is as a txt file.
Reading the source, the checksum location is skipped.
Grtz,
Sijmen.
- 1
- 1
I fixed a broken console-switch for a friend some time ago.
It are the same switches used in Atari-Paddles.
So if you have some for spare parts, replace yours with it.
- 2
Thank you so much, this was easier then I thought.
It will help me a lot debugging special hardware.Nice.
- 2
13 hours ago, phaeron said:
You can't just change the protection on an address space range, something has to provide RAM at that address. One way is to write a custom device that has a memory layer to map 256 bytes of RAM there.
How do I write a custom device?
Is there a template I can download/use?
I know my way around in 6502, that's about it....
OK, I cut/paste your example of 8k cartridge and changed to this:
It does something, any good like this ???
Thanks!
option "name": "256b D500-RAM";
Segment ram: {
source: "d5ram.bin"
};MemoryLayer wina: {
address: $D500,
segment: {
source: ram,
offset: 0,
mode: "rw"
cart_mode: "left"
I have perhaps a very stupid question, but I can not find it or figure it out....
How do I change the memory map?
I would like to change D500-D5FF from mode --R to ARW
So it can be used as normal RAM
Grtz,
Sijmen.
On 5/15/2020 at 3:41 AM, phaeron said:
This is intentional, both to prevent the emulated computer from opening huge files. This is particularly an issue with H6-H9: since the file is kept in memory to support seeking with EOL translation. You should have gotten disk full errors trying to write to the file past that point, however.
I could see lifting this limit for H1-H4: since in that case the data can be spooled to/from disk.
Any progress in fixing the 16mb limit?
One request, that is pestering me always, is it possible to include a tic-box in the device-list?
This to disable or enable devices.
That would awesome, when testing software on many different systems...
Thanks!
- 2
If that would be possible (or at least one specific Hx:), yes please.
I did not check for errors (on write), assuming when files are opened correctly, this should not happen.
So that went passed me.It had me puzzled for some time, since I was working on video-compression and I could shrink 500+ Mb into 16, lol...
Many thanks in advance ?
I have an issue with device H:
Most likely nobody noticed because of the file-size in "normal" use.
But when I output (or throughput) a file, it's output-size is limited to 16Mb.
All bytes beyond 16Mb are lost in space...
Can you have a look?
Thanks!
Move the chip to the far right.
Pin 1 to the left, that is correct.
That is how I use my programmer.
Mine has this symbol:
Better late then never ?
Enjoy !
- 1
I have one too, from an Atari maintenance guy.
He told me it was used in testing 400/800 ports.- 1
- 4
MyIDE1 and Transcend Flash module
Last firmware update I did for MyIDE-I is here.
https://www.atarimax.com/flashcart/forum/viewtopic.php?p=9942#p9942
(2017)
