702 -
Posts posted by swapd0
Coding for the Jaguar is a nightmare... Ok, let's go to the topic and see if someone spot what I'm doing wrong.
I've a something like a filesystem to get the assets from the ROM, (sounds, graphics or anything else), then I upload the game code to the skunk board (default address $4000) and play/test the game.
Now I've the assets of three games burned together into the ROM, I upload the code of each game and it works.
I've coded the menu to select a game and launch it, the code copy a small code at the end of the ram and run it, this small code copy the game to $4000 and jumps there. Now comes the funny thing.
Game 1 works
Game 2 you can see the menu, but it hangs when it shows the intro scene
Game 3 you hear the music but no image, sometimes it runs but with glitches and I doesn't read very well the joypad (I've to press fire several times to start the game)
Even if I call run_game at the start of the code it doesn't work. It looks like the Jaguar can't be initalizated two times, one for the menu, the other at the start of each game.
I've no idea why this doesn't work.
LOAD_ADDRESS .equ 2*1024*1024-64 ; end of ram ;_run_game(const void *begin, const void *end) _run_game:: move.w #$2700,sr move.w #$7fff,VI ; VI lea _copy_run,a0 move.l #LOAD_ADDRESS,a1 move.w #(_end_copy_run-_copy_run)/2-1,d7 .loop: move.w (a0)+,(a1)+ dbf d7,.loop move.l 4(sp),a0 move.l 8(sp),a1 jmp LOAD_ADDRESS _copy_run: move.l #$4000,a2 .loop: move.w (a0),$f00058 ; BG move.l (a0)+,(a2)+ cmp.l a0,a1 bge.s .loop jmp $4000.w _end_copy_run: -
Sorry, the sound is stopped but it waits forever in the wait loop, but I think that I can remove that wait because I don't upload anything into the DSP for about one second later.
And yes, that is the output of the d0 register, I send the value to the skunk board after reading it.
Anyway the sound is stopped and I don't upload anything to the DSP until I load and run the selected game.
This is the code, I've just inserted the print_d0:
_stop_sound_system:: lea playlist,a0 ; The address of the sound effect playlist moveq #15,d0 move.l d0,(a0)+ clr.l (a0)+ move.l #playlist,U235SE_sfxplaylist_ptr lea U235SE_status_reg,a0 .wait: move.w #0,BG move.l (a0),d0 jsr _skunk_print_d0 ; *** move.w #3456,BG cmp.l #U235SE_SRMSK_ALL_STOPPED,d0 bne.s .wait rtsAnd this is the output.
00000000 30303030 33303330 33333330 33333333 33333333 33333333 -
I hope that someone port it to the MiST...
1 hour ago, LinkoVitch said:Does the value in the status reg change at all?
I need to test that.
By the way I'm playing a sample in loop mode.
_stop_sound_system:: lea playlist,a0 ; The address of the sound effect playlist moveq #15,d0 move.l d0,(a0)+ clr.l (a0)+ move.l #playlist,U235SE_sfxplaylist_ptr lea U235SE_status_reg,a0 .wait: move.w #0,BG move.l (a0),d0 move.w #3456,BG cmp.l #U235SE_SRMSK_ALL_STOPPED,d0 bne.s .wait rtsMy routine to stop the u235 sound system, the move BG it's to see what is going... why it never return? it's copy&paste from the sample code
11 hours ago, j1mp4ck said:Hi, if the source code of SM64 is pseudo Open, why not try port to jaguar?
N64 uses floating point for 3D Maths, Jaguar, PSX & Saturn uses fixed point, at first I want to see if someone has enough time to convert all code and assets to fixed point and port it to ps1.
I've had a very bad cold so no coding in a couple of days, today I'm ok so it's time to test it and it works.
Thanks SPCD for your help.
10 hours ago, SCPCD said:Don't know if it's what you would like to achieve, but, I give it a try and made some modification (search SCPCD tags)
Seems working fine on real Jaguar, JagFPGA & VirtualJaguar.
I just copy&paste the raster code, in that sprite demo it works, but in the other one it doesn't work... I've no idea why this happens, IMO it should work or doesn't on both programs.
Edit: I had a quick look at your modifications, yesterday I did almost the same (including a semaphore) but I forgot to use the indexed load and one of the relative jump was too far, I had to write more code and use a unconditional jump. I'll use your solution, the code looks more clean now. Thanks.
3 hours ago, matmook said:Nice effect!
Another option is to NOT use interrupts for your rasters but a sprite instead. You will have an extra sprite to manage and write to but you won't interrupt the GPU on each line.
Yes, I though about that but I'll need a 16bits background, the OP would eat all the bus cycles and the 68000 won't have enough free cycles to run the game logic. Or use a 8bits background with less colors.
Anyway I want to try it with a semaphore.
40 minutes ago, Cyprian said:How? do you have a dedicated tool? Changing a file extension from .jag to .cof doesn't work for me.
I think that he used this tool, you just can't change the extension and make it work.
https://www.reboot-games.com/rebootnews/jiffi/
Executable version of the asm example.
When you press * a GPUOB is inserted in the beginning of the OP list, sometimes it hangs quickly, some times you must move the sprites to crash the code, I don't know why. The same code (copy & pasted) is used in the raster.zip code (sorry I forgot to include the binary) and it works there.
I hope to have some free time today to implement the semaphore, it's the right way to do it, but still don't know why it's so unstable because I'm using this for the background rasters in Classic Kong, and it worked in the demo that I uploaded some time ago.
Next thing to try is the semaphore.
I've moved the code to an old sprite test and it works...
What I don't understand it's that now it fails quickly (the C test program), and usually when I press down or right in the joypad to move the sprites down or to the right. In test-c.jag you have to press * on the joypad to turn rasters on, you can move the sprites with the joypad.
With a second read still fails 😫
I'm going to try to move the raster code to a small 100% asm sample program.
9 hours ago, CyranoJ said:The 68000 writes to the GPU RAM in 16-bit segments, so two writes for a longword.
The GPU reads as 32bit, and is clocked higher.
It's reading only half the address (the high half)
You should be setting a sempahore flag, and checking that, not the actual pointer value.
.wait_list: load (list_ptr),event_list or event_list, event_list jr EQ,.wait_list nopThat is your problem.
When I wrote the routine I though about that but I hoped that the GPU would be blocked until the 68000 writes both parts of the longword. I was wrong.
Ok, I think that I've found the bug. I call the GPU code from 6800 like this way. It hangs the Jaguar even if the loop it's executed only one time, but If I remove the last wait_gpu_idle(), it looks that never crashes.
Looks like you can't hammer a gpu address from the 68000 and the GPU at the same time, isn't it?
for ( int i = 0; i < 10; ++i ) { wait_gpu_idle(); gpu_queue[0] = (uint32_t)&gpu_shit_code; // fn gpu_queue[1] = 0; // gpu_queue[2] = 0; run_gpu_queue(); wait_gpu_idle(); }_run_gpu_queue:: move.l #_gpu_queue,_gpu_events_list rts _wait_gpu_idle:: lea _gpu_events_list,a0 .wait: moveq #127,d0 divu #3,d0 move.l (a0),d0 bne.s .wait rts .long _gpu_queue:: ds.l 128 -
My even dispatcher code:
; GPU events queue ; ptr to function [data]* ; ptr to function [data]* ; 0 ; if a function has data, it must be read from r0 pointer ; .include "jaguar/jaguar.inc" .globl _gpu_events_list .gpu list_ptr .equr r19 event_list .equr r18 event .equr r17 return .equr r16 _gpu_events:: movei #_gpu_events_list,list_ptr moveq #0,event ; store event,(list_ptr) ; clear event list .wait_list: load (list_ptr),event_list or event_list, event_list jr EQ,.wait_list nop ; execute events .execute_event: load (event_list),event or event,event ; ptr == null, end of list, go to wait event list jr EQ,_gpu_events addqt #4,event_list ; point to next event or data store event_list,(list_ptr) ; save for next event move event_list,r0 ; parameters address ; jsr to routine movei #.l0,return subqt #4,r31 jump (event) store return,(r31) .l0: ; r0 will have number of words to skip movei #_gpu_events_list,list_ptr movei #.execute_event,event load (list_ptr),event_list jump (event) add r0,event_list ; skip parameters .long _gpu_events_list:: dc.l 0 ; pointer to events listMy gpu interrupt code:
; include "jaguar/jaguar.inc" .gpu gpuFlagsPtr .equr r29 flags .equr r28 rasterAddr .equr r1 colors .equr r2 clut .equr r3 opFlags .equr r4 col .equr r5 .org G_RAM .macro EMPTY_IRQ .rept 8 nop .endr .endm cpu_interrupt: ; IRQ 0 movei #init_raster,r0 ; 3 jump t,(r0) ; 1 nop ; 1 nop ; 1 nop ; 1 nop ; 1 dsp_interrupt: EMPTY_IRQ timer_interrupt: EMPTY_IRQ op_interrupt: load (gpuFlagsPtr),flags ; GPU_FLAGS load (rasterAddr),colors movei #CLUT,clut ; 0, 1 load (colors),col addqt #8,colors store col,(clut) addqt #4,clut storew r0,(opFlags) ; resume OP store colors,(rasterAddr) ; rte bclr #3,flags ; serviced bset #12,flags ; clear interrupt flag load (r31),r30 addq #2,r30 addqt #4,r31 jump (r30) store flags,(gpuFlagsPtr) ; restore interrupt .long _raster_ptr:: dc.l 0 init_raster: movei #G_FLAGS,gpuFlagsPtr ; init gpu movei #OBF,opFlags movei #_raster_ptr,rasterAddr moveta rasterAddr,rasterAddr moveta opFlags,opFlags moveta gpuFlagsPtr,gpuFlagsPtr ; fall to next included file (must be gpu_events.s)Test code that does nothing.
_gpu_shit_code:: nop nop nop nop nop nop nop nop nop nop nop nop ;rts moveq #0,r0 ; skip 0 parameter load (r31),r1 jump (r1) addqt #4,r31Main code that tells the GPU to execute something.
wait_gpu_idle(); for ( int i = 0; i < 10; ++i ) { wait_gpu_idle(); gpu_queue[0] = (uint32_t)&gpu_shit_code; // fn gpu_queue[1] = 0; // gpu_queue[2] = 0; // with this uncommented takes more time to crash the code... run_gpu_queue(); wait_gpu_idle(); }If I uncomment the gpu_queue[2] it takes more time to hang the jaguar,
this means that r0 got some weird values so the event loop code fails?No, I'm testing the value of r0 after the execution of the event and is always 0.Maybe I can try to port this code to a small 100% asm test code.
3 hours ago, CyranoJ said:Yes. It is.
I suspect the problem swap is having is a register being trashed in the isr.
No because the event code and the interrupt routines uses different registers, there are no registers overlap.
Ok, I got an event system running on the GPU, when I write an address into a GPU RAM location, starts to execute the functions written in that array, it's something like.
gpu_queue[0] = gpu_draw_sprite; gpu_queue[1] = x; gpu_queue[2] = y; gpu_queue[3] = sprite_frame; gpu_queue[4]; run_gpu_queue(); // something like gpu_queue_ptr = gpu_queueIf I load this code (gnu_shit_code) into the GPU and call it, it works fine without the GPUOB interrupts, but when I insert a GPUOB into the sprite list it hangs, sometimes very quickly sometimes it takes a while, I've to move the sprites with the joypad or it never hang.
If I don't tell the GPU to execute this code, it works (it's in a busy wait). So I think that my event system that I've been using in all my projects (4 in total) has some bugs. Looking at the code it could be done in a better way, more simple and without move pc, rx... , maybe this instruction is messing around.
_gpu_shit_code:: ; movei #$a0000,r0 ; load (r0),r0 .loop: nop nop nop nop nop nop nop nop nop nop nop nop ;rts moveq #4,r0 ; skip 1 parameter load (r31),r1 jump (r1) addqt #4,r31 -
The code is a mix of C/68000 asm/GPU ams, without the toolchain you won't be able to compile it and it's a bit big. Although I'm doing the test with a small program, not the game, the library it's big.
Tomorrow I'll try something different, run the sprite engine with the 68000 with GPUOB interrupt and execute some "random" code in the GPU.
Nope, OP list is right but crashes... this is so frustrating 😫
I've done a few more test and it looks that every time a sprite is culled the list can be "corrupted", it works ok without a GPUOBJ and I have no glitches, also I've dumped the list and looks ok, but with a GPUOBJ the code crashes, no time to dump the sprite list
U-235 SoundEngine released!
in Atari Jaguar Programming
I want to stop all playing sounds, the sound engine & the DSP, maybe it's better if I turn off all voices, and then turn off the sound engine?
I'm not using any pad reading neither random number generator, in the setup code I don't touch U235SE_ctrl_reg register.
I doubt that the conversion is wrong because I did some test with $12345678 and it worked.
Anyway I think that I can remove the wait loop, it's called in a menu to select a game and launch it. I thought that the DSP was still running so it makes the games hang.
