42 -
Posts posted by gianlucarenzi
The custom case for MiSTer, Eclaire or whatever FPGA system is, can be accomplished AFTER we reach the first goal: having those damned keycaps!
The PCB for keyboard will remain the same, as the USB to the eclaire input are connected inside the case, but the holes in the back need to be adapted for Eclaire or other FPGA Solution. If I were able to use CAD software for 3D, I would do it... 😞
In attachment both layouts:
XE style (first production run) It can be accomplished (as stated above) for as low as 100/200 kits.
XL/800 style (second production run, but it needs more than 2000 kits to start the production, because of the costs of the custom moulds) 😞
Anyway I would share with you all my steps so far.
if in atariage there was someone willing to help me in this project that if realized it will become opensource, I would be really happy.
Regards,
Gianluca
Now I have some quotation prices so I am thinking about to start a sort of crowdfunding for this project. First of all it will be XE based keyboard style.
1- The key caps will be used as for keyboard drop in replacement for XE users. I am designing a custom PCB with cherry mx switches and looks very good so far. The only drawback issue is the need to use the original function keys or they need to be 3D printed.
2- those key caps will be used for a XE type of USB keyboard for PC/FPGA systems but they need some other keys more to suite the emulation. In that case I'll need which keys are needed for accomplish that task. And I need some people who are able to design with 3D CAD software the keyboard case mimicking the original Atari XE computer but with shorter depth.
3- the key cap set can be used to be replacement for mechanical keyboards for hackers with 61/62 TKL keyboards as they are cherry mx compatible...
Can you help me out? Do you want to join the project?
P.S. I have just asked to Atari people on Facebook about the usage of their fuji logo for copyright or other things, but with no luck so far.
@Matej no further progress on new pcb and keycaps for Atari 8-bit computers? I was thinking to start a new design PCB for Atari 130XE/65XE/800XE with cherry mx switches and (so called) Cherry or OEM keycaps profiles and custom some special keys by (wasdkeyboard) ABS Plastic:
"Clear <" "Insert >" "Break" "Atari Inverse" "Arrow keys". Or even better I think they could be laser engraved. The special function keys I think they are 3D printable and adapted for Cherry MX switches.
I know it is a very hard project but, I am looking for information and prices from whom produce keycaps...
As soon as I have a clear picture of everything a Indigogo or Kickstarter crowfounding campaign can be started... 🙂
Regards,
Gianluca
46 minutes ago, tane said:Are you compiling that code in a REAL Atari? Which assembler? Or those codes can be assembled in a Linux enviroment with some assembler? I have cc65 and atasm.
Thanks a lot! Now I have some code to look at.
On 9/10/2017 at 1:56 PM, emkay said:Any useful version around?
enotracker is not compiling on Debian Buster. Maybe some incompatibilty issue with a newer version of D Language or something else.
Nobody has written a RMT code player for Atari??? @ivop any news on that? The (R.I.P.) original author has died, so I was wondering if someone else had the maintaining job for this piece of software...
I am that guy! ;-)
The biggest issue at the moment I have a NON WORKING keyboard (mylar and PCB connector are broken or loosy) so I can not start any software by typing its name on the keyboard. At the moment I can use SIO2USB with a MyPicoDos autorun code to run all software I need to check these ramchips, but a lot of program I tried gave me wrong results.
Please have a look at the code I wrote in my github repo: https://github.com/gianlucarenzi/AT2019
and look for the ATARI-Driver folder. There is a megaram.c code. I tried both formats (130XE 192K mode and 576K mode) but they works in the emulator atari800. Tonite I will try them in my real hardware so I can see if they work or not.
Please feel free to give me suggestions or hints to write this kinda memory tester for Scott Peterson 576K upgrade I did in 1988. I have all printed instructions... ;-)
Regards,
Well, I had a similar (almost identical setup) and I tried to powerup the Atari 130xe after more than 30 years. Black screen.
But, with VIDEO COMPOSITE SYNC. I supposed the ANTIC/GTIA are using PHI2 from CPU (so it is supposed to work partially) so a BLACK SCREEN means nothing to display in VIDEO RAM.
I started to socket ALL COMPONENTS and see what happens:
1- CPU SOCKET (same issue)
2- ANTIC SOCKET (same issue)
3- GTIA SOCKET (same issue)
4- PIA (was already socketed by the 576K MOD)
5- BASIC ROM SOCKET (same issue)
6- FREDDY SOCKET (same issue)
7- OS ROM SOCKET (it start but with SELF TEST) Hurray!!!! We have a winner!! The solder joints on the ROM Chips went bad due to aging.
After I decided to redo all the soldering wires who looked bad to me with new flux and solder, and adding the shrink-tube on each solder joint.
During this rework I broke off a couple of pins of the 41256 RAM chips and I ordered a bunch of them and replaced.
And after 15 nights of reworking here is the result:
Eccomi qua. Dopo anni di stress dovuti all'acquisto di una nuova casa, della nascita di due meravigliose bambine, della convivenza andata male, sono tornato ad avere un po' il passatempo che avevo prima del 2000: l'utilizzo di Atari 8-bit e dell'Amiga. Adesso ci ho aggiunto anche un MSX2... Il primo amore non si scorda mai... Viva il retrocomputing!!! https://github.com/gianlucarenzi visitate un po' il mio repository... Chissa' se non vi viene in mente qualcosa...
Thanks for any advice you gave me. I appreciate them very much. I was looking at the specifications for MIO, and the layout is driving me crazy: let's do an example.
I want to write $de $ad at first two bytes of the Bank no.1, then write $be $ef at the address @$80 of bank no.258, then read @$fe of the 25th bank.
I will do:
lda #1 << 5 ; bit 5 is ram enable
sta $d1e2
lda #0
sta $d1e0
lda #0
sta $d1e2
...write $de $ad @ $d600
lda #$02
sta $d1e0
lda #$01
sta $d1e2; $0102 = 258
...write $be $ef @ $d680
lda #$19
sta $d1e0
lda #0
sta $d1e2
...read @ $d6fe
As you can see the ram enable bit will go high the first time, then all subsequent write in this register $d1e2 is low.
Is it to stay 1 for every ram access?
This thing is going me crazy.
Are out there some MIO user?
Go for 8MB because the Apple II scene is getting way too uppity ever since they got their 8MB upgrade solution*.
*Only counting 6502-based Apple II models, not 65816-based IIgs models....
This expansion will be the first of the series. If someone need more ram I should use the Stm32f42x line just to connect ddr2 chip to it and share memory with 6502. It should not so difficult. For now I will focus on a diy project. Bga are too difficult to solder.
Can you point me to the apple ii memory expansions?
there might be room for a serial/lan port on this as well, this is so close to being an all in one device
It should be possible if:
- the uart ports are still available in the very few pins available,
- someone gives me the 850 R: specifications (xio ioctl codes for setting the baud rate, rts-cts stuff, etc.,...) just to write the right handler.
Here I am again!!
Last week I spent a couple of e-mails with Mathy Van Nisselroy talking about MIO's ICD interface and its RAM up to 1Meg.
Yesterday I had a mumble mumble and... voila'! Here is my last project!
An expansion board for any Atari XE (Having ECI + CART) which sports a UnoCart and a MIO Expansion memory compatible plus a new registers for adding the 2 or 4 megabytes support.
It's called DUO Cart (as opposing UNOCart which in italian UNO means ONE, and DUO means TWO
).Its firmware can do all stuff like UNOCart does, plus a MIO Memory expansion.
In attachment there are some information and 3d renderings. As soon as the prototypes are ready I will be glad to share everything with you!
I hope MyDOS will include this memory expansion driver as it will be 100% compatible, but need a register more to add the extra 2Meg or 4Meg RAM Chips!
Best Regards,
Gianluca
Yes: it would be useful to disable the external PORTB expansion via a DIP switch or via software configuration.
I think the idea here is that if the target machine has no expanded RAM, providing external extended RAM via PORTB would allow software intended for standard PORTB RAM expansions to work unaltered. There is quite a bit of software around which works with extended RAM without the use of drivers (this is perhaps unfortunate, but it's the situation).
When the U1MB was being designed, I asked for a means of splitting up the 1MB of RAM between PORTB access and some special 'hidden' register, but it never happened. The idea here was to allow XL/XE software uninhibited access to PORTB RAM, while not disturbing the RAM accessible via the special register. Of course your device would provide the 'protected' RAM, but it will depend on the target machine first having an internal PORTB RAM expansion to be much use with any existing software.
$D304 and $d305 sound reasonable, although I'm sure someone who designs hardware (I don't) may be able to offer better advice than I.
I can see no compelling reason whatsoever to use $D5xx for banking control when the PBI device can decode its control registers anywhere in the hardware region. It would make sense were this a cartridge-based RAM expansion (since carts are limited to the cart banking window and CCTL).
The AtariMax 8MBit cartridge will disable itself when $D5FE/FF are written, IIRC.
But it will be a cartridge based RAM expansion (as the cart slot is used and the ECI bus too...). For the beginning I will plan these options:
1- Using PORTB $D301 as bank selector (6-bits) ) so 64 banks can be used (1024k). The other banks selection can go @ $D305... So anyone can use more than 1024k easily... In this case old software can use 1024k and the new one can go up to 4Meg
2- Using PORTB $D301 for total 8 bit. Results will be unpredictable as no OS nor BASIC... ??? I will check with emulator (atari800)
3- Using $D305 for total 8 bits. In this case the only drawback is what will happen using shadowed registers for PIA access...
4- Using $D530 and $D531. PBI device are not banked over here. They can use the address between MPD MathPack and $D800 or other addresses but NO $D5xx (only RTC-8 I think, but not at $30 and $31...)
How the Antonia 4Meg works? It need to be installed inside the motherboard?
Ideally, have some RAM accessible via PORTB and other RAM accessible via a different address. This way, software can make full use of PORTB RAM in the usual fashion without destroying the contents of the protected RAM (RAMdisk, fancy custom OS, ANTIC display buffer, etc).
As mentioned: if the device adheres to the PBI protocol, the possibility of conflicts with other hardware is greatly reduced (special RAM could be accessible only when the PBI device is selected).
Thank you for any of your suggestions: all are ok and you surely know what you are talking about. The biggest issue here, is any user who ALREADY HAD an internal expansion on PORTB address (as myself, I have a 576K 130xe done back in the days) will be forced to loose any hardware expansion and de-solder/disconnect everything from their Atari Motherboard.
Writing a PBI device I do not see any advantage at all for a memory banked expansion: the driver need to be written anyway.
Different story if the expansion is a some kind of GPIO expander, or some sort of sensors like temp sensor or humidity sensors...
Regarding the expansion maybe simulating access at $D304 as BANKCTL and $D305 as BANKSEL can be a better option? I suppose any acces in the shadowing address logic (as PORTA and PORTB uses this address too) is not a very good idea. Anyway the access must be written anyway,because no software is using those registers...Another option is to DO NOT CARE what exists inside the Atari and use the PORTB all 8 bits. I suppose some bus contentions for the same addresses or even worstthe memory window at $4000-$7FFF can have sometime the expansion data, and other times the inside-motherboard-chip ram data...Mmmmhhh... Another solution can be use the D1xx access as the Mapping the Atari says...To me the best viable solution is to move the registers up to $D5FE and $D5FF for bankctl and banksel... What hardware is using those two addesses?Regards,Gianluca
Hello, everybody!
After 30+ years I would like to keep my ATARI Systems up and running!!
I am an Computer Science and Electronic Engineer specialized in microcontrollers and microprocessors. Last year I discovered all my 8-bit systems was kept in the basement of my parents' house. They seemed to be yellowed, the capacitors seems to be NOT LEAKING (but I will replace them ASAP). So I was thinking about to build a memory expansion. I was wondering if anyone will be interested in a PLUG-AND-PLAY (no soldering, no open cases, no drills, no CPU change or whatever) 512K/1M/2M/4M memory expansion using the cartridge bus and the ECI bus present in the rear case of the 130xe. May be with a 50 pin header + edge connectors it can be easly adapted to use in a 800XL and maybe in a 600XL too, but I need to check out everything.
This expansion will be COMPLETELY OPENSOURCE, with schematics, Kicad project, Firmware, part list (mouser and digikey and others). It will be a banking scheme type-of-expansion with the memory window at 0x4000 - 0x7FFF without using the PORTB (0xD301) memory control register. In my plan it uses the address @ 0xD530 for banking control, and @ 0xD531 for enable/disable expansion.
Actually I cloned the atari800 github project, added the drivers for my expansion and try some memory access on emulator. It works!
Application Programming Interface
To enable memory expansion write 1 at bank control register @ D531:
in C:
unsigned char * bankctl = (unsigned char *) 0xd531;
*(bankctl) = 1;
in ASM:
lda #1
sta $d531in BASIC:
POKE 54577, 1
To disable, simply write 0 at the same register.
To select the bank (window will be at 0x4000-0x7fff address) write the
correct bank number @ register bank select D530:
in C:
unsigned char * banksel = (unsigned char *) 0xd530;
unsigned char * ramwindow = (unsigned char *) 0x4000;
*(bankctl) = 12;
/* Write at the window of bank 13 */
memcpy(ramwindow, data1, 0x4000); /* Max size will be 16K!!! */
*(bankctl) = 7;
/* Write at the window of bank 8 */
memcpy(ramwindow, data2, 0x4000); /* Max size will be 16K!!! */
in ASM:
; BANK 13
lda #12
sta $d530
; Do some stuff at address $4000-$7fff
; BANK 8
lda #7
sta $d530
; Do other stuff ad address $4000-$7fff
...in BASIC:
REM BANK #8
POKE 54576, 7
REM BANK #13
POKE 54576, 12
Pretty simple... ;-P
We can have up to 256 memory banks available, so the register can have
a number between 0 (bank #0) up to 255 (bank #256).
In this way any other memory expansion can be used. In a plain 130XE computer
the total amount of memory will be 4096K + 128K - 16K (for the addresses
overlapped at the memory window): 4208k!!
Basic/ANTIC/... other stuff can be co-exists in this way.
Now, I can need some awesome software (MyDOS, SpartaDOS, demos, etc.,) which
this expansion can be used.I need feedback please!
Thanks!
Open Source Atari XE keyboard (130XE/800XE style)
Before all of you are asking why there are not function keys for Atari XL and Atari XE, is the way they are built. I asked for a custom shaped key caps for XE and I am awaiting the quotation price, but for XL it is a different story.
For both system (XL and XE) the easiest way is to adapt the existing keys with a custom 3d printed adapter, but for those of you who want to have brand new function keys the easiest way is to 3D-print-them. And paint them with the correspondant plastic-spray-painting to looks like the originals...
I am open to every solution here...
