252 -
Posts posted by Retro_Game_Lover96
The Scart plugs into the PVM monitor with the Scart to BNC connector cables.
I wasn’t talking about your question, I was talking about something that has an extra potentiometer that was pictured.
Yes, both R11 and R24 are 18 , so I have to replace them with 15K.
I was right, 153 is basically 15K Ohm resistor SMD.
Besides, they have to be 15K Ohm resistors to get the sync to work.
BTW, I wonder what they look like? They are small that should have the resistor code, 153.
1 minute ago, ChildOfCv said:In your other thread, R24 looks like 18 ohms. It should be 15K, according to the diagram and schematic.
Well, do I have to replace it?
43 minutes ago, -^CrossBow^- said:Unless something has changed in electronics labeling I'm not aware of...5.6K and 5K6 are the same thing. Just two different ways of writing it with the 5K6 being more correct.
I can tell that they’re the same thing.
12 minutes ago, MrPix said:The CV and Adam have a 9928.
I see.
Oh yeah, that would work.
I think the Coleco’s vdp chip could be either TMS9918 or TMS9928.
”2” takes YPbPr while “1” takes composite only.
3 hours ago, Retro_Game_Lover96 said:Possible to use the SNES styled out connector for the RGB mod?
Cause if it is, it can be used because the SNES multi out takes RGB.
How do I adjust R23 because my RGB board doesn’t get a sync.
Also, is it possible to use the SNES styled multi out connector for the RGB mod?
I was trying to test before mounting the RGB output connector to be safe.
The bright side is, the grey scart cable works on my RGB modded 2600.
6 minutes ago, zanaxe said:I'd highly recommend an 8pin minidin breakout board
https://oshpark.com/shared_projects/0hrYbjDu
though it works with a different style minidin than what you have. Also I'd recommend getting proper individually shielded premade cables from retro-access or retro gaming cables uk. The cables you want are mainly used for NES RGB mods. Those gray 8 pin computer cables will have lots of buzz in the audio lines coming from the RGB lines.
So, I guess the grey cable sucks, and I need a different SCART cable?
Did I install the board correctly?
ColecoRGB Help
in ColecoVision Programming
The cable of for the PVM monitor has a direct connection, so it works fine with other systems that have RGB mods like the NES.
