433 -
Posts posted by Fierodoug5
30 minutes ago, manterola said:Thanks! that worked. I expanded the spiffs partition (new offset: 0x250000 new size: 0x1B0000) by shrinking the app0 previous partition (size from 0x340000 to 0x240000)
Now I was able to print to emulated Epson printer.
Could you walk me through that, i have the file open, just a bit confused which numbers to change. Thanx
Doug
2 hours ago, jamm said:I added a couple of font files that probably put things over the edge on WROOM boards. If you remove the two TTF files in the /DATA/WWW folder you should be fine and it won't affect operation.
Yup, that fixed it.
Thanx
These last couple updates are the first ones to not work with the older Wroom boards.
When I upload file system image, i get error
SPIFFS_write error(-100001):file system is full
error adding file!
error for adding content from www!
Nice find, funny I just listened to the antic podcast on databar last night
20 hours ago, mozzwald said:In addition to this, there have been reports of FujiNet not working with the Lotharek SIO Splitter/Hub which I suspect is a similar issue. @DrVenkman or @Mr Robot do you happen to have one of those?
On my wroom unit, the splitter/hub works fine on my 800xl.(that's the way I have had it hooked up since I built fujinet) Fujinet will NOT boot with a 800 and splitter/hub, even if it is the only sio device plugged in.
Very cool....good job
Was able to update my wroom units and load both XEX on the fujinet server plus a few on my local tnfs
duh, its the same way were doing it just with a new EXE.
I feel dumb now...been a long hot day
Works great, Thanx
12 minutes ago, tschak909 said:Run CMD.EXE
cd\wherever\you\put\tnfsd
tnfsd path\to\your\data\folder
-Thom
where do i type that into?
8 minutes ago, tschak909 said:please run it from a shell.
-Thom
Gonna need directions for that. Have no idea how to do that
8 minutes ago, tschak909 said:are you running from a shell?
-Thom
no
got it from the downloads page on fujinet.online
I can still connect to Fujinet and irata TNFS servers, just not my own local one
Since I updated my fujinet units my TNFS server is dead.
I downloaded the new TNFSD.exe for windows(windows10) and I cant open it. It tries to open and closes right away.
What the heck am I doing wrong?
Yup, got both my homemade ESP32 Wroom units up to current version 0.1.5f1b883f.
Will run all the fujinet tests again over the weekend
Thanx All
That seems to have fixed it, Espressif32 was one version out of date.
Thanx!
;FujiNet PlatformIO Project Configuration File
; Build options: build flags, source filter
; Upload options: custom upload port, speed and extra flags
; Library options: dependencies, extra library storages
; Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html[platformio]
description = FujiNet Atari to ESP32 WiFi Multifunction Firmware
; Change this to target the device you use from the list of [env:xxx] sections below
default_envs = fujinet-wroom[env]
; Common settings for all enivornments
platform = espressif32
framework = espidf
extra_scripts = pre:build_version.py
lib_ldf_mode = deep+
upload_port = COM10 ; Windows
;upload_port = /dev/ttyUSB0 ; Linux
upload_speed = 921600
monitor_port = COM10 ; Windows
;monitor_port = /dev/ttyUSB0 ; Linux
monitor_speed = 921600
monitor_filters = time; ESP32 WROVER (16MB Flash, 8MB PSRAM) based FujiNet
[env:fujinet-v1]
board = fujinet-v1
build_type = debug
build_flags =
;-D JTAG
-D DEBUG_SPEED=921600
-D BLUETOOTH_SUPPORT
;-D FN_HISPEED_INDEX=0
;-D VERBOSE_SIO
;-D VERBOSE_TNFS
;-D VERBOSE_DISK; ESP32 WROOM (4MB Flash, NO PSRAM) based FujiNet
[env:fujinet-wroom]
board = fujinet-wroom
build_type = debug
build_flags =
;-D VERBOSE_SIO
;-D VERBOSE_TNFS
;-D VERBOSE_DISK; ESP32 WROVER (4MB Flash, 8MB PSRAM) based FujiNet
[env:fujinet-v1-4mb]
board = fujinet-v1-4mb
build_type = debug
build_flags =
;-D VERBOSE_SIO
;-D VERBOSE_TNFS
;-D VERBOSE_DISK -
deleted the repo and cloned again(3 more times)
same error
Windows, I have tried closing and starting over again multiple times
Need some help updating a older Esp32 Wroom board. I have not been able to update since last month when The github changed.
I am following the new github wiki for PlatformIO bulid
When I try to build, i get this error
src\main.cpp:10:10:fatal error: fnsystem.h:no such file or directory
#include"fnsystem.h"
compilation failed
[.pio\build\fujinet-wroom\esp-idf\src\main.cpp.o] error 1
Thanx
Doug
I've been toying with the idea of getting this wrover dev board, they are on AliExpress. Was hoping to get a real fujinet board, then I missed the first 50 list. So maybe I still will. Can't seem to find this board from a American seller.
On 7/29/2020 at 9:57 AM, mozzwald said:I just updated the flash tool (https://fujinet.online/download/) so that you can view the serial debug output from FujiNet over USB. This is useful for those who do not want or need to install PlatformIO/vscode but still be able to report problems and supply debug output.
Is this flash tool only for the current wrover boards, and not for older wroom boards?
If you are getting mount errors, it is usually cause the filename is too long. That's the only times I have ever gotten mount errors. Rename to something shorter and it should mount fine.
40 minutes ago, DrVenkman said:As one of the"first 50", I'm rather interested.
Sure..rub it in 🤪
I use a sdrive max(as drive 1), and a sector copy program and make floppys on my drive 2 1050(leave drive one 1050 off) works great.
two games in Atari MS BASIC and resource page
The uno game is great fun, playing it now. Need to read up on the other game
Thanx!
