935 -
Posts posted by sup8pdct
Just had a look in the manual and one page is doubled up. Ive had it for over 20 years and never noticed it. actually never read it either as have the cart.
James
Gota find it first.
James
I have a very faded bug 65 manual. Not sure scanning will show much . OCR may be impossible on it.
James
- copy 256 byte sector to the DOS buffer
- switch out extended bank
- copy 256 bytes from the DOS buffer to the application's buffer
Usually the way it is done is to switch in the bank, copy one byte, switch out the bank, store byte directly to destination, update pointers, switch in bank, copy byte etc, etc
Saves double movement.
James
Actually, you could try a 1050 mech. Just need to get the IP working. Just looked at the photos. Not sure 150 tandon parts will fit. Needs a closer look.
James
The parts broken are the same as a 1050 tandon mech. Easy enough to replace, just harder to align. If you dont move the stepper motor, it "should" stay aligened. Tho the mech does look like a 1050, it isnt the same. The gt one doesnt have the switch for door close but has IP sensor. Also the black lock leaver has been cut down so that it clears the front plastics when in lock position.
James
Another way is to use the BlackBox. It has highspeed SIO built in.
James
The second is that sound signal really goes from ANTIC to Monitor port but not to SIO.
Pokey and ctia/gtia produce sounds that go to monintor and TV. SIO has an audio in pin that goes to monintor. Those with a parrallel bus/ECI also have an audio in.
Pokey does actually send audio to SIO bus serial out when using 2 tone mode for cassette use only. (see $D20F) Not otherwise useful.
James
Here is dissemblely. Only ran it through 6502 dissembler with no other work done at this point.
Am getting ready to go to frazer so won't have any more time to work on it for a while.
James
Never noticed that. Have to look now...
James
So, is dumping the EPROMs unnecessary now?
It would seam so. It appears to work for everyone except ilaskey.
What i did was to load the ATR file into a hex editor (winhex) Remove from end of DUP to start. remove what appeared to be the end of dump till end of ATR.
Starting at the end, found the munged sector link and removed it. did same for all the rest of the sector links (took some time to do). removed the 6 byte header and saved and tested it.
I also have dissembled it to have a look.
James
after a bit of work with the ATR file, saving it as a 16K cart ROM image, it works.
James
XF351 for sale on ebay
X2 for rom dump and processor type.
James
