1,010 -
Posts posted by Intelligentleman
16 hours ago, mr_me said:Two paddle controllers on each port.
https://atariage.com/controller_page.php?SystemID=2600&ControllerID=2
Ooooh. Thanks for that visualization. Well good, that means, for my purposes, this System Changer will be just fine. I don't have the same attachment to Atari as I do Intellivision, so I'm really only interested in collecting a handful of games so I can mess around a little. I have to say, I'm impressed with the few games I've played on Atari. Although the graphics maybe aren't as sophisticated, they do have their own aesthetic, which makes them look appealing.
8 hours ago, fdr4prez said:It looks a little chewed up, but all the contacts are there.
As I mentioned above, pins 5, 7 and 9 are not used, so you don't see the contacts in those holes.
You can try and do a little clean up with a small needle, contact cleaner, a good blast of compressed air, etc.
I would still recommend that you find your meter, or borrow one from a friend, and then confirm that there are no broken wires. You would need to test between the contacts in those holes and the end of the wires that are attached to the board inside the joystick. If all the wires are good, then this means that the contacts themselves are not making a good connection to the port on the System Changer.
You can try and clean out the holes with a needle, contact cleaner, a good blast of compressed air, etc, but that is a fair bit of work... at that point it may be best to go on the hunt for a replacement joystick, or a replacement cable
Thank you. I understand what you're saying, now, about those pins not being active on the 2600 controller. Which is good because that probably means that both controller ports on my System Changer are going to work with a standard 2600 joystick... Provided I find some that are fully functional.
Cleaning the button contact didn't seem to work, by the way.
18 minutes ago, fdr4prez said:Hard to tell from the picture.
The only way to really test would be with a meter so you can check from the connector to the wire connection point to the board - this will confirm if the wires are OK and if DB9 connector is OK
And then you can check between pins 6 and 8 and when you press the fire button, then the meter will beep at you (or measure 0).
Or you connect your joystick to a known working Atari console (or other compatible device), and then you connect a known working joystick to your System Changer.
I think I have a multimeter in the garage somewhere. It might need a probe.
1 hour ago, mr_me said:Pin 9 won't affect the joystick. It will keep the third paddle from working.
If you have a multimeter check the continuity on the fire button of the joystick itself. If that fails than repair the joystick.
Thanks mr_me, what is the third paddle? Is that the fire button?
Not sure whether to post this on the INTY boards or on the Atari boards, but here's the deal. I have a very nice looking Intellivision System Changer that seems to work well, aside from one thing! I can't seem to get the "fire" button to work on the lone Atari joystick I purchased to go along with the System Changer.
The fire button does not respond with the controller plugged into EITHER the left or right System Changer port, upon closer inspection, I noticed that the #9 pin is missing from the player 2 controller port. (See attached image). Again, the fire button on my only Atari joystick controller does not function when plugged into either port on the System Changer. That said, could this missing #9 pin in port 2 be to blame?
If I use the Intellivision controllers built into my INT II, the fire buttons all work - on both controllers. Not sure if that is relevant information, but there you go.
Should I bother purchasing another Atari joystick to see if that one works? Or, can someone diagnose the problem based on the above information?
Thanks!
14 minutes ago, Morpheus said:Congrats! It looks really awesome...
For the Synthesizer (US version) you missed these NIB ones at 200 bucks:https://www.ebay.com/itm/254785575302
Dunno if it was a good deal, I would say yes...
I'd say so too. Been looking at a couple used but nice ones at more than that price. That said, I can't spend upwards of $400 in dusty old video games in the same week. 🤣
4 hours ago, Morpheus said:Did u get a little discount on this one?
https://www.ebay.com/itm/353318299109
U’d better track very constantly the delivery if u want to make it...😂
Let us know how it will end...
Yeah, that's the one. The next thing I need is that music synthesizer keyboard. Talk about hard to hide!
1 hour ago, Sinjinhawke said:When I got my ECS last year it was no problem. Just brought the box in and walked it down to the basement. Wife didn't say anything. Thank you The Batchelor for distracting her.
All I gotta do is get the package when it comes. Then down to the basement with the intellivision II
2 hours ago, Morpheus said:Good luck dude! It won’t be easy...
Where did you find it?
Ebay?
Yep. It's was $215. Had all the stuff.
Well I bought a computer adapter. Condition was described as like new, in-box. Light blemishes on the box. Comes next week. Gotta hide it from the wife.
Geez... That's a little demoralizing. Lol
9 hours ago, Rickster8 said:That's what happens to me on so many INTV games. I'll get within 80% of my best score, and then spend the last remaining ships BARELY eking out an improvement.
Last time I got into this game, maybe a year ago, i remember it helps to try to have at least one move planned in advance so you can press the control disc well before the turn comes up. I'm not very good, though. Once the pace picks up it becomes difficult for me to keep up. Also, I tend not to use the ability to lock doors very strategically.
38 minutes ago, JasonlikesINTV said:So I've never used torpedos outside of bosses. Can you destroy those ships that the normal guns don't work on?
Yes you can. Torpedo blasts right through. But I'm not sure if you get any points.
29 minutes ago, gbag said:I've been in the ATARI 2600 HSC...is it too late for me to join the INTV HSC for this season???
No way, friend. You can join whenever want. And this season is brand new.
I love the yellow ships that look like mac & cheese shells.
HSC14.jpg.ddc6c4602baa8b8124f9965417ad7a3d.jpg)
Mattel Atari System Changer Help
in Intellivision / Aquarius
Haha, I was thinking the same. Honestly considering buying another one locally instead of messing with this one. They're about 5-10 bucks in these parts.
