Sign in to follow this
KAZ
Excellent, I successfully hacked my first Atari 2600 game!
Any little achievement in the realm of programming the Atari 2600 is significant to me...
This one probably won't impress too many....but.
I used:
showgfx and
editgfx
This is what I did, from my crude understanding of this whole mess:
showgfx asteroid.bin 0 4096 > hack.txt
this "pipes" the asteroid game into a text file.
Then I opened up the hack.txt, and was "pleasantly surprised" by the simplicity of the data. Of course I had NO idea in the world what it all meant, so I randomly deleted a bunch of X's all over the place....
every time I deleted an X, and added a space, so that the line would remain the same length.
then I went:
editgfx hack.txt hack.bin
Making it a BIN file (JOY).
I ran it on my emulator, and guess what?
Yeah, a bunch of garbled mess.
But the important part is that my alterations MADE a difference to the bin file, and the changes caused by ME.
I am barely starting to grasp just getting text files into bin files. I did just now...
So now I at least know how to make a text file, and how to make it into a bin file using this program
Now if I just knew what to put in for code....hmm??!
The tools you are using are NOT made for changing code. They were develeoped for hacking the graphics inside an existing ROM.
For coding you need an editor (any will do, I suggest Textpad) and an Assembler (DASM).
Try to assemble "How to draw a Playfield" first, and then slowly dig into the code. Try to understand the framework (VSYNC) first and then how the kernel works, because that is the interesting part.
I have dasm downloaded from the net....
I don't have the slightest idea how to use it on a text file...
would I just go into ms dos, and type:
dasm hack.txt
maybe some sort of -F switch thing that I've heard about.
I have wordpad, and textpad....are those the same as what you are talking about? Can I actually put code (commands) into a normal text file?
And then the dasm somehow takes that and makes what I saw showgfx showed, all those X's and numbers on the left side?
I just need a few basic basic clues on where to even begin putting in code...maybe I'm overthinking this very first part, and it really just requires a text file, and a dasm assembler.
dasm hack.txt
The correct minimal syntax would be:
dasm code.asm -f3 -ocode.bin
code.asm is the source code file where you put in all commands (a simple text file) and code.bin is the resulting binary file that you can directly run in the emulator.
Textpad is just a better editor than Notepad. But for a start Notepad will do. Wordpad might work too, if you can save your code as plain text file.
Exactly. An editor, an assembler and your brain is all you need. :)
No, DASM creates the binary file which is ready to run, Showgfx is used to hack existing binary files.
Here's the command you wrote, let me ask a little more...
My text editor creates files with a TXT extension, so would mine go like this? (my file would be called kaz let's say)
dasm kaz.txt -f3 -okaz.bin
what is that "o" before kaz for? Is that another type of switch or something?
And dasm does stuff "behind the scenes"? You never actually open a program called dasm, it just crunches the commands?
Wow, I'm actually starting to almost get the first part of this.
That's ok, you can call the file whatever you want. But you should limit the name to the 8.3 letters format.
Yup, -o is another parameter that is described in the DASM documentation. You should read this too.
Exactly, it's a command-line program that simply translates your code. There is no window etc., just some output into the DOS box.
That's how "old style" programming worked. :)
