Sign in to follow this
Cybergoth
Omega Boooster / Spy Hunter Controllers
Hi there!
Since nobody answered my calls for testing the Omega Booster / Spy Hunter controller code from the latest Colony 7 build:
http://www.atariage.com/forums/index.php?a...;showentry=2781
I now think it's safe to drop support of those obscure devices that apparently nobody owns anyway?
Greetings,
Manuel
Hi there!
Greetings,
Manuel
AFAIK the Dual Control Module for Spy Hunter is nothing more than a piece of plastic that holds two joysticks together:
http://www.atarimania.com/detail_soft.php?...VERSION_ID=8373
8)
The booster grip consists of two normally opened switch that connects the 2 paddle lines (pin 5-9 of controller port/ bit 7 of inpt0-1) to +5v (pin 7). Connecting a paddle in the joystick port "should" be detected as a simultaneous pression of the 2 booster grip buttons (i'm not sure about that), or you can plug a female db-9 connector and alternately shorten pin 5-7 and 9-7 to see if your code detects the buttons.
I think you should mantain support for it since any joystick/joypad with at least 3 buttons can be easily rewired to act as a joystick + booster grip, even if the original device is uncommon.
Edited by alex_79
Hi there!
Greetings,
Manuel
I wouldn't support a controller that is that hard to come by. Secondly, they aren't that comfortable to use IMHO. I'd rather have to use a second controller.
I've decided to drop the Booster Grip support. Colony 7 supports the "C" Button of Genesis controllers though, amongst other things.
Back when I built arcade style controllers, I useually had a switch and extra button to support the omega race button. But that was short lived with no interest at the time (about ten years ago)
