Sign in to follow this
B.U.Terriers
INTV II replacement power supply...
Just wondering if anyone has tried this solution:
http://cgi.ebay.com/NEW-NINTENDO-POWER-SUP...2QQcmdZViewItem
I've tried using the power supply for my NES and Genesis, but the opening for the power supply is slightly smaller than the tip on the back of the INTV II. Wondering if the universal one is slightly larger and works with the INTV II. Thanks!
BU
The standard Atari 8bit power supply works for me. The ones that are used with a 400,800, 1200xl, 1050, xf551 should work. The tip is the same size too.
This is from the faq
9 V AC 15.3 VA (1.7 A) Atari#CO14319
400,800,822,850,1010,1200XL
9 V AC 18 VA (2.0 A) Atari#CA014748/CA016804
400,800,822,850,1010,1200XL,810
9 V AC 31 VA (3.4 A) Atari#CO17945
400,800,822,850,1010,1200XL,810,1020,1050,XF551
9 V AC 50 VA (5.6 A) Atari#CA017964
I'd just like to second that the 5200 power supply works - but I'd also like to add: You tried the NES and Genesis adapters? That could have fared quite poorly for you had the tips fit - the Genesis uses DC (I don't remember which is positive, which is negative), so I guess in theory you only had a 50% chance of frying the system, but as for the NES - that's an AC voltage coming out of that thing - you could have toasted it.
Not trying to sound too harsh (hell, like I haven't done the same thing myself) - but take my word for it: you'll save yourself some grief if you look to check that the power brick/tip is compatible with your system before you even check to see if it fits.
Also, (somebody check me on this if you will), I think I read that the Jaguar PS works on the Intellivision as well (I've never tried it myself)
No, the Jaguar power supply doesn't fit (it's almost identical to the Genesis power supply).
Edited by ApolloBoy
