PkK
480 -
Posts posted by PkK
Since a few hours, there is SDCC 3.6.0:
Today a new release of SDCC was made. We are now at version 3.6.0.
You can get it at:
http://sourceforge.net/projects/sdcc/files/
So what's new?
* Merged upstream binutils 2.25
* New memory management with lower overhead
* Changed default language dialect to --std-sdcc11
* Diagnostic for missing type specifier: No implicit int outside of C90
mode anymore
* C11 generic selections
* char type is now unsigned by default (old behaviour can be restored
using --fsigned-char)
* Character constants are now of type int instead of char.
* ISO C95 and ISO C11 wide character constants
* ISO C95 and ISO C11 wide string literals
* Basic standard library support for wide characters: c16rtomb(),
mbrtoc16(), mbsinit(), mbtowc(), mbrlen(), mbrtoc32, c32rtomb(),
mbrtowc(), wcrtomb(), mblen(), wctomb()
* Treat all ports the same in the manual (i.e. mcs51-specific stuff is now
clearly described as such)
* Reorganized interrupt handling for z80, z180, r2k, r3ka, tlcs90, gbz80
backends
* Workaround for stm8 division hardware bug
* ELF/DWARF support for stm8
* Output symbol table for ELF
* pic16 port now uses standard-compliant crt0iz that initializes static
and globals to 0 by default
And of course numerous feature requests and bug fixes are included as well.
Once again I hope you will enjoy using this new release.
Maarten Brock
SDCC 3.6.0 Release ManagerMost relevant for ColecoVision programmers are probably the improved standard support and various bugfixes in the Z80 backend.
Philipp
I recommend the tutorials at
http://colecovision.eu/ColecoVision/development/tutorial0.shtml
Philipp
Are you aware of the facilities in libcvu and of abc2cvm? See
http://colecovision.eu/ColecoVision/development/tutorial2.shtml
Another example from a libcvu demo is attached.
Philipp
do you have a binary. what are you compiling this using
I compile using the usual
./configure
make
installation as root via
make install
Philipp
png2cv is a tool that creates ColecoVision characters for bitmap mode from .png images.
0.16 NEWS:
-Fixed help message option text.
-Renamed --monochrome option to --bitmap-text.
-Added --bitmap option.
-Added support for SMS mode 4.
-Fixed RGBA support.Donwload from: http://colecovision.eu/ColecoVision/development/png2cv.shtml
The improvements for ColecoVision development are minor, but it is a step towards a unified envrionment for writing ColecoVision / SegaMasterSystem games. The new support for mode 4 is still rather basic. In particular it always assumes the TMS9918A palette.
Philipp
Schlange CV has red carts.
Philipp
Yes, please , it would be nice if you can send me few chips. At least to test if it works with these ones.OK.
Philipp
I updated my sofware to versio n 3.7.7.2 , my firmware is still 2.33 (i did not find where i could download firmware update) .
Yellow lightning symbol in the upper right.
Philipp
I made a mistake when testing a few days ago. I accidentially had a PLCC32 to DIP32 adapter in my Batronix instead of the PLCC32 to DIP28.
Sorry for the confusion.
Actually my setup (Batronix BX32P Barlino II with firmware 2.34 and prog-express 3.7.3 on Debian GNU/Linux) works with the SST27SF512 70-3C-NHE.
I noticed this today, when I put a 27C256 in the bruner and it didn't work. Then I noticed that I had the wrong adapter installed. When I put in the correct one, both the SST27SF512 and the AT27C256 worked fine.
Again, sorry for the confusion.
Philipp
P.S.: youki, the 27C256 are here now. If you want, I can send them by tomorrow.
I was able to contact the otehr person who received Homebrew kits with SST27SF512 70-3C-NHE. They encountered no problems so far, and use a variant of the Willem EPROM burner. Looks like the problem is on the Batronix side. You can still have the 27C256, which should arrive at my place within a few days, maybe already tomorrow.
Philipp
P.S.: I had a Willem 3.1 before, but replaced it with the Batronix, since the Batronix had better Linux support.
I just burn EPROMs, and put them in a pcb with ZIF socket (essentially the same as the "Homebrew kit CV prototype"). Back when I started writing games, there was no real alternative. And by now, for years I never experienced a problem on real hardware that I could not reproduce in the simulator, so the effort for testing on real hardware is not that much, as I don't have to burn that many EPROMs. I still do quite some testing on hardware, mostly to try the two-player mode with a friend. But when you go to another place for the testing, the relative effort of burning/erasing EPROMs is not that much either.
Philipp
thanks a lot for your investigation.
I had opened a support ticket to Batronix , but i did not get answer yet.
I'lll keep you inform if i got an answer from Batronix.
I opened a ticket with them last night, too since we are using slightly different EPROM burners (BX32 vs. BX32P), software versions (3.6.2 vs. 3.7.3) and possibly operating systems.
Philipp
I'll look into the issue in the next few days, and report back here.
Philipp
I was able to reproduce the issue using my BATRONIX BX32P Barlino II with the latest firmware and prog-express on my Debian GNU/Linux system.
These PLCC 27SF512 chips came from Farnell earlier this year when I ordered 27C512, as I had run out of PLCC 27C512. At most two people received them in homebrew kits CVs.
I do not know yet if there is a problem with the chips or on the BATRONIX side. Since finding out might take time, for now I can offer to replace the PLCC 27SF512 by PLCC 27C256. But with the holidays it might take a bit of time (I just ordered a small number of 27C256 from a supplier other than Farnell).
Philipp
Hi Philipp,
Would you have an idea why i got a Programming Error using the BATRONIX and the batronix prog-express software?
Thanks
Youki
Philipp
thats the website i got my kits from, i'm not particularly very happy with the game boards as i usually need to push the board to one side, it's almost like the cartridge connector touches the board either side of the board contact strip so there is no contactDid you put the small woodpüieces into their place above the PCB?
Philipp
The homebrew kits come with either 27C256 or 27C512 EPROMs. These are common EPROM types that should be supported by virtually any EPROM burner and software these days. I'm using a BATRONIX myself.
When using 27C256 the whole 32K of the EPROM are visible to the ColecoVision.
When using 27C512, the upper half of the 64K EPROM is visible to the ColecoVision.
Philipp
Though using goto without a need to do so is usually considered bad style. Alternatives for infinite loops:
for(;; while(true);
It's not clear what you mean by "ending point". What is the desired behaviour?
Philipp
Edit: Typo.
another question, i'm using structure with bit size specification like that :
typedef struct { byte password[5]; // 0..4 level password byte bonus:3; // 5 bonus type (0..7) bbbbbttt byte nbbircks:5; // 5 nb bricks to destroy (0..31) } LevelStruct;bonus is 3 bit sized (so values between 0..7) and nbbricks 5 (values between 0..31).
I want to define a const with such structure.
const LevelStruct contentlevel[MAXAREA*MAXLEVEL] = { { "AAAA", 2 | (20<<3) , ...But what I tried to test to init the bit sized value, the compiler says :
level.c(63) : warning 158: overflow in implicit constant conversion
and of course, put 0 instead of the value in the constant.
Someone has a solution regarding this problem ?
Your code tries to assign 2 | (20 << 3) into LevelStruct.bonus. LevelStruct.bonus cannot hold values that big, so something is lost when converting the constant 2 | (20 << 3) into a 3-bit bitfield. The result is 0. LevelStruct.nbbricks, on the other hand, does not have an initializer, and according to the C standard, is to be initialized to 0.
So your code is correct C to initialize both LevelStruct.bonus and LevelStruct.nbbricks to 0. We still give a warning in SDCC, since we consider it quite likely that this is not what was intended by the author of the code.
Philipp
ok, I tested your last version (i used sdcc 3.3.0, not the 3.4.0).
Here are some things I noticed :
- it use less code, we can save more than 1K for some games
!, that's really great and it seems to work well. I can't notice some changes with sdcc 3.3.0 (but it is certainly faster because of code saving).Example for RObeeBlaster :
- I still have this warning for bagman compilation but not for RobeeBlaster :
Any idea about this warning, what does it mean ?
Normally, the live-ranges should be connected by the time they reach register allocation (non-connected ones should have been split).
This problem does not affect correctness of the generated code, but it can force two variables to go to the same register, potentially resulting in slightly less efficient code.
Philipp
Edit: Two variables that, of course, are not alive at the same time.
Most of my tools and libraries fro ColecoVision programmng have received an update. You can find them at http://colecovision.eu/ColecoVision/development/
List of Changes in the current versions:
libcv 0.23 / libcvu 0.15:
-Suggested compiler: sdcc 3.5.0 or newer
-Clarified license as LGPL-2.1
-libcv: Name change of sdcc function pointer call helper.
-libcv: Made cv_vinb() and cvu_voutb() inline for speed.
-libcvu: Speed up playing of music, elimiate dependency on integer division, fix synchronization of multivoice music when vint frequency is not a multiple of sixteenth_notes_per_second.abc2cvm 0.14:
-Renamed configure.in to configure.ac and cleaned up file.
-Updated to autotools 1.14.1.compression tools 0.3:
-Fixed handling of file open errors.png2cv 0.15:
-Fixed help message.
-configure.ac cleanup.png2cvs 0.7:
-configure.ac cleanup.Philipp
SDCC 3.5.0 has just been released. Alan Cox' FUZIX has brought the Z80
suport in 3.4.0 a bit more into the spotlight, resulting in improvements
since, which also benefit ColecoVision developers.A recent presentation on SDCC can be found at
http://video.fosdem.org/2015/devroom-embedded/8bit_compiler.mp4See below for the announcement with the list of the most important changes.
Philipp
-------- Forwarded Message --------
Subject: [sdcc-user] SDCC 3.5.0 Released
Date: Wed, 24 Jun 2015 11:55:29 +0200 (CEST)
Reply-To: [email protected]
To: [email protected], [email protected]
Hello SDCC friends,
Today a new release of SDCC was made. We are now at version 3.5.0.
You can get it at:
So what's new?
* --disable-non-free configure option
* Changed default language dialect from --std-sdcc89 to --std-sdcc99
* Reorganized and updated manual
* Reduced memory consumption (most noticeable for high
--max-allocs-per-node)
* Faster compilation for stm8 (most noticeable for high
* atoll() function for conversion of strings to long long
* __z88dk_fastcall and __z88dk_callee calling conventions for more
efficient function calls and better compability with z88dk
* --lospre-unsafe-read renamed to --allow-unsafe-read
Maarten Brock
SDCC 3.5.0 Release Manager -
Assuming byte is a typedef to unsigned char, all the warnings are right. unsigned char can't hod -1. signed char cannot hold 254 or 175.
Philipp
SDCC 3.6.0 released
in ColecoVision Programming
At FOSDEM 2015, there was a talk on SDCC:
https://archive.fosdem.org/2015/schedule/event/8bit_compiler/
there is also a blog post on what happened in SDCC since the talk up to the SDCC 3.6.0 release:
http://www.embecosm.com/2016/06/14/recent-updates-to-sdcc-in-release-3-6-0/
Philipp
