79 -
Posts posted by Sknarp
It does free up the three score vars for whatever use you want, unfortunately it does not free up the 6 scorepointer vars because that's the one part I have yet to figure out (see below). As far as cycles are concerned, about 3-4k of asm is being completely removed, and while some of it was conditional (such as if const debug was set) a lot of it just always was executed. I replaced all of that with something like 3 WSYNCs over the course of the kernel, not entirely sure what the effect on cycle count would mean (should be faster?) Not sure how to measure it.
All that remains of the score code (with my added comments, sorry if they aren't 100% accurate) if someone can figure out how to skip all of this (Sleep? WSYNC again?) then those 6 additional vars could be free space in the mem map as well. Best I can figure this is what allows for the tens places in each section of the score?
Quotesetscorepointers
lax score+2 ;simply loads the score vars
jsr scorepointerset ;one at a time
sty scorepointers+5 ;jumps to scorepointerset
stx scorepointers+2 ;and back here to do same thing with next var
lax score+1 ;note that the score vars arent changed, just scorepointers vars are
jsr scorepointerset
sty scorepointers+4
stx scorepointers+1
lax score
jsr scorepointerset
sty scorepointers+3
stx scorepointers
wastetime
rtsscorepointerset
and #$0F ; score is in A and X, makes the the lowest four digits zero
asl ; over the course of these shifts the 16s place digit becomes
asl ; the 128s place
asl ; now shifted the number left 3, so we now should have a000 0000
adc #<scoretable ; ???.What is scoretable?
tay ; move A (shifted: a000 0000) to Y
txa ; move X(unshifted) to A
and #$F0 ; makes the 4 highest values of A zero (0000 aaaa)
lsr ; shifts right once, now we should have 0000 0aaa
adc #<scoretable ; ???? this again.What/where is scoretable?
tax ; move A to X
rts ; X will store to scorepointer, Y will store to scorepointer+3 -
Yeah I can see a couple of things, when you use lda you're undoing the prior randomization stored in the accumulator . Also, the jsr's all loop to one another. Even if your randomization works the program flow could theoretically end up looping forever. It would be better to have a routine with a predictable execution time, like any of the examples already posted.
Saved another 124 bytes by replacing 10 if-then statements with 1 on-goto and shortening labels in the
part of the code that changes the playfields. This was something I had been meaning to do for a while,
but got sidetracked with trickier optimizations.
I still have to program the second game mode, win conditions, and reset switch support. Right now there
are 10 screens (not counting the title), I'd like that number to be 20 or 30 so I have a lot more pixel
drawing to do. Currently at 960b free.
Title screen, shows how CTRLPF manipulation can be used to get around MSK limitations.
Reclaiming bytes via kernel
558b free
SpoilerSo in the previous post I mentioned that I had 558b free and that I was sure I could reclaim more. First off, that 558b was with the debugscore on, which uses 190 bytes more than no options, or 170 bytes more than the noscore option. So if I was to set it to const noscore=1 then I would have 728 (558+170) bytes free. I don't plan on using the score at all so that's the best I can do right? Well, not if we actually dig into the multisprite kernel and see that a lot of that space is being used for the score routines, which we don't need. After a bit of trial and error and a few extra STA WSYNCs, I was able to make a scoreless MSK. In total this saved 86 bytes! Free space: 814 (728+86)
814b free
So that saved some bytes, but here's another idea, which DOES NOT save any bytes, but this shows how I went about testing it.
Reclaiming bytes via RAM sprites
Spoilerrem EXAMPLE ONE
rem drawing an arrow to player0 sprite in ROM
player0:
%00000000
%00010000
%00111111
%11111111
%00111111
%00010000
%00000000
end
rem EXAMPLE TWO
rem using RAM s-y
s=0 : y=0 : player0pointerhi=0
t=16 : x=16
u=63 : w=63
v=255
player0pointerlo = $E9
player0height=7rem EXAMPLE THREE
rem using ram s-y and in ASM
asm
lda #0
sta s
sta y
sta player0pointerhi
lda #7
sta player0height
lda #16
sta t
sta x
lda #63
sta u
sta w
lda #233
sta player0pointerlo
lda #255
sta v
endSo the second and third example both work just as well as example one, and I was willing to remove "LDA #255" since it would have sped up the routine and would only have caused there to have been two dots in the middle of the arrow, I could live with that. The problem was simply that doing this doesn't save any ROM at all... I believe this is because of the images being stored as bytes that need to be page aligned, so this doesn't circumvent that requirement. I scrapped this idea because it's not useful in this application.
SUCCESS!
I figured out what the problem was, the scorepointerset and setscorepointer routines are either required by or factored in to the screen drawing. I was able to remove everything else and ended up with a working scoreless multisprite kernel. As far as I'm aware, any options will have no effect on this kernel, so you don't need to set noscore, and setting something like debug will do nothing.
Quote748 bytes free with fixed MSK
728 bytes free with const noscore defined
814 bytes free with noscore_MSK
This is a savings of 64-86 bytes!-
This was really interesting, not ashamed to say I sat down and read this disassembly like it was a book. Comments very clear and the original code being so tight means it's a good learning exercise. Thank you for posting this.
On 7/29/2019 at 10:29 PM, Sknarp said:If you want to compile this you'll need the modified includes in the same directory, otherwise there's not enough free space.
WIPsourceAA.bas 18.82 kB · 20 downloads multisprite_kernel.asm 15.49 kB · 18 downloads score_graphics.asm 929 B · 18 downloads
Final version and source above. Might still have alignment issues that need to be fixed, but this is the most complete version as far as I know.
ATAX-ATAX is my newest project. I've been working on it for about 8 days so far, so I figured I should try to keep track of my development. I still have quite a lot to do. This is going to be a 4k game, but I'm confident that that won't be a limiting factor in this project. If you're curious why I think 4k will be plenty of room:
Spoiler---BITS!---
There's several places where I only need 1 bit: The player0 has four directions tomove in, we can assign each one to a bit for four bits total. The player0's reflected
property can be stored in one bit. Player1 needs a 1 bit flag for his missile's
direction of movement and one bit to control it turning around when it reaches the
edge of the sceen, we can use one bit per flag for a total of two bits. This adds up
to seven bits, I put all seven bits in one variable, and made sure that single unused
bit is being masked in all operations, so that unused bit can still be utilized for
something else later.
---Shared sprite data---
Four of the five enemies have the same sprite, so I just have one copy of the spritedata and use an indexed loop to set the other three pointers to that one, saving a lot
of bytes that would have been used by the three redundant sprites.
---Understanding NUSIZ and CTRLPF---
So I wasted time reverse-engineering the NUSIZ and CTRLPF options when all thisinformation already exists somewhere online. Anyway, once I understood what each bit
was being used for I found that using binary made it much easier to work with. Doesn't
save much, just makes the work go by faster.
---ASM init's---
I've been rewriting all the variable inits to optimized ASM. Overall a lot of LDA'scan be removed or changed to shifts and while each change is small it can add up.
---A world without BCD---
I've stripped every single BCD number out, in effect everywhere that used a BCDpreviously now uses a binary number which overall means a pretty big savings in bytes.
---Low cost logic---
I use things that have reliable values to drive multiple events, rather than waste byusing a seperate variable for each action. On the title screen a single 1-byte counter
is being used to fade in the title screen, play/stop playing a sound effect, and
restrain the fire button at the same time. This same counter is being used in the main
loop for an enemy respawn timer, to adjust the probability of player1 attacking, and
to slow down the speed at which player0 takes damage at the same time.
---simple math only plz---
I take the time to make sure the math is simple... most of the numbers are divisableby two. Actual divison is used sparingly and always in powers of two. I use bit
shifts. The same logic is applied to the vast majority of my comparisons, I focus on
checking for zero or nonzero instead of comparing to numbers whenever possible.
---simplified AI---
I control one of the five enemies with one bit for it's AI. The other four enemies arecontrolled with one loop, with just a few lines of code outside of the loop to allow
one of them to shoot missiles.
So anyway, I've got the sprites displaying correctly, I have a good chunk of game logic in place, and at this point I'm up to ten screens and have 558b left. I am sure I can reclaim more bytes, and that i can fit plenty more in. I'll try to keep updating as things happen instead of as a retrospective.
On 3/16/2019 at 10:20 PM, OldSchoolRetroGamer said:What Flomojo said above, as well......
At the time these were made not all TV's were color. It is not so much choosing to play in B&W, if you happen to be using the console on a B&W display (again very common back in the day) you would select the option so the games would simply look better on a black and white display. The output is tweaked to have better contrast etc. Not to dissimilar to old movies and TV shows that were filmed in black and white but knowing they would be viewed on B&W Television the actors and sets were actually very odd looking "color" palettes. For example, the old Superman series George Reeves wore a brown for red, gray for blue and white for yellow suit. This looked odd to people on set of course expecting the famous red, white , yellow suite but made for a more outstanding look on TV's that could only display B&W. Sadly, I am old enough to know this first hand but for reference and to verify what has been said already
http://nerdlypleasures.blogspot.com/2015/03/the-forgotten-switch-atari-2600s-b.html
Immediately made me think of the Addams Family set
Quotep0dir=0
if joy0up then p0dir=1
if joy0down then p0dir = 2
if joy0left then p0dir=3
if joy0right then p0dir = 4
if p0dir = 1 then player0y=player0y-1
if p0dir = 2 then player0y=player0y+1
if p0dir = 3 then player0x = player0x-1
if p0dir = 4 then player0x = player0x+1Just make sure you dim p0dir to a variable first, something like dim p0dir = a
I think I just messed up some of the re positioning using HMP0. if you search for the label cycle74_HMCLR and change the preceding line from
lda #$80to
LDA #0
then it only gets offset by -4 (x) at 2 (y) positions, which makes me think I'm close
fixed multisprite with no options: 748 b free
fixed multisprite with noscore defined: 728 b free
" " with debug cyclescore: 558 b free
scoreless multisprite: 938 b free
What I think orange808 meant was if I am not using the score at all that I should remove all the score code from the multisprite asm so I can gain back the bytes that it wastes (I think this is what they meant anyway and it is a good idea)
I attempted to do this, but now I have an issue where sprites, ball, missiles all have a strange x offset problem (worse the closer to the bottom of the screen it gets). If this can be fixed then a completely scoreless kernel could save about 70 bytes on one where the code is just being skipped.(not to mention the parts of the mem map that could be freed up) Here is what I have, right now you have to use const noscore=1 and since score is completely removed you can't use this kernel for debug or cyclescore either.
Sorry, I thought since it's an asm question it belonged with other asm questions. I'm a little confused...
There's no mention anywhere of what "the fix" is that I could find- except a different post that as I mentioned said to add two PLAs before the jmp. Is this all the fix is, or is the fix something else completely?
I'm not using any modifications here, I've reverted back to stock when the above mentioned (pla) fix didn't change anything.
Sending you a PM with the files you requested.
EDIT: Thank you Karl G for reviewing this and sending me a fixed asm- I also think I probably forgot at some point to move the newest modded include into the same directory *facepalm* so it wouldn't have changed anything anyway.
Hello, I've been looking for a solution to this for over a day-
const noscore =1
in
multisprite kernel
This is documented as being broken, I found a post where Karl G said he "found a fix" but the only other mentions are one suggestion to modify multisprite_kernel.asm with 2 pla's, which I tried and did nothing, and a custom multisprite.h, which I downloaded and tried and did nothing.
Description for those unfamiliar:
When setting const noscore in multisprite kernel games you end up with screen rolls, playern's flying off the screen, general chaos. obviously something is very wrong with the noscore jump in the MSK. There are a million little nuances to this kernel, I can deal with/work around/fix most of them, but this one is stumping me.I'm currently using a 4k rom, so no need for bankswitching stuff, if that makes a difference in how this can be fixed. Any help?
EDIT: I ended up removing all the score related code from the kernel. I have managed to free up the
roughly 70bytes(86 bytes) Also frees up 10 vars (score and scorepointers) also you do not need to use const noscore so that saves you a few bytes itself. (Roughly 108 bytes in total savings)
The ASM on THIS post is the most recent version
If I have the option, I'll go physical. It's nice to hold something in your hands and not just have your physical money disappear into digital content. Besides that there are usually limitations on digital copies, like only being able to have them on so many different platforms, requiring an internet connection despite already having the full game, etc. Even if those aren't an issue, the simple fact that console companies keep trying to kill off the second-hand games market is a sore spot for me. I like being able to trade disks with others, something digital copies deprive us of.
If I don't have the option, digital is fine. I own several digital games because the physical version was simply too difficult or too expensive to acquire. It's also the most reasonable way to share indie/homebrew games (my games.niche website is all digital only for this reason, no cost for media overhead). I was tempted to select "don't care" because if digital is the cheapest/easiest/only way to get a game, it's perfectly fine.
Streaming? I think you'll have a hard time finding anyone who's excited to stream games, unless they work for google stadia. One possible reason is that streaming a game makes it feel like you don't own it at all, but that's just speculation. -
Chiming in with some specific incompatibilities on the Atari FB9 w/ composite outputs. I did a search and saw this requested in several places but not actually posted. Here's some of the ones I've found.
Demos seem to run slower than intended:
4kra VCS
Sphaera stellarumGames that (I assume use multipsrite kernel) have a syncing issue that causes problems:
Bit Quest
Halo 2600Games that just don't run at all:
Alien Pinball
FNAF 2600
Gizzle Wap and the.... blizzard
Reindeer Rescue
Stay FrostyStratogems_DX
Toyshop Trouble
Pitfall II Lost Caverns
Zippy the Porcupine
Probably anything over a certain file size...Games that function oddly:
SC games like SC Space Invaders (I believe this is a known glitch, haven't tried patched versions)
Princess Rescue (The enemy AI stops working at a seemlingly random point during play)
AVGN the game (The title screen is off sync, otherwise fine)
Cosmic Ark and any game that uses the "starfield effect" (Plays fine, but the starfield effect isn't present- instead the stars just appear as long strips) -
This was exactly what I was looking for, I used it in the game I just finished, CRT: Link to post and game that uses this
CHANGELOG
Original WIP (alpha):
SpoilerLevel 3 and onward: left side of screen has pfpixels randomly flipped on each new room loaded
Level 6 and onward: Obstruction added to right side.
Level 9 and onward: Second right playfield obstructionLevel 12 and onward: Final large obstruction (stretching into the middle play area)
Level 15 and onward: Extra enemies on shooting screens equal to level / 4 ( so 4 extra spawns at level 16 and so on)
Level 20: Crazy rainbow strobing starts
Level 22: Reverse-moving scanline added as distraction
Level 23: scanline doubles in width
Level 24: scanline doubles again
Level 25: playfield becomes invisible
There's no ending, it's just survival/score based like classic Atari. You use up/down on the titlescreen to select a starting level from 1-15, and then press fire or hit the select switch to start playing.
Beta:
SpoilerLevel select increased from 1-15 to 1-255
gem and enemy spawns are more balanced and more directly based on the level
party lights no longer make jarring noises
enemy movement slightly more random
hitting an enemy with your shot now resets the shooting delay
"invisible" levels given a more fair lightning-flash effect
health bar & game over added
BW switch can be used to disable the constant HP drain
Reset switch returns you to title from game/game over
small tweaks to the score handling and coloring
CRT has 4-directional sprites
fixed a glitch that occasionally caused an enemy room to be emptyFinal:
SpoilerBoss rooms added + boss attack & sfx
reworked the level #s for playfield changes
fixed mistake of repeated sprite data in the source
reworked timing of certain counters
small tweaks to random-driven events
moved the HP drain toggle to left difficulty switch
reached the maximum for a 4k ROMFinal version added to first post.
This is a great question, agree it's probably different for everyone but the OP did seem to only ask for personal opinions.
I would be willing to call anything that you can't just go and buy at a store today to be retro, but if that's way too inclusive then I'd say that in this particular case, bits would make the most sense to go by, as in essence, at it's lowest level, the number of bits available determine how much can be done at any given time. That being said, it's still super fun to mess around with limited older consoles because the limitations are what force creativity.-
Hello, setting up an IDE is usually the first big hurdle, so I'll offer some points to go over:
1. Directory: I always like to keep programming stuff as close to the C dir as possible to limit on long directory names, for example I use for visual BB
C:/Atari2600/Visualbbbb itself I have in
C:/Atari2600/bataribasic
I've always found this practice helpful in the long run1b. Directory spaces: As mentioned visualbb doesn't seem to like spaces anywhere in the file path, so when you label your folder try to avoid uses spaces anywhere.
2. Follow the installation guide- I just set up visualbb recently and as I recall you had to: install an emulator, install bb, possibly move a few specific files, run an installation file (presumably to set registry values), set paths within visualbb itself, and THEN you can start using it. (There's also warnings everywhere not to cheap out and use the tinkernut installer- it's outdated and will cause issues)
3. When you start, start with some extremely simple, small program, like just drawing a specified screen.
4. If you start running into errors that make no sense (like blank characters being marked as syntax errors- which they are NOT actually the error almost assuredly) then rem out or take your code and drop it into a text file, then go back and refer to point 3 and add code back in one small section at a time, when the compilation finally breaks again you can then focus on the last chunk that you added and you'll find where the mistake is a lot easier that way.5. It's okay to add one line or change one variable and do a recompile, this way you can see right away when something breaks, and if it's not an easy fix, you can just delete it and be back to having a working program again.
6. invisible binaries? If your file path has a space in it somewhere, sometimes visualbb will SEEM to be working fine, you can even compile and test run code, but when you go to the bin directory nothing will be there. It seems like this is because when you click the run button from the IDE it actually compiles and runs a temporary file, which is deleted the moment you close it. So refer to point 1b to make sure that the compile actually works as intended.
Help CRT, the chromatic alien life form, to find his way through 255 levels of increasing difficulty. Collect Rainbow Gems for power, defeat Evil Things that want to suck all the color out of existence, and bring color to the universe. Thank you to Zeropage Homebrew for giving me some ideas on things I could fix, and thank you Karl G for providing the statusbaronly mini-kernel.
Final Version:
Gem rooms: 25 points each, restore HP (40% chance)
Mob rooms: 100 points each, chases player (40% chance)
Boss rooms: 500 points and full HP upon kill, uses a beam attack (20% chance)level 2: pfpixels flip randomly each new level
level 4: permanent wall 1 (right)
level 6: permanent wall 2 (right)
level 8: permanent wall 3 (center)
level 10: permanent wall 4 (left)
level 16: rainbow strobing playfields
level 18: 1 pixel reverse scanline
level 20: 2 pixel reverse scanline
level 22: 4 pixel reverse scanline
level 24: playfield flashes visible/invisible
Enemies: 1 to 3 + (level/4) enemy spawns
Gems: 4 + (level/4) gem spawns
Bosses: 4 to 5 + (level/2) Boss HP
Main screen: select level from 1-255 using up/down, start with fire or select.
Game: move with up/down/left/right, shoot with fire, collect gems, kill enemies, advance to the next room when the north wall opens up. Reset switch returns to title screen. Left Difficulty Switch toggles the constant HP drain.
Game Over: use the Reset Switch to return to title*Not Recommended for people with photo-sensitive epilepsy*
That would be awesome, and thank you for the info about noscore, I was hoping it took close to as many cycles as the lives mini kernel since it suggests disabling score when using it to free up cycles.
Yeah..
I stuffed about as much as I could into 4k with my current skillset.(EDIT: Better example of a 4k game)This is abandoned, no updates are planned. I've uploaded the source BAS so you can play around with it yourself.
Title screen, win screen, platformer, 10 screens, two unique deaths, and a few bleeps and bloops.
Press Down to charge a higher jump. Press Fire to jump. Left/Right self explanatory.-
Multisprite kernel and const noscore
in batari Basic
Posted · Edited by Sknarp
clarity
I can replace the quoted in the above post with
to free up the scorepointers variables, but I feel like this is a really inefficient way of doing it. Could really use some ASM god to chime in here please.
