654 -
Posts posted by Mehridian Sanders
Looking for this in the FAQ. Thanks !TI to PC. The saving to the recorder should only be done by the TI. The ground loop issue is addressed internally in the recorder, from what I can tell.
The TI really belts out the signal, while the PC kinda just half-asses it, even with volume turned up to 130%. Saving from the Ti assures proper output levels.
Sent from my SM-G955U using Tapatalk
I am big on harvesting from current tech and repurposing for old.1) I place a 2.5-inch 12v computer fan on top of the vent slots behind the cartridge port. Not noisy at all when I power it from an old 3v DC wallwart and the console runs much cooler with zero lockups after hours of running. Before that, I had plenty of lockups. That happened often enough I had dual TI-PEB setups running the same program that could take over in short order.Why, you ask? I was using my TI to time color darkroom processing. Unknown amounts of time lost while rebooting to get back to timing meant failed prints. After I added a console cooling fan, I was able to "retire" the second system from work duties and could instead play a game or write programs on it while the "work TI" minded the clock. The prints were in daylight light-tight drums rotating on a motor, so other than draining and refilling between steps, I often had nothing to do for 10 or more minutes. It was a great home business till everything photographic went digital.
-Ed
An easy way to do this would be to take a laptop cooling station, open it up, take the fans and whatever cheap circuit is in there. Then mount it inside the TI. Make a hole for the switch and/or usb(micro sometimes). I can usually find a station at Goodwill or some 2nd hand store for $2-$5.
I use these a lot for my sons projects in his costumes. Blue/Red LED, propylene glycol, shielded heating agent, couple of fans. BAM! Blue/Red exhaust from blaster or backpack.
I know you said it wasn't worth it ... I just kept having the wires slip off. Wanted something to make sure that the connections remained solid through the transfer.
Now I am a total noob when it comes to actually working with programming on the TI. So, I am gonna run though the "Getting to know you" book. The Big yellow one. see if I can't teach myself something..... annnd get rid of this damn mechannical keyboard that loves to ghost in letters.
PC2TI v0.1
On the stripped male connector the red wire is tip, white is base.
White (Earphone) TI wire connected to Tip.
Red (Mic) TI wire connected to Base.
On my first TI, I had to remove the power board completely, as I didn't have the original power supply. I used an old ATX 1 power supply and made 2 custom Molex form factor power connections to connect it.
That left a lot more room available inside. I did have 2 led strips breathe/glow blue on the bottom grill and the upper grill from the inside.
I almost had a Knightrider-esque boot cycle planned. Would have a 11-LED running fader go back and forth, and it would play the KITT woosh-woosh once when powered on/g3 reset.
http://
Dumped it when I got the second 99/4a, 'cause it came with the power supply. More projects came and it fell by the wayside. If I didn't toss the board, I'll see if I can get it working.
It appears that time was on this one's side...in truth I didn't think I going to be lucky enough to find an original.Did you have to replace the belt on the program recorder, or had it survived the ravages of time?
Ok somehow I thought I n.v would be soldering this.. lol just wrap. Ok.TI to PC. The saving to the recorder should only be done by the TI. The ground loop issue is addressed internally in the recorder, from what I can tell.
same here
On 12/29/2019 at 11:29 AM, wierd_w said:is this connection solely for "PC to Program Recorder" or is it also for "TI-99/4a to Program Recorder"?
So bout a week or so..
Sent from my SM-G955U using Tapatalk -
Should be Barbara Walter's...... for 20/20... *ducks*
Hahahahaha I know. That damn build program is gonna drive me insane lolOne playful observation... if FinalGROM had come first, you would have just been able to download XB.
(ducking and running for cover)
All right will have to get one of those. Lol week or so till next update there.
Speech Synthesizer has the power pass through mod..
Does the external power supply have to be soldered down ?
That's probably it....
Ok. The 32k Sidecar is complete
I made sure the jumpers were set proper.
Over TI and center.
LED does not come on.
No way to test if it actually works.
Thank you kindly for this wav repository.
If I am reading this correctly, this is solely for keyboard. Not quite the same as an OTG connection. However, thanks for the link, I may have need of them if I completely bork up my keyboard. 🙂
I am not really versed/instructed in Python... I am googling most of my questions. So if you know something basic to python that would be beginners noob level, don't hesitate to interject it. 🙂 the more I know!
I have made a Stackoverflow account which should also be helpful.
Thanks in advance.
2 hours ago, Mehridian Sanders said:
- I got python version of 2.7
somehow keep running into the same error :
OSError: [Errno 2] No such file or directoryi did make sure to add the PATH
sys.path.append('/home/pi/finalgrom/xdt99')all of the xdt suite files are there
Should I move this over to the development forum as I am running this on Linux? and debugging code ?
If so please move this thread.
TYIA
oh man.... i hate being broke post christmas... got an offer to buy a PEB for $115 Wife took my wallet away and started watching the bank account hourly... dammit she's so smart. Gotta love her 🙂
Update:
Finally got round to making more time to program the FG99.
CHECKLIST :
- I got a python version of 2.*
- I redownloaded the FG master and Xdt suite.
- Fresh Buster install of Raspian on the 3B+
- Installed xdt suite, Avrdude and TI Logo background (for luck!).
Ran the make.py script in terminal.
Still no love ... cant find the files...
Let The Debugging Begin!!
Well found a Skips Music near my house. Best buy did not have it either. So Amazon it is.
Walmart = no
Home Depot = no
Building the Finalgrom99 and the 32K sidecar.
in TI-99/4A Computers
