MrDave
    158
Posts posted by MrDave
  1. Yes i can be modded for composite or vga..
    Make sure all your wires are ok.. nothing loose in the rf box.. .. that your tv tunes to channel 3 or 4 ( make sure coco is one when you scan ypur channels) ..that you connected to vhf not uhf  ( if older set)
    Try skipping the nintendo rf and use a rca wire right from the coco to tv in
  2. Sure , I can make a eprom .. usually 5$  cdn to 2$ shipping..  make sure you have the correct ,model.. right now you should have a 24 pin rom in a 28 pin socket if we are talking about thw correct machine.. do you need ram as well ?
  3. After its turned on if you carefully type
    MOTOR ON
    then press enter...you should hear a faint click.. if you do the machine is working and its a video
    Issue.. check the 3/4 switch.. make sure your tv is on channel 3 or 4 and does not need to rescan
  4. Your ram upgrade is easy .. only 2 chips to replace and they are not hard to find.. as for the extended basic ( a must have ) there are a few jumpers to solder.. i can provide you with a eprom if needed ..
    If you know someone good at soldering get their help or ..using a fine tip soldering iron do some practice then solder your jumpers
  5. Here is the diagram , including the missing trace (normal) half the pins are outputs from the pua chip and should be pulsing   and the others shouod stay high untill connected wirh a button press.
    You need a logic probe with the little flashing lights, they are cheap and easy to use to poke around these machine.. you want to see flashing lights to know something might be working.
    With the keyboard disconneced  a small jumperwire from pin 1 to pin 16 would activate a "G"    from pin 2 (Pa1) to pin 12 will get you a ""K"
    This will tell you if its a keyboard or chip problem.
  6. The mc 10 is a cheap hobby computer.. its limited in what it can do.. so people are having fun pushing those limits.. actually making games that are fun.. more memory. Sd card storage etc.. i havevsome . Havent done much with them yet...
