jferio
    603
Posts posted by jferio
  1. The gestalt Transformers are all knockoffs, sadly. Magnus is the commemorative rerelease they sold at Toys R Us, as is Smokescreen in front of him and Tracks off to the side.
    The Bat'leth on the wall was a gift from my ex-wife, who was at one point in one of the local Klingon groups here.
    Meh, knockoffs are fine by me if the quality is good, and probably preferred for displaying/playing with. :)
    Those commemorative ones were all pretty good.
    Not only do you have a nice setup, but you surround it with classy gear. Bat'leths and robots. Rock on!
    I've put some effort into making the room my "inner sanctum", complete with the stuff I like. Most of my posters live on the walls of it. I'm not ready to give up the idea of being childish sometimes, otherwise there's no point in being all grown up. :)
    My next goal is to try to get a better solution for all those controllers... preferably that doesn't add a noticeable 'kipple' effect to the look.
  2. 29" television, lots of game storage, and a less than ideal controller storage solution.
    For the record, consoles in the pictures:
    Sega Genesis Model 1, with Sega CD Model 2 and Power Base Converter
    Nintendo Entertainment System, both models
    Super Nintendo Entertainment System
    Atari 7800
    Nintendo Gamecube
    Microsoft Xbox Halo Edition
    Sony Playstation Two
    Mattel Intellivision (in the case)
    Atari Flashback 2
    Not pictured:
    Sega Game Gear
    Nintendo Gameboy Advance
  3. Most of my issue with SNES saves wasn't that it would erase them outright or prevent saving... it's that from time to time the connection between the game and the particular Genie wasn't very solid. I have lost saves through the use of the Genie on account of that.
    I've since sworn off using external cheat devices entirely.
  4. :rolling: That's so true. It's quite a culture shock for the modern gamers. Their first time playing many of those games, within thirty seconds the game's over! It's a great lead in to one of those old-fart, "When I was your age..." monologues.
    <old man voice>Why, when I was your age, kid, we had one button, and we were just plain happy to have that one button. And we didn't have even multicolored sprites, we had a misshapen, blocky, single color hollow duck!</old man voice>
  5. I should also mention, I was around during the whole DP banning process as well. An individual was spamming dp links (which is looked down on there) throughout video game articles over several different accounts over a several year period. That individual was also consistently vandalizing specific articles from those accounts. As such, the admins finally had enough and blacklisted the site altogether. Its not a trivial process to have happen, i.e., you can't just have someone spam links to a site for a day and have it suddenly blacklisted. It has to go through a process of warnings, vigilance by editors (i.e. reverts and removals), etc. to the point of being deemed a significant and non-ending problem to be put in to a blacklist. Its a shame to, because there were a lot of good interviews up at DP that could be used as references (at least that I'd still like to use).
    Sounds like it's time for DigitPress to get together with the PTB at Wikipedia, figure out who it is, and go after him themselves for basically getting them blacked out.
  6. I'll add a third comment on the NES, but that's in part because I spent so much time on the refurbishment of my own toaster here that I won't risk screwing it up by leaving a cart in it.
    On the other hand, I prefer to keep my games on the media shelf, so I don't have to go hunting for a game I want to play, then smack my forehead because it was in the console the whole time... :lol:
  7. The 'wall wart' is the little power pack you plug into the wall (so called because the bulk of it is basically on the wall when you plug it into a regular outlet). Sometimes, they stop delivering the juice they're rated for. The 7800 side of things requires more than the 2600 side, so when it goes marginal, that's the symptom you get.
    The SVideo mod would likely not be the culprit, but that's my guess.
    Ok I used the wall wart on my other 7800 and it worked fine. So I put Crossbow in and held it in and was able to get it working on the s-video modded 7800. Then I unplugged it and tried another 7800 and it did not work. So again I tried crossbow and this time it did not work. What are those knobs for inside the 7800. They are kind of like the pokey knob in the 5200 but there are two of them labeled R57 and R58.
    The knobs are typically video adjustment pots, I wouldn't touch those.
    From the sound of it, the bits of the cart connector that relate to 7800 games may be marginal. I'd get some Blue Shower from an electronics store, hit a common 7800 cart (like Pole Position II) on the connector with it, wiggle it in and out of the 7800's connector, then let it dry.
    If you only have Crossbow, I'd actually tend to suspect the cart. Give its connector a good cleaning with alcohol and a swab.
  8. The 'wall wart' is the little power pack you plug into the wall (so called because the bulk of it is basically on the wall when you plug it into a regular outlet). Sometimes, they stop delivering the juice they're rated for. The 7800 side of things requires more than the 2600 side, so when it goes marginal, that's the symptom you get.
  9. I had this problem a few months ago. It turned out I'd bumped the switch on the little universal wall wart I use with it (my 7800 is modded to use a standard connector), so it wasn't delivering power at the correct spec. It was giving enough to drive the 2600 portion, but not enough to drive the 7800 stuff. So you might try a different wall wart with it, see if that clears it up.
  10. Seeing as the PBC only works with the Genesis 1, I can see how something like this would be quite useful for those of us with Genesis 2's, Nomad's, X'Eye's, LaserActive's, etc... If a Game Genie-sized PBC were available, I'd probably buy one.
    Oddly, the PBC does work with the Genesis 2, but only after cosmetic surgery to remove part of it that hangs over the back. It's only the Genesis 3 that it won't actually work with regardless, and that's because the 3 uses a variant Z80 that's not really compatible.
    Yes, I've got one, and it already was altered when I got it. :)
    The 2 did have a specific version of the PBC, in the form of a cartridge (basically Game Genie sized), but it was Europe only. :(
  11. Only things I've found in two weeks was this weird Playstation "Fighter's Choice" arcade stick for $5.99. I don't even know why I bought it, maybe I can hack it into a CV controller or something!
    That's not the actual stick, just a pic I found on ebay, mines in better shape.
    Heh, I've got one of these, I had to 'rebuild' it by installing the guts of a Sony digital stick, the encoding chip in it apparently died on me.
    It's a good stick otherwise, $6 is a really good price for it. It made playing the fighting games and classic games packages that much more playable to me.
  12. I busted one open and re-soldered the wires so I can turn it upside down and play with the stick on the right and the two fire buttons reversed. I like that a bit better. Wish it had a straight stick instead of that mushroom thing though. Putting your thumb on top makes it hard to get precise control but if you hold it between yr thumb and finger it's better.
    Just grab that mushroom, and pull on it until it pops off the aluminum shaft. That's how I disassembled one for parts for my Space Invaders 7800 stick. It's only held on by friction, but it's quite a LOT of friction the first time.
  13. This one here is it almost: CR 2032 LP
    The one in GAW is also a CR 2032, but with only two pins, which are on opposite sides of it. Anyone knowing a source for those?
    I'd check your local battery replacement store, like a Batteries Plus. They carry the CR2032 coin cells, and I'm willing to bet they also stock in some solder-in holders that will make it work with the cart board.
  14. All that remains then is the "why." Why take it out; furthermore, why after taking it out put it back in! Bee-zarre.
    My guess is, the ROM manufacturing industry has a similar problem to the printing industry. Unless a shop is clear on policy about files, no shop can throw away ANY file/information. (We've had customers come in after TEN YEARS wanting to reorder jobs we had art for.) So it's likely that some exec placed a reorder after the order of ROMs that were changed, without knowing, and requested the old file.
    Yes, the place could've looked, and seen there was a new file. However, in most cases, if a customer says, "we'd like more of this," you give them more of that, even if there's a more recent file to go with.
    Of course, I might also be blowing smoke. :P
  15. Thanks everyone for telling me about using the Genesis pad! I'm actually going to get one for *myself* - I really like the look of them, but I showed my wife the Genesis pad, and she said she'd prefer some type of analog joystick.
    At that level, there really isn't a way to get an analog gamepad. The digital gamepad is about as close as you're going to get without prevailing upon a modder with some presented money to make one that works.
  16. If she's used to the gamepad that ships with the Playstation, then it might be better to go for a Genesis or Master System gamepad to start with. Most people I know use what they're used to, unless forced to by gameplay considerations. I know people who prefer to use sticks when they have the option, and others who prefer to use gamepads, and then those who just don't care.
  17. I'll play with emulation if I'm in a hurry, or it's something I don't have. But on the whole, I'm into the ritual. Plugging in the controller, inserting the cart or disc, and finally pressing that big power button or flipping that huge switch.
    Yes, this means despite the fact that I can play 'em for free in the comfort of my own home, I'll occasionally get together with friends and hit a real, bonafide arcade, where the machines still actually take quarters. Because I need the ritual in my life.
