Retro_Game_Lover96
    252
Posts posted by Retro_Game_Lover96
  1. Welp, I am certainly having the hard times to get this mod working.
    Despite having the 9918 chip replaced by 9928 chip.
    UPDATE: The sync is working, but there are no colors.
  2. 3 hours ago, ChildOfCv said:
    The video signals will connect to the DIN the same way they do on the CV.  The audio... you'll have to find out where the TI prepares for final output on that.  Looks like pin 3 of the monitor port will work.
    The pin of TI’s video connector will work for the audio for the RGB mod.
  3. 1 hour ago, Kernel said:
    Yes, another thread on this...apologies in advance if I have not dug enough.
    I am trying to troubleshoot my CV that has glitching as these pics show:
    https://imgur.com/3Mn6tbv
    https://imgur.com/Escq53k
    I know the power supply is fine as I've tested it, but I also purchased a COLUSB on the off chance I was not using the multi-meter correctly.  I'm still a novice at this sort of stuff.
    I've also un-soldered, trimmed/cleaned the power cables and re-attached them to no avail (the ground had what looked like corrosion on it, so figured it was worth a try).
    I know that this could be anything really, so before I pull off the power switch and try that fix, and before I pull the RAM and try that, and before I try to replace the video chip, what I'm looking for is some guidance on where I should test for power on the board to ensure it's flowing properly.  I've found the technical manual and schematics by way of the god that is google, but other than 2 other threads here, I have not found info on how to test the various chips for proper connectivity.  I'm thinking I just haven't looked int he right place.
    The threads I've seen so far that have some info that I am going to try are:
    ^^ I have a logic probe on the way so I can complete this step.
    Any help/pointers would be appreciated.  I know I can buy a new one from ebay and probably just move on, but I really want to be able to save this thing and hone my troubleshooting and soldering skills.
    Thanks.
    I fixed my ColecoVision graphics with the 5v Ram mod and replacing the power switch.
  4. 5 hours ago, ChildOfCv said:
    Find a short length of wire, strip both ends.  Place one end on one side of R1.  Place the other end on the other side of R1.
    Alternatively, you could use your meter probes by sticking them on both sides of R1 and then angling both probes so that they contact each other.  Alternatively, set the meter in amps mode, make sure the probes are plugged into the appropriate outlets for reading amps (some meters use an alternate outlet), and then put a probe on each side of R1.
    I tried, but it didn’t work. :(
