PkK
    480
Posts posted by PkK
  1. When i tried to compile bagman with last version of sdcc, i have this message :
    What does it means.
    Also, the rom is 800 bytes more than with sdcc 3.3 ... So i will continue to use sdcc 3.3 :/
    The warning is not a big issue, and should only have a minor effect on code quality (possibly slightly bigger code for the function being compiled).
    If you care about code size, you might want to use --opt-code-size and possibly --max-allocs-per-node with a suitable parameter (the default for --max-alloocs-per-node is 3000; lower values speed up compilation, higher values result in more optimization).
    Philipp
    Edit: Fix typo.
  2. It would make more sense to have a Flashback forum within dedicated consoles.
    It is emulating a ColecoVision, it runs ColecoVision games, it is meant to look and feel like a ColecoVision. The people interested in it are probably mostly the same as those interested in the real ColecoVision. Thus, IMO, it makes sense to have it as a subforum of the ColecoVision subforum.
    Even better would be both: Just like the ColecoVision programming forum is a subforum of both the ColecoVision and the Programming forum.
    Philipp
  3. Some peole are creating threads for idividual Flashback topics, cluttering the forum.
    Others are replying to the big Flashback thread, making it hard to read (75 pages already).
    IMO having a Flashback subforum would be better.
    Philipp
    P.S.: My two Flashbacks arrived yesterday, didn't find time to unpack them yet.
  4. I used Hitech C to make Ghost'n Zombie. Then swichted to SDCC for other games . (on recent version of SDCC you have an allocation parameter (don't have the name in head now) to set in the command line to avoid it take ages... ).
    --max-allocs-per-node. The defualt is equivalent to --max-allocs-per-node 3000. Lower numbers make sdcc faster, but the resulting code worse. I rerely set it to valeus lower than the default. AFAIR, the release version of Bankcrupty Builder was compiled with --max-allocs-per-node 1000000. For the code speed vs. code size trade-off, there's also --opt-code-size and --opt-code-speed.
    Philipp
  5. Although C and other compilers do exist for CV it produces rather slow and bloated code. Originally all CV games were written in Z80 assembler, which is harder to code from scratch but over time you build up libraries of common routines and functions which with macros can result in reasonably fast coding.
    C will let you produce your code quicker, but CV is a fraction of the speed of the lowest level PC, so you should use the fastest most compact coding system possible, which is assembler.
    If you already have chosen efficient algorithms, and have some function called in an inner loop that has a big impact on the speed of your game, and a look at the compiler-generated code shows ineffciencies, and you are willing to really think about how to do the calculations fast in assembler, then assembler is the right tool for that function.
    Often, however, hand-written assembler would only be marginally faster than hand-written assembler code, and assembler code written without putting a lot of effort into making it very efficient might even be worse than compiler-generated code. And the sdcc compiler keeps improving. My games first written around 2006-2008 often had about a dozen functions written in assembler. When I now look at them again, many of them would be adequately handled by the compiler. I sometimes removed asm functions and went back to the C version, because the improvements in the compiler, with the C version now being as good or nearly as good as the asm version.
    There are some functions for which I noticed sdcc would generate rather bad code many years ago. I kept them around and used them as a benchmark while working on sdcc. Numbers that show how sdcc improved over time can be found at http://sdcc.sourceforge.net/mediawiki/index.php/Z80_code_size - even though the graphs are old).
    Philipp
  6. A new version of sdcc, the compiler used with both Daniel's and my ColecoVision development tools, has been released yesterday. Compared to the previous release, the improvements relevant to Z80, and thus ColecoVision development are mostly moderate improvements in code size and speed, bug fixes, and (for those using some forms of Megacarts) the named address spaces in ROM.
    Here's the release announcement from Maarten:
    Hello SDCC friends,
    Today a new release of SDCC was made. We are now at version 3.4.0.
    You can get it at:
    http://sourceforge.net/projects/sdcc/files/
    So what's new?
    * New TLCS90 (Toshiba Z80 clone) target support
    * New STMicroelectronics STM8 target support
    * Support for named address spaces in ROM
    * Detects supported devices by gputils when building SDCC
    And of course numerous feature requests and bug fixes are included as
    well.
    I hope you will enjoy using this new release.
    Maarten Brock
    SDCC 3.4.0 Release Manager
  7. I jut noticed there was a minor mistake in the example I posted. Here's a corrected version:
    void setb0(void) // The function that sets the currently active memory bank to b0
      *((volatile char*)0xffff);
    void setb1(void) // The function that sets the currently active memory bank to b1
      *((volatile char*)0xfffe);
    __addressmod setb0 const spaceb0; // Declare a named address space called spaceb0 that uses setb0() and resides in ROM
    __addressmod setb1 spaceb1; // Declare a named address space called spaceb1 that uses setb1() and resides in RAM
    const spaceb0 int x = 42; // An int in address space spaceb0
    spaceb1 int *y; // A pointer to an int in address space spaceb1
    const spaceb0 int *spaceb1 z; //A pointer in address space sapceb1 that points to a constant int in address space spaceb0
  8. There are multiple options. The most popular ones these days seem to be programming in C or in asm. Now, most C programmers seem to use sdcc as their compiler (previously, HITECH-C was popular). For sdcc there are at least two sets of libraries/tools: The one by newcoleco and mine.
    Here are some tutorials on getting started:
    http://colecovision.eu/ColecoVision/development/tutorial0.shtml
    http://colecovision.eu/ColecoVision/development/tutorial1.shtml
    http://colecovision.eu/ColecoVision/development/tutorial2.shtml
    Philipp
