wierd_w
    1,621
Posts posted by wierd_w
  1. hmm.. Printing.
    Could you not set up some named pipes on the pi, then shoot your "RS232" (ahem) data there?
    https://www.guru99.com/linux-redirection.html
    EG, you could use echo, with std-in replaced with the input from the Ti, and redirect it to /dev/tty0, and put it through a real serial port (via a USB dongle).
    It would be stuff you have to configure on the Pi, but should be doable.  I think they are doing something similar with the functions to get text/data back from web hosts over that bridge.
    Virtualized proxy IO should be doable.
  2. The turn off to me, is the number of people reporting negative reviews of the product.
    However, the user manual says it DOES do playback from the USB device.
    http://www.naxa.com/downloads/NPB300EnglishManual.pdf
    Quote
    USB Play and Recording from MIC
    1. Insert the USB device to USB port on the top of unit.
    2. Set USB/TAPE(OFF) switch to USB.
    3. Press PLAY/PAUSE button to playback music from USB device. Press PLAY/PAUSE button again to stop play,at meantime the red USB indicator will blink once about a second.
    4. Press and hold the PLAY/PAUSE/REC button to record from the MIC(built-in), the red REC indicator will keep blinking rapidly. Press the PLAY/PAUSE/REC button again to stop Recording.
    5. Then press and hold the PLAY/PAUSE/REC button once again to play music or the sound recording from USB device. Press PLAY/PAUSE button again to stop play. -
    7 - 6. Set USB/TAPE(OFF) button to TAPE(OFF) to stop USB playing mode and to TAPE mode.
    The controls are clunky and foolishly put the playback and record functions together in a way that is easy to mess up a recording.  (If you hold in the play/pause button, it starts recording!)
    Since it has track selection buttons (but no display to show which track) it would be easy to put one program per track. Again though, Not sure if it supports .wav or not.
  3. 11 minutes ago, OLD CS1 said:
    Nah, take it as a challenge!  I have seen some pretty impressive results within the limits of the 9918A.  Case in point: Dragon's Lair.
    Gets away with it by being pretty simplistic in its program code though (It seems to mostly be a video decoder, with some logic for keypress and or joystick movement.)
    I have a game concept in my mind that would be more like an NES zelda-like, with some interesting game mechanics.  I really need more colors, without going into bitmapped mode.
    I really need at least 4 colors per char, and 4 colors per sprite.  I could work with that with some grumbling. 1bpp is just.... bleh. Not even fun to try.
  4. I actually got mine because I had never gotten to experience one of these old micros properly.  Sure I could have gone with the C64, but everyone does that.
    This one uses a standard cassette player (which was a sell-- I am not going to hunt down potentially broken cassette systems for a commodore product.), and cassette media is making a retro resurgence with audiophiles, so they are available inexpensively again. (and thus, practical.)
    I havent played with my fancy little toy as much as I would like, because the video is currently limited to an RF Modulator... and it has more snow than a blizzard on Mt McKinley.  When my composite cable comes, I will have more fun.
    The presence of hardware sprites greatly appeals to me. (I am a pixel artist.) I am put off by the limits on the palette (by the stock VDP) however.  I am compelled to get an F18A when they become available again.
  5. You know, if we are talking unusual software and hardware...
    There is a parallel port based adlib synthesizer out there, and there is a parallel port sidecar for the A4.
    https://www.serdashop.com/OPL2LPT
    One could have both a SID, AND OPL2... (Newer version is OPL3!)
    That would give you SID music, AND FM synthesis. (EG, you could send and play audio samples without playing silly tricks with the 3 channel tone generators. Just write appropriate data to the parallel port. You CAN get the yamaha chip it is based on to play PCM samples if you set the frequency exactly the same as the DAC, then modulate the volume. ;))
  6. Word.
    I got my base (no upgrades) system for 40$.  Already spent more than that on cables and Extended basic (though it did come with terminal emulator, though I lack an RS232, and speech editor-- through I lack speech sidecar.)
    The 32k sidecar expansion should show up eventually.
    My finalgrom 99 should show up sometime before the end of the month.
    TiPi or nanoPEB will have to wait until next month, when I have allowance again.
  7. The wizardry ditherer expands in both directions; yes.
    However, the attribute cutoff is at 8 horizontal pixel demarcations.  (At least with the original VDP anyway-- At least that's what I get from cursory reading.) You will have less statistical likelihood of needing the same exact palette over a space of 4 pixels horizontally. Even if every single pixel was different, the max colors you are using is 4.  You don't need more.  Instead, the ditherer interjects new colors at every other column, bringing the full image size up, and selecting additional colors, based on the colors AND PATTERN used by the pixels in the source row. :) Instead of defining 8x8 tiles, you are defining 4x4 tiles, which are less complex, and cannot realistically house the higher color density anyway per row. You generate the higher color density on the fly, by evaluating the colors and pattern of the source tile.
    Like I said-- designing images for use by the ditherer is "Challenging", but not impossible.  Rather than selecting colors and patterns based on intuition, you have to select them based on the rules of the upscaling/dithering algo. However, results will be consistent, and if color selections are sane-- visually pleasing.
  8. 15 minutes ago, Mehridian Sanders said:
    Just as a side note, if you do go this route, you will either have to make sure that the onboard switch can handle the power inputs, or replace the switch. I know that when using 2 PSU side by side (eg: External Video Card, Thunderbolt External Enclosure, etc.) you have to shunt Pin 15 and 16 (on the main power connector) to the switch to allow it to power on and off the supply. I could be completely wrong here. Please let me know if I am misguided. 🙂
    The connection on those pins is very low voltage, otherwise the people doing this stuff here--- would cause their jumper wire to catch fire.
    https://www.overclockersclub.com/guides/atx_psu_startup/
    It's a signal to the PSU to turn on. Not direct interrupt to system power. (at least on ATX supply.)
    Intel says this about the PS_ON signal.
    https://www.intel.co.jp/content/dam/www/public/us/en/documents/design-guides/resellers-power-supply-design-guide-changes.pdf
    Quote
    PS_ON# – Required
    PS_ON# is an active-low, TTL-compatible signal that allows a motherboard to remotely control the power supply in conjunction with features such as soft on/off, Wake on LAN*, or wake-on-modem.
    When PS_ON# is pulled to TTL low, the power supply should turn on the four main DC output rails: +12 VDC, +5 VDC, +3.3 VDC, and -12 VDC.
    When PS_ON# is pulled to TTL high or open-circuited, the DC output rails should not deliver current and should be held at zero potential with respect to ground.
    PS_ON# has no effect on the +5VSB output, which is always enabled whenever the AC power is present.
    Table below lists PS_ON# signal characteristics.The power supply shall provide an internal pull-up to TTL high.
    The power supply shall also provide de-bounce circuitry on PS_ON# to prevent it from oscillating on/off at startup when activated by a mechanical switch.
    The DC output enable circuitry must be SELV-compliant.
    The power supply shall not latch into a shutdown state when PS_ON# is driven active by pulses between 10 ms to 100 ms during the decay of the power rails.
    Table 3-10: PS_ON# Signal Characteristics
    Parameter                   Minimum          Maximum
    VI        L0                     0.8
    VIIL (VIN = 0.4 V)             -                        -1.6 mA1
    VIH (IIN = 200 uA)           2.0 V                    -
    VIH open circuit                 -                      -5.25
    VRipple / Noise                                      400 mV p-p
  9. To turn on an ATX supply, you just have to short the specified pins. (A slide switch would do fine, you would just have to have it mounted to a suitable PCB that attaches to the same 4 screw mounts as the original internal "cup warmer".
    Really, from what I see here, you just need is a small protoboard with an ATX motherboard header, with a 4 wire breakout, and a slide switch in the appropriate location.
    Then you just need a 12v DC barrel connector in the back in place of the 4 lead AC input.
  10. On 7/17/2019 at 9:43 AM, --- Ω --- said:
    I bet others are interested in this project as well.  So far the only achilles heel I see is the switch mounting in the Black & Silver console.  However once a 3D printed retainer is developed for a switch to use with the stock slider, everyone will be in business.  I'm sure our resident go-to-guy arcadeshopper will carry them when available. 😁
    Modernizing/Updating our TI's will give us decades (if we live that long) of fun.
    I own a silver model unit... The PSU and switch are fine, but I do eventually plan on getting an F18A, and will have to disassemble then.  Do you want me to reverse-engineer the switch slider? I have an FDM printer to test the printed parts...
    I understand that the switch assembly is "Fragile" though, so some hand-holding on safe disassembly would be appreciated-- but I have digital calipers and have experience reverse engineering parts.
    (Also, I don't mean to be obtuse, but wouldn't a pico-ATX supply (with v1 atx header), with the switch wired to ATX header pins 14 (PRW-ON) and 15 (GND) be sufficient? ATX power v1.0 (20 pin version, not v2.0, which has missing -5v!!) has all the necessary voltages... (+5v (pin 4), -5V (pin18), +12v (pin10), and GND (pins 3,5,7,13,15,&17))
    Like this guy?
    https://www.amazon.com/RGEEK-Output-Switch-Supply-Computer/dp/B07H5FP5KY/ref=sr_1_2?keywords=20pin+picoatx&qid=1568835723&s=gateway&sr=8-2-spell
    OR-- If you need more juice...
    https://www.amazon.com/dp/B005TWE3O8/ref=psdc_1161760_t4_B07H5FP5KY
    (both are 20 pin, v1.0 ATX supplies, which should provide -5v on pin 18)
    You could run your TI on a 12v DC wall wart then. Those are everywhere. Just make sure it is regulated, and has sufficient amperage.
  11. 40 minutes ago, HOME AUTOMATION said:
    Well o.k., but a digital recorder(they're really cheap) already has indexing... plus I just say the program name into the mic. right before each leader. Wait time, 2 sec.
    :grin:
    Sure-- There are even shoebox cassette decks that have a fancy USB port on them to read digital files off the USB stick even.  walmart.com carries them.
    https://www.walmart.com/ip/Naxa-NPB-300-Portable-Cassette-Recorder-Digital-Converter/529348725
    Neat little switch and everything.  However, the ONN one was right there in the store, and I could get it that day. :P  Pick which kind of convenience you want.  I resisted the purchase because the audio format is MP3, not WAV.  I dont know how the compression routine will mangle the data being put down.
  12. The deal is that it simply pulls motor control high, requests that you press FF, then puts it low for a fixed interval of time (fixed temporal indexing) in order to set the tape to the next program position.  A CD in a player will not reliably FF like that.  (But putting WAV data on a CD as a track is an interesting idea. 44100khz @ 16bit resolution is more than adequate.)  This is for setting up actual audio cassettes with multiple programs on them, for people without a minute counter. (the cheap walmart ONN recorders I have lack a minute counter. However, the fixed temporal indexing of the FINDEX program works just fine to reliably seek to the start of each program, at least so far.)
    This would let me get many programs on cassettes easily. that way I don't have to fumble around with my home-made audio lead being connected to my laptop, played through VLC with the audio at 125%, etc... I can just use the tape indexer to move the tape to the right index, then do the needful.
    Since I would need a 2 cassette cable to do this, (and already have a legit original 1 cassette cable that I would then not need) I can be a good netizen and just ship it.
  13. Fine with me. I can use the setter routine to move the tape, then save programs to cassette 2. :P
    The reading of the index is optional with the FINDEX program.  It's default mode is to seek to an index, which does not require a read. (Fixed temporal indexes).
    So- Keep index routine on cassette 1, and load between pulling wav files in. Save wav file data to cassette 2. A simple poke here and there will make the program work on cassette 2 instead of cassette 1, at least as far as seeking to indexes is concerned.
    • Haha 1
